- PROP/ESC/Batt match
- JAE 21 outrigger
- Fiegao motor shaft replacements??
- Toy Zodiac, what motor will fit?
- Pursuit Mono
- Open water!
- Help HPR115 boat wanted
- Genesis upgrades?
- Where can I find a Neu/CC 1518?
- Hydro & Rigger Question
- Does anyone have pictures of cockpit detail for a 1990 u-31 circus?
- timing for suppo outrunners?
- r2hobbies outrigger
- determining motor kv rating
- HPR135.....slowed down a bit?
- new here and need some help
- 38" Seaducer and Castle 1717
- Best Hull for Twin Deep Vee?
- Temping the important stuff
- Improving your stock boat stand
- Hobby Wing runs at 1/2 throttle?
- Need Motor mount recommendations
- kv check
- 4s3p??????
- wild cat needs taming
- need a little bit more info
- My New Insane FE-30
- Here is What I have bought, what DV for it?
- DF26 Build
- Winter Project Second Try
- new genesis build
- genesis drivedog/strut gap
- Inline Cooling from Kintec
- to teflon or not to teflon
- GPS Tech...accuracy
- ICE 200HV cap problem/warning...
- No spark calculator
- Genesis flex shaft upgrade
- Motor upgrade??
- Where can i get a teflon washer for a 1/8" prop shaft ?
- can i use teflon tape as a bushing ?
- df 29 on 4s2p?
- how to make square drive cable
- Water proofing a T-180? Or is there a similar water proof one?
- pursuit mono lso legal
- Cutting flex shaft to length
- Drilling genesis strut to fit 3/16 shaft
- Dumas disappointment
- 380 xl feigo motors
- Genesis cat, calmer water faster?
- ca glue caused silcon to split on my t180
- DF26 build questions.
- df29 vs. 26
- Motor esc or rx
- I need a hydro
- Miss Geico upgrade questions
- Timing Advance - The Basics
- Best RTR 32" (ish) CAT
- Ducks, fisherman and boats running up on shore
- Twin screw bow lift.....
- Banned again!
- New Spartan Stock Motor and ESC?
- FE-30 Hatch Poor Fit
- What do i need to do to get a break?
- What is a good RTR boat for......
- mmmmmmmm
- Boat Hull Weight
- Aeromarine sprint cat 42" twin 1717's????
- Bud select boat????
- glassing balsa hull... yes - no?
- water jacket
- ProBoat A3630-1500 Motor. timing y or d wind ???
- 40th Annual NAMBA Gas Nats will offer 2 FE Classes
- Waterproof RX switch...
- Hit 60 mph on my genesis today...
- Adding foam so they won't sink
- H&M Agitator 120XL Build
- Can you rebuild a feigao
- Brushed Motor Question
- piano drive shafts
- df 35" vs DF pirate hull, whats the difference?
- fans for cooling??
- Good Source for Smoked Lexan/Plexiglas Hatch Material
- Home for my Medusa 3670/2300kv
- Live broadcast from Joe's right now!!!!!!!!!
- A question about NIMH batteries...
- 4MM collet from Kintec,wrong one
- Sealing transom holes
- Best Spray Paint for Fiberglass
- What is a good ul1 rudder upgrade?
- ammo cans
- Got transome?
- Why ESCs Fail....
- Happy easter ose
- battery placement in a df copy
- 5xl??? How many cells
- Help with a Drive Shaft issue
- Recall Advisory 2011-01: Hydra Ice HV Capacitor Value
- will this work?
- 1717 Mount For 4" Rails
- Mtc
- Newbie looking for advise
- programming a T180
- Falcon cat
- This should be interesting..
- feigao's 9xl's
- Who's gota Sprintcat!
- boat in fo
- batt connecters and wire size
- Miss Geico
- Help request - hydraulic look steering
- 2 hulls 2 motors what to do
- Tiqueman's Computer Issue
- Mono issues at full throttle
- whiplash FE hydro?
- my self righting mono looks very lobsided when standing still ?
- local fibber on e-bay
- genesis rear strut ?
- What to buy? Your thoughts
- Motor & ESC ???
- Twin Motor Mono Question
- Strut bushing stop
- Prather fun cruiser ?
- Pursuit flex drive
- Pursuit
- Motor mount
- Phantom
- Looking for a new cat to build..
