View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Very simple Rescue boat
  2. ESC Glitch
  3. new to hobbie need some help please.
  4. new to hobbie need some help please.
  5. New to Electrics
  6. Hobby King Warranty Return, FYI
  7. Mayden Voyage for the Daytona Today, had just one issue...
  8. Holy Toled'oh
  9. turbojet esc programming instructions
  10. Need help to put power in my hydro!!!
  11. Greasing the drive cable....
  12. Help me to choose a good clear coat
  13. Conquest twin motor sync
  14. boat wants to roll over under power
  15. Adjusting to keep nose up a tad?
  16. Finding CG for Genesis twin setup
  17. Battery Location for MiniCat Tsunami
  18. Help
  19. Speed Calculator
  20. 1527 1y equals...
  21. Another "Help identify this hull" thread...
  22. powering a Delta force 35 suggestions.
  23. Moldova store-- good/bad ?
  24. Caps caps caps!!!???
  25. mounting alum motor mounts
  26. Off Set Rudder on Genesis.
  27. Upgrade motor
  28. loepard 4082
  29. 44" Avenger Pro Build
  30. IMPBA Rulebook has been updated!!
  31. How far above the bottom should prop shaft be
  32. Good brushless RTR with self righting
  33. Fighter Cat Lynx SAW build: need advice
  34. Twin CC1512 1800KV in a 32 cat
  35. 25" ABS Vintage Classichydros Recommendations for Strut/Rudder/TurnFin
  36. No beeps from motor
  37. new esc, amp suggestions for t600?
  38. Good First Run with the Daytona, fried the Collet tho...
  39. Stock Genesis Motor on 5S ?
  40. Boat Building supplies
  41. ESC wiring
  42. JAE 21 strut question
  43. Hughey Dual .05 Power Units
  44. VHull needs a bigger BL motor any suggestions??
  45. BlackJack: which motor/prop for NAMBA N-2 Offshore racing
  46. Flint, Michigan SAW trials????
  47. How to best clean your boat hull?
  48. rudder
  49. Is your FE Sport Hydro legal under the proposed IMPBA Rule Change?
  50. Any one convert a Nitro Seaducer to fast electric?
  51. Program card wiring: need help!!!
  52. Jet drive Boat?
  53. My persuit suddenly stops then starts
  54. My first fried speed controller
  55. Flip over problem
  56. TP 4092 1600 kv motors
  57. tunnel hull
  58. Help me rig this boat!
  59. Shaft tube sleeve question
  60. Cut Flexi-Shaft
  61. elecrical spray to seal esc ect
  62. Rudder placement
  63. Please read impba sport 20/40 rules update
  64. 101 uses for used earplugs
  65. witch epoxy to use
  66. Nylon breakaway screw
  67. Drilling for the shaft
  68. Silicone water jacket
  69. mounting stingers
  70. New T600 Outrunners from HK
  71. DF33 Motor question
  72. 8MM vs 5MM Motor Shaft
  73. Hyperions or Grim Racer
  74. removing original mounting holes in plastic hull
  75. Twin Genesis motors?? 4074 2200kv what do you think?
  76. Duck police!
  77. Shoe goo or Mono caulk?
  78. running Hot!!! help!!!
  79. 2012 NAMBA FE Nat's sign ups
  80. Want a new boat help. Lol
  81. I Guess I Blew It - Looking For Some Guidance Please
  82. Kermit, the Hydro VX electric
  83. Non silicon sealant- Lexel?
  84. Delta Force Explorer 36 motor and prop
  85. best way to strenghten a soft plastic hatch?
  86. What do you folks think?
  87. Teflon stuffing box/shaft tube liners -- good or bad?
  88. Baahahahaha! R2 hobbies is funny
  89. Repair kits for Neu motors?
  90. Need some help
  91. Force 22
  92. Ul-1 to mono
  93. up in smoke
  94. So you said a DF26 can't 84.1 mph!!! Soon 100mph??!!!
  95. Where to buy PVC piping for boat stands?
  96. Most Expensive FE You've Seen Or Heard Of?
  97. 25 mono prince?
  98. Hobby King New Large Boats
  99. Eight Smokin' new NAMBA 2-Lap records set this weekend
  100. Looking for fast 6S hull suggestions...
  101. Timing and frequency for Leo 5692 720kv with FC 16S 300A esc?
  102. genisis torque roll
  103. Hull hook.. good or bad ?
  104. Would this be considered a twin or single motor for SAW racing?????
  105. Running warm
  106. More r2hobbies pain
  107. Needs Same help indentifying parts of a kit I received!!!Please Help!!
  108. Got me a ToysPort Syncron
  109. What side to mount gps on Genesis
  110. New Guy new boat looking for set up suggestions
  111. Which motor and esc to power 32'' Wildthing mono on 4s?
  112. Tunnel strut angle
  113. Rescue Boa/Proboat Gaff
  114. To BEC or not to BEC..that is the question/
  115. Sorry Guys.....Yet More Questions
  116. Average speeds in racing ?
  117. Another problem
  118. How important is a liner?
  119. Stinger placement on a cat
  120. Escs, 180
  121. loose comparison regarding electric motor size and nitro motors
  122. help guys, counter rotating flex shafts, how to?
