View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Esc cutting on and off
  2. MHZ USA any one having trouble with there web page
  3. 36" H & M Cat set up
  4. Experience with Hydro and Marine?
  5. What hull should I get?
  6. Is a 540 6xl on 3s a good powerplant for a jae21?
  7. Motor support, different...
  8. I need advise for a high KV motor on 2 cell lipo
  9. Proper way to install a stuffing tube?
  10. 1.6 pitch C/R SS props
  11. Best wiring for a twin setup ???
  12. 5S on a neu 1515?
  13. Pistix
  14. Wire vs Cable...Noise
  15. Securing Hatch to Hull - ?
  16. Electric fan cooling for codite SS1
  17. Hatch "gasket"?
  18. Pursuit!
  19. Triton
  20. any carbon fiber props under 40mm graupner size?
  21. At least I Know I Have Enough Flotation
  22. rio ep motor fried!
  23. CF Props
  24. Big mistake today
  25. New Hobbyking vee
  26. Lehner 2280 in a SPRINTCAT?
  27. Delta Force Sniper...bye bye 2215 2y
  28. A reminder
  29. oval master 21" motor/prop advice
  30. Advice on first boat
  31. 540S vs 540L
  32. ***Mystery 200A Pentium ESC Water Cooled, Heatsink & Fan Conversion Walk Through***
  33. Managing Distractions...
  34. UL-1 ESc with Feigao motor?
  35. anyone ever buy from Head Of The RIver rc?
  36. Help! Twin setup wiring
  37. Double Your Motors Power (Cheaply)
  38. Spy shot Insanes new sport hydro
  39. HC... another one
  40. Prop info for ABC H5
  41. Which GPS?
  42. Silicone Conformal Coating
  43. Unique 200A ESC cooling system
  44. anyone know where i can get a ul-1?
  45. Who isn't doing there job at NAMBA
  46. Quick Removable Turn Fin!
  47. How big a Mono?
  48. Water cooling tubing
  49. Drive Tube Self Oiler?
  50. 1/3 Bud The Ultimate RC Project
  51. Cat with no rudder?
  52. R.E.K. Lower Unit
  53. Mamba Monster Max 2200 combo on large hull possible?
  54. Velocity Mono
  55. Seaducer Mono?
  56. Rudder
  57. Reef Racer Batteries
  58. Will this work for a 4mm drive cable?
  59. It wont go straight
  60. What to build ?
  61. help with fecalc
  62. DF 29 M440+ MMM 2200 +6s = ok?
  63. H&M Distributers
  64. Waterproofing ESC
  65. Thank you OSE
  66. Another couple more boats at Hobby City
  67. brushless Outboard on a V hull
  68. anyone have an aquacraft v24?
  69. ? Mean Machine For LSO ??
  70. Genesis twin setup, what strut ???
  71. Maximum watts
  72. stinger drive length on twin cats
  73. New REK lower unit coming
  74. kink in stuffing tube?!?!?!
  75. Pursuit
  76. This must be inspiration for a design/build
  77. A different twin.
  78. New HK Deep Vee's?
  79. Painting a gel coated glass hull
  80. Twin Hydro, is it possible?
  81. Thunder Tiger Bandit Brushless Tunnel
  82. hydro/ cat advice
  83. solid capacitors
  84. Genesis catamaran
  85. My Pitch Gage
  86. do 3 blade props need to be balanced?
  87. Large cat hull info wanted
  88. Brushless equivalent to an Aquacraft T270
  89. Schulze Repair Prasie= Mega 40.160WK
  90. Need Advice on what motor to run in a 37"cat.
  91. Youtube? Good or Bad?
  92. OMG !! New ARTR OB TUNNEL !!
  93. Cap replacement
  94. Strut placement question...
  95. Single blade prop effeciency myth
  96. Strut Bushing Measurements
  97. Duty
  98. Cooling INFINITE motors?
  99. Kyosho Twin Storm Brushless
  100. Hobby City Shipments
  101. Is this really an F1 boat?
  102. 2s lipo for UBEC, what size?
  103. Which way to offset?
  104. Genesis stuffing tube damage
  105. feigao 9XL smoked
  106. Unhappy with Lipo Performance
  107. New SV is comming!
  108. What size hull for the Ammo 36-88-1280?
  109. About time.. ing
  110. Looking for german website
  111. will a kb45 17xl 700kv motor push a jae 45 on 12 or 10 s
  112. Stinger to stuffing tube
  113. eflite esc question
  114. Q for the Twin experienced
  115. Measure motor/esc/battery temps?
  116. Odd ball couplers- help locating
  117. I want 10minutes and 50mph, what will it take?
  118. A quick esc ?
  119. EP race boat
  120. 40.160. Schulze Question
  121. Outboard adaptors for OS Lower units
  122. power supply questions
  123. Spin her up!! Rev it up high! (maybe)
  124. Hydro strut location?
  125. Aquacraft miss vegas conversion whats needed ??
  126. Feigao 8xl on 12 cells in cat 26. what prop?
  127. Strut prop balancer? LOL
  128. CC Hydra 240 lv low voltage cutoff
  129. Upgrade my PB Fastec
  130. Prop mods
  131. Polishing props
  132. Motor for 1/12 ProBoat Hydro
  133. Is this too hot a setup??
  134. Just Praising Scorpion
  135. props sizing to match motor
  136. hopping in the turns
  137. hydra 240 issues...
