View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. Flex shaft lubrication
  2. Does anybody have experience with G freak boats?
  3. 8 Cell Predator Rigger
  4. Differences between props
  5. motor, esc, battery temps?
  6. conformal coating?
  7. Any scale boats with outboards out there?
  8. 32" Delta Force copy quest for more speed!
  9. How to build a Hydro2 boat for racing?
  10. Easy Question about OPC
  11. Eco does backflips off waves in the pacific ocean
  12. Too much cooling
  13. New to brushless..help
  14. What should I do?
  15. Feigao 580L
  16. any good online boaing stores in canada?
  17. New and improved eco video in ocaen
  18. Suggestions for scale looking boat hull ,outboard preferred
  19. 32" Imex Cat
  20. ran my saw boat.. thanks Danny.
  21. gotta make a descision
  22. Fs-gt3 2.4g 3ch tx
  23. counter-rotating props ?
  24. Best boat for my purposes?
  25. I still dont get it
  26. all in the name of fun
  27. power source for triton jr. Can't beat $12.79
  28. NEU motors back plate set screws
  29. need source for SC cooling fan
  30. Which bullet connectors are the best?
  31. Rough water boat
  32. hydra 240 waterproofing
  33. rc lipos .com
  34. Smokin' Boats!!
  35. HELP.. water pic up esc cooling in ECO MANTA
  36. Water transfer decal questions
  37. Hires pictures of offshore logos and boats needed
  38. wire drive
  39. Securing the prop.
  40. hydro motor set up
  41. Az racers
  42. motor quistion
  43. Graupner Arrow rejuvination
  44. First Attempt At Seacam
  45. esc prob
  46. teflon liner
  47. Balancing
  48. New boat for beginners
  49. ESC temps
  50. rigged insanity
  51. calculation for amps possible?
  52. You gotta see this : R8 catamaran !
  53. PolyRC introduces 43C packs
  54. Mixed lipo brand names work?
  55. FEISUDA Motors???
  56. Nemesis Blue 8L specs?
  57. Australian Chewing Sticks to the Rescue !
  58. Paypal scam, watch out
  59. motor temp?
  60. AquaCraft 36-56-2030 and ESC
  61. Need help and suggestions
  62. Twin Drive Question???
  63. charging lipos
  64. 2.33 meter boat setups?
  65. Outrigger websites
  66. Anodizing at home
  67. Damaged lipos?
  68. Looking for advice on buying a boat
  69. MRP Python Canard.
  70. New Graupner Brushless O/B questions
  71. Some Consideration
  72. A liltle test with X462
  73. UL1 programming issue?
  74. dx3s in boats
  75. CAT sponson shape and angle questions
  76. the proud owner of.....
  77. CC ESC Capacitors
  78. attaching water cooling lines to Hydra 240
  79. Krylon paint question
  80. how do you tell an orig super hawaii
  81. Aquacraft UL-1 ESC fix quastion...
  82. 2009 LA FE SAWs cancelled
  83. Where can i get good decals,specially numbers....
  84. Cad Data Files
  85. Mean machine 1st run #'s
  86. Question reguarding lipo batt charging
  87. Ose 700sc
  88. Large Hydro Build Possible??
  89. Filling holes
  90. My Sniper finally dial in finish, video
  91. finished props
  92. Buying Parts On-Line...?
  93. Great Foam?
  94. Doubling the batt Mah = longer run time?
  95. Graupner GTX 820 Oh Steven
  96. Where does heat come from?
  97. Velcro Straps
  98. A wild looking hull
  99. flex shaft problems....
  100. hobbytron.com
  101. melting esc wires
  102. Prop shaft size question
  103. Rio Roses Fountain.
  104. question about prather props
  105. cell sheild
  106. FE Calc and detongued Props
  107. Aquacraft Miss Vegas Electric Conversion
  108. Bad day.Smoked esc, cracked motor
  109. One weird cat
  110. 3 motor mono
  111. Bad day on the pond....
  112. Prop question - Aqua Jet
  113. MEAN MACHINE ?'s
  114. Hydra 240 lv shorted
  115. Best Buy "Cat" - Twin application
  116. What's going on inside a puffed cell ?
  117. Need help with stinger strut
  118. Jolly upgrade
  119. ESC question
  120. rcraceboat.com closed for a week.
  121. 0.062 wire drive Qs
  122. Hydra-180 hv replacement
  123. Props for DF Sniper on 12S??????
  124. The New GUY!!!
  125. Traveling
  126. 200a ESC won't take WOT
  127. dumb battery/charge Q's
  128. running a himodel 200 amp
  129. Testing an ESC
  130. AquaCraft 2030kv Motors and Combos Back in stock
  131. why do props hop
  132. first ,rigger, plans, help ?
