- .062 wire drive ques
- 36 40 ammo motor in micro drifter?
- swapped to a 12XL
- proboat 1/12 setup suggestions
- prop advice for my drifter cat
- super hawaii mod or sell
- Its up to us to police ourselves.
- Fiegao 380 shaft size problem
- laser cutting
- high voltage/low voltage systems
- Hydro & Marine Agitator Catamaran
- How often do you grease the flexshaft?
- Different wire guages bad?
- Prop Finishing
- Team Tekin Products and Support Q&A
- Catamaran Flex Drive
- Catamaran Tunning
- RC Lipos
- Under Attack
- Thanks for the help! And a favor to ask......
- After Valdosta
- 29" skunkworks vee hull
- Hardware question
- Ebay buy
- Electric Riggers Video
- Delta Force 33" Speed Run Video
- Geardrive Lube??
- Dean,s Plug
- RRR down again!!??!!
- RRR, OSE and other forums
- What kind of Boat... & Brushless Motor...
- Help & Info please
- 7XL Brushless 2370KV Marine motor and hydro 240 ESC..
- Viper videos
- looking to build a new cat- need advice
- Balancing plugs in series
- cmdi props
- What is your rc boat video?
- Where did the Solinger Hardware go?
- Graupner U-Joint Trouble
- Found Some Specifications on All Kinds of Motors, ESC, Servos
- Equipment for new Jolly Cat from OSE
- Steven Help with order
- RC boat graphics.
- micro drifter problems
- classic shovelnose prop Q
- Cat question?
- Speed Master 21 strut and rudder ???
- cordite ss1 in sv
- HELP me choose propeller for cat.
- Thank You Tony Heller (aka: ProperChopper)
- flex and collet
- When blue printing your hull.........
- lipo getting hot/ loss of power
- crystals
- stock class ques
- Good Plans
- OSE welcomes Diegoboy.......
- Delta Force 29 shopping list
- "Fried" AQ esc
- 22" stepped hull mono El Lobo II setup
- M1 supercat fun
- ESC problem??
- Anyone running a mystery 200A ESC on 6S?
- Neu motor water jacket
- RRR has been hit again
- Raider Hydro Feedback
- Aquacraft Hammer BL
- New Hydro
- LA Saws
- Diver Down
- Best mono in class
- error message: balance cell voltage to low
- Mystery and Himodel ESC
- Aquacraft Motor
- Congratulation Darin !
- Feigao Motor Spec Info
- Darin's thread is open for on topic conversations. Please read.
- Big cat
- need help with an HXT 120amp ESC
- cooling things down
- Mine is bigger then yours...
- Prop help
- Batteries no long have a punch
- LA Saws
- REK Aluminum Coupler Supplier??
- Hyperion esc's
- Swissmodelpowerboast - Rudder
- Venom Killer Vee
- Decals and Paint
- Neu batteries?
- Turborix ESC programming?
- Wnter Project
- Parallel packs mha difference ?
- Strange noise from esc, motor
- Post up best U-boat pics
- which hardware for a 29" mono?
- FeCalc equipment txt file
- adjustable motor mount question
- AquaCraft VS1 Tunnel
- Proud new papa...........
- lipo heating on the cheap
- Do Lipo's need break in?
- CA NOV 2nd SAW
- Guys from hotmbc look here
- Smarty Pants
- Interesting Rigger
- TS2 weight
- Lipo info & comparison
- Paula III
- NiMh question
- Aquajet resting
- What is your favorite brand of Rattle can paint?
- Power for a 21" mono?
- Prathers number?
- look what just got here !
- Twin motor wiring
- OHHHH STEVEN>>>>> can you find out more about this esc?
- Balance Pro
- jeti 600 question
- battery charge
- FYI - New Hyperion DUO2 now available at multiple sites
- choosing a lower unit for the VS=-1
- Is anyone familiar with this Sea Drifter hydro?
- anybody seen this
- Lipo winter storage questions
- Hydrolift 1100
- To use turn fins or not...
