View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Mean machine Motor...
  2. mean machine motor 2
  3. bby scat cat brushless motor
  4. Hydra 120 max temps on 6s?
  5. brushless esc question with reverse ??
  6. Project Red Evo
  7. GPS Problems?
  8. motor wires to ESC help
  9. Velocity MiniCat - burned stock ESC
  10. Surge Crusher in the waves
  11. some help needed
  12. Silicone or Aluminium Cooler
  13. Apparition on 6s with typhoon 1800kv
  14. Roll over chamber? Where could I get one?
  15. How strict is the 27-30% CG rule??
  16. Prop spinning wrong way
  17. MHZ.USA not responding?
  18. Expanding Foam
  19. Frosty clear coat.
  20. Good place for boat stickers
  21. hello from a new px1 hull owner
  22. CAUTION ! : Corrosion-X is FLAMMABLE !!
  23. Has anyone ever ordered from Fuyuanrc?
  24. Strut to Drive Dog Spacing?
  25. Surge Crusher 'dipping'
  26. NAMBA FE NATS results
  27. Esc for Leopard hobby 56x92??
  28. burnt up scorpion
  29. blowing caps 180esc
  30. whats the best way to watercool an outrunner?
  31. Boat Batt.
  32. JBWeld to seal up an ESC?
  33. Hydro & Marine?
  34. Do the rules fit what's best for today
  35. Bullet Hyperformance flex drive question
  36. Twin motor question
  37. Suggest a Motor for a Boat
  38. Best timing on a genesis cat
  39. motors help needed !
  40. WTB alluminum motor straps..
  41. My schulze picture hosting...sorry
  42. What does your wife think of this hobby?
  43. antennas
  44. help, prop shaft and flex cable
  45. Venom King of Shaves help
  46. Hydro Turn Fin Discussion
  47. Rigger rear ride steps
  48. Big boat motor help please
  49. speedmaster rudder observation
  50. Parallel & Discharge rate
  51. Drive shaft maintenance
  52. New Guy...need a little help...Miss Geico
  53. 1/8th Scale Power Combination
  54. brushless motors efficiency/throttle position
  55. minicat velocity esc
  56. Corrosion X
  57. to much ESC???
  58. Newbie Flex question
  59. 40" Delta force knock off
  60. Full Size Outboard Race - Hartford,CT - (9/3-9/5 )
  61. E class Hydro plans.
  62. Hyperion EOS606i internals question
  63. gyro
  64. FE 30's big brother
  65. Has anyone ever ordered from RC Ninja?
  66. My new FE Outboard!!!!
  67. Aquastar ESC Timing Question
  68. terminology
  69. spekrtum question
  70. I want a fast boat
  71. Prop ID numbers
  72. 40/60 Solder
  73. Gieco & John Q Public
  74. Horizon Hobby CS IS THE BEST
  75. What esc to use ?
  76. Hot battery and connectors
  77. austin texas
  78. Prop Questions
  79. Octura collet substitute?
  80. 1/10 Scale racing with Classic Thunder!!!
  81. ESC with built in data logging
  82. I want a slow boat
  83. whats the best way to cut 2.5mm carbon sheet?
  84. OSE Steven is the MAN.
  85. MHZ hulls
  86. Esc q for you knowledgeable guy
  87. Hyperformance liner question
  88. Anyone do anything with one of these yet?
  89. Seems "G-Freak" has Freaked Out
  90. Stiletto Hatch Question
  91. new aquacraft cat
  92. Speed Estimates and Advice.... 54" MHZ Twin
  93. maybe dumb question...
  94. scott @ littlescreamers
  95. RTR boats
  96. ESC question: Will a ESC not 'arm' if a motor is bad?
  97. esc for Leopard 4074(2000kv)
  98. Miss geico genesis hull "done"
  99. proboat stilletto tunnel
  100. Damaged bearings in wire drive strut
  101. Starting my FE 30 build.What battery?
  102. Identify this boat?
  103. SV27 motor rebuild ??
  104. which is better?
  105. Throttle Fluctuation
  106. Esc decision for a Maus/Bandit Shovel hydro
  107. Wire Drive & Custom Couplers
  108. This caught my attention.
  109. Whats up with the 1717?
  110. RC Raceboats Powertrims 3/16"
  111. Temperature monitor
  112. Skunk Cat Gen 1 Set-up
  113. Motor/Temperature/Run time question
  114. 50" Vee Bottom 24 deg
  115. 580l motor mount
  116. better brushless esc for widowmaker
  117. Kintec Racing
  118. Center of gravity
  119. Proboat ESC settings for 3S + Fiegao
  120. big kitty fever
  121. 150 octura collet question
  122. Is this boat any good ??
  123. new boat at hk
  124. 1s esc
  125. HK cpy of the Stiletto 29?
  126. info re: Aquastar 90 amp ESC
  127. Stock RTR Speeds???
  128. Miss Budwiser
  129. Can You
  130. 43-44 mpg Tops
  131. When is enough.....enough
  132. neu water jacket dilemma
  133. stringers or no stringers ??
