View Full Version : Items for Sale
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69
  1. Dynamite 50A Brushed ESC (DYNM3825) (x2)
  2. Brushed Marine ESC - 30A
  3. 2 Posieden 1515 2200kv motors
  4. 2lb Urethane Foam for Flotation
  5. 2 TP 4050 1700kv, 2 180amp esc, 2 cr 7.5 DRIVES with cowls
  6. MBoatworks PX300 For sale
  7. Vans Racing Warhead 33" OPC Tunnel hull
  8. V-cat prototype hull (hull only; painted; newer edition)
  9. Brand new 2x Dynamite 2000kv and 120 amp
  10. rtr traxxas spartan
  11. TFL Mini Zonda 27" All Carbon Fiber Catamaran
  12. 32 Pursuit Mono
  13. Wooden mono boat
  14. F.S Garmin Forerunner 201
  15. F.S.Garmin ETREX H GPS
  16. F/S: Castle Creations Hydra HV 240 ESC (New out of box)
  17. Fs, neu 1521 and CASTLE MM W/bec
  18. Toys’Port Triton Edition 32" stepped Mono
  19. wanted :magnetic prop balancer
  20. race prepped 1815/17*
  21. Daytona fighter cat
  22. Swordfish pro esc 200 amp
  23. 1714/17* set & 1916/17* set for sale Finished
  24. Free micro servos
  25. Looking for .312 ID black fiberglass tubing
  26. Spektrum DX4C transmitter, like new
  27. Speedmaster dual pickup tapered rudder
  28. New Motors for sale
  29. F.s. Zr48 corvette hull vinyl badges
  30. F.s. Robbe navigation light set
  31. F.s. Hor stuffing tube mount
  32. F.s. Ac250 cable/prop savers
  33. F.s hughey flex cables/prop shafts 30" standard and reverse hardened lot of 4
  34. Baby sv43
  35. 36 inch aeromarine team believer. castle neu 1527 swordfish 300 amp lite
  36. New Swordfish Pro+ II 240A ESE
  37. Octura 447 c/r set
  38. Spartan for sale
  39. 2 Neu 1527 1.5 D Motors 8mm + HRC Cooling Cans $500
  40. Hifei Swordfish Pro+ II High Voltage, 240 amp ESC with Water Cooling and Data Logging
  41. Various Props
  42. 2 TP 4050's with Cooling Cans
  43. Big TP Motors
  44. swordfish pro 300 lite esc with data logging (new) castle neu 1527 1250 kv hrc mounts
  45. KBB / Radtek 45
  46. Motley crew
  47. HPR 06 Bulletproof Hull and Hardware
  48. Plettenberg Motor HP 370 BM A1 "S" - Top of the line 10s Motors For sale Pair: $650
  49. 600 size OutRunner Fighter Cat. $25 plus shipping CONUSA
  50. Brand New Fightercat Racing 200 amp 3-16s HV esc For Boat. Never used but fired up.
  51. MHZ Z-drive
  52. Solinger Hardware Mono and Hydro
  53. Johnson HC970 Motors
  54. Lehner LMT 2260LK 8 Wind (1233kv) 8mm with Cooling Can
  55. Motley crew with tacon motor
  56. Little screamers 650kv outrunner
  57. F.S. HPR233 or RADTEK 92 WINDSCREEN AND CARBON FRAME
  58. 2 Spektrum DX2E transmitters
  59. Traxxas 2056 & 2075 servos
  60. Two 3s,60-120C, 4000mAh Turnigy HD LiPo's
  61. Two Giant Power 2s, 65-130C, 6000mAh LiPo's
  62. Proboat Shockwave 26 V3 - lots of upgrades
  63. Flycolor 150amp ESC 2-6s
  64. castle neu 1527 1250kv double sided hrc 5 inch mounts jacket and collet
  65. Hyperion EOSO610i duo
  66. Hyperion EOS 0720i net3 charger
  67. For sale Daytona carbon hull
  68. Garmin eTrex 10
  69. F.s. Hughey flex cables 30" long, .250 stepdown to 3/16 hardened std. & rev. Pair
  70. F.s. Hughey flex cables 30" long, .250 stepdown to 3/16 hardened rev. Lay
  71. For Sale Black Pearl V.5
  72. 1:10 Scale 1955 Gale V For Sale!