  138. cutting a flex shaft
  139. Kudos to OSE
  140. Sealed drive shaft?
  141. SV27 Flex size? .150?...
  142. Just took delivery of HK NTN-600 brushlesss
  143. What could this be ????
  144. why dont turn fins and trim tabs have water pickup's built in like rudder?
  145. Motor question
  146. 8XL OR 10XL on 6S
  147. Outboard lubricant
  148. New motor for the Fastech
  149. Lehner 2280's Motor Noise
  150. Midrange brushless motors
  151. UL 1 Motor Upgrade
  152. What prop to start with?
  153. Homemade cooling for esc???
  154. Feigao motor question??
  155. what to get for first brushless boat?
  156. What Voltage and Mah Lipo's for Lehner 1920 7 wind motors
  157. i need your help for outrigger boat
  158. alternative to NEU 1515 1.5y
  159. right size motor coupler
  160. Running parallel batteries
  161. LiFe question
  162. Prop advice
  163. Partial throttle harder for ESC?
  164. Is my boat running wet?
  165. Tenshock brushless motors ???
  166. ul-1 esc
  167. help me watercool my esc
  168. Feigao motor timing
  169. testing a brushless motor&esc
  170. Hpr06 1st run...
  171. Australia Bound
  172. Need help on new boat purchse.
  173. need to go faster of course
  174. Adding Caps to ESC
  175. No More LiPo's?
  176. Twin Setup Questions
  177. Water Cooling
  178. Insane Boats P-Spec Sport Hydro 1st run with Vid !!!
  179. Looking for a lake in Philly
  180. Phil Thomas 45
  181. Hardware help selection and where to buy - mono and cat
  182. CT03 and CT04 hulls where to buy??
  183. Genesis catamaran
  184. Anyone know where to get this Cat inline hardware?
  185. Hydra 240 running twin motors?
  186. Hull Hatch Handles?
  187. MISS VEGAS FE w/UL-1 COWL???
  188. Jae 21 FE 6s lipo
  189. What Outrunner Motor?
  190. Motor timing ??
  191. will the 120 pursuit esc handle 6s
  192. Small cat question
  193. Delta Force Boats
  194. Does this look right?? pix....
  195. miss vegas bl conversion?
  196. Strut depth Vac-U-Pickle
  197. hobbyking v hull:pursuit
  198. Delta Force Sniper... Little Screamers or Scorpion
  199. Water Pump?
  200. Insane Boats Sport Hydro Pricing Released
  201. 27" sk daddle motor suggestions
  202. hobbycity pursuit
  203. 11L 2200kv motor
  204. Possible twin setup ??
  205. Another new boat at HK
  206. Another Boat?..
  207. I'm gettin' all warm & Fuzzy !
  208. Help with wirring new motor
  209. JMSCARD, your PM box is full.
  210. Who makes a high quality ESC at a reasonable $.
  211. bby war zone jr
  212. Thoughts on Swap Shop Change
  213. How do you hide your obsession?
  214. K & B 16.5cc / 1 cu. in.
  215. Do I buy it from China or the USA???
  216. Rio EP esc?
  217. JMSCARD clean out your full pm box.
  218. Optical illusion
  219. Cooling... Plan B
  220. Ammo motor 2300kv
  221. Would this work ?
  222. It's all in the timing
  223. Scorpion outrunners and ESCs
  224. Motor Selection Help???
  225. Genesis catamaran neu setup
  226. Delta Force Cyberstorm RTR!
  227. Feigao XL Motors
  228. Timing Ammo 2300kv
  229. stickers
  230. Props for HPR233 twin 3080's
  231. What boat is this?
  232. 100mph Hulls?
  233. Solid shaft coupler question
  234. What size esc?
  235. having a problem viewing pics with droid
  236. cen brushless conversion pb 6s
  237. ammo 1280kv
  238. What ESC to use with Lehner 2240/7
  239. Secret prop revealed !
  240. Why HK marine ESC's are not greater than 180Amps???
  241. Teflon liner for #128 brass & 078 wire
  242. Need some help with choosing the right boat for ME
  243. Little Screamers mount?
  244. Tenshock 3 blades propellers L + R ?
  245. Schulze 160 or 300 ESC's with Lehner 3080 9wind?
  246. Leaning to one side
  247. Making a "SLOWTech" for my daughter, motor/ESC choice?
  248. Offshore prop for Neu 1521/ 1.5D?
  249. upload question
  250. cogging...
