- Do you need water jackets
- New 1/10 scale modern hull!
- Aeromarine- Avenger Pro 44"
- they made a 19.5" rigger now
- Which adhesive to use waterjacket -motor
- rigger question
- Destroyed motor questions?
- rudder needed
- Measuring boat for boat stand...
- Tube slidding
- Skeg Use
- is there an hpr hull under $600?
- Ubec ?
- Modern Hydroplane Themes Ideas
- glue
- suitable mono for an outboard
- q-mono motor choice
- Aveox 380 Motor Question
- School me on CF layups!
- Stolen
- what kind of speeds can a delta force sniper 45 handle?
- Clearnace for cooling jacket
- Tsunami
- Black Jack 55 FE conversion
- Genesis mk2 (with single flex shaft) hmmmm!
- Schulze ESC Wiring + Wire Length Question
- Corrosion X question
- ESC fluid?
- fightercat twin build problem
- Plans for 1950s era Outboard Hydros and Utilities
- 2 part expandable foam safe for epoxy hulls?
- Suggested Motor Mount for a 1521?
- water cooling jacket
- Water cooling jacket
- what hull is THIS???
- Genesis Jerky when on throttle
- Steering but no throttle
- motor mount for DF33 w/cc1520
- mhz drambuie on ice cat. need opinions.
- thoughts on drag hydroplane for racing
- A Tribute to Peter Zicha!
- tube grease
- Canopy for 26" Prince...where?
- Whats going on??-boat wont plane
- post rescue rigs here
- what causes cavitation and how do you slove it
- what flex and tube to run on 1/12 hydro
- Esc
- inline rudder and strut on hydro?
- Finished Scoop for a hull?
- not having good luck !!!
- Genesis set-up
- has anyone ordered from fuyuan rc?
- what would be a good hull for the c/c 1515 2200kv motor
- Reaction to SPAM
- Velc for Batteries etc Question?
- High amp ESC question.
- Rio ep Hulls
- what are average (safe/normal) temps on capacitors?
- I'd like to welcome our new moderator.
- Watts question
- CC 10amp BEC
- Day out. Nothing broke today, i repeat!!!!
- Need Drive Shaft Help
- EDF systems
- DF29 Cable size
- Miss excite type hydro with twin motors
- Prince / Rocket Upgrades
- what modle is this
- Can you identify this part?
- Rudder distance from prop and transom?
- Boat help needed. FLYING BOAT!
- Steering fins ?
- 45in mono
- Prop choice
- Tower hobbies
- Water Resistant Brushed ESC
- Boat runs better turning left?
- ProBoat A3630-1500 Motor. timing
- Overheating motor
- Set-Up Choices 32" CAT
- 1/8 hydro
- trim tabs
- Darin smashes N1 Record...........
- H&M 1/8 viper VS 1/8 smokin joes.
- Mini Rio disappointment
- Boat just stopped working
- Leopard brand can coolers
- Light weight flotation
- How much difference do 40C batteries make??
- Miss Bud Conversion Help
- Brian Buaas Breaks the P-Sport and S-Hydro 2-Lap Records!
- esc program card?
- hull custom water jackets
- tunnel hull set up advise
- 25" prince hull
- Boat questions Shockwave 26
- whats the best cap bank for the t180 /seaking180
- GPS Unit for Speed Question
- The all elusive CG!!!!!!!!!!!!!!
- Left hand Hydro mino rudder?
- Rudder Pin
- Customer ratings of online RC stores please read.
- Virginia Craftsman
- Pwm setting on esc
- Where to get motor bearings
- Eagle tree quest ?
- First Build Need Help with desgning a Catamaran
- Lipo shield and LiSaver questions
- Looking for setup for 36" cat
- Trim tab position?
- How would you rank these in order of importance?
- ESC waterproofing
- Throttle going berserk
- paypal
- 2s rigger or hydro's, kits or plans?
- Is this another ekos copy?
- RC Beer Cooler
- HPR 010 Mono Mystic Style
- Fiberglass cowl lay-up ?
- dynamite fuze
- stinger strut angles
- good Esc
- Is This A Bad Idea ?????
