View Full Version : Fast Electric Rc Boating Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
  1. blast cat VS hpr115
  2. Assan Hack 2.4Ghz module
  3. HOTMBC at the Dallas May Race!
  4. Strut depth vs. Shaft Angle
  5. HELP: Sub C Cells to Lipo
  6. rudder question
  7. Motor and Prop Charts
  8. Left lipo charger on last night!
  9. Do I need to water cool an ele. outboard?
  10. villian questions
  11. P Sport Hydro Options
  12. Vee, How sharp ??
  13. Mixed mAh lipos OK?
  14. MiniCatRacing Diablo?
  15. anyone have a toysport triton?
  16. HobbyKing Support
  17. N2 Mono Hulls
  18. Brushed/brushless Motor freezer
  19. ETTI power analyzer
  20. Help !!
  21. class
  22. How much power can a wire drive take
  23. Medusa Motors, anyone using them?
  24. prop size?
  25. Is It Safe To Use The 3.17mm Shaft Motors For N2
  26. rc stern paddle wheeler
  27. Motor-ESC-Battery Wiring hook ups, please help!
  28. Delta Force 41 Maximum Weight?
  29. "Boogieman" new china hull
  30. What did I do wrong?
  31. stinger or strut drive
  32. setting up my skunkworks cat
  33. 5mm to .078" Couplers...
  34. Heads UP Miss Attitude
  35. Ammo 2300 and Cooling Jacket
  36. Dual line cooling
  37. Stinger installation in mono
  38. NAMBA rule question
  39. ERCU 1/10th and 1/7th Pictures
  40. Prince Mono Hull
  41. Batavia 2009
  42. New Counter Rotating, Forward Facing Prop Technology: Military to Consumer Markets.
  43. Get free boats here
  44. Cooling inlets/outlets
  45. Does a 20S-capable ESC exist?
  46. What have i done?
  47. Anyone with experience with this 180a speed control?
  48. Vortex Hydro, or Vac-u-Pickle?
  49. Noob question...Pond size
  50. N1 Mono Questions
  51. Running in Alabama?
  52. Bby micro hydro 50+
  53. hardware layout
  54. Help programming new ESC - Hextronik HXT120
  55. 1515 Neu motor
  56. 1.1M Cat setup help
  57. Atlas setup help
  58. twin drive mono?
  59. Zippy-R Lipos- 4500mah 3S 21-32C
  60. AMPS, how to figure them?
  61. oval master BBY
  62. Oldie turned newbie in FE
  63. Quick driveshaft question
  64. renegade rigger battery?
  65. Twins with single drive?
  66. Kids and the 2009 Nationals
  67. Motor Torque
  68. How Good Are the 50 Series Hacker Motors?
  69. rudder help
  70. Quick 8xl question
  71. Y-harness max length- ATTENTION!
  72. DF Vortex is in. YAY. Dumb question though
  73. Paint??
  74. what motor mount for kb 45
  75. Cat skipping
  76. So close!...Help
  77. screwed up prop
  78. Servicing a BL motor
  79. Center of Gravity
  80. Unique hydro design
  81. BBY Micro Scat Cat SAWS record holder
  82. 2 ul-1 motors and esc's in 30' cat
  83. a bunch of questions
  84. Motor question
  85. Question: motor and esc amp
  86. Having trouble with new Hextronik 120A ESC
  87. Sickest FE boat ever !!!
  88. Thanks! Fine tuning help...
  89. Traxxas?! WTF?!
  90. Vee hull features.
  91. Hatch tape ?
  92. DF Vortex
  93. Anyone have a Prather Lap Cat I?
  94. Contra-rotating props
  95. KX860024A 650L Brushless Moto
  96. brushed vs. brushless esc
  97. Power Loss?
  98. add sound?
  99. Xzess III Evo Mr. Krabs
  100. quick help...
  101. Running your Lipos in series or parallel?
  102. Prop Movement??
  103. Would it work...?
  104. Anyone actually running 6s through a hydra 120?
  105. Running 1s lipo is now possible
  106. Fine Design Racing
  107. Diode question
  108. Ovalmaster 26 cg?
  109. Very frusterating...
  110. It's Alive!! Pic's included!!
  111. Data Analysis
  112. What other RC do you guys run?
  113. VS1 with UL-1 FE...Looking to see what run times people are getting
  114. Need help with a 45amp Aquacraft esc.
  115. A beautiful boat
  116. Propeller work
  117. silicone for waterproofing?
