- Titan Video
- BlackJack run today
- Cable a tad short...please help
- Converting 1/12th scale hydro to brushless question
- Teflon tube question
- What type of hull would this be?
- Opinions on Hull Material
- Jolly Cat
- Which cat hull to use for dual drive?
- Jolly Cat tests.
- Elite 3600 cells
- Need Help, please
- question about jeti 600
- Burning up the brushes
- Does the Jeti Navy have reverse?
- cutting down props
- ammo motor
- another dumb ?
- Questions on Heat Transfer Materials
- dumbest moment (an inspired thread)
- I hope this works
- Caribbean Cruiser 2 mods
- fusion gp3700 ?
- Need Shockwave 26 ESC advice.
- Sv-27 In 1 Foot Waves
- Delta Force 12(25"hull)
- Graupner Jet Sprint
- esc opinions
- jb weld heat transfer ?
- motor/esc question
- Ib3600 vs gp3300 batteries
- 2007 Namba FE Nats Results
- 700SC and BB out of stock
- Is Mini-V faster than Shockwave26?
- Contacts Page Problems
- Forum issues soon to be resolved. I hope :-)
- SV27 Hull for LSO class????
- 3 blade prop?
- thanx steven
- whats the difference???
- I need Shockwave 26 help
- Brushless Black Jack Hits 52.5 Mph
- Lets See What We All Look Like
- Feigao Motors
- The Jolly Cat Decals
- M11 needs no PiStix
- Hatch tape?
- Just scored one of these on ebay (2007)
- super duck
- nomad 1st run
- kb 45 xl motors
- Wire drive on the Jolly Cat.
- 1/8 Scale Super Saver Class
- Saleens 7
- gotta prob
- feigao motor q wires
- Teflon tube doesn't stay in place and water help
- Site will be down sometime in the next 24 hours for about 6-24 hours.
- challenger 31" vid
- Public appology
- Proper Prop
- We should be back!
- Get this.....
- New pics of drag boat build
- Sorry for the down time.......
- Need a rudder
- steven v
- Links in tips and Info do not work
- deans connectors
- Lipo question
- rae chance
- CC80 program
- 5.25lb Cat
- delta force testing
- Piano wire drive
- Feigao Motor Question
- 31" Hydro Conversion
- How To Change Feigao Bearins
- bandit cat pics and vid
- Conversion questions
- Steven V...waterproof switch
- After Run Oil
- Something has changed.
- Oil for a wire drive?
- Failsafe question
- In-runner/Out-runner
- Painting styrofoam?
- hv maxx motor issues!!! locked rotor
- Mhz Nomad XL
- Recovery boat
- Feigao 2 pole motor - physical timing?
- avatar
- Jet Drives
- wire drive
- Finally a rapid running video in high res
- ATTN Steven 120 hydras In stock?
- drilling a coupler?
- photobucket prob
- Anyone using a KB45?
- Drifter S
- Waterproof your Watts Up meter
- OSE SHIPPING Info
- Different pole motors
- Scored an MRP Tunnel Hull
- mystery 80a esc
- 49.7 Mph
- Need Shockwave 26 Help, overheating
- Death of a Hydra and XL7
- Jolly Cat hits 55 mph!!!
- Motor Temperature
- Fast electric prop calculator???
- This Brushless thing is A OK!!!!!
- I have gone to the dark side!!
- Prop selection for 32" Mono
- motor question
- sweet vid of bj55
- I did it!
- a fe break...with a lot of fe
- Storage options
- New balancer.....New batterys....
- Kinda scared......will carbon work?
- New Skunk Works Cooling Jacket
- Races in minnesota
- Neu motor question
- 40 MPH Titan-29
- Oval Master OffShore
- H&M Lifter 50+video
- 29.5" mean machine Cat
- Lipo question
- What kind of GPS do you use?
- stinger strut bushing
- Lipo recommendations
- Y series of props
- What is the best handling boat or hull type?
- avengersteve
- Filler Question
- Why clockwise racing?
- How did everone start out?
- Traxxas marine goes Brushless
- Do U know the SW26 stock shaft diameter?
- Lipo Safe Proto
- Triton and Syncron
- Neu motor jacket question
- Swap shop
- Something is wrong with boat
- N2 power question
- 5mm rotor shaft replacement
- Aug !2 race!
- hydra 120 programing instructions
- OSE.com ROCKS!!!!!
- hello!
- Titan to good home
- learning alot!
- Low voltage cutoff equipment?
- Shockwave 36 Electric conversion
- posts per page!! suggestion
- Store that will balance propeller's
- First Jolly Cat run
- Which prop would work for my boat?
- tower hobbies coupons
- Hydro help
- kb45 vs. fegiao xl
- Supervee 27 or blackjack 26
- Stuck coupler!!! stuck to motor
- Another prop question?
- Weight & Voltage reduction vs Prop?
- Steve, whats up with those ESC's?
- Hydra 120
- OK, Not FE Related, But Very Cool!
- Information question
- Burnt controller odor
- Is Legg Lake in the Bermuda Triangle ?
- Fast Crackerbox ques
- prop question
- nylon washer ?
- Drifter at Legg Lake Video
- OSE Chat Room
- Data Logger Info
- Is the OSE store down?
- Get Well DOOZIE!!!
- yellow jacket rigger
- We hit 400 members today!!!
- Lipo Question/help
- New Gadget from Tekin
- Suggestions Please
- ABC Super Hawaii
- It only takes one donkey of a moderator to ruin a forum
- New smilies added
- Proboat Hydro Brushless
- twin drives; prop rotations
- jolly cat
- Bus bars
- More troubles
- question
- Handling problems on a Supervee 27 Electric
- Lipo specs?
- Hydro Crash!
- kb 45xl speed controler
- DPR results
- looking for a "big" hull
- Hull repair
- my first boat
- Hydra 240 connectors.
- Cooling the nitro motor at my house
- set up help
- aquajet 775 prop selection
- Traxxas Villain Props
- ose-700sc
- Brushless blackjack advice
- scat cat vid "miami vice lives"
- Am I asking too much?
- Check This Out
- HYDRA 120 help
- New Vortex hydro
- Running in waves and motor heat
- Jolly on S4-1P X2
- Hydra 120
- Speedmaster mini rudder replacement
- CC Barracuda 125 with 6S LiPo
- Missing posts?
- Mini Drifter
- My SW36 conversion....ive been thinkin
- Been painting...
- Traxxas Villain on ROUGH water
- ? motor esc for 6-8 cell rigger
- Water Jacket
- Passing 1500
- Fine Design ABS Hull
- mean machine problems.... :(
- Non-shorting parallel batt. harness tip
- Jolly prop test
- Rescue Cat test 1
- Villain New graphics (pics)
- Running Batts in Series
- Prop for 43" cat.
- Puffy Caps and Twisted Cable.
- idea for rescue boat
- catamaran power plant
- Need more Lipo batts
- turborix esc
- chinese esc warranty
- El-Lobo 25” CG?
- Easy way to keep the hatch on
- Another dumb lipo question
- 50" apache power
- watercooling ?
- Ordering aggravation
- Water Jacket Placement
- Toysport Triton questions
