View Full Version : Fast Electric Rc Boating Talk
- Matrix ultimate rigger Qs
- Programming 3PM to Hydra 120
- Wisconsin-Minnesota Midwest Challenge
- Deans Connectors
- miss elam brushless
- How To
- Series or Parallel Connection
- Bullet connectors for high current
- old hull info WTD
- Just got 4 of these in today
- hyperion duo II
- Need a prop recommendation
- New china harware
- Brushless Motor Timing Advance.
- Best Brushless/ESC starter combo?
- Ul-1 esc and SV27 motor
- Esc.
- Kontronik KIRA 650-17
- Dect 2.0
- Decal set for Model Rc Segad Class-1 Offshore Racing Boat
- Feigao Motor Changes
- Anyone Tried the Neu Razor Motors?
- Electric boat
- Wetmate Connectors, A Better Solution?
- Straightline Pass
- Niagara Marine Hobbies
- two part flex and prop shaft
- Need help on props!!!!
- Maus micro setup?
- funny looking prop
- Something to talk about, HV Micros
- rigger turn fin?
- proping up
- hydro setup
- Five new NAMBA 2-lap records set today
- Hi model esc cooling?
- happy fathers day to all
- Water cooling
- Tamiya oh no.
- Bullet connectors.
- Where to buy Maritimo hulls?
- New to boats.
- Small L+R props
- Powersupply to HYPERION EOS720INET in network?
- Lipo Advise
- sprint cat 41
- Feigao 540 L
- Lipo
- Nicd vs Nimh
- Advantages of using wire-drive?
- More C or mAh ?
- OffshoreElectrics Vacation Schedule
- Motor Mount ??? for 540 L/XL size motors
- Carbon Fiber Mono
- motor&prop help on 26 bby oval master
- Decided to get more run time from my boats
- Trim plates on an older Villian
- Kinnda weird question..???
- 1/8 hydro setup
- Which boat for 3s2200 or 6s2600?
- Hull reinforcement
- NEW Nue 1415 motor size
- Cat setup
- Head Of The River Cat Hardware.
- My new Sniper mono
- please help
- Project: Aeromarine Titan 29", POWER: 6s or 12s
- Ordering parts??
- Not so fast Silver Rocket
- Red BEC lead.
- Need Doublechecking PLEASE!!!
- tennis ball
- Maritimo Racing Catamaran.
- Is it me or what?
- Summer/Turtles/Kickup rudder
- Anyone got a MHZ dpx24 nimbus?
- Thundercat 31 conversion questions
- Hypeion packs and 5C charging
- G-Force Products?
- Quick question...
- 1/10 scale hydro
- Which hull to get (using sv27 electronics)
- need set up
- Rigger sponson sizes
- New Technology: RC Fishing Boats, complete with fishfinder?
- ETTI Oriental Dragon...
- Soldering Iron
- Vortex DF 16"
- what's up with rum runner?
- Sweet scale boat
- GOOD running 2s rigger
- rc-hydro Victory ESC turning off
- Need some mono setup help...
- How To Avoid a Turtle!
- Happy 4th of july!
- Large bullet connectors, where?
- FE Gods were smilin' on me today
- 1/4" flex
- EOS0610iDUO help
- Please show me your PVC boat rack
- 6s rigger and only 37mph? help
- elite lipos
- new water cooled mystery 200 amp
- Does getting lipos wet ruin them?
- 7.5 / 11cc Electric lower leg conversion..How are people doing it?
- '2P' lipo
- FE datalogger
- Desperately need Lipo
- Running on the edge, a leaf and a bad day!
- SPC Lipo
- CBM Marlin
- Prop Balancing Discussion
- x640 or x442 prop
- Avatar & Signature change
- avatar test
- Mono Rudder Question...
- Neu 1515 2.5d vs medusa 3680 1600kv
- zippy lipos thread
- Need A Brushless RTR Boat
- Feigao 580L motor, ETTI 150 esc good setup?
- Holly crapola!
- Micro Mogli motor/flexshaft question
- 43" mono powering
- What is this prop for
- Who's fault is this crash?