- expresscraft thunderbolt
- Tips for growing FE in your local club/district.
- Eagle tree elogger v4
- Turnigy Watt meter power analyzer
- Is it timefor new lipos
- 2 part urethane over krylon?
- T-180 esc
- Why no Feigao 580L motors?
- replacing caps t-120
- Recovery Boat Help & Suggestions
- what size caps for t180
- 25" mono question
- NAMBA - April Propwash - New FE Rules Proposal...
- hydra 240
- Bushnell onix 400 gps
- 60Amp Aqua Craft DH-AQUM 7011 ESC
- Does racing a FE boat take less driving skill than racing a nitro/gas boat?
- Dragon saga or venom p1?
- how to measure strut angle?
- Electric Motor Question?
- what difference does stinger length make ?
- Winter Project
- How do you charge your new lipos
- Best deal on esc's
- Universal joint
- cheap hydra 120 on ebay
- Mono Set-up Question/Comments
- 30in hydro input
- boat riding wet ?
- Epoxy glue
- HK Genesis Offshore 1045mm
- shop
- Prop selection- SAW rigger
- Toppower 4082 bearings
- what the ??????
- Mean Machine and LSO "Need setup"
- Does a rudder water pickup cause drag
- A little help please !!!
- How to make a 24mm water jacket
- Hk Genesis running warm need help.
- Finishing a wood boat
- esc problem
- PLEASE HELP ME get in the water
- 2 Pole Motor Timing
- water pickups
- Website Question
- Happy Birthday Mark F.
- I am thinking of building a electric boat from a gas powered boat?
- esc
- understanding brushless motors
- 30" SprintCat make over, props suggestions?
- cheap data logger??
- Flex Cable assembly... HELP
- Dewalt power
- miss vegas
- blackjack 26 upgrading
- LYNX Tunnel Hull
- Hey Jesse ---- Look!
- Freya 36" 2 x neu 1521 + 2 x castle hv 240
- Steering Rudder placement and some help
- CC 1717 what size are the motor mounting bolts
- ToysPort Jollycat Owners
- castle 2200 ose water jacket install
- Flex shaft myth?
- Using a stuffing tube as a stinger ?
- Miss Geico: 8 or 10 with 5.5 bullits
- jeff wholt .078 wire drive
- JAE 21FE..Which motor??
- Turnigy T-180 users please
- Spec motors
- rigger for 1527 1.5d 6s
- ? about reverse
- Falcon 41 on 10s?
- Wanting to get back into boats
- Whats a good hatch tape?
- Through hull water pickups
- Hacker B50 7XL replacement
- iphone gps speedometer apps
- Anyone got one of these?
- Smoke on the water...
- Converting 2 battery ESC to single battery
- Cunard Help
- cc 120esc
- How I added caps 3 more to my T-180
- 1520 cc motor 1518 cc water jacket
- 29" fine design mono, right u turns
- OSE Contact
- turn fin placement on deep vee
- 1520/1y on 10S
- Delta Force ESC instructions?
- tape friendly hatch locks
- CC Hydra 120
- CC HYDRA ICE is finally out.
- Warning
- Hydra ice HV owners, heads up.
- 8mm coupler to .187 wrench sizes??
- Genesis or Motley Crew?
- 300 amp Eagletree inductive pickup
- caps
- Burnt out JST Connector
- timing quest
- shrink wrap
- Cracked Sponson ?
- In and outs of high pole count outrunners and esc compatibility
- proboat water jacket
- Nitro to Electric
- Fighter Cat Twin
- whats out there for good Motor Couplers
- Connectors?
- Genesis Lipo Fit
- Drilling holes in foam
- Boat stands How to make?
- Going To Bainbridge Pond on Sunday
- 1/8 inch drive dogs with 3/16 props?
- BBY Racing 1-24 cell outrigger
- help
- Help!
- crackerbox
- turnergy 120 esc cooling
- Looking for help with motor, ESC and lipo setup
- GENESIS is it worth the money?
- Genesis prop shaft size?
- Boat ID Help?
- Genesis Length??
- How many boats do you have?
- Improve your handling mean machine
