View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Hydro turn fin
  2. Does this eBay boat worth the $$
  3. fan to run on lipo
  4. Cable or rods ?
  5. Is there a class for electric r/c cats?
  6. New IMPBA Q Tunnel SAW record !!
  7. I want to handmake my own stuff. Where can I get plans?
  8. Saw
  9. Is a 45A ESC enough for a Lehner 1530/8?
  10. TERRIBLE Sank my boat:(
  11. Are They "G-Freakin" Nuts???
  12. Super Brain ???????
  13. Rigger 10S1P, Scorpion HK 4035 Schulze 32-200WK (Updated with video)
  14. TFL Genesis Cat Testing & Video
  15. looking for cat pics
  16. Best motor for MHZ Tsunami
  17. Copi Hollow ??
  18. Replacement prop
  19. Question on bullet connectors
  20. Stuffing tube help needed
  21. Stinger help needed
  22. Anyone run this boat??? HOR Sea Predator Hydro
  23. anyone else hear this????
  24. Getting rid of burned smell from the boat.
  25. Wanting to have a race in Folsom
  26. Sponson angle
  27. What size bullet connectors to used?
  28. OPC Tunnel Recovery Pad Pictures??
  29. Lipo shield help
  30. Aeromarine Chaos Hydro - Looking for Pictures
  31. Need Some Help Schulze 40.160
  32. Motor Identification
  33. New NAMBA National Fast Electric Chairman
  34. Battery Pack/Prop Recommendations for KB 45L...
  35. Gyro controlled step plates?
  36. Proboat's new Shockwave 26?
  37. what lipos for a hpr115
  38. Perk of Living in Seattle Area
  39. Hi model 200 amp ESCs
  40. Prop Suggestions for Matrix Rigger?
  41. AeroMarine Chaos Hydro
  42. How many of you build your own carbon/glass hulls
  43. tfl hobby on hobbyking?
  44. Best setup for 32" catamaran
  45. What motor and esc and propeller to the hull of a catamaran of 1045mm?
  46. brown box boat co any one ever build one
  47. big sale of boats on RRR now saturday2.13pm
  48. top speed 2 handling
  49. How do you transport your boat to the water?
  50. Can my cable still be used?
  51. RainX B-28
  52. 60/40 or 40/60?
  53. all i can say is sham wooow
  54. Just a comment
  55. hydro help please
  56. Video hosting?
  57. Power Glitches
  58. Tight Spinning Flex Shaft Help
  59. Has Anyone Put Ride Pads on a Viper?
  60. Zinc lake gone ??
  61. is there smoe one making the hpr 115 in north america
  62. Outrunner for a 20"cat
  63. Good size lipos for 700`s brushed motors?
  64. anyone recognise this tunnel hull?
  65. anyone from Europe waiting for package from OSE?
  66. Idaho boaters
  67. UBEC Hobbywing 5V /V
  68. Need Advice on Bearing Swap
  69. to b.e.c. or not to b.e.c. ??
  70. Hydro hooking in turns
  71. UBEC Hobbywing 5V / 6V
  72. MM help
  73. Turnigy Typhoon 500 videos
  74. Hi-Model 200 amp 4-8s
  75. Tunnel hull & radio ?
  76. tunnel hulls is it normal for a slight porpoise
  77. shipping
  78. cooler for a 41mm dia motor xerun 4 pole
  79. Anyone Try These Cyclon Motors? - Watercooled Outrunners
  80. Insane Boats P Sport/Spec Hydro first Hull !!
  81. df 35 suggestions
  82. Rigger Help More speed needed
  83. What does a (-1) mean....
  84. OmniModels
  85. Lipo Shield Questions
  86. Cat stinger length....???
  87. Proboat ESC on 4s?
  88. ECO and Ammo Motor
  89. Will I cook my batteries?
  90. 11XL on 6v ?
  91. Spark!
  92. Do I have this Speedmaster strut set-up right?
  93. question about eagletree logger
  94. T.H. Turbo Vee 3
  95. How much power is P-Spec power?
  96. SV ESC and a 10xl
  97. SS 3mm cap screws
  98. Stopping torque roll
  99. Cutting a flat spot on a motor shaft
  100. studder bump???
  101. 4 cycle motor
  102. Need help finding a lake to run on!
  103. Interesting hull on ebay
  104. hotr delivery time
  105. esc safety
  106. Couplers for 7.5 OPC Lower Unit??
  107. Who Makes This Hydro???
  108. Whitch boat to build ??
  109. What's a cool use of a 3rd channel in an electric build?
  110. Stryker 2 Hydro
  111. BEC for hydra 240 on 4S
  112. Stuffing tube lube nube
  113. MPH Calculator?
  114. brushless ?
  115. What motors ?
  116. HK Water Cooled Inrunner
  117. Aquacraft Rio wanting to roll over on it's back
  118. Collet style Flex Hex couplers
  119. Twin wing
  120. Polishing Aluminum
  121. FWIW: SV27 Discontinued
  122. Fine Design
  123. bouncing boat!