  73. great hobbies 6s 5000 mah lipo 35c
  74. Used twice servos
  75. Jet pump, Aquacraft Revolt 1800kv motor, ESC and Eagle Tree sensors
  76. Octura small bronze strut with extension and rudder moved to the rear servo, mount
  77. NEW Aqua 1800kv motors, NEW Castle ESC, USED Seaking ESC w/box, Aqua trim tabs
  78. NEW Stater w/ belt, Gen IV Flow meter 2 motors for setting needle valves Nitro or Gas
  79. HPR 115 mystic style cat
  80. F.S. HPR233 or RADTEK 92 4MM CARBON BULKHEAD REINFORCEMENT
  81. ARTR AquaCraft SV27 Box Stock and GrimRacer Batteries
  82. F.S. `AEROMARINE TITAN' ARTR w/Hardware
  83. F.S. New `ETTI & SCHULZE HV ESC CAP SETS'
  84. F.S. SHOLUND PROPS Pro-Sharpened/Balanced/Polished
  85. 2 seaking 120 amp 2 to 6 cell speed controllers they have gold conn
  86. Nw traxxas 5000mah 3-cell lipos and charger
  87. UL1 new motors 2 45,99 each. 2 seaking esc 120 amp 2 to 6 cells used onlt 15 m
  88. Spektrum DX4S transmitter, excellent condition
  89. Spektrum receivers
  90. baby scat cat for sale
  91. 6s 5000 mah lipo 35c ... $65 great shape !!
  92. 1 UL1 motorAQucraft
  93. Aquacraft Atlantic Harbor Tug, new in box
  94. duratrax onyx 245 lipo charger
  95. Misc. parts
  96. Tiapan 6S rigger
  97. Toys’Port Syncron 28" P-Mono with used Kontronk motor
  98. For the multirotor flyers here 1300mm octo and 1000mm hex
  99. Octura x457's for twins (left and right, for 3/16 shaft, new in the packages)
  100. Octura x442's for twins (left and right, for 3/16 shaft, new in the packages)
  101. Pro Boat 40mm stainless prop's (PRB4019)
  102. 68.5mm Venom Prop
  103. Exceed Racing 28" mono, modified...
  104. Fightercat Shocker
  105. Props for Twin setups
  106. TLR Losi 1/5 Scale 5ive-B Brushless Conversion, MGM Cars ESC's, Spektrum 1/5 Servos,
  107. NON-WORKING Seaking 180 V2 ESC...?
  108. HPR 135 for Sale RTR
  109. Spektrum DX4R Pro transmitter
  110. Spektrum DSM & DSMR 3 and 4 channel receivers
  111. Mini Cat Racing Micro Hydro Generation I
  112. New Pro Boat Recoil 17"
  113. Aeromarine Titan 29 Hull, Hardware and Motor
  114. Aquacraft VS1
  115. New (open box) pair of Seaking 180v3's with Programming card
  116. Brushed Speed Controls
  117. New OSE outboard lower unit
  118. Octura props from X427 to X452/3
  119. Toys’Port 35" Jolly Catamaran
  120. For Sale or Trade KMD EVO 2 MERLIN
  121. ABC 1814 & 1815 sets available for sale
  122. Orion 80a 3-4s brushless esc. NEW.
  123. Hitec X4 AC Plus 4-port AC/DC multi-charger 44167
  124. AquaCraft Motley Crew RTR
  125. FS New White Revolt 30
  126. 1/5 Scale Brushless Cars- MCD's, Losi and more....
