- noob greenhorn new boat set up
- found my old boat need advice
- TX/RX Upgrade Question
- Found this Cool Hydro on the Bay and need advice for Electric Conversion.
- HOTR Twin ESC problems.
- Off to the Straightlines !
- Bulkhead for my GENESIS
- shocker 950 or sprintcat ?
- "the right set up" MHz 54"mystic?
- Esc troubles. Forward works as long as long as don't hit reverse
- twin pursuit?
- Need help, does anyone do hull repairs?????
- Help on my first boat
- Delta Force Explorer setup question
- Motor maintanence
- looking for a tool
- Deans - poor connection?! Recommendations?
- Which ESC is better
- Shaft sleeve on strut coming out in high RPM
- any window decals for the 36 explorer
- Sixteen New FE Records Set At L.A. SAWS
- Square drive adapter for 5mm motor shaft for OB
- 1981 Pay N Pak graphics
- Ohio steel 40''
- anyone use a 1512 1y 2650k motor in a hull
- 2732kv on 4s???
- This boat has quality problems?
- help with picking a new boat
- blueprinting a hull?
- Twin cat ruder position
- modding hkt6a?
- Namba SAW Events
- Stinger versus Strut. Which is better?
- Stealth new setup help.
- I need your Opinion on Speedmaster21 E-conversion
- JAE Design
- TP power motors
- Spartan castle motot in a genesis?
- 4mm to.... 3/16 dog forks?
- Need some "BATTERY" and "ESC" Info
- Need advice on setting up a Venom King of Shaves P1 hull
- Where is the water?
- NAMBA PRESIDENT and Director VOTES - Deadline Oct. 25th!!
- What Drive for a Graupner B-24 "bat boat"
- building a boat for the first time. Genesis
- Count down clock
- Electric NOS
- Basic ESC question
- Silver solder or 40/60 tin lead based
- Mrp miss bud hydro
- For All The Canadians....
- how does the evo2 compare to the fe30?
- 2230 powered mono
- Which resin?
- Apiration vs Gensis?
- Is there a boat that could:
- WHERE do I get this????
- Traxxas Villain IV reborn with question
- 5.5 Bullet Connectors Hole diameter??
- tunnel depth
- Question from Anyone who owns a Mystic Cat from HMZ
- CC1515 2200kv motor timing?
- Question! Anyone know this boat?
- Configuration for a 1/16 ms k shovel
- should have a noobs corner section here......
- Does anyone use a thrust bearing between prop shaft and strut???
- New Toronto Area LHS
- Ebay boats are such a ripoff!
- what size delta force hull?
- best boat for a noob?
- R2 hobbies 36" cat hull
- RC range?
- Thank You to Mark Grim, and Congrats to Robert Holland - NAMBA Vice-President
- Miss Bud Or Miss Elam
- identify this tunell hull.i need info,name this model?engine?see pics broo tank :-)
- Limited spec mono
- 36" H & m cat setup question
- TFL Hobby Kiton NTN600 70cm/25"
- aqucraft ep-1
- 36"dumas hydros
- Death wobble at top speed
- Genesis speed controller
- OSE Shipping Price?
- Anyone in for a little FE FUN, Jersey Style ?
- Gary Finlay's shovelnose kits
- Which type of collet? Three piece or regular two piece?
- Running Hardware for Dumas Pay'n Pak
- What tape on hatch ?
- Newbie geneiss revamp. Need info
- hull build for delta force 29
- Timing for motor
- Bens got yet another Cat out
- Limited spec sport
- Cooling hose wrap?
- Do Not Buy This boat Exceed racing Shark
- Opinion Needed! EKOS or Miss Geico? Which is better?
- "Newb" to this forum & boating
- Are there any reasonable cats out there in the 23-24' size
- New Stock HK Genesis Motor now Shipping
- Anyone ever try running ESCs in series on a 10s setup
- ESC selection, HELP!!!
- How far in the collet should the flex shaft sit?
- Brushless in Miss Bud copy
- What colour and type of paint this may be?????
- Smart phone app for r/c
- Any tips on a df29 build???????
- Nqd px-16 ????? any info ?
- Question about Loctite for Flex shafts
- Email notifications notice
- Twin ESC Setup
- 15kw LMT outrunner anyone?
- Bob Morgan - "Bad Moon Risin" offshore racing killed in Key West
- anyone build fightercat cheetah 34" yet?
- Paint v's Gel coat ???
- MHZ Mystic 1350, Newbie questions
- Water Cooling through ESC or Motor first?
- Easy way to cut PVC for boat stands
- My T-180 only goes 1/2 throttle now....any help?
