View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. CC 1515 2200 timing
  2. 4S goes into half speed in 3 laps, while 3S runs for over 40 laps?
  3. P spec/ltd timing
  4. .150 flex
  5. New Guy Sounding Off
  6. Pursuit boat
  7. Almost afordable GPS+data logger from HK
  8. P hydro Strut placement question?
  9. DPI Leisure Sports Back in Business...
  10. how much capacity does your recharging show after running until lvc kicks in?
  11. 3660 3060 kv
  12. Setup questions
  13. Darn customs
  14. Genesis help
  15. Future cat build, want a hull that will good in the turns too, was thinking cheetah?
  16. Finally getting around to actually running my hpr115....
  17. ProBoats New Line Up Flyer
  18. counter rotating shafts
  19. Are you G-Freaking kidding me?!?!
  20. Atomik/Venom Bill Oxidean Prototype Custom Race boats
  21. New to RC boats
  22. rc drag boats
  23. New Hydro?
  24. what effects timing has??
  25. Help me pick a FE cat? Genesis, aquacraft MC, proboat MG?
  26. New RC Boat Mag - not too sure about this one...
  27. Fiberglass prep ?
  28. New to FE Boats - 32 Cat Rebuild
  29. Question on 36 inch tummel hull.
  30. First boat....Miss Geico or AQ Revolt?
  31. genesis set up please
  32. Genesis question
  33. Carbon fiber Pattern Question
  34. Repowered Miss Geico running at half speed...HELP
  35. CF Fightercat Daytona build, help me with my setup
  36. T sport!
  37. Opinion rubber water cooling jacket?
  38. How do I read an "Unread picture comment"?
  39. Recomendations for a Mono Hull
  40. Aeromarine collet style coupler
  41. Flex shaft coming loose
  42. Scratch building, need HELP!!
  43. Scratch building, need HELP!!
  44. Cant find extended shaft wire drive or reverse wind drives
  45. I need feedback, FMT outrunner 3650
  46. happy little vegiemite
  47. looking for a fast single motor setup for an apparition cat
  48. Speed help please
  49. which paint?
  50. Help setting up K&B 3.5 OB.
  51. Large electric tunnel hulls!!!!!!!!!!!!!
  52. a heli outrunner motor for a genesis cat?!! did i miss a memo??
  53. 56" Force 21 Mono?????
  54. Flex shaft question
  55. Specs on 16s 200a fightercat esc
  56. Flex cable lubrication
  57. Schulze ESC
  58. Fighter Cat 8S 300 Amp ESC
  59. How Much Water Pressure Should A Typical Rudder Pickup Generate?
  60. New Kyosho RTR Boat
  61. Will the high temperature of Epoxy curing damage fibre-glass hull?
  62. Stuffing tube rattle.
  63. mhz ocean spray suggestions
  64. tp power and 12000 watts
  65. neu 1527/1D esc timing
  66. Big electric project & presentation
  67. Spartan Heat Ranges?
  68. Flex cable question---how is a .187 made?
  69. The Most "fun" boat you run??
  70. AQUACRAFT 60Amp ESC Repair/Modification
  71. Clarification for the Leo 4092
  72. Heat
  73. Fine design rc 48" deep v 60mph
  74. quick fiberglass question
  75. Kyosho getting on board too :)
  76. Good Web site for Stainless Screws
  77. 1/10 shovels-- best location for lipos, and prop options?
  78. Geneis esc question
  79. World's Fastest Mean Ma!chine
  80. Leaking water jacket
  81. Help me build my new driveshaft
  82. corrosion x
  83. Connectors style question?
  84. Whos going to come out ahead with their new boats- proboat or aquacraft?
  85. Carbon fiber cloth.
  86. Can you reuse a prop shaft?
  87. Value my boat!
  88. Who has the best price on carbon fibre cloth and plates?
  89. Jae 21 rigger
  90. how to remove these?
  91. GENESIS, first runs need help on settings
  92. Teflon washers and Inox thrust bearing high speed
  93. water up flex shaft
  94. Don't blaime all that water on the flex shaft.
  95. Need advice mystic 29
  96. Flex shaft very HOT!!!!
  97. Fed up with the Vanquish
  98. Can I get some feedback?
  99. Dyeing fiberglass?
  100. P LTD mono???
  101. Best boat for beginner
  102. arpro 750ep
  103. Need Advice on either Hydro & Marine or MHZ
  104. Eagle Tree GPS Bad?
  105. HK Apparition Motor Choice?
  106. water where its not supposed to be
  107. Intro
  108. One more T-180 problem
  109. Toysport Syncron Setup Help
  110. Can someone explain how to use the watt rating for brushless motors
  111. Can someone explain how to use the watt rating for brushless motors
  112. Kinetic offset bracket
  113. Speed predictions
  114. Great little waterproof RX box
  115. time to take a dump on my local LHS
  116. looking to get genisis offshore but is it my best bet....
  117. Genisis first run today
  118. My newest boat
  119. Unexpected final for my run with Osprey today....
  120. CF reinforcment, cloth or plate?
  121. 3/16 flex threshold?