  123. Strut depth and distance
  124. esc problems i think
  125. waterproofing
  126. boat hekp
  127. Looking for Help picking Electric Boat
  128. Anyone and Everyone Chime in here
  129. Going crazy with my esc
  130. Oopppss
  131. Couple of new 50 inchers from Hobby King
  132. Amp draw!!!
  133. Apparition Question
  134. df 29 stering issue
  135. New motors from China, Uh Oh Lehener, watch out! Sneak peek!
  136. Water Jacket ?
  137. Please take a look at my flex shaft alignment
  138. How much to make this boat electric
  139. Lucky me
  140. Closed loop cooling
  141. Stinger bushings to smal
  142. For those rainy days and blowouts...
  143. What stub assembly will fit a K&B lower
  144. Tenshock Viper timing?
  145. Need help hitting 70mph
  146. Info on .187 flex
  147. Apparition twin motor
  148. esc no power
  149. need help converting a jae .12 zipkits rigger to electric
  150. Looking for help picking out a boat to buy for all fun.
  151. Need help with color choice
  152. Boating Basics - Recommendations?
  153. Color code for Ms. Geico green for OPC tunnel
  154. Proboat 1500kv on 5s
  155. Miss Vegas brushless conversion?
  156. FE30 Turbine Cowl Now Available
  157. Is there a difference between a rotor from a leo 3674 3270kv and a leo 3674 2650kv?
  158. Rescue boat?
  159. Looking to "build" new boat. Recommendation needed please.
  160. Newbie with a hull
  161. P Mono
  162. 7xl toasted any good suggestions
  163. 2.4 ghzz antennae design
  164. flatbottom runner bottom, painted
  165. Help and Advice with a New Setup
  166. Neu 1530??
  167. df 25 help
  168. Looking for alittle setup help,31.6" RC EP FRP Epoxy Fiberglass Sea Arrow ARR Racing
  169. JAE 21 FE options
  170. Another first boat recommendation thread
  171. Fightercat esc spark arrestor
  172. solder temps?
  173. HELP! LH/RH cable question/issue
  174. BS Electric Classes Posted for the Celina Race
  175. Lehner motor and schulze esc
  176. Rudder depth
  177. Timing- quick help!
  178. Genesis skittish at high speed
  179. rudder lenth (df26) and general guidelines
  180. Skid Fin Design Help
  181. Turtles: We must project a good-guy image or loose
  182. starting clock recording
  183. outrigger boom clamps
  184. Cooling system pressure?
  185. Steering setup for Twin outboards
  186. Can't Make My Mind Up
  187. Arpro 700 or snap 720 are they any good?
  188. HET Typhoon EDF engine
  189. smoked my ul1 motor
  190. Is my system enough for this boat
  191. Looking to convert my 45 inch Seaducer to fast electric.
  192. Help me decide what to do...
  193. Advice on what kv motors to use
  194. Wire drive slippage
  195. connector newbe question
  196. hobbyking really stepped it up
  197. mrp skater cat build up
  198. Hobbyking now has a 48" Hydro.............and a 52" Tunnel...!!!
  199. Teflon liner in Miss Geico or not?
  200. Questions about one HOR boat
  201. Into boating now, thanks alot
  202. Repairing ESC Caps
  203. Need advice on a rescue boat
  204. HK T180 programmer?
  205. Fighter cat 3-16s 200 amp motor controller programming box issues
  206. data logging/recorder unit
  207. R2hobbnies update: THE HORROR!!!
  208. need help on a hull
  209. What am i doing wrong here?
  210. Banned from the pond? I think not!
  211. Happy Boating
  212. How I solder 6-8mm bullets: simple jig
  213. Question about boat "airbag"
  214. Canopy for woodstuff tunnel OPC
  215. How to calibrate throttle?
  216. Server problems on hear today ?
  217. new shovel head at hk
  218. Tunnel box repair
  219. first day boating first boat FIRE
  220. Prop question
  221. Pursuit Mono
  222. Apparition drive questions...help!
  223. another cat build help needed understanding lingo here. please translate thanks!!!
  224. Recomendations for gluing ABS to wood
  225. Advantage of a 4082 2000kv over 4074 2000kv?
  226. Painting help
  227. Best way to cut carbon fiber sheets
  228. Best way to cut carbon fiber sheets
  229. Power loss a full throttle.
  230. R2 hobbies cat build
  231. 40inch mono v hull motor
  232. Your thoughts about this hull
  233. n1 ....n2 motors
  234. Pursuit trim tabs & turn fins
  235. New hardware fad or gimmick?
  236. outrigger
  237. cat help
  238. ??? What is the hull of choice for sport hydro ????
  239. electric outboard leg
  240. timing for a 1515 2700kv nuemotor
  241. MHZ Lizard Extreme---motor, hardware, etc.,suggestions
  242. " Y " fittings for single cooling line
  243. esc motor combo advice
  244. Hobby King Genesis
  245. amps
  246. Genesis Build
  247. Your expert advice needed as to what to build and or buy
  248. R/C Jet-Powered Lifeguard
  249. Longest Boat Available
  250. Stinger placement for a deep v mono?