  133. Happy birthday
  134. un-joining?
  135. cat question
  136. Running a temp gauge
  137. Cen Aqua Jet
  138. Painting Plastic Parts
  139. Video for Venom's KOS 34" cat
  140. Thunder Tiger Outlaw OBL
  141. SkyWing esc's?
  142. Gps
  143. Dual Jet Challenge
  144. Delta Force 33" Help
  145. Question about BECs
  146. Ways that LiPoly will get banned
  147. Amp Draw?
  148. Capacitors
  149. what cells will work?
  150. Hydra 120 and a Hacker 7L???
  151. FE GONE WILD....you gotta see this
  152. Mah vs. Voltage question
  153. Fines on MSNBC
  154. electric boats and the IMPBA
  155. Cant upload picture
  156. Vacu-DILL!! w/UL-1 Elec
  157. Ahhhh!!!!
  158. 8mm collets?
  159. 10-01-2009
  160. Magic smoke And 2 - 240's
  161. where to buy delte force 29 hulls
  162. When ESC's go boom?
  163. spwktrum dx5e
  164. Assembling spark arrestors!
  165. How to implement bullet connector system?
  166. Cooling coil question
  167. ETTI Demon Tub
  168. motor and esc for a predator
  169. LiPo Charging...
  170. Adding auto-lipo feature to Hydra ESCs...need your opinion
  171. Increase Motor KV or # of lipos
  172. Question about EagleTree loggers
  173. Garmin Forerunner question
  174. Looking for video....
  175. Motor diameters...
  176. Help with an esc
  177. What's up with the forum?
  178. need ammo motor bearings
  179. Fiegao 8 & 9 xl motors
  180. Rigger
  181. Bonzi Sport out drive
  182. ESC programming
  183. making a pistix??
  184. Laminating w/ Carbon Fiber
  185. Can Lipo batt be saved
  186. Louisiana/ Southern boaters I need some advice
  187. Is 40 too much to ask for???
  188. KD Brushless motors
  189. CG vs. Drive Angle
  190. Checking Lipos
  191. Phoenix ICE HV esc
  192. How to figure out flex shaft size?
  193. To all member's of i.m.p.b.a.
  194. Trashing other members
  195. 29-32" Best Deep Vee Hull
  196. Brushless mtor help
  197. Lehner Motor choice??
  198. raptor marine
  199. N2 Sport Hydro for Nats- NEED HELP
  200. The Villain EX Theory
  201. 25.8" (Fortune) U9 Miss Exide
  202. The best boat you built and why, Rtr's are excluded
  203. The Swiss never cease to amaze me...
  204. my new boat racing oval
  205. kit wodden mono
  206. Best Motor for O mono
  207. 6mm Bullets or Deans
  208. Exactly why and where- bulkhead
  209. 2344 Graupner jet info
  210. villian on 5s
  211. To the Mods....section request...
  212. Burned a Schulze 40160 today
  213. S.s. 3/16'' drive dogs?
  214. 2s Motor options?
  215. Need help
  216. Mini XXX
  217. sentilon 100HV prog ??
  218. How Far Do You Discharge Your Lipos?
  219. twin 32" cat
  220. Is prop too big, too small, or wrong pitch?
  221. jeti jes 600 esc set up help please!
  222. GONE FISHING! Unbelievable!!
  223. New Fastech and my son
  224. Building my first FE Tunnel Need Advice
  225. Email and Laptop Down
  226. Water Cooling
  227. Piano Drive Wire Snapped like a Shot
  228. Gundert thru hull pickup...
  229. Hor 25
  230. BIG hull outboard questions
  231. Anyone know who makes this "Vintage" hull?
  232. Remember that POS Kyosho Viper build????
  233. out-of-balance drive dog problem
  234. Strut bushing mod
  235. electric calculator
  236. boot linkage for CEN Aqua Jet
  237. Rudder Trailing Edge.
  238. swollen lipo pack
  239. Hydro&Marine Viper
  240. SAW cooling
  241. lipo winter storage
  242. BBY Zephyer Hull 27"!!!
  243. Measuring flex shaft with a caliper
  244. Waterproofing Esc's - Advice Needed.
  245. Prop change or weight transfer?
  246. H&M Sport 21 Hull
  247. Lipo questions
  248. Prop sacrafice
  249. Noooo - Viking Funeral!
  250. Noob says hi and thanx hor 32 setup
