- An Answer to All our Cooling Needs
- Mhz usa
- Twin prop Genesis?
- 1/8 Hydro 8s motor options/ esc
- Is this boat Plastic or Fiberglass or something else??
- Will 4mm flexi's be ok?
- timing
- 1/4" flex shaft breaking
- What to do with dead NEU motors..
- GPS suggestions?
- Rigger turnfin question.
- Turn Fin for Small JAE Style Hydro??
- moulding carbon fibre
- another newb question.....
- TWO ESCs to one Motor??
- Shear bolt question
- Are you ever satisfied?
- Et v4 150a data logger wires: Too small??? Placement???
- High voltage servos
- Where to buy 36mm and larger motor mounts???
- front sponson adjustment
- SORRY and SPAM..............
- Garmin Foretrex 101 accuracy?
- Wiring bypass for eagle tree e-logger v4 150 amp to 300 amp
- Hitec marine phone number
- DF33 Issues
- Need something to carry boats in / on ???
- Motors and boat size
- RCBM 2007 article by Jay
- Neu motors setups
- What rudder for Delta Force 35"?
- Speedfreak Gen2 Hydro Build
- best solder
- How many model kit builders progressed
- Willl more timing make outrunner run hot ?
- T600 in a 42" hull, kv suggestion?
- Gps?
- How do you ad a avitar?
- Equivalent inrunner size to outrunner
- Ferro ring placement?
- Eagletree GPS
- my water sliders and builds
- anodizing services intrest?
- Out of the game for a bit - motor question
- Delta Force 41 mono?????????
- Fightercat PCS exe
- Help with deep v conversion
- New Outboard Drive from HOR
- Whats the best for quality and looks motor mount lehner 2250
- flex cables and shaft 3/16
- Dedicated to FE racing
- Are outboards legal for Limited spec offshore class?
- 1/4 steg strut to 3/16
- Carbon fibre clear coat tips question
- 3/16 flex questions.
- youtube vids question
- 41" Osprey,is a T600 1400kv on 6s to small.
- Piano or Flex, Teflon or No
- Additional Caps, Why?
- Warped wood boat kits?
- Burst rate of motors
- Whiplash 40
- Interesting Air Rigger
- hull sucking to water
- Unknown boat hull
- Exceed RC spyder 45" w/gs260m gas engine
- Het Typhoon.Any good?
- Are Cen spare parts available anywhere?
- Will we ever see this as an RC model?
- measure degrees of attack with gauge?
- adding a water pickup
- Genesis prop shaft/strut height and angle
- Electric Tunnel Hull Outboards BESIDES the Stiletto?
- How much effect can stinger angle have on speed?
- Is an inline rudder faster than an offset rudder?
- replica surface drives
- Got a New Boat for my 1 year Anniversary - few questions
- Want an HV ESC that fits "right in the middle" of the pack?
- DF33 on 4S? Can I do it?
- 6s amp draw question
- 34" Vyper build tips ?
- 4074 2000kv - 4082 2000kv difference
- What does everyone think of the Genesis cat
- Fountain 51 inch scale looking hull
- Seven NEW NAMBA FE SAW Records set this weekend
- Thoughts & advice?
- My first boat, my first boat build
- TX preferences? Sticks vs. Trigger?
- her hip shakes at high speed....
- Neumotor wires to be shorten?
- Cooling jackets
- What is this boat? Anybody recognize? Need advise !!!
- new game: find lost boat lol
- HiModel 120HV
- Who is acutaboveboatworks?
- RC Mart - Hong Kong
- fiberglass mat
- R2 Hobbies Godspeed U or Twin Power Catamaran
- Graupner Rennyacht Portifino I
- MHZ Mystic C5000 small (84cm)
- Start up issues...
- Q...Hydro and Marine of Germany
- New ESC?
- Whatever happened to Dan Chase?
- The Spark...
- mystic esc
- upgrading to a larger fe boat
- RPM question
- Advice on which ESC with a Velineon motor
- A useful apk for android users!
- need some advice on 7 volt Villian
- brushed twin motor esc
- small gps units?
- Do Turnfins or Trim tabs help with torque roll
- GT3B model presets?
- leo motors
- What to buy/Build for less then 300$ ?
- Vegetable oil?
- Offset rudder placement on catamarans
- Need suggestion for Pursuit motor
- Question about classes?
- Namba
- Are these caps still good?
