- Just ordered a Impulse31 !!!
- Looking for Hull Suggestions
- water pouring in through stuffing tube
- Repair or new hull? ABS OM26 bby
- Hi Guys whats new
- Anyone bought from Astecmodels in UK???? Twin Genesis
- NEU 1527 1250Kv ESC GOOD
- issues with trim tab placement/ need info
- Wiring Connectors
- Electric TS 2 plowing in the corners
- Soldering Help.....
- Adding capacitor banks to ESC
- Electrified 20" mono set up
- Parallel connector for twin motors
- ICE question
- Best Setup for JAE 21 for saw type racing!
- 20" mono setup
- motor heat question
- counter rotating props!!
- Anyone ever tried this?
- Miss geico trim suggestions. H e l p!!!!
- Need advice on step mono setup
- Which twin motor combo to use for the MHZ cat I have
- Need twin cat setup help
- Spider cracks???
- Fly sky tx / rx any good ?
- Something New I have been Helping on
- Shortening stinger strut - good or bad idea?
- Test/check an ESC
- Cat 32 twin- right Motor spinning when turning??? Why.. How to stop this.
- Where to buy collet or coupler?
- Couplers requested by?
- 4s0p or 4s1p???
- Bad test run
- New guy introduction and question
- Mystic C5000 33,07'' Motors & ESC
- Choosing the right boat
- Mystery motor purchase from Neu
- Offshore Electrics on Facebook
- first post outside of the traxxas rt... i bought a twin genesis setup now what??
- 47 inch deep v hull setup advice needed
- Grease Issues on Apparition
- Mini Mercury or Evinrude e-tec decals
- Which monohull for Feigo 540 S 7s ?
- X-blaze super version
- hk pursuit questions,newb to this hull
- how to stop spark from lipo
- 36"-43" Titan 29 Hull Replica?
- Hull Suggestion - Castle 1515 motor, Choppy Water
- Paging Jeff Wohlt!!!
- ICE 240 turn off BEC volt??
- Put my boat back together, but now vibratinnng!!!
- Re-using wire drive stub shaft question
- No more Tx's ; Just THINK your boat around the pond
- Anybody use the Fat Shark? (or other FPV?)
- Another noob question
- Mystic C5000 streeing problem
- Mean Machine rudder length?
- genesis help
- RPM range
- HPR CT04 67" carbon fiber
- CAD DWG help
- 54" v boat can keep it on the water after around 63+mph
- Hull Choice
- hello from a newbie and question
- Aeromarine Titan 29 Motor
- .187 without teflone question
- Question about loaded RPM
- New HK inrunner motors
- New Member - Electric Running Gear Help for Scratch Build
- Hobbyking Surge Crusher
- Wich size flex shaft ???
- Delta Force 33
- Nitro tunnel.. Switching to elec..?
- Fatboy esc
- Looking for esc???
- How about an app?
- newbie needs help
- LogView Data Logger
- Transom overhang on HPR 135?
- Pursuit bare hull- hardware question
- 32 pursuit
- prince 25 help
- Dust off your camera for OSE goodies
- df29 build help
- help 43
- Questions before I build my boat stands
- Check my math please
- Looking to R&R A 36" Shockwave to FE 4s, Any info on a good cheap motor for it.
- mystic
- Impulse 31 or Motley crew
- gps interference?
- How do I delete old pics in my pics section on OSE?
- Trouble posting pics for sale ad
- How in the heck do I upload pics from MY computer? Won't let me now!!
- Exceed Shark 600?
- df33 rail's
- Pursuit questions, motor upgrade, hull reinforcement, etc...
- Hull forming
- a good mono
- C5000 33"in
- fiegao motors
- N-1 mono SAWS
- Noob needs some help... Please?
- Can someone please help me?????
- Leopard 4082 flex cable
- Help With HOR Racing!
- Hydro problem! need some info..
- Revised math calcs/motor determination
- Will my new setup work.
- Steering boot on stuffing tube?
- FC 32" River Cat
- Best brass stuffing tube size??
- motor mount
- sponson angle
- Building an Apparition, need some advice
- Hull for twin motors?
- Stinger Strut Adjustment (Pros and Cons)
- Project super hawaii
- Interesting discussion on RRR board
- Wire drive woes.
- what esc???
- pursuit help
- Sea King 180 up in smoke
- Keeping the bushing in the strut?
