- demon Rigger
- Rumdog 39" df battery clearance
- Micro Scat Cat
- How hot is too hot for ESC
- New Hobby King Cat (Surge Crusher)
- Poly rc's 30c 35c 5000 5050 are they the same
- my connectors are getting hott!!!
- Props and Battery Recomendations for 54" MHZ with 2215's
- Think this might be a problem?
- Boys there is a new Sheriff in town........
- theoritical setup
- steve v
- how to reach jeffm912
- Fried my motor
- New Pickle Build!! "AMP-O-HOLIC"
- Flex shaft oilers
- Changing a Miss Elam from gas to electric
- Turnigy UBEC questions
- Expieriences after the sale?
- Your First Boat
- Will this work?
- Amp Draw Question
- How did this happen???
- dp270 and corrosion x
- ESC waterproofing by total encapsulation
- School me on EDF
- Traxxas "waterproof" servos???
- Taking Temperature Readings
- Delta Force 33 need HELP
- Video on fiberglass RTM manufacturing
- Running a BEC off of the balance plug?
- Shaft material
- stinger drive length
- ok.. whats next.....
- Paint remover?
- Rigger sponson Q&A
- Setup for Genesis cat Twin ??
- turnagy 180 esc
- Bullet connectors
- Better KV for a Neu
- Adhesive for battery straps
- xxxxxxx Let's have a build contest
- Safety with beryllium copper
- Question.......Neu 2215/2y
- Neu 1524
- Is this strut big enough
- 8s Pursuit
- Happy Birthday Doug Smock!!!
- Help with my scratch build CG
- *sigh*
- Genesis cat,,,
- Motor questions...
- Another reason Steve Neu is the MAN!
- please help me choose a prop.
- Easy deans cap bank
- Hobby Services ( Waranty Srervice for RC parts and other... )
- Drifter L Suggestions
- push rod seals
- May be useful for setting up a rigger.
- Leopard Motor.....Schulze 32-200WK
- Higher Prices from China Coming?
- Thinking about water cooling...
- Lipo question
- Prices in england are high
- New 32" catamaran hull
- Thanks OSE....
- Swap shop tip of the day
- what pitch is this prop?
- Prop Questions
- mhz micro iceberg??
- DF 33 Prop Size
- Stuffing Tube Question: 0.187" flex in 1/4"
- Toysport mono w/ flood chamber
- Newbie help...BBY Oval Master setup
- Turnigy nano-tech
- Carbon fiber and plastic hulls
- h&m m-1 super cat/esc Q
- Motor and ESC question
- speed control help
- Get It On (Bang a Swan Gong)
- Mono Rudder Placement - Why the Offset??
- Do I want a 40.160?
- Twin Setup Question
- Programming Instructions for SuperSimple 100A?
- Delta Force 33
- Urgent Question!
- Carbon Fibre
- What motor for Toysport Triton?
- Typhoon 700 vs Neu 1515-1521?
- Contest in the Making!
- formula fastech nitro
- Brushless Motor Comparison Testing
- One must go. Which one?
- Lets see your Renegade Rigger!
- What wood to use?
- De-tongue 3 blade props
- wil the eagle tree blow up ?
- feigao motor problem
- Esc
- WTH is that ???
- New Hull......Longboard Boats
- New Motor no power-Help
- help sponson angle
- Bad Motors
- One LARGE BL Motor
- ESC sealing
- Offshore Warrior ESC ?
- Retreival boat for an HPR 233 ??
- Water entering my Genesis Hull
- How to build your own boat......
- 15,000 watt kayak????
- SV27 vs BJ
- NEU 1512 - 1,5Y Where ??
- WARNING: Ordering LiPo Batteries from Hobbyking
- BEC question
- Eagle Tree
- Thank you Sailr
- New member
- Delta Force Mono Prop
- Boat suggestions wanted...
- neu 1515 Question
- New Guy, Looking for Some Helpful Info Please
- HELP with prop selections please??
- project saw
- What is scuffing and how do i do it?
- Help with Bullet outboard
- H&M hulls...where to buy?
- C.O.D. Charges???
