View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. MHZ link
  2. Faa
  3. 6S motor options for whip 20
  4. best prop recommendation for the following setup
  5. Epoxy/Glass cowl for JAE 21FE
  6. Bby scat cat 26 abs repair
  7. Top speed: cats vs hydros...
  8. Flush mount water water pick ups???
  9. hatch cover
  10. How to make sub-hatch with bubble?
  11. 54" bonzi boat
  12. Best setup questions for my 25" prince
  13. cavitation??
  14. internal failure of bec on esc?
  15. !New here and have some questions!
  16. Proboat apache q
  17. Lipo Batt hull location
  18. Best setup for single drive Apparition
  19. where to buy carbon cloth
  20. connecting 2 esc
  21. laying carbon sheet in 25" prince
  22. 37" Daytona cat motor choises
  23. How long with no cooling?
  24. Please can anyone tell me????
  25. Reaching the 1717's full potential/limits
  26. Anyone running outriggers?
  27. motor esc problem
  28. Bending Aluminum
  29. What motors MHZ
  30. esc
  31. hk pursuit 1600 kv on 5s?
  32. Shipping a used boat customs info?
  33. Propellers
  34. Sad News - Passing of Bill "Gas Pump Bill" Payne
  35. Who all has vinyl cutters?
  36. Self-righting mono?
  37. ESC Max Temp?
  38. understanding KV to RPM
  39. Windshield Template
  40. Turnigy Monster-2000 200A 4-12S Brushless ESC
  41. RC Trim Tabs
  42. Motor selection for twin drive apparition
  43. hydro ,how they supposed to run
  44. Where to put temp sensor
  45. MHZ Mystic c5000 setup help
  46. Pursuit HELP with motor
  47. Boating Weather Forecast
  48. DF Syniper from OSE?
  49. How fast can a RC boat accelerate ?
  50. Motor questions DF prince 25"
  51. Change motor on my boat
  52. RTR Boat Part Sizes & Dimensions Reference Manual
  53. My latest project. Barbie gets a new ride!
  54. Width of the Insane FE30 transom?
  55. New twin apparition help
  56. is 18 lbs too heavy???
  57. Which Prop
  58. Propshaft height question
  59. Aquacraft Motley Crew up on the AQ site!!!
  60. Flex Shaft Installation
  61. Instaling dual water pick ups question
  62. Looking for a cheap GPS????
  63. Help on bec for twin setup
  64. 1512 2650kv, 4S in a Miss Geico... too much?
  65. JAE 21 Tribute
  66. Garmin Forrunner 101 gps question
  67. Hit 58 MPH with Miss Geico today**VIDEO**
  68. Ms Geico Twin revisited
  69. need cat hull suggestions
  70. setup
  71. Tandem Wing Hydro balance point
  72. Cheap Brushless ESCs with Reverse
  73. K&B Lower Unit
  74. Thank you to OSE...
  75. ToysPort Jolly Catamaran Vs Mystic C5000 M
  76. cheap hk datalogger
  77. Bad JuJu - 3 ESCs and one LiPo in one day
  78. Drives for Mystic
  79. strut bushing damage
  80. Hydro turn fins
  81. What proboat is this
  82. Wireless cycle speedometer...can it be use on rc boat?
  83. Need help with a fast setup!
  84. 42" Aeromarine Sprint Cat
  85. please look cat/tunnel owners
  86. F1 Hydrofighter
  87. HAS ANYONE USED THESE YET, Water Pickup
  88. Please HELP with T600 Outrunners and SkyWing 150A ESCs
  89. HPR115 hull
  90. Teflon tube for geico
  91. What went wrong?
  92. Esc & prop
  93. Eagle Tree - What the heck is this???
  94. motors
  95. Need Help
  96. help needed on setup for newbie/school project
  97. What are the aquacraft rio ep and pro boat apache 24 hulls like ?
  98. bad throttle habits
  99. IMPBA’s new P-limited “spec” class rule proposal.
  100. Water cooling
  101. Water cooling motor?
  102. What config?
  103. Drives 1674/A
  104. NEU timing
  105. 5 mm motor in king of shave
  106. resistors
  107. JAE 21fe what motor and esc for 70mph?
  108. Need Help
  109. Seriously, someone is charging this much for a Genesis
  110. Great OSE service
  111. how did I smoke my new feigao
  112. New RC Boater needs some advice...
  113. paint jobs
  114. Windshield for my CF Daytona
  115. The Countdown to WW VII Has Begun
  116. Motor Checker tests for KV,RPM, & Amp rating
  117. Hornet Tunnel from hobbyking?
  118. Grease Problem? ( noob alert)
  119. esc for neu
  120. BEC wiring
  121. help with motor selection for limited class
  122. Who races 1/8 scales
  123. Color Red
  124. prop shaft spacer
  125. HOR 25" self righting mono
  126. Another great site
  127. Hello, and a question!
  128. cheapest GPS
  129. is this a bad idea?
