- trim tab location
- Are HK 180 A ESC repairable
- Stupid Speedmaster strut question
- Octura collets and .187 flex
- Today
- motor/battery ?
- Cowl Lock Water Proofing
- How to Lay Decals
- Neu 1515 1Y Equivalent
- Looking for some info on a Miss Bud
- Work bench light switch replacement
- Renegade Riger- my first rigger
- Question on mono rudder placement
- First FE flex/strut - OK?
- maybe i am thinking to much?
- Runnin out of place to run are FE Boats
- hydro and marine parts?
- Miss gieco cat speed set up
- Laying Carbon Fiber
- Top flight balancer
- Can you add a no spark resistor to a Hydra Ice HV
- USPS issues??
- 50% power with 100% throttle ?
- COG for mono hulls
- Traxxas Marine Motor
- Just got my HW 180 and need alittle help
- Wire vs. Flex drive?
- Huge pop + Schulze ESC question
- Old Mono, New electric
- Kintec contact
- Help needed: what do I need?
- Is this boat worth updating
- Apparition upgrade
- Removing Wood Stringers
- What paint do you use.
- WOW..............new website format!!
- 6s ESC with full reverse suggestions
- New Look OSE
- New Site format... like Jim Boat Dock..
- Wiring and connector thoughts
- Tapatalk for iphone forum support.
- Motor for 32 inch cat
- FeCalc Plots
- Miss G and 180 amp esc
- new wrap for my ul-1
- Help me build at 60mph boat
- Anti Spark brigde
- How would this motor differ from the AQ 1800kv one?
- Question about which Motor / ESC to use for a Boat
- XPS? (extreme power systems)
- 1/5th hydro burns up electronics
- Finishing up an HK-Genesis
- How far in should my stuffing tube go into the strut?
- New to FE, Building a hydro need ESC Motor Bat help
- Fightercat 32" Miss Geico build
- OK: So whats up with the pictures on OSE?
- Converting 40size nitro sprint cat to fe
- new guy ...help me choose
- DF23 hardware dimension questions
- Dual brushless motors
- Prop Size Comparison Chart
- Anyone purchase a t120 or t180 from hobbyking in the last few days?
- Where 2 get 8mmx187 collets
- water cooling for bec ?
- Where to get 2 inch wide shrink wrap?
- Why it's bad to daydream with your finger on the throttle...
- Need setup recommendations 42" aeromarine sprintcat & 51" x-hydro
- 5.5 mm bullet spring pressure?
- Which FE can Race Vs a 1/8 miss Bud?
- R2 god speed flex shaft
- Pictrures from today's Puget Sound fast Electric Race
- Ponds located near Livonia MI
- Bullet connections, shrink wrap, heat, and water
- Who's got the best ESC???
- Setup advice
- Twin ep1's
- Soldering flex cable
- Ok Big Leap of Faith on a HV ESC
- well i destroyed my brand new tacon 3674 1900kv
- Figuring amps and voltage in to watts
- help
- Rx waterproof.. bag?
- New Member New Project With A British Twist
- n2 rigger?
- Image Upload Answers and Tweaks
- some important information about Hanspeter - HPR Powerboats
- Motor/esc cooling setup-whats best tubing route?
- Df 33 w cc1717 will a wire be strong enough
- now that adjustable!
- spec on the HK 3900kv motor
- Please Help me!!!!!
- Twin ep1's: steering
- Paint and hull work
- Design flaw?
- T180 issues
- Something New?
- 3S setup Ideas and Help
- Outfitting a P/Spec (LSH) Hull
- Pursuit Owners.....Help me out!
- Driveline Problems
- Wind your own scorpion outrunner kits
- Problems with Caste Creation Hydra 240A?
- What are some basic supplies needed for building a scratch boat?
- carbon fiber inlay
- good wave jumper???
- 150A SkyWing ESC mod
- Schultze controllers, where to buy (other than finedesign).. thanks!
- How to add Capacitators to a controller??
- Esc issues
- Heat soak and motor temperature observations
- need help
- 1717vs4082vs1520 which has the most to offer
- What is rudder set back?
- edf boat
- What is wrong?
- New Rigger, what motor, esc and battery to use?
- Osprey from HK
- How to Post photos in swap shop
- "P" class which motor 2200kv 4082 or 1515?
- Check out the new "Gallery" tab next to the "new posts" tab.
- power of the 5692x1090
- 41" areomarine sprint cat cg (center of gravity)???
