View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Neu 38mm motor?
  2. Are these Motors any good?
  3. FE Boat Decals
  4. on 8s?
  5. wire drive vs flex 12s setup
  6. BEWARE of Krylon Clear Fusion Over Color Fusion
  7. Help: FE Mean Machine Mystery
  8. Mhz Mystic S turning problem
  9. can anybody help who run OS & Bullet drive outboards
  10. Lehner problem
  11. Gibberish?
  12. Anyone waterproof an eagle tree?
  13. Daiwa PS-304 II Anyone familiar with this power supply?
  14. Help on motor choice please
  15. Do Graupner flex couplers shorten when under load?
  16. Grease flexshaft on genesis question
  17. lipo source other than HK
  18. Triton..next prop for 50mph...
  19. Today's PSFE Race Pictures
  20. Diagnosing a demaged motor?
  21. sell the holc aycula or the n2 rigger?
  22. Hydra 240 Lv setup
  23. what Classes do you race ?
  24. How do I keep my boat from diving?
  25. Hydro&Marine Skater build
  26. Hobby King Cat (Surge Crusher) hull repair
  27. Hatch keeps popping (one way valve?)
  28. A 32" cat?
  29. Genesis cat
  30. Genesis toRque roll fix
  31. I need a fast boat
  32. Genesis first run
  33. New Phil Thomas Stealth Sport Hydro
  34. Large prop low pitch or small high pitch?
  35. Question
  36. Stuffing tube question
  37. Can anyone tell me what kind of boat this is???
  38. Breaking news
  39. txt message from hobby king
  40. 3/16th shaft for .078 wire
  41. Rigger Sponson Design Q: Trailing Edge
  42. Lehner ESC type 1895 programing
  43. PSA- 2nd degree burns hurt.
  44. driveline heat ideas?
  45. Lehner or Neu ????
  46. Strut Position Delta Force 25
  47. Miss Vegas as a LSH Hull
  48. Stuffing tube size
  49. Stepping down
  50. Anyone talk to Ned Schmidt lately?
  51. Hardcase or Softpack Lipo's?
  52. Motor cooler
  53. Rio 51 conversion
  54. ToyPorts Ozone
  55. Replacing the Hydra line
  56. Clear coat application question
  57. Gensis cat esc
  58. 1/8 to 3/16 drive dog?
  59. Miss Vegas hull ?
  60. SuperVee 27 - Test run with Feigao 7XL motor
  61. where is it?
  62. Looks like the HYDRA ICE is finally coming.
  63. upping wire awg?
  64. Attention Schulze esc users
  65. super hawaii drives
  66. Good 6s-8s outrunner?
  67. new aquacraft tunnel topspeed3
  68. What turn fins??
  69. Motor for a 31" Challenger
  70. PT super sport 45
  71. What plastic props are these?
  72. Need some help!!!
  73. effect of airdams on hydros?
  74. 32" Cat, 65 mph, 3+ min runtime ; Do-able ?
  75. First FE = Proboat Brushless 26 for noobie?
  76. new here with a few ?s please
  77. LiPo lead failure
  78. ETTI Coupler 5mm/3.2mm (.130")
  79. Aussie Hydros 33" Sports Hydro now taking orders
  80. Miss circus circus
  81. Delta force help..
  82. 1/8th scale FE future?
  83. Would you be disappointed?
  84. What is actual diameter of .250" flex cable?
  85. HiModel ESC problems?
  86. Anybody want a $8.00 60 Amp Controller??
  87. Duo ii question
  88. Carbon Fiber
  89. Impulse buy, now what to plan for it
  90. Newby from Italy
  91. New, Neu motor chart.
  92. Advice for my Shouland H-7 modded prop, HELP.
  93. UL-1 Hull Separating?
  94. Reverse on esc
  95. stackable cells
  96. New Insane FE hydro, or Phil Thomas Stealth hydro?
  97. DF 29 7XL to go fast -timing and prop q´s
  98. PSA- The R2 Cat hull is NOT like the HOTR
  99. Wild super vee
  100. Best set-up for a Pursuit Mono
  101. Shipping to Hong Kong $
  102. Fine design rc.
  103. Rough Water Setup Need Some Help
  104. PSA- Metric 4mm Cable Systems
  105. Prop work?
  106. Trouble breaking 70
  107. Miss geico genesis complete " for now "
  108. ESCs: Back-EMF Question on Logic Circuits
  109. Prop recomendations please!
  110. HELP Please....Porpoising Hull
  111. Teflon into brass trouble, 3/16" Help
  112. Anodizing Removal
  113. Started to, but...
  114. Quick ?
  115. Colored cooling tube
  116. 37" Genesis Cat
  117. DF Copy 33
  118. Six New NAMBA 2-Lap records set today
  119. Whats a good Fe tunnel hull ???
  120. Would this be good replacement ESC?
  121. Apparition on 6s? (HiModel 125a ESC)
  122. Where to use my boat.
  123. gas to FE
  124. Motor(s) for Aeromarine Cyclone
  125. motor for a Keywest
  126. new boat german pretator mx
  127. GPS Anyone used this one?
  128. Big boat advice
  129. etti demon
  130. My first order with HK...
  131. Where can I find aluminum battery trays
  132. bearings vs bushings
  133. feigao or keda any difference ?
