View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Forum Notifications
  2. Pit Box
  3. what do you think?
  4. Gps
  5. 4mm threaded props?
  6. Good motor and ESC for a SV27
  7. Can you dye a ABS Hull
  8. newbie question
  9. MG Decals left an outline...
  10. Help me tune this motor setup
  11. Cooling
  12. motor temp.
  13. This Thing Rocks
  14. kde/neu motors!!!???? collaboration
  15. Central NJ rcers?
  16. Hard Case Lipo vs Heat Shrink Wrapped Lipo
  17. Thermal Epoxy Filler- Calcium Carbonate Experiment
  18. LiFePo4 pack
  19. Schulze 40-160 cap problem??
  20. Esc cooling plate mods
  21. ESC ? Lipo cut off?
  22. 0.150" vs. 0.187" flex
  23. Mean machine motor help
  24. PWM rate
  25. Pistix gone bad? Anyone familiar with ICE escs...or any esc that requires a pistix?
  26. Can any one tell me details on this?
  27. Contra-rotating prop deep v help
  28. SHockwave 26 bl project
  29. I need counter rotating props.
  30. HOR 41" ARTR Mono
  31. Genesis v Apparition v Dragon cats
  32. Genesis v Apparition v Dragon cats
  33. Will my 1527 handle a 645....?
  34. Genesis rudder
  35. Pictures from todays race
  36. UL-1.. ELAM or another..??
  37. Prop advice
  38. 1717 in a 43" Hydro
  39. Chainsaw oil on flexshafts
  40. Help on Hydra 240 LV warranty
  41. New a replacement for a Proboat drive dog
  42. 1527 1.5d or 1717?
  43. Teflon or no?
  44. Dual rudder on mono?
  45. Pursuit?
  46. cogging
  47. Little Dumas V
  48. Recommended 2S-#s Fun Boat
  49. Wireless Temp Monitor
  50. Pursuit mono
  51. importance of taping and foaming a hatch
  52. is the hobbycity server down?????
  53. Where to buy Batteries?
  54. Heat Xfer Compound Question
  55. What's the major difference between nitro a FE rudders?
  56. How many volts ??
  57. Pursuit mono motor
  58. copy of pursuit mono
  59. How Many People Race Their Boats??
  60. Miss Budweiser convert to brushless
  61. Props from R2Hobbies
  62. Neu question / possible issue?
  63. Next Year...... BBQ at Steve's Place
  64. Waveform of a Brushless Motor ESC.
  65. 1518 Prop ?
  66. need help finding some pics for a scale hydro build
  67. Whats your timing?
  68. What is it!!!
  69. 41" DF type hull, Need motor position.
  70. What the Duck???
  71. NEU Timing HELP
  72. Emergency... stripped allen
  73. 1/13th scale 26" Finlay Hydro hardware questions
  74. Electroluminescent wire or panels
  75. What P-limited "Spec" classes do you race?
  76. Status of the Aqua Craft Titon??
  77. FE motor selections
  78. HOPF CNC Aluminium Props 3 blades ??
  79. brushless hydro
  80. Help!?!?!?
  81. Racing classes, rules, boat requirements
  82. V Series - High Rake Props
  83. Cross Reference a Motor?
  84. flex shaft replacement question.
  85. Traxxas Lifetime Warranty Rocks!
  86. Lipo Air Transport Heads-Up Update
  87. Okay Im Starting to get frustrated.
  88. ShockWave 26 Brushless 2.4 RTR what type of hull ?
  89. Corrosion X Question
  90. Installing Capacitors
  91. I wish my Insane FE30 was this fast...
  92. Eagle Tree setup
  93. help with a new setup
  94. Where to get small bolts
  95. Rc boat lingo
  96. Amps or Watts ????
  97. premo set up for the rio ep
  98. NEU Motor 1512 vs Lehner LMT 1940
  99. Lipo charge
  100. Industrial Strength Velcro
  101. motor question
  102. 32.3" EP RC Catamaran a-RTR BL Motor Racing
  103. Would this work ???
  104. UL-1 motor jacketed in an XL mount
  105. SUGGESTION to repair broken hull
  106. Vac-u-cracker
  107. Battlepack supports Wil Muncey
  108. NAMBA Dist 19 breaks new ground
  109. Self Righting
  110. what ESC?
  111. cool speed detector
  112. Which 30" Hydro hull
  113. anyone run 5s on ul-1 esc
  114. 24" V-Hull Setup Help
  115. Carbon Fiber Hulls
  116. stiletto and bandit obl
  117. Hyperperformance OS Adapter
  118. Heat Shrink question (ESC)
  119. Happy Birthday Properchopper
  120. Happy B-day
  121. What prop to use
  122. problems.
  123. 120A esc too small for <30" hydro?
  124. Site may go down for a bit tonight.
  125. anyone seen this cat yet?
