- Conformal Coating
- Computer going down
- Hobby King 1-cent shipping!
- Lepoard motor
- Boat Recovery
- How to distinguish and old version UL1 esc from the newer one...
- Tunnel Hull
- Brushless Out Runner
- Cool Life Saving Fast Electric Lifeguard Boat
- Race speed measurement
- NAMBA Oct '10 Propwash
- painting
- converting Nitro over to FE
- LiPo + brushed 550 motor help
- IMPBA FE Rules are online
- 1515 1y
- Etti Saber - Flood Chamber - Please help
- Jeff Wolt, Looking for 4mm clockwise cable/shaft
- Motor KV chart
- df-33 question
- Few quick questions about a brushless build.
- df29 and turnigy180 esc
- Down Time
- ul-1 esc with 9xl motor
- Please Look at the motor KV chart
- Want to start a new build, need help
- Tower Hobbies $60 off code!!!!
- EKOS: question P1/C1 flex shafts
- I need of someone to make shaft with universal
- Is this a big leak?
- Twin Outrunners on a Hydro?
- motor mount position df29
- Advice about HPR115
- anyone ever try putting a 2 speed transmission into a boat?
- Mhz Mystic
- How to set strut angle
- Apparition
- df29 advice
- prop for df29
- lipo question
- 4mm threaded props
- what motor and esc for sv27 for 7 year old daughter
- sealing the ESC ends
- ul-1 motor in df29???
- Where do you get OSE stickers for my boat??
- Brass size for Speedmaster sleeve bushing??
- Balance ppoint on a DF26
- Max Amps
- How to fit this ??
- Need advice for my hydoplane!
- decals
- df29 prop issues???
- Suggestion!
- General amp draw question
- Hydro paint theme?
- Greaser info
- boat sealing
- Lead Or Lead Free solder
- newb question on running wet?
- Hulls
- my first tunnel hull. got a couple questions
- Orlando Winternationals - No FE!
- Prop rpm question
- Got my Pursuit Mono! - Some Questions
- boat setup help apparition
- What is fe?
- 6S ESCs
- Insane Measurement
- Formula for estimating speed using RPM and Prop Pitch??
- Spain oval race championship photos
- cooling jacket 36 mm?
- Big Assed Tug
- Flex cable
- Batt for pit charging
- Leapard or Neu for triton
- Dimpled hull?
- 4s2p weight differences
- 2200KV H3126 Outrunner Motors Performance
- EC THUNDERBOLT Cat. suggestions
- Painting a Vac-U-Pickle
- TX questions
- rudder position
- Setting UP Hydra 240LV
- 8 dollar waterjacket for casltle 1515 1y finned
- What external bec do you use.
- Minicat racing Velocity mono VS....
- Heat diff betweeen these setups
- 26 inch Canard
- is this esc any goood ?
- New Joysway larger boats
- New boat!!
- New boat....new problems
- DF29 T29 Ourboard?
- Poor handling cat
- Reef Racer 2 Brushless
- x442 vs. 42x55 grim
- Jae 21g rigger
- What is timing?
- hotr stinger drive length
- Genesis Motor options?
- 1527 in a DF33 to much?
- Mystery Hull
- anyone tried a skywing 200a esc?
- 1717 max power ??
- how do i solder brass cooling tube to a motor case ?
- The paparazzi came to the lake today.
- Need engineer/ brushless motor watt/ amp draw
- Pursuit Kintec Mono - First Run...
- I'm going to buy a HV esc and would like some recommendations.
- How do you calculate volts = rpms?
- Genesis Stock Drive setup
- Titan 29" hatch screws/nuts?
- For you guys up north!!....
- New feigao cans
- HPR Hulls/ Purchase/Specs?
- m645 prop with a df29?????
- Traxxas 2075 buzzing?
- x447/3
- Cob
- Setup Help Please!
- Hobby King goggles
- soldering cut flex shaft
- Looking for hardware for titian 29
- 9xl on 6s in df29????
- Any one know anything??
- flex sizes for rio and wilcat
- Battery placement in mono
- It has to be my next build!!!!