  127. ESC Swordfish Pro II 240A 4-12s
  128. F.s. Contour gps action camera
  129. Propellers For Sale - Octura 3/16"
  130. Aquacraft UL-1 Superior FE Hydro RTR BRAND NEW
  131. F.S. 'Astro Flight SUPER WHATT METER' final clearance sale!!!
  132. F.S. 'AEO KV/RPM METER' Final Clearance Sale!!!
  133. F.S. 'MHZ/ETTI ESC WATER-COOLING BLOCKS' Final Clearance Sale!!!
  134. F.S. 'FDM GEAR DRIVE SETS LOT' Final Clearance Sale!!!
  135. F.S. 'FDM Mono TURN FINS SET' Final Clearance Sale!!!
  136. F.S. 'FDM Mono Blue TURN FIN & TABS SET' Final Clearance Sale!!!
  137. F.S. 'OSE Mono TURN FIN SETs' Final Clearance Sale!!!
  138. F.S. 'Team Pirate MONO TRIM TAB SETs' Final Clearance Sale!!!
  139. F.S. 'OSE WATER-COOLED MOTOR MOUNT SETS ' Final Clearance Sale!!!
  140. F.S. 'ETTI MOTOR MOUNT SETS ' Final Clearance Sale!!!
  141. F.S. 'FDM Mono INLINE STRUT/RUDDER ASSEMBLY' Final Clearance Sale!!!
  142. F.S. `FlexShaft LUBE FITTINGs, EASY BAILERS & OCTURA Brass WATER PICKUPS'!!!
  143. F.S. HRC `MOTOR MOUNT' 36mm ,1" Spacing, 3" Rails Final Clearance Sale
  144. F.S. New `Machined Aluminum WATER PICKUPS'!!! Final Clearance Sale !!!
  145. Traxxas Spartan - modified & upgraded 36" deep V
  146. 32" Carbon Fiber Apparition RTR
  147. F/S: Castle Creations Hydra 240
  148. F/S: Q Sport/Sport 40 Hydro Hardware....
  149. F/S: Virginia Craftsman Sport 40 Turn Fin....
  150. F/S: Virginia Craftsman Sport 20 Turn Fin and Bracket...
  151. Thunder Power Rampage 4s and 6s 5000 and Lehner 3060/14
  152. Pro Boat Zelos 48
  153. Pro Boat Voracity 36
  154. For Sale NEW Futaba Rx R603FS
  155. Jet pump, Aquacraft Revolt 1800kv motor, ESC and Eagle Tree data logger plus sensors
  156. New Octure strut, Etti motor mount, 452-3 prop and cable, Astro Blinky, Traxxas 2075
  157. F.S. NEW 'FEIGAO 6L & 8S BL Motors' FINAL CLEARANCE SALE!!!
  158. All new wire Connectors 4s, 6s, and 8's
  159. New Castle Link & cable, New Castle Arm Lock, 2-6 lipo low voltage buzzers, mics caps
  160. FS JAE .12 turn fin, 5.5mm spark elim, 2-6 batt balancer misc H20 etc
  161. For Sale 12 Octura Props, 4 JG props and 2 unmarked
  162. Pro Boat DYNM3900, 2000kv motor and 30Amp ESC (from Shockwave)
  163. 3/16" Props for sale
  164. Spektrum DX6R Transmitter Case SPM6719
  165. (2) Tenshock 6-Pole Motors
  166. Thick Wall Silicone Tubing
  167. FS Bingo Eco Self Righting
  168. FS 28 Inch 4S 1/12th Scale Hydro
  169. FS Micro Hydro Oberto
  170. F/S 50" Aeromarine Cat
  171. Three Boats for Sale
  172. 92" Radek - HPR 2.33m Catamaran carbon hull and hardware new must sell!!