- Etti Exiga mono
- 3/16 35-37mm dog drive GRP props to fit a 4mm stub
- df 33 need help to find flex cable or wire drive
- Where to buy 1/4" to 3/16 prop shafts???
- Is a vintage MRP tunnel hull with an electric outboard worth converting to brushless?
- 5692 1340k batt setup???
- Need build info for Delta Force Vortex 24" Hydro
- traxxas spartan.. rudder upgrade what works thats in stock
- Hor???
- Reply to an old PM
- Sealing tape removal from boat hull- decals coming off!?
- Leopard 4074 & Barracuda 125
- Miss geico updates from proboat?
- Neu 1527
- anyone using a traxxas 2075 for steering?
- Sport 40 top speeds
- Budget radios. Thoughts?
- Help finding motors similar to t600 880kv -maybe Himodel Pro series outrunners?
- Rudder water pickup placement
- striped srews
- Setting up dual motors
- In need of urgent strut advice!!!
- Can 2 escs be run with a single battery pack (with split connections)?
- Expanding foam?
- Good tx?
- Painting question
- spartan adjustable trim tabs question
- deans plug
- Scorpion motor Wires
- Aquacrfat 60amp ESC on 3s??
- Deep Vee with twin motors setup?
- Attention Cat Owners
- CG
- Does an ICE 160 require a Pistix?
- Candy anti-spark resistor cause the ESC to fail?
- ESC to motor 4mm or 5.5mm Bullets?
- Hop-up 34" king of shaves
- outrunner on OB lower unit
- Help ( cat plans)
- fan on NEU 1527
- broken transmission shaft from Appariton
- Link for boats terminology?
- Painting/Airbrush question
- Deep Vee 40"
- Painting plans
- Hor Apparition 32 too Heavy Low at back, Need Advice
- m442, x445/3, x445R
- Drag boat
- HPR 115 build question
- Retrieval methods?
- 8 MM Wire Drive Coupler
- Solder temps & ?
- Will a prop shaft from a REK work with a Hyper Performance Bullet Drive?
- Another Tragedy It's just not worth it!
- fastest Mystic C5000
- Timing for 540 6XL
- Motor/esc question
- Lmt 2250
- Well that sucks...
- Which BL boat should I get?
- Kintec Racing
- Larger catamaran suppliers
- Seaducer 40 and 60
- First build HPR 115 or MHZ 5000c
- Flex shaft question
- Hacker Motor Repair
- ESC fire STINK
- vegas parts
- 17" Deep Vee upgrade?
- R2 Hobbies Mono Hull
- Upgrading toy boat
- What Size Heat Shrink?
- What is "saw"?
- Genesis handling problem help
- Will a Sv27 esc work on 2s lipo?
- What to do with a dolphin outboard (hull choice?)
- thunder tiger outlaw 29 inch mono
- Forum question
- 25" brushless mono motor and esc questions!
- NEU vs Lehner in a 6s SAW Outrigger (Mr. Krabs)
- need 380 brushless outrunners
- temp danger zone?
- Electrified recommendation-copied here
- 40mm tail ring- motor mount
- Prop shaft thread question
- 31" mono help plz
- Best brushless racing boat out ATM?
- D19 H20 Gassers Benefit FE P-Mono Race
- joysway x-blaze super version
- Hydra 240 LV
- Pursuit Question
- delta force 29
- Need a motor mount
- hobbyking pursuit hatch?
- Every have one of those days!
- FE and Radios question.
- Stuffing a Traxxas Spartan
- Confused, Need Clerification On This....
- DF23 Sniper question
- Which boat to get ?
- 240amp
- cc 1518 fit in apparition
- 1717 or 1520
- budweiser
- Spec motor choice for 29" cat
- What size tubing for a 3/16 flexshaft with teflon?
- 20" mono surface drive setup
- Converting air ESC into Marine???
- What's happening with the Canadian Postal strike ?
- Boat setup help for twin monos.
- Mystic c5000 44" Drives??
- Any tips for soldering?
- How to install a new Prop Shaft Strut Bushing
- Flexdrive stuffing tube- straight or s-bend?
- Apparition flex drive HELP PLEASE
- Buying SV27 Motor - Help?
- radios
- water jackets
- fun mutiple choice question
- Genesis - can't get the collitt off of the flex drive, can u help an idiot?
- 7xl in df25..what esc and prop?
- 2.5 quick questions
- Safety Loops
- T180 timming program and lipo cut off
- What's the best boat to build?
- Insane FE-30 Hatch
- GPS or Radar gun? + a slow start....
- converting nitro to FE, confused on hardware and parts....