  134. Anyone know who this is?
  135. motor recommendations
  136. Hatch Tape vs 3M electrical tape
  137. Where can I buy those stingers?
  138. Motor timing for 5807l 1898kv
  139. 646 3blade on kb45 17xl?
  140. anyone have one?
  141. P-Spec Sport Hydro/LSH?
  142. Banana Hobby Cat same as Surge Crusher ?
  143. where can i get a vector format of the miss geico lizard?
  144. BQY Li-Po batteries ???
  145. Brushless Car Motors
  146. ESC auto-shutdown, were do i go wrong?
  147. any tips of motor mounts ?
  148. 33" Mono ?
  149. Wave Max, airplane guy
  150. New to boats...
  151. Paint Choices
  152. Outrunner ?
  153. Eagle tree systems
  154. Steering Linage Help
  155. Another new hull from HK??
  156. Cell count vs Hull size, a discussion.
  157. Prop size?? Delta force Neu
  158. New HK Hydro
  159. 700 brushed motor
  160. is this boat any good ?
  161. cat hull
  162. Help me spec out my power system
  163. New boast from HK - Mini Cat Twin Hull Offshore
  164. New lipos
  165. Lipo's in pairs charging to diff mah
  166. Where can I get a good 32" cat hull for under $100
  167. BJ26 ESC programming ?
  168. has anyone run a pursuit esc on 6s
  169. Beginner advises
  170. Help with set-up
  171. Stinger length??
  172. Help -- motor KV specs
  173. Lehner Motor Specs
  174. Motor/Esc recommendation
  175. new here and has a rigger question.
  176. Need esc set up instructions for Suppo ESC
  177. 25-06 headers
  178. Turnigy vs. Hyperion Eagle Tree Comparison
  179. dual rudder ? pros cons ?
  180. Toysport Jolly Owners - Step in
  181. 10s setups
  182. Let's See How Smart Everyone Is...
  183. Input on this boat
  184. WTT up to 1527/1D
  185. DF-33 Wiring and Lay-out Review?
  186. Cigarette Carbon Fibre Boat
  187. 1/16 scale hydro driver source?
  188. motor = lipo combo
  189. Stuffing Tube Seal ?
  190. Help this motor smok's
  191. New HK Twin, EKOS?!?
  192. Titan 33" with twin screws???
  193. BJ26 plastic hardware strength
  194. Mono Hardware ?
  195. delta vortex 16 prop
  196. Can Someone fix this for me? ESC FET GONE
  197. SV 27 of DF 26 copy ??
  198. Temp ?s
  199. twin cat non-counter rotating props?
  200. New Boater question
  201. hardware recommendations
  202. Timing
  203. Interesting HK info
  204. Catamaran single vs double drive
  205. 33" Mono First Runs ?
  206. Silcon water jackets
  207. Genesis Throttle Problem
  208. Good, Cheap Motor for 6s, 200 amp
  209. Temp Range
  210. what prop for a tenshock mini eco with a 4200kv motor ?
  211. Best self-righting boat???? Help!
  212. Monster 2000 ESC
  213. Advice on a Hull
  214. VERY nice Genesis Cat run........fast boat
  215. Best 11.1 lipos for 6 cell 33" mono
  216. Props
  217. I want to get started in boats.
  218. Hopping in turns
  219. Lake ozark mini shootout!!
  220. Question about 380 motors and 22 volts
  221. outboards
  222. quannum motor
  223. Insane FE30 issue
  224. Solinger hardware?
  225. FYI new P-1 mono in stock
  226. Insane FE 30 motor/esc/prop advise
  227. Help! Stop my boat from being lost at Sea...
  228. Fuller's Mono Hardware Lube ?
  229. Pursuit Upgrading
  230. Amp draw question?
  231. 447r
  232. pvc boat stand
  233. Brushless motor question
  234. pcv boat stand bby micro patroit
  235. Speed Guess 33-DF
  236. sv27 1800kv motor question
  237. Ever thought of encapsulating the hull?
  238. About motors
  239. First big cat
  240. Help finding water cooled motor mounts
  241. hydra 120 feiago 10l set up
  242. df vortex prop question
  243. Bushing
  244. Oil for motor's ball bearings
  245. Ok please help
  246. HK Dragon boats
  247. Smoking NIMH batteries
  248. 2010 Fast Electric Nationals
  249. How to use a Rescue Boat??
  250. Miss Vegas Deuce