- Flex Coupler
- neu or mega
- NQD jet boat upgrade
- Motor amp draw?
- ESC for 1527 1D
- Water Cooled Motor
- Miss Budwiser XSEV T4 Turbine 2 Wing Experimental new age hydro
- Got a new boat holc aycula
- Need Help NEU1515/1Y
- Are there 2 different types of Genesis cat ??
- even more new hulls and boats at hobbyking
- How do you tune a boat?
- strut bushing
- Help finding a pair of outrunners
- pursuit 32" mono
- Who makes custom motor and esc mounts?
- Turn fin adjustment
- boat turns right better than left and heat!
- How can i make my own flex for a K&b 3.5 elec..conversion
- Masking a complex paint scheme
- Twin 2215's with twin hv120's in big cat?
- pursuit mono
- pursuit mono
- Foward and reverse ESC?
- Balance Taps
- home anodizing article
- Propshaft Angle
- best way to drive to keep all componets coolest?
- where to buy resistors for anti spark??
- D.Smock
- HK Surge Crusher
- Worlds Fastest RC Model Lobster Boat Races
- Genesis is in stock - act now!!
- Motor mount ?
- ul1 weight
- 1/4 scale Cobra
- What size wire
- Point me to a system
- Syncron running a proboat motor?
- Do head of the river rc have a website ??
- 2 channel signal mixer?
- Prices of Chinese goods going up
- interfernce
- Thrust bearings
- Another Tragic Day at the Lake....
- Cc bec
- 5700kv in a mean machine
- Motor/ESC running hot, not sure why
- Motor suggestion 30" Balsa Cat
- motor suggstion for Titan 29
- what hull is this ?
- epoxy over poly : can it be done?
- Heiner Gundert Died?
- Scuffing hull another proposing ?
- Who builds this hydro?
- Solo Video'ing rig
- Converting Dumas boats to electric...
- Rudder offset positioning..
- Steven - problem with payment system
- Where can I find a flexible shaft hex driver ?
- 8 awg to 14 awg?
- One cool lookin' cat!
- Stringers
- Breaking Flex cable
- DF Cyberstorm 33 setup
- SoCal FE Demo at new Water Park in Marina Del Rey
- Hobbycity/Joysway "Sea Fire" Hydro
- Replacing proboat motor bearings
- What does a "lifter" prop do??
- Post run cooling system rinse
- Cooling jacket for a Neu 1110 ???
- Prop balancing HELP!!??
- Need help with my first set up
- Do I need two water pickups?
- Ghetto Tree (Cheap azz remote temp thingy)
- Replacement motor for Tenshock Mono1
- Sprint Cat .40 Hardware
- Help???have alot of fe hydro's and outrigger!!!
- 1:8 scale 1981 Atlas Hydro
- 33" Fiberglass Rigger
- phil thomas supersport 45
- mhz z drives
- Question on water pickup..
- motor selection for small rigger
- proformance increase by setting timing
- Venom Lipos, good, bad, ugly?
- What the heck boat is this!!!!
- switches
- Need to find an SV27 rudder water nipple
- New Forum Member
- Central Circulating Watercooled Outrunner?
- Will it blowup?
- CC hydra 240 settings for Neu 1521/1.5D
- Speed comparison
- Whats the difference ??
- Shovel Nose Hydro
- Hobbyking lead time?
- rc boat race in Sunapee NH august 6th?
- interesting SAW rigger
- Motor Question?
- Amp Draw
- motor choices on a bj 26
- a few questions before i begin
- What Happened to Ozzie's thread ????
- just what are these?
- Polyquest 30c 6s 5000mah problems
- HPR not FE but AAAAAAAAAAAAA
- Painting Hardware?
- New 22.5" Hull- Arowana
- Help- Flex shaft seizing in strut
- Tunnels with flood chambers?
- wire drive advice
- Performance International Hydro gen 2
- Eagle Tree RPM sensor
- detachable motor mount?
- P mono 55+mph set up
- SV27 Drive cable sheared off
- NEU 1512 1,5Y vs TENSHOCK 2240/8 ?
- programming genesis esc
- happy birthday Steve
- Hot Stuff
- $23 fibreglass mono