  124. To buy a "water damaged" M-Machine with or without hardware?
  125. 18" or close Mini-Cat
  126. Pre Built or find a builder?
  127. Help with a Rescue Boat.
  128. Venom Smart Temp w/ an ESC?
  129. short run time
  130. Repair Chip in Eco Hull
  131. Any one seen this boat thinking of buying
  132. Almost sunk my Delta Force 33" Today
  133. MHZ Miss Trendwest 54" hydro 1/6 Scale
  134. Replacement DF 33" Hatch
  135. hyperion STORE mode
  136. mm esc
  137. JAE 21 FE fast setup?
  138. swap shop items are like a girl at a heavy metal show
  139. Coupler problem ? Or bearings?
  140. maintenance tips
  141. What hull is this?
  142. Is this to much angle?
  143. Set up question.
  144. well i went swimming today up here in mass
  145. Prop for Toysport syncron
  146. SV question that may assist all
  147. Noiskilling a deep vee?
  148. Great Stuff for flotaion
  149. Congrats to Dick Loeb on winning the WTC P-Spec FE class
  150. Need help with my boat
  151. Help! Issue with Castle 5.5 Bullet Connectors
  152. Using packs in parallel with dual ESC's
  153. Rescue Rigs
  154. Motor Mounts Keep Breaking Loose.. Help???
  155. How hot is too hot?
  156. Super Hawaii help
  157. cleaning primer
  158. What 120a ESC's are available?
  159. Kyosho Wave Master broken flex shaft.
  160. Cheapo ESC settings
  161. Small cat problems.
  162. lap cat conversion
  163. lap cat conversion
  164. Leaving an ESC plugged in
  165. Looking for Self-righting boats
  166. Kt value in FE calc ?
  167. What Feigao 580l motor for a 37.5" Mono
  168. Removing Epoxy Fingerprints - any tips?
  169. hv hydra esc
  170. number of prop blades????
  171. Is it worth it?
  172. do low volt cut offs work with todays high powered batteries
  173. what is the most efficient power to weight ratio?
  174. Euro at $1.27
  175. Timing Question: Timing for 6XL?
  176. scorpion 5035 500KV
  177. Propeller Calculator Links?
  178. prop shafts for .078 music wire
  179. Coupler to thrust bearing spacing
  180. HOR boats?
  181. Carbon filled props? Two blade? Three blade?
  182. Velociyt mono or jollymoto
  183. 3060 kv ?
  184. Another new Sport 21 Hull on the market
  185. Motor mount for ammo 36-88-1280?
  186. understanding FE
  187. DF-33 Hatch Lock
  188. New Hydro from Phil Thomas
  189. mono rudder
  190. Motor and coupler recommendation
  191. More noob questions... How do I find the center of my transom? Mount motor?
  192. Props
  193. smoke
  194. 4mm Prop selection?
  195. Tunnel Hull setup
  196. Will my RC hydro esc work with dual Traxxas titan 775's?
  197. So... Why aren't my Deans plugs melting?
  198. soldering tabs on lipo help
  199. Best mono
  200. Ul-1 esc what's a good motor match up
  201. J.G. Props. Anybody remember these?
  202. Prop recomendation
  203. Velocity mono prop upgrade
  204. Delta Force 29 Build
  205. Data on MHZ no-step
  206. Triton Data
  207. Water absorbtion & flotation
  208. Good target RPM?
  209. 23" Rigger
  210. What kind of projest will be your nest offshore ???
  211. New FE RTR Boat
  212. What should go in this gap !!
  213. Octura dual rudder alignment
  214. Insane setup or not ??
  215. Genesis catamaran ???
  216. So, Really... What does it take to be considered "Fast Electric"?
  217. What do you use for data logging?
  218. Setting a Maus/Bandit 24" shovel
  219. pictures
  220. esc's
  221. Cant we do this?
  222. Need help with a GPS unit
  223. twin strut setup
  224. GFreak Elam GPS placement video hahahaha
  225. HiTopMax 11.1V 4500mAh 3S 35C ???
  226. What are my cheap esc options?
  227. Stripped hex set screw for coupler
  228. Stacking thrust bearings?
  229. Most reliable ESC for 10s
  230. Outrunner HB3650 ($21.50) pushes 5lb 4s O/B mono 37mph
  231. traxxas nitro vee conversion (crazy)
  232. Advice
  233. Octura flex hex set screw size
  234. ESC for a mincat?
  235. Check out these items.
  236. Prop washers?
  237. Wanted ! Helpful Whiplash owner, 40 prefered
  238. fastec amo 2300 kv motor upgrade
  239. Rudder depth on small boat
  240. RCMK 1100 hydrolift owners need drive dimensions PLZ
  241. My ignorant questions
  242. great deal on a cat on ebay i found
  243. New Water cooled Outrunner design
  244. Degrease flexshaft
  245. Motor for my Yellow Jacket
  246. Strut bushing ?.
  247. df 26 choices
  248. Conformal Coating
  249. 1521 0.5y KV?
  250. 4wd onroad cars