  122. P-Limited Offshore Boat
  123. general opinions about arrow shark
  124. A Quick Tour of the Pits of the 2012 NAMBA FE Nationals
  125. 32" Pursuit/FC Bling Rocket build questions
  126. Does this sound about right?
  127. Looking for flex hex coupler 4mm motor shaft to .098'' flex shaft
  128. Anyone running an electric Seaducer?
  129. Idea for foaming inside of hull
  130. Mean machine stickers
  131. Custom foam and laser cutting?
  132. 5692
  133. help needed !!
  134. New to rc boats...need some advice.
  135. soldering new bullet connectors
  136. Gluing 101, I'm failing
  137. LIPO fire at the FE Nationals
  138. Never seen a rotor like this b4
  139. 2012 FE Nationals-Additional raffle items
  140. Before apply a clear coat
  141. Need opinions on my next project!
  142. Apparition Offshore Brushless single motor
  143. Info on some speed boat hull....
  144. Hull Question guys
  145. First Build Need Some Suggestions
  146. Jae21 FE assembly!
  147. Water inlet fitting location
  148. Which motors for Apache hull,twin.
  149. Fighter cat racing
  150. 31.5 inch firberglass "Sea Arrow" by R2Hobbies and infomation good bad?
  151. Please need answers for jae21 fe setup!
  152. The June Roostertail is online.
  153. need help with jae21 rigger setup! (electronics, and prop)
  154. LIPO on fire: what can we do to control it & limit damage?
  155. New sleve bearing on flexshaft. Is this right ? (pic's)
  156. great surprise from the Nationals Organizers, Tony and the Drivers!!!!
  157. Forum Rules Reboot...
  158. If I went rtr...what would I go for
  159. Opinions on radar guns vs. GPS
  160. Help with drive shaft
  161. Cooling jackets for Lipo's?
  162. cf cat prediction
  163. ESC voltage Astroflight 212d
  164. help finding a small rigger
  165. Jae21 speed predictions?
  166. just picked up rc boat-volume one, opinions?
  167. Sad News
  168. ESC rating... Amps vs Volts
  169. Winter may not be so bad.
  170. Jae21fe motor suggestiom
  171. 36" Twin Cat motor choice?
  172. foam inserts
  173. Namba hull length specs?
  174. Discount coupon from Tower Hobbies
  175. wet electronics
  176. VS-1 Randomly hooking to the right - what's going on?
  177. What is a BEC?
  178. Upgrading Pursuit flex
  179. Corrosion X HD?
  180. Anyone running the Atomik A.R.C 58" RTR?
  181. Aeromarine sabre canard???
  182. Need Advice: TT Outlaw Jr. OBL Replacement Motor
  183. 72" MHZ Mystic C5000 setup
  184. Where should the COG be on a 30 inch cat?
  185. Christmas in July give away thread?
  186. Lipo Safe Handling Month
  187. hydra ice 240
  188. Water cooling information
  189. Please welcome our newest Moderator.
  190. aquacraft esc
  191. Junk or good? Need some better understanding on the setup..new to me.
  192. Drive options for 73" (185CM) Mystic Cat
  193. Stuffing tube question
  194. birthday
  195. Happy 4th of July
  196. nqd jet boat
  197. fc in sponson square motor mount thrust bearings?
  198. Aligning the Motor
  199. Stuffing tube and stinger temp.
  200. Waterproofing? Corrosion X or spray electrical tape?
  201. waterjacket
  202. Fixing a paint problem
  203. Neu 2215 1440kv Question Help
  204. Insane FE 30 Engine Recomendations
  205. 1st Cat Build: Delta Force Explorer 36" - Some Basic Questions
  206. Building a Venom P1 35'' hull with twin outrunner motors
  207. Shrink wraping a esc
  208. need more speed...
  209. Pb 1500 vs aq 1800 ?
  210. Height of Hyper Performance 3.5 Bullet Electric Conversion Motor mount
  211. 33" hor racing hydro???
  212. 2013 NAMBA Fast Electric Nationals
  213. Hull Identification help please
  214. What was your first offshore boat?
  215. Modified Castle Bullet Connectors
  216. change..
  217. 2012 FE Nationals: where are the results posted???
  218. Anyone here running the Radtek 92?
  219. New 37" daytona from fightercat.
  220. Getting fed up with this boat and brushless stuff NEED HELP PLEASE! !!!!!!!!!
  221. How to propose a rule change/addendum for namba
  222. lack of female participants.
  223. Stuffing tube
  224. Is all teflon the same?
  225. Way too Hot even before running
  226. tp5058 motors
  227. Visual difference between thermal shut down and throttle fail-safe
  228. Carbon Fiber
  229. 1st run cobra 2 tunnel (question)
  230. Newbie asking for help!
  231. New guy with a Villian IV, now a rebuild.
  232. Programming FC ESC 2-8s 240A
  233. Twin 2028 Cat?
  234. Burned up another one, why?
  235. stop a spinning teflon tube
  236. GPS system???
  237. wich one would you choose?
  238. HELP need motor replacment but dont know witch one to get
  239. Drive Dog Clearence
  240. Timing help- Pursuit w/Leo 4074
  241. Cable size for 7/32 stuffing tube (no liner)
  242. What kind of temps should I be running?
  243. Possible new hull. What is it?
  244. Geargrip. Excellent double boat caddy.
  245. check this out for pricing
  246. another genesis Q :)
  247. Boat speeds ????
  248. Question about programming Seawing 180 ESC
  249. What would you do with this hull?
  250. Grease your cable!!!!
