- What to do when cutting a stinger?
- New T180?
- pursuit turning issues
- Electrified balance point
- Finally put my Miss Geico to the test.
- REK outboard flex and coupler
- ESC issues feigao 8xl and 60 amp esc
- Best bang for the buck ESC w Lipo cut off
- New guy trying to get into boats a bit deeper..
- Hobbyking shipping question
- every detail
- Wildthing painted. What do you think?
- 37" Fightercat Daytona voltage and prop help
- newbie with some stupid question
- Hobby King kv checker
- Need help with setup
- Light weight motors?
- I need help for a twin setup,, Hydro Marine Freya MKII 1m./40''
- battery placement
- Help with a build
- Rigger ala HK..? ;o)
- df 25 or prince help plz
- dragon v24
- Motor KV and Number of Lipo cells combination
- Ebay esc? Anyone tried em?
- Do I need to replace the caps?
- Outboard motor choice
- anyone know were i can get this for a 7/32 tube ?
- 1717 motor value
- All things being equal - Better ESC - lower temps?
- Ballast/balance/weight
- Using a UL-1 motor in LSO
- where to buy a 30"-40" hydro??????
- Please advise!!!
- What extent to Waterproof a DF26's electronics? If any...
- max recommended temps for motor, battery, esc
- What ESC to run?
- Genesis questions. Not fast enough.
- How hot is too hot?
- joysway
- Titan 29 ?
- Mono Build Need Help!
- Which standard for US shaft ?
- ESC problem, please help.
- fitting an offset ruder to a 32" River Cat?
- Lso. Lsh ???
- What electrical set up for a cat
- Reference point for measuring COG on Genesis
- COG and Balance Point
- New P Spec Hydro Heat Race Record
- is it really worth it???
- Proboat 1500 on 6S
- Bench testing a motor
- water in boat
- help!!miss bud 1/12 problems
- Water sanding epoxy coating
- Can I diminish prop walk more?
- Apparition cooling
- Value- Minicat Samurai/ Tenshock Warrior
- Paint tips?? SprayMax 2K looks good to me.
- delta force 36 cat
- Awesome Wife!
- Twin setup for a 45" MHZ Cat
- What about DELTA FORCE CAT?
- I need help! Leopard 5692 6mm shaft to 1/4" flex cable
- Quiet Season?
- New boat in the fleet!
- 5692x1340kv on 6s is it ok????
- Anyone ever thought about a twin tunnel?
- OSE 5.5mm bullet conectors - Tips to solder motor wires??
- motor turn question
- Installed new rear shaft on 4mm genesis
- driveshaft liine up techniques
- fightercat cf dytona question
- Genesis prop shaft help
- Genesis or Saga
- Pursuit Mono Question
- 300 amp hv speed esc & other hv escs ???
- Rc boat magazine
- 32" rivercat 3/16 twin struts options & motor mounts?
- Need help with twinstorm ve
- Does anybody have any mono rc boat plans
- sport 40 hull advice
- What Feigao Motor in this Hull?
- Leopard 3650 or 3660?
- FE Boat Calender?? Anyone Interest??
- Hk Osprey or Hk Vanquish?
- MHZ Trimax drives
- super cat 34" turning help
- Looking for some info from the Nitro Guys
- I can't remember who makes custom hardware.............????
- Looking to help a boater pick out a boat
- CC 1717 1580kV on 5S
- Etti power analyzer
- esc problems
- Opinions Needed from the all FE boat know it alls!!!
- Opinion please
- Will these find their way into our bigger boats?
- What is ACTUALLY bad about the NEW style 40-160??
- teflon tubing
- What takes to get one of those going...
- shaping rudder
- product watch question
- Where to send neu motor to be repaired
- Search function blocked by blue bar...........yours too?????
- need recommendations for ac razor 45
- programming card help
- Electric boats and Saltwater??
- RC Boat Modeler Magazine
- Sf200, leopard 4082 on 4s2p issues
- Props not spinning in sync???
- ripmax tomkat
- batts vs esc
- Can I build a cat like the 29 Mystic for $400.00 to $500.00
- CC1512 2650kv DF29
- Newbie with a boat pursuit
- schulze esc repair cost
- Dumas Hotshot Sprint 11 cc to electric conversion
- sponson angle off attack
- Kyosho Jet Stream 800 Newb going brushless??
- A Slow HPR 115
- Got a Dumas Hot Shot 45 hull - worth rebuilding?
- Aluminium Bottom Water Pick Up Double
- Mono-Catamaran - Check this out !
