- new wiring for twin cat
- 2012 Az Winter Warmups VIII signups are open
- Boat plans
- Been gone a while......I'm back!
- ESC For Brushed Motor-Newbie Question
- 5682-1360-Y wind, Has Anyone used one???!!
- Steve I am Having PM and Email issues again Including a emai to U.
- HTVboats PLEASE CONTACT ME ASAP
- Question about Spektrums' DX3S & recievers
- Aeromarine problem
- help with builds CF river cat, mhz 43" nomad Cat, king of shaves cat
- Unable to paint boat
- Which is the better 200amp cheap esc?
- WidowMaker vs. SV27
- Stuffing tube question
- Paypal question
- Not enough speed
- swordfish240 questions
- Leapord 4082 SK 180 Timing
- Amp measurement increasing
- 42" v-hull,leopard5692(props,voltage)recomendations
- wiring
- pirate 35 w/1520
- My 240hv is back and looks different
- Touring car guy getting into boats....help
- Noob
- burned up esc
- The Dec. Roostertail is online
- new wires
- Bending a brass tube...
- Dr. Super-Evil Hydro II - Shaft
- Can you help me to identify this deep vee hull?
- Question about temperature?
- Need help choosing motor size!!1
- Anyone ever use one of these for Boat retrieval??
- This vintage boat any good
- cat build with another motor question. i'm lost!
- Mounting transom hardware?
- Merry Christmas.........
- MGM-Compro Esc
- New HK "POD RACER" futuristic rigger
- RX signal through carbon fibre
- Mounting Turn Fin ideas
- df 29 setup questions
- Kevlar
- Check out this electric rc boat website and forum
- New Guy
- Help please!
- Stuffing tube Question
- Hobbyking Genesis
- Looking for boat action pictures
- need help
- need help please
- Rudder water pick up and cooling problem ??
- tape?
- Fake scoop mounting
- Stuffing Tube Bend/Bending Issue...
- Ride pad question
- Motor ESC Prop question
- Pursuit motor upgrade.
- Exceed vyper set up advice
- MHZ 39" Racemaster?
- Please Help me recovering mine boat...alll ideas are welcomed...
- Drilling Carbon Fiber Booms
- Mounting trim tabs +turn fins on John Finch Wild thing mono ?
- painting pros please help
- Paint over Gelcoat?
- would this outrunner be any good for an Apparition/River Cat?
- program card
- Will this combo work?
- Brushless motors
- Shearing rudder nylon safety screw
- Painting over gelcoat?
- Gps
- Something from HK that is easy to make and could save people a bit of trouble
- Order FE boat stuff from Hobbyking.............get a free gift!
- does anyone have problem with this coupler?
- Happy New Year!
- why would same kv motors perform so different?
- Need info on C-BOX
- What prop for Mistic 29?
- CG help
- Anyone ever hear of these boats from this site??
- mounting of motor mount
- A little late but, Happy New Year!!
- battery and prop help
- Climate Blizzard Rigger HELP?
- Clear coat over Carbon Fibre
- thunder tiger outlaw jr
- Eagle Tree
- found a useful site today
- ESC capabilties
- 2012 NAMBA renewal
- Neu Motors
- New member that needs advice
- Just bought an HK Apparition, Who has/had one??
- Very nice and high quality boats
- 5682 1700kv, CC240 6s2p and X646/3 in a 45" hull?
- Why does a boat "spin out"...............need advice.
- #10 wire
- 32" Mono Best Stinger Angle?
- How many of you have lost or destroyed a boat?
- My first FE a JAE 21
- How should I fix a 1-2" split in the seam of a mono hull??
- Red Loctite for flex shafts
- Apparition 800mm (HK) Setup Questions
- Cat CG question
- T180 programming help
- New Electric Rigger
- KEDA Motors. How good are they?
- Carbon Fiber
- Thinking about building a Genesis twin
- Twin Motors
- OUTERLIMITS Font ??
- outboard motor
- New mystic 1380mm .What sould i put in there ?
- Fast Cornering Whiplash
- Hex screw size and spacer?? on stinger
- Esc info
- GPS for speed check
- Anyone know what happened to Paul Pachmayer?
- HK Osprey + Turnigy 180 + Leopard 4082 + 6S
- Horracing 41" CAT
- Who had the EDF boogie board rescue craft?
- D verses Y winding
- New to FE, and have some questions!
- RC Electric Outboards
- It's wonderfull craftmanship
- Looking for the best Garmin.