  118. What's your opinion on my prososed setup?
  119. Strut size??
  120. Bullet connectors...best way to install them.
  121. Memorial Day
  122. HELP! Minicat: Velocity Mono - Flex cable size and length?
  123. What Lipos
  124. How do I convert pitch of a Grim prop?
  125. Safe to update my older version CC ESC's?
  126. transom to prop distance (cats)
  127. MAH and 1p 2p Question
  128. new boat, imex company
  129. Nice Bud Select cat
  130. Lipo ballancing
  131. Fiberglass/Carbon Fiber hulls?
  132. A-Z Racing, Mach/1 Hydro?
  133. Hey all you mono experts
  134. trrouble with hydra 120 need help
  135. Set Up questions??
  136. start up problem
  137. motor question.....
  138. Twisted drive line
  139. Lehner Brushless question?
  140. Motor mount/coupler/tube holder combo
  141. 580L 7turn in 37" Mono..need ESC and lipo cell suggestions.
  142. Maximum RPM's on Ammo Motors?
  143. Soldering batts together??
  144. Mini C vs mini rio
  145. Motor Timing - Anyone know?
  146. CC Hydra 120 problems I think?
  147. Hydro SAW problems
  148. spring time
  149. 1/10 Scale Hydro rules
  150. Hydra 120
  151. Twin wing Hydros
  152. wire length questions...
  153. A lipo's amp rating ability question
  154. Hughey vs. Octura Flex
  155. soldering melting problem
  156. ETT[ 150 setup
  157. First run, what to look for- temps, props, ect.
  158. cooling question ?
  159. Prop question
  160. 2 blade vs. 3 blade...
  161. coupler set screw size ??
  162. Phill thomas sport 20 hull
  163. Pictures of Bottom of H&M Micro Maritmo?
  164. Prop Box?
  165. 39 mph out of my Titan 29..What am I doing wrong???
  166. Renagade Rigger
  167. Lipo Shield problem?
  168. Bilge Pump?
  169. Problem with Etti150
  170. motor question
  171. What CC 240 LV timing for 1521 1.5D ?
  172. FaceBook
  173. First run went pretty well!! (more pics too)
  174. Proper Feigao 8XL motor timing in Titan 29
  175. 14xl 8s MM data log
  176. Minicatracing Hydro Turn Fin...
  177. Cheap LiPos
  178. Paint
  179. rudders
  180. What foam do you use in your hulls?
  181. Noob questions about what motor/esc combo
  182. Rudder placement on Hydros & riggers?
  183. Mixing brands of Lipos
  184. Help Needed Outboard & Mono
  185. feiago 580L
  186. Hi-model 200 amp 8s problems
  187. COG For a 41" Cat
  188. Prop for SS1 on 4S lipos ?
  189. Rigger Sponson Angles From Side to Side? Not AOA.
  190. THIS is the neatest thing since sliced bread
  191. Charging Lipo's with an MRC Super Brain 977...
  192. rio51
  193. Vibration found, motor/cable coupler...
  194. Australian Built Super Sport 45
  195. How many times to cycle new lipos?
  196. Where do the Unlimted and Limited numbers come from?
  197. graupner sx4000
  198. Is it a submarine? Is it a Hydro? Is it a cat? You decide
  199. brushless timing ?
  200. Oct.V/937-3 935- qUeStIoN!!
  201. wiring an on/off switch
  202. ESC Connections
  203. eBay Hydro Build
  204. Anyone notice this??
  205. Hyperion duo ii firmware update question..................
  206. Out of the box thinking.
  207. Esc arming on my apparition
  208. Saw hydro wieght
  209. 600 sized heli motor
  210. Lipo Batteries
  211. Parallel Charging
  212. MM & an X645
  213. Need help with prop choice
  214. What esc is water proof and water cooled?
  215. Solder for lipo tabs....Help
  216. DF 29 setup
  217. traxxas villain
  218. cog for a micro hydro?
  219. New neu motor endbell grubscrews
  220. what is your favorite soldering station?
  221. soldering capacitors
  222. 32" eBay Mono
  223. FUNNY VIDEO of gas mono!
  224. POLL: Chinese 32" Cat sponsons angle
  225. What GPS are you guys running?
  226. is my Hydra 120 fried??
  227. Which is better SV27 or Blackjack motor?
  228. Which will take more AMPS
  229. CMD CNC props
  230. ID size on a strut for 316 cablet?
  231. Temp gauge?
  232. Check out this Hydro.
  233. Water Pickup on Eco Hull?
  234. 1/8 scale kits
  235. RTR versus build your own
  236. Prop Chart Calculator
  237. NEWS! EOS NET3 and DUO3 Released June 1st 2009!
  238. WooHoo Lipoly is now obsolete
  239. Power seriously drops after 30 or so seconds.
  240. Motor selection help.
  241. hydrolift 1100
  242. Feigao 380 8L...
  243. parallel charging
  244. What timing settings for an Ammo 36-50-2300?
  245. What is going on with my Neu motors?
  246. Thrust bearings Need Help
  247. How To Repair Hull Damage ?
  248. Teflon liner
  249. 700 motor to gtx800 o/b
  250. Cavatation??