  134. Anyone running outrunners and HV240's castles?
  135. prop shaft bushing
  136. DF 41" type mono hull
  137. Esc battery wire question.
  138. Delta Force VORTEX 22"
  139. Motor question
  140. mounting question for strut on mean machine.
  141. cf waterjacket how to
  142. Aquastar Monster ESC
  143. Hobypartz lobotomy - beware
  144. 200a esc
  145. NEU Motor 1512 Series
  146. Site down time
  147. balsa cat
  148. Rumdog gets the "G-Freak" Treatment
  149. Semi fast/stable boat for youngin?
  150. stay away from waldorf rc on ebay
  151. Lehner 2250 Hi Amp smoked :(
  152. Ammo 2300
  153. Site is now moved
  154. Need some help pricing for selling a boat
  155. Surge Crusher on 4s/4s nano-tech and 5s
  156. Full size boat cleaning
  157. Reliable mid sized boat suggestions?
  158. Hop up suggestions, anyone...
  159. Maxamps video featuring OSE !!
  160. Genesis Setup?
  161. Miss Geico Hull Only Review
  162. Z Drives
  163. please help me with my boat i want MORE speed
  164. Mini pump ?
  165. Shear Bolt Gone
  166. 1/8 scale
  167. props for a twin 55" cat
  168. Why???
  169. Help -What esc do I need - leopard 4074 on 6s
  170. max unloaded rpm
  171. Is this site very slow now
  172. 46" Hydro Build
  173. UL-1 or Stiletto?
  174. Rudder for a DF 33 mono
  175. elam battery compartment
  176. HELP - water coming up stuffing tube :(
  177. Cyberstorm beats gassers at Camarillo race !
  178. Prop???
  179. Help please......SV27 ESC not working.
  180. My New Toy Garage....
  181. Detla Copy Rudder Ripped off.
  182. Genesis cat
  183. vvvIIvvv's HPR115
  184. Skywing 200a ESC
  185. watercooling issues
  186. Which hull for P-hydro?
  187. Reading the RCU Master Hull Roster??
  188. Pictures from the 2010 Classic Thunder Governor's Cup 1/10th Scale Unlimited Race
  189. Water inlets for a catamaran
  190. Delta force 33
  191. rudder length
  192. Replacement motors
  193. email address underscore
  194. h&m super cat owners
  195. Replacing shaft on small inrunners?
  196. Random Album Picture
  197. What prop to start with?
  198. Who sells the Outerlimits SV 43 ?
  199. Bad signal???
  200. Genesis Cat with Leopard 5692 motor
  201. Boat Prop Blade effeciency
  202. Outrigger's
  203. Who has motor mounts?
  204. Hull/hardware source
  205. 440-2 vs 440-3 prop
  206. miss geico or the stiletto...
  207. Esc's and throttle travel = Problems!
  208. Source for Pre-Made Carbon Fiber Angle??
  209. New ESC, how to figure out amp draw.
  210. Dark Horse hydro scale
  211. Teflon liner for a 3/16 Shaft
  212. H&M Maritimo v H&M M-1 Supercat
  213. Run a BEC or rx pack?
  214. cap bank
  215. Water tube connection issue
  216. Motor problem - can seems to spin
  217. what voltage to use on Genesis cat & 41"DF
  218. The New " Porkmaster 2000" Lipo Saver/Run Timer
  219. Salt Water......
  220. m1 Supercat
  221. ICE 160HV ESC under water (long story)
  222. 200amp himodel speed control
  223. Bondo
  224. Genesis Cat
  225. Is there a way to clean up smoke damage?
  226. Piggyback Brushless ESC's
  227. Piggyback Brushless ESC's
  228. Spicing up a Reef Racer 2
  229. Genesis cat. questions/comments
  230. esc to motor questions
  231. handeling ? problem
  232. don't under estimate fotation... in the cowl!
  233. Optimal set up for 30" hydro.
  234. replacment motor options in an sv27
  235. What can possibly go wrong with this set up???
  236. ABS or not to ABS that is the question...
  237. Genesis/ help/advise with a fast setup!!
  238. HELP... My boat is a lush.
  239. flush fitting water pick up location ?
  240. *attention all lipo users liposack saves my house*
  241. Want to know Best glue/epoxy for velcro on fiberglass
  242. esc gone bad
  243. 44 inch cat which neu?
  244. cap board pics.
  245. can you identify this strut
  246. Esc recommendation 4 380L
  247. Wax or paint sealant?
  248. Shovel nose or V-hull
  249. g freak out
  250. What flex shaft grease to use
