View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Info on Twin prop rotation...
  2. correct way to solder 5.5 bulletts?
  3. Twin Cat Strut assembly on a budget -> help please ;)
  4. 2009 Nat's-Thanks OSE!
  5. Delta Force Sniper 45 Questions
  6. carbon or carbon/kevlar?
  7. any thought of this rudder system?
  8. apache 24 brushless set up help..
  9. Spark Arrestor
  10. Inrunner --- outrunner
  11. typical wiring in parallel
  12. Converting the Chinese square drive stinger to 3/16!
  13. Ajoda 200 amp esc?
  14. Water Coolers for Lipos.
  15. Thai Long Tail Boat
  16. Trying to understand ESC's a bit more
  17. Amazing Poltergeist Powered Propeller !
  18. Dissappointing Miss Budweiser Lipo conversion
  19. Hydra 120 ??????
  20. Which Neu for 2cell stepped mono ?
  21. Saw run records
  22. Lipo repair ?
  23. three new FE NAMBA 2-lap records set today !!
  24. my new h&m ss.21
  25. 21 Phil Thomas with Spec power
  26. Active tunnel wing for cat
  27. New motor for 32" Deep Vee
  28. RX Box
  29. hydra 240 replacements
  30. counter rotating out runner
  31. where can i get cf in aus?
  32. Mean machine motor
  33. SWANG it! anyone try these esc's?
  34. Twin cat rpm questions
  35. Hanspeters new monster
  36. need source for fm crystals 75mhz
  37. I need a prop
  38. Fried the HiModel 125A
  39. Waterproofing a hatch
  40. Balsa hull. ??
  41. whats the future of FE boating
  42. Eagle Tree Data Logger
  43. Deep vee questions
  44. O-Rings for OSE type 540 size jacket
  45. 2009 Nationals results
  46. Hong Kong Lipos
  47. Mhzusa?
  48. Help with esc. application
  49. Turingy Marine 120 amp version
  50. Is 130 degrees for lipo and motor, and 170 degrees for ESC too much?
  51. RTR car/boat
  52. Quick lipo question and new to the board
  53. New PQ packs- 45C/90C
  54. Funny shipping handling fee practice
  55. New to me Vac-U Pickle
  56. 1/8 Scale Hydro Websites
  57. Motors max. safe temperatures
  58. flex saver
  59. Setup for 1/16 Hydro
  60. high touqe inrunner
  61. Ebasy find for updating the caps on esc's
  62. ammo 2300
  63. Hydro & Marine Micro Kat Tunnel hull
  64. Possible solution to battery connect spark??
  65. sv27 VS UL-1 motors
  66. Jolly cat setup.
  67. boat has lost all drive
  68. Rumrunner racing website update
  69. Adding Weight
  70. Is there a correct rotation for a prop?
  71. crash info.
  72. OSE gots their ABCs
  73. Band Saws
  74. need a little help with first boat
  75. Going out with a whimper
  76. neu 1515 1y timing on 4s
  77. motor shaft diameter
  78. is it the esc or the reciver?!?!?!?!
  79. Anodizing?
  80. Boat to play in the waves with
  81. VS-1 with Scorpion outrunner
  82. Today's Guessing Game...
  83. Pushing the limits of a motor
  84. PropperChopper Happy B Day
  85. carbon fiber
  86. flex shaft dia.
  87. Who says you can't power a BIG hull?
  88. IMPBA FE Rules
  89. POLL: Who here is a member of IMPBA or NAMBA
  90. REK Lower units and Snapped Cables
  91. Who is running Feigao 580L motors???
  92. Delta Force
  93. Help me figure out the amp.
  94. XPower brushless motor for 6S Lipo
  95. New motor... same speed
  96. Hardcase Lipo in Boats?
  97. Flex Wind-Up
  98. What do you think about XPower?
  99. H&M Maritimo motor
  100. Toysport Twin Drive Jolly Cable help
  101. $400 ESC poll
  102. lipo lingo
  103. hydro /rigger question
  104. Any experience with XPOWER motors?
  105. OPC Tunnel Boat
  106. Colored Carbon Cloth?
  107. 380 xl help please
  108. kv
  109. Program card required?
  110. erri with no go
  111. Turns to kv conversion
  112. Aquacraft EP1 Outboard
  113. hull bottom mount strut
  114. ? on epoxy sealing ESC
  115. Follow up - Magic smoke/240's
  116. Lipo batt works with 550 brushed motor, esc?
  117. Swap Shop is a Success!!!!!
  118. Trim Tabs
  119. Unsure of what C rating lipo to get
  120. water proofing a esc?
  121. For all the droolers out there
  122. ESC Cooling Concept- Theory and Practice
  123. Reinforcing a hull
  124. Hobby King brand esc's
  125. plywood 12x48 1/16-1/8-3/32 ?