- Help with boat identification please ???.
- IMPBA LSO Rules Question
- What Paint? Need HELP
- upcomming project
- continuing the thread about ben's cat.
- flux tork motors in boats
- Will I get away with a 60a esc?
- building a twin genesis
- need help with motors
- Kos p1 cooling prob
- Teflon liner or not, part II
- Water inlets
- tools
- wire
- need canadian help
- Need 27" os catamaran choices??? What's the best hull???
- New Prototype Water Cooling Intake
- New 12s 4kw motor from Hobbyking for under $100
- Motor Mount Help
- H&M Spyder Triple Wing Hydro SETUP
- Need help from any of the GlassMasters
- 1/4 scale kneeler outboard hydro power?
- Hull choices rtr
- Fake USPS email. It's a virus
- Is this enough power?
- What gps for boats!
- How to mount stuffing tube?
- program cards
- Rigged Insanity Rudder Location
- Flex shaft problems
- What is BEC ??
- Epoxy by Bob Smith?????
- Remote trimable outboard?
- Z-poxy
- genesis plunge
- Pistix ?
- Rudder placement for a 1/10 shovelnose
- Has any one modded a 36"Shackwave.
- T180 program card
- 5.5kg/cm enough torque?
- How to stop capillary action on stuffing tube?? Water in Hull
- Please Help
- Flex cable and its expansion for FE's
- FS-GT3B How do you change steering and throttle direction.
- newby form the uk
- Anybody in need of a small size lower leg ???
- Boat does'nt feel right
- In line prop & rudder pros & cons
- Trun Fin Sport 20
- Vertical turn fins on a mono do they work ?
- How to power this cat?
- T180 lvc
- Apparition or miss Geico
- Does an air dam work on cat hulls to reduce lift at high speeds.
- 7mm tube and 9/32 OD are they the same
- Question about a Hull
- hpr boats
- looking for a 29 to 36" CF cat hull
- How about thus Johnson Outboard !!!!
- Raise namba voltage limits, please: 10s lipo max is not good enough
- Need answer quickly about mamba pro esc
- Turnigh 12s 240a esc wiring??????
- Anyone here of these folks??????
- Outboard water cooling questions???
- Been spammed twice now by an OSE post notification
- I need help from the outboard guys.
- Chrsitmas Giveaway??? Would it be ok with Steven?? Anyone interested to participate?
- winter builds
- FYI 50% off boca bearings this weekend only
- Rudder Placement
- iPhone users having issues or just me?
- Victory 51 Cat
- Bending Pushrod
- Power from motor size?
- preparing for paint
- 1/4" Dual Rudder for 51" FE
- Repairing Cracks in Pursuit How to??
- JAE .Fe some questions
- Flooded stuffing tube questions
- orlando hobby shop
- Suggestions
- I need help chooseing a hull
- motor mount
- CF sheets
- 5mm shaft / 6.3mm flex, Electric motor coupler
- need help setting up an outrigger/ motor-prop
- Really Cool link to R/C Electrical Stuff - Must See !
- Flex shaft and Collet advice Needed !!!
- collet
- hobby king commercial
- Quick question??
- 29" sprintkat - motor selection
- 29" MEAN MACHINE SAW BUILD: TWIN C/R LEOPARD MOTORS, HOW MANY ESCs?
- Can you run 2 motors from 1 esc???
- no load amps
- props and motors
- I have CC1520 1y 1600kv motor, What size hull would good.
- Best Sport Setup for Single Apparition/Rivercat
- What am I missing?
- Bearings instead of bushings. Makes a difference?
- motor suggestions for hk osprey with 240 esc
- 29" sprintcat setup
- Flotation Question from Newbie
- Value?
- amp draw
- strange esc behavior
- How To Find a Model Boating Pond Near You.
- H&M Spyder Triple Wing Electric Setup
- Hor shovelnose
- New to boating (one boat) suggestions on next boat please
- 30in. cat
- Fightercat Racing
- Capacitors,,
- Best way to remove a bad paint job
- Epoxy still sticky?
- Categories for boats
- What am i missing - 2
- esc for 7s and 8s setup
- People not receiving pms sent
- New To Hobby And.....
- SK 180 where do I waterproof at?
- Site maintenance
- 5.5mm connectors ok?
- New front page.....
- New 130 Amp HV Hobby Wing ESC Search
- RC Surveillence Boat
- test1
- Testing. What would it take to make you jump from the 10th floor?
- Rudder on left?
- la gran argentina
- Maker of These 39x96 Motors?
- TP Power 4082 Motor Any Good???