- Happy 235th
- Thank You Veterans. Everyone Please Watch This
- Esc
- what brushless motor for the nqd surfer ?
- Supersport 45 Hydro
- What's the difference between these two?
- how to remove a waterjacket
- Anybody know if Virginia Craftsman is still in business?
- sv27 hardware on a df25 copy
- Hey Doby!
- New build need ideas...
- discharge lipos
- How to build a boat stand for a titian 29
- Pt 40
- 1/10 scale classic hydro questions - Scale Scratch Build
- JAE .12 Novarossi setup
- Mhz-usa
- pocket radar?
- 40' prather deep vee project
- Please help me understand BL motors
- gear drives
- 200 MPH Hydro
- 32" HK twin drive apparition questions
- Carbon Fiber Mid-Sized hulls?
- poor throttle response
- Aquarcraft boat stand
- NEU 1.5Y 850 Kv Question?
- Dana's Heineken Aeromarine Predator
- What to use to waterproof ESC?
- R2Hobbies 26" Hydro Setup Questions/Advice?!?
- Turn fin
- FE 1:10/1:12 Hyrdo Hulls
- PVC Shrink for lipos?
- Big power coupler's questions
- Steven's A-1+++
- decals
- whats a good motor for this boat?
- Maximum safe temperature for Motor and ESC???
- Kintec Pursuit Mono - Second Run
- Esc and motor temps good.Lipos HOT!!!
- Prop suggestion for Challenger 43?
- FE Knee ; Ouch !!
- Spain championship videos oval electric
- Mean Machine water damaged
- ready to try.
- Suitable stuffing tube for piano drives
- Schulze 40-160: Solder won't stick???
- ESC size for this triton setup
- Sword fish 120 problems
- Aeromarine Chaos hydro
- Delta Force 35" trim tabs
- traxxas servos
- Connection break charging lipos
- 603 or Solder
- motor and kv rating for a 33-36"cat
- Thunder Tiger Cat
- STORM race Dec 4-5 FE Tunnel entries needed!
- Boat cam
- ESC recommendation
- Welcome to OSE a prop God
- Nitro?
- Hatch Tape
- EagleTree GPS Expander or Waterspeed sensor??
- MHZ Mystic C5000 M Setup
- Aquacraft UL1 motor upgrade
- best way to install octura strut bush?
- Shrink wrap size for 5.5 bullets...
- genesis leporad combo
- set-up advise for tunnel hull
- what brushless motor for the nqd jet boat ?
- Strut for Genesis ?
- HK 5.5 Connectors...Anybody use them?
- amperes consumption neu1509 5200kv
- Contour HD with GPS
- Need input!!
- X-tra thin shrink wrap, where to buy?
- Desktop Vinyl Cutter?
- Zippy 5000mAh 5S2P on Titan 29"
- T-180 are in stock at HK !!!
- how to find water line?
- What's the fastest thing you could do with a 1717?
- thrust bearings
- Black monday in the swap shop
- Esc/motor
- Proboat tip FYI
- Cogging???
- What's the worst day you ever had boating?
- Newbie first boat
- prop ? for bj26
- Adjusting reverse speed on a Schulze ESC
- PT 45 wants to fly !!
- If you could order a new boat any way, how would you order it?
- Lehner 2250 12 Turn Hi Amp SMOKED
- Need help w/dual outboard cat setup!!!
- 1 x 33" Pursuit left at HK for $179 + shipping
- Happy Thanksgiving to All!
- Opinions
- Happy Thanksgiving!!!!
- What are safe motor rpm?
- Strut bushing ?
- will this work
- self righting boat
- Opinions on this BEC...
- Like The Looks
- I want in and need some advice?
- Stingers
- Heads up about Phil Thomas hulls
- cool chart.
- DF knock off 25"
- new boat
- when will.....
- ESC shortage?
- blown neu 1512/1.5 y
- gps
- Supplier of Premade Stringers
- GPS Update?
- new hidro 2-3s H&M
- hidro etti modification
- OMG check this out!
- MHZ Lizard X, need about 10mph extra, setup advise?
- whats the deal with this??
- h&M VIPER setup