- Water cooling tubing
- Esc Smoked for Unknown Reason. ideas?
- upset with hobbyking
- stripped out set screw on drive dog???
- Stainless Steel Propeller Shaft Material Grade??
- sponsons VS tub
- AWESOME new FC hull!
- Twin electric outrigger or mono hull help with esc hook ups please!
- Is this a bad idea?????
- New HPR C5008 (115) Build
- Suppo ESC programming issue
- testing motor rpm
- Opinions / Input
- DF explorer twin cat help
- Great lakes area building inquiry
- underwater camera boat finder
- Props for 72" Class One Skater
- Sword fish esc
- Suppo (Genesis) ESC problems
- Can I run a 4S ESC on 3S?
- Stuffing Tube Gease NOT to Use?
- Water Cooled Lipos?
- ready to buy 32 fighter cat ?????
- cc 1717
- If doing a build with no Teflon liners and 3/16?
- Carbon Fiber
- Timming for Leopard 4074 2200kv....
- X & M prop series
- First run.
- Kyosho steerable outdrive help
- Sea king 180a (old model?p
- bought the 32 fighter cat.... wife not happy o well
- Major Accident The Canadian Dream Crash
- Fc anti spark capacator installation
- stuffing tube questions
- Power Options for 32" Deep V???
- Science Project
- Flex cable .150 x 3/16 for Genesis
- Hydro sponson tip weight
- OSE "Friending"???
- Genesis or Miss Geico?
- AC Sport 40 II FE setup
- Shocker!!!!!!!mti cat
- Cooling question
- Probably been ask a hundred times
- What boat should I
- Genesis pulls Right????
- Genesis on 10S not fast enough
- HK SS Boat Series ESC...So what's the concensus?
- Why paint the boat b4 you build it?
- t180 timing help
- HK apparation
- Catamaran hull vs sport hydro ?
- Looking for catamaran plans
- Fine Design visit
- Speedmaster Stinger Harware with Water flow problem- Low flow
- Saw hydroplane 1S
- Himax 3630 1500kv timing?
- Flex cable loose strand
- Replacement Motors
- Rocket hobbyists need our help!!!
- Trim tabs mount
- CC 1515 2200KV or Leopard 4082 2200KV Which is better?
- Haven't seen these esc at hobbyking before, Cheap!
- What size flex shaft ?
- what prop for mean machine 4s 1500kv
- anybody ever have a cc1515 2200kv grenade
- Missing thread/motor requirement...
- RTR recommendations
- Kyosho twin storm brushless recommendations please!!
- Single or twin Fc 32"
- Need to remove Paint and graphics ?
- bilge water pump
- Best rough water boat?
- Stika users
- Miss Geico Clearwater 2011
- Question
- Rotomax 50cc Equiv?
- prince 25 hopping
- Amp Draw question
- Speaking of LVC…
- Need suggestions new to the hobby...
- Need help for Schulze 40-160 ESC
- effectiveness of silicone water jackets
- Happy Birthday Properchopper
- Water Cooling Jacket.
- yet another question
- Minicat Samurai powerplant and prop
- G-freak youtube vids
- Aeromarine Preditor Tunnel ?
- HK-GT3B AFHDS 2.4ghz 3 Channel TX newbie question
- 2011 Fall Nationals (not FE)
- How to remove stock Teflon liner it won't budge
- Yet another LIPO question
- Does anybody remember writing this?
- anyone know the cog on the intruder s
- steeped mono v deep vee
- BL Electric Motor Maintenance?
- What kv and voltage 51"' mono
- Anybody had any experience with getting an out of warranty MGM compro repaired?
- Want to see a cyberstorm with a CC1515 2200 in Any vids?
- Want to get a Cat for $300! 30 in +
- Team FFRB
- Aluminum or Stainless Steel Blind nuts?
- GPS recommendations anyone?
- Taking Apart Proboat 1500 Motor NEED HELP
- Winter Conquest Build
- teflon liners and flex shaft gaps
- IMPBA Fast Electric Director discussion
- motor upgrade
- electronics cooling while waiting setup????
- New guy with questions
- GPS Problems
- prather 31 setup help!
- Teflon or not to Teflon (which is better)
- Turn fin
- Brushless Motor/ESC Saver?
- NAMBA Propwash is online
- How to disable the bec?
- Some people have nothing better to do.
- Esc temps
- Strakes for Finch Wildthing .21 monohull?
- Ordered a FighterCat 37" Daytona Cat!! Set-up??
- TURNFIN Info (hydro).
- motor/esc guide