- Jim Clark, who is PGI models?
- Thrust bearings, do I need them?
- TS2 conversions?
- 67 inch hpr ct04
- EC3 or Bullet Connectors?
- Painting a 'pickle'
- sprint cat 40 copy
- A123 batteries
- Good Starting Place for Newbies.
- rigger bouncing
- Puffed Cells ?
- MAYTECH 200 amp HV esc
- 12s mono prop choice
- esc timing
- Balsa hull repower time.
- blackjacksven
- Needing some help with my set up
- What boat to use with a 1515 1Y and MMM
- Graupner GTX 820 anybody?
- ESC melt down.
- Delta Force Cyber Storm 33 turning problems
- 540 motor coupling
- The dreaded electrical "Crack"
- Graupner Z-Drive 820
- Swap shop and removing photos after sale
- 100 inch mono
- MGM compro Black Box
- Scorpion Outrunner power in my Rigger
- Firest FE boat I ever built steering hard right at full throttle
- Drive cable lube?
- 8s2p cat
- FE at the 2009 gas/nitro nats
- what prop?
- Graphics for rc boats
- Himark/proboat esc
- Looks like Enerland wants the Boat Biz
- mystery motors and esc`s
- What To Use To Clean Boat After Burn ESC???
- My new Sniper mono 1st run video
- Coupler slipping...
- Best 5mm to 3.17mm coupler
- Rhino 3S 3700Mah plugs.
- Slooooow Renegade.
- Hacker Navy 70 Programming
- wrong motor kv
- Connecting Hyperion Duo3 to PC
- timing for the neu motors
- lipo packs Ul-1 and Blackjack 26
- Midwest Challenge Results
- Remote going in reverse help !!!!!
- Marlin rtr
- Drive Set-Up
- Hard case for lipos?
- Motors for mhz mystic 44"
- 4th Annual "Roostertails in the Rockies" Thanks to OSE
- How Often Do You Run
- were to get a lipo cutoff
- Hyperformance & K&B propshaft compatibility
- Lipo Wiring gotcha
- Flight Power
- Sprint cats question
- shaft diameter on feigao 540xl
- Rigger Building
- Lipo Bat
- Hyperion DUO Update - 20 Memories!!
- Feigao 580 L water jacket
- brushless
- idle prop question
- Flex shaft size for a Mean Machine
- supervee27 new motor and esc??
- ESC trouble!
- Rigger Insanity
- RCU Threads...
- Etti power analyzer
- Hull speeds
- Anyone see this yet????
- Newbee needing help...
- turn around time vac-pickle
- lipo verses NiMH
- saw
- Mach 5 Racing couplers
- Neu 2230 smooth case + new sizes!
- what hull?
- Looking for new prop.
- Hull pairs for BJ 26
- intlwaters.com login problems?
- Prop sugguestions
- Lipo packs
- Really cheap 20c lipos.
- Bye Bye Medusa
- charging batt,s
- Shaft Lube
- X-Power 100 RIP.
- Twin Powered Hydro....Drag boat
- Minicat Racing Volocity Mono
- Would you pay $499 for this?
- hobbycity esc
- cant decide on a hull
- Rudder/drive setup?
- flex cable size hydro
- Water pick up ideas
- Testing an ESC???
- large mono hull with twins
- You'll find this funny, I did
- bby War Zone Jr
- HP-LUV 2s1p 5000 25C lipos-any good?
- Just another reason why the Cheap ESC's are looking better and better
- cowling hardware
- Q about flex cables
- whiplash cowl..anyone make them. or have a used one.
- Feigao 12L or 13L or ? UL-1
- Need help to mod my ep Arpo 700mm
- OSE response time to customer?
- where can one find...
- Lehner basic XL 3600 HELP
- new rigger build.
- Hydro & Marine Shovel, or PTss21
- N.A.S.A s new space boat
- question about sprint cat 40
- How to apply decals?
- Upsetting news out of Florida this morning
- hobbyking.com
- lipos in 115 degree weather?
- cat hulls