  130. Shop is closed because of my Dads Passing
  131. Best ESC for Leopard 2845, 2950Kv
  132. FE Calc needed
  133. hydolift 1100 korea?
  134. 1/8" stinger?
  135. wanting a unique boat for limited
  136. Thanks Tiqueman SV arrived!
  137. Super Hawaii questions
  138. 5XL / How many cell???
  139. Hobbyking.com???
  140. Viper Owners: Anyone have experience on 2s1p?
  141. Build vote!
  142. Mystic C5000 motors
  143. ooking for a 25" mono/v hull to work on ?
  144. Hello and some advice please
  145. solder iron you use for sensitive electronics
  146. Mystic C5000 run time
  147. Project geico/motley crue
  148. In your opinion what is the best RTR boat for a newby to get into the hobby?
  149. Proboat Blackjack 26/Miss Geico Legal under NAMBA rules?
  150. anyone know how to set the timing on a elf hobby amp amp esc?
  151. T-180 ESC Programming?
  152. My apparition is here! Now what?
  153. Genesis verses geico
  154. need some idea where to put all stuff into this hydro 1
  155. 3/16 to .187
  156. abrivations
  157. BEC question
  158. Up in the air
  159. Leaving esc plugged in between runs
  160. 700SC Motor Wiring and Specifications
  161. do caps have a directional signal flow?
  162. pursuit motor swap question
  163. neu 1527 - 1500kv vs 1250kv
  164. mono balance point
  165. motor esc cut off
  166. Max Length for 2s1p Rigger?
  167. venom segad brushless conversion
  168. I need some pictures please
  169. Would this hull be any good ?
  170. Flex Shaft - 4mm vs .150
  171. Trim tabs on v hulls
  172. Has this happened to anyone before?
  173. stuffing tube support?
  174. call me crazy
  175. 1512 Water Jacket question
  176. conversion plate for Lawless Lower Unit
  177. lazer cutting
  178. Would this hull be any good ?
  179. building a micro rigger, where should i put the stuffing tube ?
  180. So, Hyperion really makes this?!
  181. NEU 1527 1.5d
  182. IMPBA or NAMBA?
  183. removing a stub from a flex cable?
  184. Power for my new rigger ??
  185. Mike/Cybecrxt sets a new bar in Tunnels
  186. High Voltage ESC/Motor Question
  187. Marine propeller calculator ap
  188. What's been going on around here?
  189. how long can a esc last?
  190. Neu 1521 1.5d rigger
  191. venom segad OR expresscraft thundercat? 411 please!
  192. Custom bullet covers
  193. 1/10 scale hardware setup question
  194. programming card
  195. videos prop balancer
  196. Newb ?'s about Buying my First Boat
  197. should i add caps to my t180?
  198. Converting to brushless questions?
  199. Brushless efficiency ??
  200. 25cc cat
  201. Hoobyking Genesis RC boat...
  202. HK Vanquish
  203. Do all esc's need to be programed out the box?
  204. Want new boat
  205. my reciver melted
  206. Whos built a solar powered FE?
  207. anyone heard of aeromarinerc.com?
  208. Eagle Tree v3 logger google earth set up probs and stuff!!
  209. lakes
  210. should you grind flat spot for drive dog??
  211. Phil T. Stealth Build ??
  212. Cheapest way to ship 1/12 miss bud??
  213. Anyone seen Kris Flynn?
  214. Power Suggestions for 36" rigger
  215. Can i put a different rotor in it
  216. Add trim tabs and turn fins or not?
  217. what to due?
  218. has anyone built a donzi 49" from aeromarine??
  219. Can i run a 1521 1.5d on 6 cells?
  220. Flippin' Boat
  221. 54" boat speed
  222. What flex cable and propshaft for a 25" mono ?
  223. stut/rudder opinion needed
  224. Which would you rather have?
  225. Buying a Boat to use in Surf
  226. ESC programming
  227. Motor info
  228. Jet Drive
  229. thrust bearing help
  230. Hatch Latch HPR115
  231. Help identify this cat! Please!
  232. help: want to make sub-hatch with bubble
  233. which catermeran is better?
  234. Which BL system do I need?
  235. Turn fins
  236. Why are there 2 model boating organizations?
  237. What motor for a 26" mono ?
  238. Where can i buy a DF 29" Copy hatch
  239. How many sets of LiPos do you bring to the lake?
  240. New Juicy out runners @ HK ...AGAIN!
  241. Kintec Racing shipping problems
  242. Spartan race class?
  243. Thunder tiger, Outlaw OBL
  244. is this a bad idea?
  245. Any other boats I should consider buying?
  246. Dragon hobby snap, any good?
  247. 58" cat. Is 55mph possible?
  248. grab screws
  249. flex shaft wont take solder
  250. My first RC Boat/Hydrofoil