  126. Himodel 200A ESC Price drop.
  127. What motors?
  128. Tower sale
  129. question on tube dia.
  130. What mono superboat hull 1m/39"
  131. XXL surge crusher??
  132. delta force 29 hardware issues plz?
  133. sv 27 replacement hull?
  134. porpoise in sv
  135. Surge Crusher / turnigy 180 amp / typhoon 500 motor
  136. Best LiPo for Kintec Pursuit Mono?
  137. Campbell Shovelnose
  138. hot connectors
  139. NQD Jet boat first few mods
  140. leaking stuffing tube ?
  141. OH BOY! Here we go again
  142. Which motor for genesis?
  143. should i put the motor at the front or back of boat ?
  144. 3n1 Oil Any Good In FE?
  145. Stinger height/depth
  146. HobbyKing USA Wharehouse
  147. ul-1 gear in a delta force 29??
  148. carbon treating hull?
  149. Fan cooling anybody?
  150. So where do all the scratch builders buy their plywood?
  151. What is too much temp bl motor?
  152. 1600watts what speed?
  153. any tips on sealing the hatch ?
  154. Maiden voyage
  155. oil for the motor bearings
  156. AQ Reef Racer 2 Upgrades?
  157. Which Coupler for a BJ 26 motor
  158. Genesis/ Leopard combo question(s)
  159. European R/C Class1 powerboat Magazines
  160. Etti Power Monitor
  161. Miss Geico Flex Cable
  162. JAE FE LiPo Compartment
  163. Typhoon 500 motor on 6s problem.(video)
  164. Genesis gets redbull makeover.
  165. 150 C Lipo from Maxamps
  166. Twin 33" Mystic Cat-Which side should counterrotate.
  167. Heavy duty motor mounts recommendations for a Feigao 580L 8L
  168. Best set-up for a Titan 29??
  169. What We HATE Most
  170. Any one with fecalc
  171. ten day air mail from HK
  172. Prop pitch and power
  173. Properchopper, an inspiration to FE!
  174. Is the nqd surfer any good ?
  175. Speed Controllers are a pain in the A**
  176. Turn fins too big?
  177. Best Connectors?
  178. Sworfish 120A problem
  179. Steve, No 20' .150 Flex Cables!
  180. Someone please explain this - ESC Motor wiring matters?
  181. F1 or Formula 1 Tunnel Hulls
  182. Which RTR
  183. water cooling fitting on transom
  184. Mini Mystic w/MHZ Drives Question
  185. first legit FE build, need advice from the masters
  186. Hull painting
  187. Tenshock mono1 flood chambers
  188. Recommend a brushless boat to a noob!
  189. esc comparisions.
  190. OSE, first class customer service
  191. What are Nqd boats clones of ?
  192. capacitors: what are they for and how many is enough?
  193. Douggie
  194. custom esc's?
  195. Racing Pictures
  196. Rum Runner Racing help
  197. no step 3 questions?
  198. what ESC for Pspec hydro
  199. Cat Advice?
  200. 60" Cat brushless help?
  201. Best place for turn fin on hydro?
  202. hk 5035 760 kv
  203. r2 hobbies cat video
  204. Hydro Advice.
  205. Aquacraft EP1 gears!!!
  206. newbie question
  207. genesis ESC manual
  208. Prop X642 Question?????
  209. Recommend a brusless motor for the nqd tear into ?
  210. What hull is this?
  211. 14 volt Lipo config ?
  212. Motor Lathe?
  213. Under Hull Water Pickup
  214. Moving an epoxied motor mount??
  215. fe miss vegas prop questions
  216. Delta Force Hydro with 5S 5000mAh ?
  217. Where to get scale boat parts?
  218. Apparition flex shaft conversion questions
  219. Head of the River
  220. Motor/ESC and battery combo - will this work?
  221. Thinking of a Genesis, need f/back
  222. NEU Batteries
  223. Running 5s with t180esc ?
  224. Neu motor diameter
  225. Three NAMBA FE SAW Records set Today
  226. titian 29
  227. Why do we do it
  228. Weller Soldering Iron
  229. Why are brushless outrunner motors crap for boats ?
  230. 70 mph Insane Hydro ?
  231. Good day at the pond..
  232. Speed predictions for twin drive boats
  233. More lipo config ??
  234. 27" custom jet ski boat
  235. Fusing the battery connection?
  236. London bound - Just curious
  237. What Hydro for 5S 5000mAh?
  238. Sprint cat 41" building
  239. Swap meet in london ontario
  240. anyone ever use the chat room feature on here?
  241. Motor question
  242. hydro problem
  243. Prop *!***!***!***!**....lol
  244. Why do some people solder a capacitor to their esc ?
  245. Stilletto reverse rotation flex
  246. Setup Help
  247. Painting my titian 29
  248. Best lipo plugs
  249. Jae 21 fe
  250. Humm???