  126. 2mm Collete
  127. BEC or UBEC?
  128. Battery Monitors, cutoff's etc
  129. nitro conversion
  130. Please explain how to free up a drive sys
  131. Warming Lipo's for running in cool weather
  132. Garry Finaly plans, vs dumas sponson designs/changes needed?
  133. small props for 3/16 units?
  134. Feigao 540 8xl inside
  135. Nemesis motors?
  136. BEC Amperage?
  137. SAILR...CLEAR YOUR INBOX, Whipkits arrived!
  138. what esc reversing for brushless
  139. micro kat
  140. printing plans
  141. Waterproof a lipo pack???
  142. Making a fiberglass hull for a hydrofoil
  143. "CAT"astrophic day on the lake
  144. Corrosion X
  145. Bad trader notes maybe can you help
  146. Drifter s
  147. My micro drifter
  148. BEC Question
  149. OSE 700SC Super on 20 Cell
  150. Smoked motor??
  151. New Whip
  152. Balanced props
  153. Deep V Sub-surface 23" Restoration - Neep help :)
  154. I Hobby Expo - Chicago
  155. motor for hydro2 5min ovall racing
  156. Old Kyosho outboard
  157. 80" 36lb Catamaran
  158. 1/4 vs 3/16 flex
  159. new memeber question (esc)
  160. So I have this Sniper hull...........
  161. MHZ USA back in biz?
  162. 2.4 Mhz or FM
  163. Batt question
  164. Triton cat hull question
  165. Aquacraft Hammer BL question?
  166. RC Fishing boat
  167. Any ideas what i did wrong?!?!
  168. What to do with Fine Design?
  169. Well....
  170. A 200amp Monster-2000 ESC
  171. ***newbie questions re motors / props / esc / batteries info required***
  172. Beware the glue
  173. Mega power future 120 HV
  174. Brushless Cyclone.
  175. K&B
  176. Chemtronics conformal coating
  177. Watt's Up Meter Question
  178. Newbie question about lipos & esc
  179. mixing 2 and 3 cell packs?
  180. Use clockwise or anti clockwise prop?
  181. Osborn Miss Supertest Motor Selection
  182. Can't decide on esc to choose????
  183. porposing?
  184. Miha holc
  185. Predator size saw rigger
  186. Question for the wood scratch builders
  187. a lil help
  188. 5.5mm vs 6mm
  189. Anderson Power Poles.
  190. Turn Fin Sharping/Polishing
  191. any one see this ESC 200A
  192. R/C Boat Modeler is back!
  193. K1 KV meter
  194. ***Skunkworks Cat Owners thread TIPS / TRICKS / PICS / SET UPS and SIMILAR HULLS***
  195. Mgm speed control for twin mhz mystic
  196. Delta Force 33
  197. Tony Call me(BBY)
  198. vacu pickle vs ul-1
  199. jae .21 rigger plans release today.
  200. Fiberglass or Carbon Fiber?
  201. winter
  202. esc's w/o bec question
  203. What to glue abs together?
  204. Hello
  205. Where to find coupler?
  206. Flex shaft self oiler for FE???
  207. Flex Cable size for a 26 inch?
  208. Sponson rock
  209. Venting UL-1 sponsons
  210. Bullet Connectors
  211. Tunnel COG
  212. Prather vs. Mercury cable grease
  213. New Bluetooth Data Logger found...
  214. Feigao 580L in a Mean Machine?
  215. a few questions....
  216. Cat Bulkhead ?
  217. Motor efficiency
  218. any bigger than 34"?
  219. BIG and HEAVY Brushless DC Motor Controller (12v - 144v)
  220. Piano Wire
  221. Will Non-Counter-Rotating (or same direction rotating ) work on twin set-up?
  222. Output power question
  223. stick vs pistol on some esc question
  224. Medusa 3680 ??
  225. La saws???
  226. Help me decide with this poll
  227. Seeking 325 Astro Motors
  228. Thrust bearing on a Neu motor
  229. Best jacket choice for a Medusa 36-70
  230. Anyone have Kyosho Wavemaster converted to brushless
  231. Lehner vs Neu
  232. water through the stuffing tube?
  233. Prop question
  234. Need help setting up a boat
  235. Silicon Water Jacket on Vented Motor
  236. Trim tab position on 31" mono
  237. Dumas Hot Shot
  238. Aeromarine 43" Challenger Hull
  239. 1515 1y on 6s
  240. brushless motor rpm's
  241. help selecting engine for 4s riguer
  242. Whipash props
  243. LA SAWs Videos
  244. Prop shoice for twin 33in cat
  245. Happy Birthday
  246. Veterans Day 2009
  247. What Prop....
  248. making hardware?
  249. Rum Runner
  250. What props to start with?