- Newly released : HOR/TFL ARTR Genesis Twin Cat
- RCRACEBOAT Closed thru August
- Pushrod connectors
- Apparition RC Boat
- rigger queston
- help needed.
- District 12 August 26th Race....Anyone going?
- Genesis 900
- DF pirate/ CF
- Teach me about flexible drive shafts please- bend radius- liners- material types ect.
- fast electric boat
- prop depth and angle
- help with wire drive please
- proboat 1800kv?
- 2012 NAMBA FE Nat's information
- Great News !
- Paint Type - ABS Plastic
- Peter Zicha
- Never had this problem before...
- another villain build- help.
- twin cat prop/strut distance. How close is too close?????
- speed calculation
- Wire drive sizing
- How to repair gelcoat in hull
- Need help to pick a motor!
- 1717 in a Proboat 1/8 gas Miss Bud
- New Boat help
- tore between 2 boats
- 1/8 hydro kit
- Thread placement 101
- Can anyone find this!!
- rudders and struts for riggers
- Brake on boats?
- prince flexshaft
- Insane or just insane...
- Power Supply
- New Thunder Power R/C Z3R-8 1/8th Scale (Buggy) sized motors!!
- Help with an outboard.
- pursuit hatch seal
- ESC Programming question
- Wire drive question.
- Using the speed Calc for a twin setup?
- Genesis help
- Race markers
- CEN Baja boss vs traxxas villain
- HK SS boat series 125A ESC
- CEN Baja boss upgrades - motor
- Proboats mono canopy
- Technology improvements if used correctly
- Kb 45
- anyone know where I can find this strut for sale within us or china lol
- New Himodel marine ESC's
- Matrix Ultimate set-up problems?
- Outboard hydro plans.
- Genesis 1 piece 3/16 flex cable conversion
- HK Genesis set ups?
- motor angle
- Fighter Cat Programming
- Boat ESC's vs Car ESC's
- Monohull vs Catamaran ?
- scorpion Motor Question
- DF 41 or 45?
- Llooking for paint design ideas - custom28 mono
- What to buy....
- Drying out my 2028.................???
- Flex drive question
- Anybody seen these before????
- Dc current flow
- Boatl weight?
- Water coming up Flex shaft
- Motor combo Question, rotor/ kv
- Esc?
- A Few Questions about Set-up on a Carbon Fiber 6S Rigger
- Mounting hardware to the hull- lets talk about position
- Please explain watts/amps/volts
- paint
- Need some help with my set up on my 37 daytona cat
- What speeds can a Mean Machine handle?????
- De greasing a nitro hull to convert to electric?
- Mounting and cooling questions 4 the 1518 in my project boat
- anyone ever heard of this
- what is the best paint for wood boats?
- Are you double checking everything?????
- Do brushless motors care what way they spin.
- Need a little help
- Tubing sizer?
- Any one try one of this yet
- lepard 4082 2200kv in a df 35" pirate, would it be enough
- Strut/Stinger Size for 32" Mono Hull
- Do you prefer trigger & wheel tx over twin stick tx & why.
- 36" Twinbrushless Catamaran
- Its me again!
- 1717 Hull choice
- One of those days
- What did I do wrong?
- Silent Engines-Justin Hill
- hatch latches
- What is the going price for a 1717?
- Drive coupler question.
- Boat newbie just bought a Dragon Hobby Miss Budwiser got a couple of questions
- Bullets in series
- Replace teflon liner-BJ26BL
- ESC water cooling
- What Motor Will Get this BEAUTIFUL BOAT in the 55-60 mph range!
- ESC programming card
- was way off
- Need help with battery hold-downs
- MR3000 issues
- does this strut look about right????
- Pursuit or Delta Force for a nice mono?
- Genesis modifications: Looking for Prop
- Need help with "TUNNEL" build
- little help with df or prince 25 please
- Flashes and magic smoke...oh my. What happened
- Was is the best way to test a brushless motor?
- K&B 11cc to Brushless Conversion...is it possible?
- eagle tree
- hydro ,how do you run them
- How to delete a post???
- Running motor, flexshaft and prop unloaded ??
- Can i mix capacitors when adding a bank to my ESC's stock caps?
- "brushless" cooling fan?
- Hello from the sunshine Coast qld oz..... Need some help?
- Which Gas Sport Hydro to convert to FE?
