- Neu 1512 question
- Aquacraft rio ep
- Power Analyzer Quest.
- Venom killer vee or nqd px16 cat with o/b motor conversion
- ESC issue???
- Advice on building a Boat for the Mini Shoot Out Lake of the Ozarks.
- Hydra Ice 240a lv controller pic is up.
- Hobbyking super simple boat series escĀ“s
- Would this work ?
- good deal on stainless hardware
- Eagle tree amps
- New member OSE-Phil
- -180A ESC just beeps after getting wet.
- Cant find the answer to this question
- HELP! what sticks to mean machine interior?
- SAW 8s setup?
- Hobbyking motors
- Would these work ?
- Weight issue
- 204km!!
- CF hull question???
- Hydro rear-spoiler mount
- MTC hardware, any good?
- Help with killer vee outboard project
- What to do with this?
- Hobby King starts carrying
- water cooling a esc
- ThunderTiger Desparado Cat
- Jay Turner
- Video of the Delta force Pirate.
- leopard esc from kershaw designs
- Mbcofnsw " a outboard sport "
- Expresscraft THUNDERCAT
- Bec ESC quest
- New Water Cooled Scorpion
- Drive line drag O.B vs straight shaft?
- Brushless O.B getting wet?
- Spy shots of the new insane mono !!!
- Made this coolig plate for my 3424 outrunner motor
- Question
- flex collet
- hydrolift 1100 2215
- Rescue boat
- Mono building questions ...MUST READ !
- lubricating flex shaft
- Dumas Hotshot 45: is it a good boat?
- MHZ Update
- Marine MHZ-Scorpion 5035/760 (2136/W)
- minimum spacing for twin outrunners
- Functional Exhaust
- tunnel hulls
- An Announcement from MHZ Germany.
- battery bullets
- How much water is too much
- prop advice for a bby ov 21
- need mesurements of speedmaster 21 strut with mono bracket
- parallel batts and voltage cut off ?
- motor timming
- Garmin eTrex
- Vac U Pickle
- Adding cap to a ESC
- rudder placement ?
- anyone heard of the 1/10 miss bud from finedesignrc?
- help with picking an outboard motor
- BL Motors equivalent
- mean machine conversion
- Old boat, new hardware. Help
- Esc cooling plate
- Problems with HobbyKing shipping?
- Swap shop
- Accepted Convention for Bullet Connectors
- Finishing a glass hull
- how many poles on an Ammo 2300kv 36-50 motor??
- Feigao motor shaft? no flat spot
- Feigao RPM limit's?
- Leopard 4074/30" Hydro setup
- Member question for Q & A Section readers
- swap shop???
- Lehner Basic XL water jacket?
- Firefox canard CG?
- Help with Twin ESC hook up
- Motor timing
- Source for 4mm dog and prop nut?
- Cat Selection
- identify this u1 model
- User Titles
- HOR, no more?
- A weightable question
- looking for some who speeks German
- MTC-Hardware.
- Why i like fe
- More Message Storage !
- mount for xzess
- battery tray?
- Offshore power duck
- carbon fiber
- Best BL motor for outboard
- Site may go down for maintenance tonight for a hour or so.
- found a great source for cc bearings
- neu d winds...try it???
- DIY Cap Bank
- radtek boats
- small cracks
- What to buy while in hong kong?!
- Mini Hull ?
- Is This the Cure for Spinouts ?
- Timing Feigao 10xl T-180esc apparition
- Cheap 50" mono
- Cutting long straight lines
- Bushnell radar guns for checking speeds
- Roll over rule
- schulze 40/160 old style
- garmin forerunner 201?? GPS
- geico v-hull
- Amps
- Offshore Hardware
- Steve Neu
- carbon/ kevlar?
- p tunnel speeds
- Will this setup work?