- Poor garmin 201 reception
- quick Apparition question,
- Is this a pin or set screw???
- Rudder length?
- is this Aeromarine SprintCat 36???? need advice on motor and prop
- Current NAMBA 2-Lap TT P-Limited Records??
- Cen aquajet worth buying?
- 1/10 shovel question- motor cover installation
- RiverCat question
- ESC waterproofing options for my situation
- Want to up grade cooling lines?
- Feigao 9xl motor with bent shaft ?
- Question Nobody Asked
- What motor in a 42" Mono??? (DF MKII
- Flex Cable Lubrication?
- Please help me tune my Cat
- Throttle falls off???
- FE conversion for the Segad 58
- Cooling Issues --> Water flow = Little to None
- Cc1515 esc choice
- drambuie on ice question
- Flex Shaft, end of stuffing tube to collet distance, to much exposed shaft?
- safe tempatures
- How to add attachments to a pm???
- ESC Problem swordfish120
- Funny video about leopard motors, feel so uncomfortable for this guy
- Seamless Stainless Steel stuffing tubes
- Target Color
- Genesis Timing question?
- Stuffing tube fitting
- First run of the season!!!
- Need Blue 1/4"od 1/8" id water tubing.......
- Will my flex stand up to big power?
- RC Boat Trailers
- 45A proboat esc & ul-1 motor
- Do you have to run your brushless at max rpm
- Flatbottom v drive build
- need more flow for outboard cooling
- broken cooling tube
- CF Daytona Motor and ESC Selection
- What would you do?
- Carbon fiber sheets
- I'm sure this has been ask a million times (CG)
- Waterjacket with 90degree fittings
- 2.4ghz questions
- Need help with identifying a bolt/nut
- Stuffing Tube/Motor Mount Angle & CG
- not an RC question but
- Help bouncing at full throttle 30 inch cat
- ABS plastic boat ??
- Any Waterproof ESC for boats?
- Need strut with 1/4" ball bearings for 1/4" shaft
- Dragon Sword Mono replacement motor advice
- eagle tree
- Lehner motor in star mode? Is this right?
- Good deal on a 6S motor
- Right-Hand Twist Octura or ??? Couplers??
- temp questions
- hobbyking
- Apparation Twin motor
- Prop, and rudder relationship
- Which Apparition set-up would you choose?
- another question for you guys
- Anybody have a clue as to what this might be ???
- Extending ESC wires to the RX
- District 11 New England 2012 NAMBA Nationals?
- Will this esc do?
- Anyone ever seen this hull???
- AquaCraft UL-1 ESC vs Sworfish 120A ESC
- Catamaran offset rudder placement???
- Doesn't sound right, short vid...
- Improper Stuffing tube install
- P spec ?
- Astroflight 05 6turn cobalt motor ?
- Restrictor Plate racing
- Octura strut length?
- rx/tx range
- disappointed with myself
- setting up a twin cat
- Help Understanding brushless motor specs
- This summers project... Hydro 40+" suggestions
- Vegas hydro tuning.
- Best Collets?
- MY Experiences with R2hobbies
- any ideas??
- Flex Size issues
- big boat questions
- DF 26 Setup Help Please?
- Made a couple runs with the new leopards 2860's
- Looking for a N-2 (<27") cat for SAW racing
- GTX from Heiko
- R2hobbies horr story #2
- ESC "bling"
- Water coming in from stuffing tube
- leo 4092 on 4S
- New R2 Hobbies hull
- Where to find some info about the Insane FE30?
- Boat
- Paul Pachmayer e-mail address??
- motor suggestions
- sponson mod.
- Painting a fiberglas hull
- 1/8 th hydro exceed hull could use advice
- 49 1/2 inch hydro build help please
- First Time Build - Several Questions
- Help choose....
- genesis single struggling with speed help me out
- Great looking outdrive........any good?
- Genisis...
- Indentification Help
- Rigger Help - Making a Tub
- Boat trailers?
- Trim tabs on a catarmaran
- Real Ampdraw discussions etc.
- G10 fiberglass for rails in a mono?
- Cat Strut/Rudder Setup
- Coolest boat retrieval ever!!!!
- Which will give me more speed?
- Waterproofing esc- caps?
- Adhesives
- Mgm compro
- Prop thrust bearings
- Eagle tree recorder
- 32" cat
- Anyone make custom intake scoops?
- Mono help