  173. Motor and parts
  174. Brushless motors and esc ....
  175. Atomik Barbwire XL 24 w/ upgrades
  176. Aeromarine Jersey Skiff for sale
  177. Sss 3660 1620kv
  178. 2ea Seaking 180A -V3 and Hobby Wing program card-b
  179. TP Power 4060,s V2 6D-1650W 2 each
  180. TP power 2ea 4060-V2 4d-2450/w
  181. Used Lehner 3060/14
  182. NIB Neu 1530 1.5D (1355kv) 8mm shaft with water jacket.
  183. Prather Lap Cat II/ 1500kv Electric conversion
  184. Two new Seaking 180A V3 ESC's, plus program card
  185. RTR Carbon Reinforced TFL Cheetah Catamaran $450
  186. River Jet Boat 23" RTR $265
  187. AquaCraft Cajun Commander Brushless RTR $185
  188. Dumas Scarab 40 Miami Vice w/ Amps Speedmaster Outdrive- Mint!!
  189. Tp motors
  190. For sale: Etti demon rigger rtr
  191. For Sale 2ea Turnigy nano-tech- tech 5.0
  192. 2 MR3000 & 2 MR200 for sale
  193. For Sale 41" Zonda R
  194. Miss Budweiser Original, EV converted, Carbon reinforced
  195. (3) SSS Brushless Motors 36mm
  196. 8 Neu Motors for sale! 1515's, 1518's, 1521's and 1527's
  197. F/S Lehner 2280 12T
  198. F/S Aquacraft 2030KV Motor
  199. F/S Motor Couplers (3)
  200. F/S TFL Rudder
  201. F/S Seaking T180 V2 - Not Working
  202. F/S EagleTree V3 Datalogger 150 amp
  203. F/S Octura Props 3/16" Shaft 40mm - 45mm
  204. F/S Prather Props - 3/16" shaft
  205. F/S CNC Prop and Proboat Prop - 3/16" shaft
  206. F/S Turnigy A-Spec 2s 6600 mah packs 65-120C rating
  207. Executone 1/8th scale
  208. King of Shaves - Hatch wanted OR sell for parts
  209. Three NEU Brushless Motors For Sale
  210. Castle 1515/1Y motor For Sale
  211. Aeromarine Avenger 36"
  212. Castle Phoenix ICE 200 controllers $120
  213. aquacraft 3656 1800
  214. New in Box Schulze 40.333WK
  215. F/S Leopard 36mm cooling can
  216. ESC Schulze 40.161wk
  217. Motors for sale
  218. F/S Mean Machine Catamaran w/ different options
  219. Revo and Venom 3S batteries
  220. Spektrum DX4S DSMR transmitter, DSM compatible
  221. 4x HRB 3S 50C 5000mAh lipo batteries
  222. Sicrc jet boat
  223. KV/RPM Checker
  224. Like New Impulse 31 with a LOT of Extras For a Great Price 400.00 Local Pickup NC
  225. F/S JetChopper 30 Mono Setup
  226. F/S FIne Design 32" Deep-V Boat RTR
  227. F/S Octura X440/3 blade
  228. F/S Octura M447
  229. Z-drive MHZ set
  230. Pro boat zelos 36
  231. Blacklack 29"
  232. 3 brushless boats great deal!
  233. Insane FE 30 RTR
  234. Popeye hydro for sale
  235. Neu Motor - 1410/2Y/S/5MM
  236. Nib Turnigy 180a v3 with extra caps $100 shipped
  237. Neu Motor - 1409/2Y/S/5MM
  238. Neu Motor - 1415/1Y/S/5MM
  239. Propbox 60 and s&b props
  240. Props and propbox 60 for sale
  241. Castle 2028 & HRC Cooling Can
  242. Seaking 120a V2 ESC
  243. 2 Seaking 60A v2 ESC
  244. MHZ Medium Trimax Drive with 1/4" shaft
  245. Brand new lipo's
  246. (2) Tenshock 6-Pole Motors EZ 2230/1690kv
  247. (2) Tenshock 6-Pole Motors EZ 2230/2020kv
  248. Dasboata ABC 1914 prop
  249. Cheetah Boat For Sale
  250. FS SR210 Recievers, flex shaft, Couplers