- Tunnel
- Capacitors
- Race apparition water cooling thoughts
- Brushless motor recommendation
- DF Cyberstorm 32 RTR
- how to fit cap board
- timing
- Big cheap motor advice
- turn fins
- Corrosion-X Heavy Duty
- Welcome Chiefy_44 to OSE
- Massive outrunner motor that will be coming soon @Hobby king
- A big mono hull that will be coming next week @Hobby king...maybe Im not sure
- Flex cable
- 54" cat build need lots of help
- Don't forget, it can happen to you
- Thunder tiger vee hull
- Running Lipo with an ESC set for Ni-MH...what can happen?
- Jet drive boat build
- hk pursuit with 1620kv
- Another pursuit mono but need help???
- where can i find?
- T-120 stut-t-t-t-tering issue?
- Apparition crash carnage
- What would it take to build a 100MPH Cat
- MHZ Drambuie on Ice
- Swordy 200 lv
- T-180 Caps Mod
- spartan's motor
- boat flipping and waiting insted a retreiving ,
- Solder question
- Twin motors in what classes
- Is OPC tunnel going to grow to more than P spec?
- bat boat--V24
- Down and Dirty 'outdrive' steering
- Mono Hull Boat project set-up, newbiw questions
- Leopard 5692 motor mount???
- OSE T-Shirts
- Need help with thread and screw size
- help with EB Spec genesis cat
- Miss Geico 29" BL Tips?
- LSH Hydros
- Matrix Ultimate 4s outrigger
- battery loading on esc
- x442 on df29
- 25" deep vee questions!! answers will help alot!!!
- proboat 1/8 scale. need someones opinion!
- 1/8 scale ESC
- 35" Hull or Bigger
- Piano wire driveshaft fix
- prop suggestions
- whats the best brusless racing boat i can get for $300
- Fire!!!!
- will this setup work for a 36'' deep vee
- KB45 mounting screws/holes distance
- horse power
- 43''mono hall
- Electric boat info needed
- steve, or anyone, what motor mount?
- Newbie
- What's the best 540 brushless motor for 25" prince answers will be appreciated
- pursuit brushless
- best placement of batteries in 25" pince deep vee for maximum speed and best handling
- New 36" cat from RVM-R2Hobbies
- hydro scuffing questions
- The American Flag Needs Some Help
- Jae rigger dimensions help
- lso esc?
- 25" prince (are they race boats)?
- esc rapped in foam
- 27" Rigger ? on motor/esc config.
- Danny's mom is in the er tonight
- Pursuit with a feiago
- what is the best esc for the $$$$$? and setup
- best esc for leopard 4074 2200kv?
- Deadrise angle for a DF29
- Need Instructions for this ESC
- waterproofing electrics
- Bl- esc ??
- Insane 34" Mono - First Pictures
- Anyone Have one of these?
- My mono "WRAP" I just finished
- EKOS flex cable size????
- Hatch hold downs?
- Which rtr boat to buy?
- Does anyone use a HK-B125A esc?
- Difference between marine and surface recievers?
- Put me right please????
- Fluid Dynamics of Drag
- What is this kit?? miss bud
- Jae rigger out of stock
- NEU 2215 motor Q
- The Triton that has been around the world
- 60mph setup
- best way to cut cf sheet
- Twin cat questions???
- Tunnel Setup Boards???
- Where to buy flex shaft solder?
- Stuffing tube angle
- ESC Programming Terminology ( need clerification )
- Pusuit
- 8s 5692 1000kv, what esc?
- smaller batteries on there way (one day lol)
- HPR Mania - Version 2011
- Help....ESC dead, brand new...
- Flood chamber
- Hobbyking SS Boat Series 200A ESC
- Mystery pentium 80a esc programming
- hk jet drive aluminum
- Has anyone ever tried to buy from Lehner directly?
- New Hull from HK
- strut degree question
- motor selection for 20" twin cat
- stopping chine walk
- New wooden rigger for under $100
- 31" artr rigger
- Stock Genesis Motor KV?
- Rx/tx opinions
- Question re: stuffing tube and stinger installation
- Twin drag cat
- Another Coupler Question
- 10S Pursuit
- First post and a few newbie questions!
- What switching frequency works best on UL-1
- internal failure of bec on esc?
- teflon
- low and mid lift props
- Esc ???
- 6mm motor Coupler
- Where did it go ??