- Tug Boats
- H&M M-1 Supercat setup suggestions?
- Solidworks drawings
- distance between motor collet and stuffing tube
- Whiplash/P Sport Hydro
- neu 1509 outboard on 28 in. woodstuff
- Stuffing tube to Strut Question
- Cats and struts
- looking for a hull to put ul-1 power plant, whatcha got?
- Looking for recommendation
- 5.5 mm bullets
- Who Makes a Soldering Station That Holds Your Items?
- Prince 25 running issue
- T-180 lvc
- Mini Vid Cam Housing & Test
- Eagle tree setup help
- v plus 4s 30-50c 4000mah question HELP ?????
- Cleaning The Hull after ESC fire...
- Show Me Your Soldering Equipment and Soldering Iron
- MG prop and li-po...
- Rc Retrieval boats ?? What do you use?
- catamaran build advice
- Motor, Esc or Both?
- Let's hear it for the u.s led combined forces
- Titan 29 suggested Rudder lenght?
- 1/16 shovelnose battery config
- hpr
- mgm compro 16025 3s
- Solo Ski Boat
- Drive Setup
- Looking for beta testers for forum.........
- Swordwish 200 ?
- Fixing The Hull quastion...
- amps
- mhz trimax crap to the max
- A Day of Fustration
- Lipo Batt.
- 1/12 Miss Budweiser Brushless conversion
- new guy needs help
- Stripped drive system on Spartan
- Whats going on here
- gettin closer to racing which for a first boat
- Second Boat
- ESC's BEC in twin drive cat
- where to find motor mount with 30mm hole mounting ?
- Shopping in Kissimmee?
- Neu 1415 backing plate hex screw size?
- Are any of you dorky like me and...
- UL-1 Motor/ hydra 120 ESC Timing?
- rigger help
- How will this setup hold up?
- R these the correct motors for a Genesis Twin?
- Kyosho hull Identification
- Search Function within OSE Forums
- Mean Machine Setup help
- GPS readings, true or false!
- flood chamber make
- Speedmaster Pitch Gauge
- Conversion help?
- Anyone who has Messaged me Past few weeks my PMs have vanished!!
- HK Apparition Drive system question
- anyone using the keda motors yet?
- Help with upgrade (newcomer)
- What rigger is this?
- Genesis 63.7 today
- Does a de tongued prop increase top end speed
- How do you work out amp draw
- can i take away the teflon and go up 1 size in flex ?
- Objects in veiw finder are closer....
- Sky-wing ESC's?
- Large Hulls?
- Apparition or Genesis for fun?
- I need help with 1515 .5y competition wind
- Rigger Balance
- mono rudder depth
- Mhz
- glue for velcro
- Video Editing Software???
- 1/8 Scale
- wire drive question
- Video Camera
- shorten motorwires?
- teflon liner?
- Phil Thomas Hydro, bouncing around at full throttle..
- 34" Sprintcat with 2 align 600xls Hauling Video
- Does Anyone Know TRK Props?
- Motor Information needed!
- Castle 2028 / Swordfish 240 / Aeromarine Avenger
- Extending ESC wiring?
- Tenshock Motor
- Where can I find a charge cord for Hyperian 6s Batteries?
- My lipos are baking bread...
- Y Harness For 2 Lipos?
- HK is selling bare hulls now?
- dragon sword mono boat
- Best Boat Set up
- 1/8 hydro
- Lipo & esc wire length
- Genesis collet
- Ose new 4082 1500kv motor wires
- 34" M-1 supercat, 1527 2300kv on 4s?
- 4082 in Appariton cat
- Copy of Chop's Airboat
- Osprey lepard 4082?
- Need picture of FE sport hydro and rigger for plaques
- Neu 1518 1.5d 2340kv for Whiplash
- 56" Performance International Fountain Power Plant
- Dragon hobby
- Charging AA batteries
- Tunnel hull adding weigh
- paint job
- MM with 1717 on 4s???
- 36" hydro setup????
- FE Heat Measurements and Terminology
- Carbon trim tabs?
- question about os lower unit
- Lube the flex shaft?
- rc boat game
- Trim tabs and turn fin height
- converting brushed to brushless
- bullets getting hott!
- Prop advice