- So which well known hobbiest built this ebay find?
- Forum clean up and organiing
- chargers
- Anyone see this yet??
- Graupner motors
- feigo 9xl in tunnel
- Thinking of turning an older Aeromarine tunnel hull into a cat
- lubrication question
- watt meter
- Motor mount for KB45 XL
- Twin hydra marine maritiamo cat
- Graupner SX4000 - finally here!
- Link to ETTI website
- Vacu Pickle motor mount
- Rc4wd gru 2:1, 3:1, 4:1
- Aveox and Hackar motors
- Was anyone aware?
- Hyperion Duo firmware update
- Brushless Avenger/ Spider Help
- any body notice the off set on the ts2?
- Does your wife know how much you spend on your FE boats?
- suggestions on removing silicone
- 2 or 3 blades
- HELP with Hitex Aggressor Srx Tx
- FE whiplash owners/builders
- Teflon liner won't slide into stuff tube
- Very good info
- Lipo Low Voltage Cutoff device
- FeCalc - Feigao motors
- Thank You Steven
- Lipo Questions
- Deans Ultra Y harness
- Just a pipe dream....
- Mhz usa
- Feigao w SV/ BJ controls
- Speedmaster Strut Installation
- Top Speed 2 Center Of Gravity
- Burned up speedcontrols
- Flex or wire for Mean Machine
- Hundreds of cycles?
- Self-Righting Hulls
- Hatch tape
- SALE 10% Off entire order when you purchase a Neu motor.
- Eagle Tree 10% Mail in Rebates
- help with prop size
- 2009 Az WW V race taking shape
- Soldering 5,5mm Bullet connectors
- A Graupner 820 BB Turbo Race
- Hull Attitude changes
- strut level question
- Aquacraft EP1 outboard motor
- High Charge
- Flex shaft question
- Mega rc motors?
- Speedfreek sport hydro video
- Sad day for Rc FE boaters and anyone that knew him....
- Mamba Monster Speedo?
- Kids and boats
- what prop to use
- how to adjust the prop angle?
- Does anyone use AAA's for BEC?
- Raider Hydro Question
- Where can I find this turn fin?
- Need help Weight questions?????
- Eagle Tree GPS on sale!
- DF33 and 1515 1y, what prop
- 2009 could be a tough year for R/C boat racing
- Speed Control...Fail Safe?
- HiModel 4s-8s 200 amp esc
- Rigger turn fins
- Who's seen this Canard? Earthrace
- ESC blow ups
- IB Lipo's
- lipo question
- Elite 30c and 35c Lipo's
- hardwere Q
- Brushed motor items
- Sport 40 power, opinion's wanted
- Tunnel Hull & Outboard
- Balance Taps?
- Lipo's 2s2p vs. 2s1p
- Ebay boat
- Xmas
- Running boat in cold temp?
- The good ole days....
- Windscreen template
- Chargers
- HPR06 or H&M Bandit-M. Which hull, what material ?
- AOA question for the rigger experts
- Lipo storage
- What Prop ?
- Elam and UL-1 comparison pictures.
- Water jacket for 580L ?
- Merry christmas
- 35-38" Wingless Hydros For a Neu 1527?
- p1 arpro
- Lipo Capacities
- Wishes and suggestion
- Lipo Weight
- Dremel???
- Lipo/NiMH equivalent
- merry christmas
- Prop Tuning For Performance
- So much for X-mas '08
- Minimum mAh
- It's the water........and a lot more
- DF 33 Correct rudder length
- Ripple Current
- Would any of you guys be interested in this.....
- Apogee users
- Tony's VS1
- Brush cooling
- How to clean ESC burn mess
- Charging lead acid?
- 1/8 scale hydro brushless setup
- Using balance leads for power?
- Decals
- Lipo Labeling, Connections and Taps
- scale motors
- Titan 29 vs. Delta Force 29 or 33
- No Spark Calculator
- 2009 Gary Johnson Grand Prix Classic - FE Welcome