- Is "S" mono very popular? I wanna build one.............
- Fighter Cat 3-16s 200a ESC and CC2028 has any body used this combination successfully
- 1800 or 2030?
- Mono hull recommendations
- New to FE and impressed
- Question about Motor sizes 4074 vs 3674
- new to boat building...
- new 200 sw esc help
- Want your high amp draw ESC to run cooler?
- Old school made new
- Nano Technology Waterproofing
- Will this esc handle a 5692/72 on a p 255?
- Speedmaster strut shafts?
- 41" Fighter Cat Fantasm
- thunder tiger outlaw obl help with stuffing tube mounting
- First Cat!!
- OUTERLIMITS Font
- Princess Express Cruiser
- Q: Strut Adjustment Inside Tub or Hull?
- Which ESC for a serious 2S setup?
- rudders
- One or Two Rudders for the MMP Rapid?
- build question
- best upgrade package for NQD 757T-4017 lobster
- Where do we leave ratings for sellers?
- Carbon fiber weave clean edges?
- Brushed ESC help!
- Twin esc - bec disconnect
- boat hull
- RPM question
- Hey guys, how about a hull identification please?
- Stealth question
- Best motor for 1040mm Genesis
- Drilling holes???
- Apparition: Upgaded flex shaft question
- vac u pickle setup
- Duratrax Flash Point infrared temp. gauge
- Garmin forerunner 201 vs foretrex 201
- Fighter Cat ESC
- Carbon Fiber Genesis Motor Setup
- Conquest ESC help
- Need Advice Managing Castle 8mm Bulletts
- Intlwaters.com
- OSE set up question
- Crrcboatz-Anyone Who Bought an Item From Me in the Last Wk or So
- OSE phone #
- my fisrt jae 21fe
- where do i put my esc?
- Anti spark resistor: Which end points toward the esc?
- D wind Y wind
- Strut - rudder setback confusion
- T120 LVC issues
- What is the best handling 32-35" Mono hull on 4s in RACING conditions?
- Motor mounting Hole Spacing?
- New Sub-Forums- Thank You Steven
- Want a self writing wave basher hull
- vac-u pickle help
- Air Pockets in the Cooling Jacket
- anyone ever used a Hobbico Model Maker DA500
- Anyone looking for one of these MRP hulls?
- Lipo pack in TX (GT3B)
- Genesis RC Boat...your thoughts?
- Apparition motor mount template
- Cheetah hull origins
- the engine mounting point
- How to fix a busted transom?
- Anyone using the Scorpion 5035-760 Marine Motor
- scat cat 21 help
- HK 5682 1700kv Pro Competition
- Stupid ESC question
- Speedmaster 21 strut
- Condolences to Cold Weather/frozen pond folks - Phil has spoken !
- Hull floatation
- flex cable length
- delta force votrex hydro 22 question
- Etti 2mm coupler question
- snow running
- Neat FE setup calculator
- Mm products the Watersnake
- Cracked the transom on my Genesis
- Safety Loop ??? Amps etc
- Permatex bearing and sleeve retainer
- Genesis question
- What garmen to get?
- Old boat nitro to electric conversion, sub-surface drive
- Scuffing review!!
- Edwin Hall Effect & How It Applies to 4-Pole Inrunners and Higher Pole Outrunners?
- FighterCat Cheetah Build
- T120 up in smoke
- Straight couplers
- Fast New Build Info
- How to set the timing on Birdie 200amp escs?
- The pinkert Gator
- FE Publications
- Two ESC programing questons??
- 36 delta force cat
- soldering help
- Paint Jae rigger ?
- Fiberglass installation help
- Positioning of esc's and batteries 44" mystic?
- UL-1 Competition?
- HK & TP Power Motor Info (5660 5692)
- Stuffing tube for wire drive
- Help with hull
- something new and big....
- Rolled my Persuit :(
- HK rigger- who bought one?
- Apparition twin motor or single??
- Changing member signature?
- Molding need help
- looking to achieve 70 to 75mph
- neu 2220 2y
- LVC or Overheat?
- Best deep-vee hull 30"+ to build ($250 budget)
- Hydro build link
- FE happenings this past weekend at NAMBA Dist 19's race in Lake Havasu, Az
- do i need a skeg?
- What kind of hull is this?? anyone ever see one?
- Newbie water cooling question
- 8mm to 3/16 collets
- To add a BEC or not...
