View Full Version : Items for Sale
- Leopard 4074 /2200 kv and 4082 /2200kv Lightly used WTS
- spektrum dx2e&srs4201 avc rx
- 26" All Carbon Fiber Delta Force Mono
- 26" All Carbon Rocket Mono
- Castle Hydra Ice HV200A ESC FOR SALE
- Atomik Whiplash24
- 2 Dynamite 3630 1500kv
- ProBoat Stealthwake
- Twin scatcat from rc-raceboats shop
- ALMOST New TFL Pursuit ARTR with One-Drive
- 60" mti carbon hv setup twin
- VS-1 tunnel hull w/ scale outboard - for sale
- 2 Leopard motors
- Used Schulze 24.150
- New X447 L & R set cut to 45mm Zelos
- Revolectrix 5000mah Lipo : Blend420 SILVER Label 70C : Graphene Oxide Hard Carbon
- Set of 4 Dinogy Graphene 2.0, 3S 70C 5000mah
- Set of 4 New never used GiantPower 3s, 5000mah- 65c-130c burst lipos.
- ProBoat Shockwave 26 Brushless
- 33.5" DYMotorshop Carbon/Kevlar P-Mono Package
- Trade neu 1521/1557 kv ???
- Direction of twin motor setup
- Extra props sale, Dasboata, octura, sharp/balanced
- Brand New VisionCraft 3.5 OPC Tunnel hull
- Octura Twin Drive Strudder
- Spartan Rudder with dual water pickups.
- Proboat Voracity 70+ mph upgrade kit
- 1M Osprey, 32" Pursuit, 26" Bling rocket & more $700
- New Leopard 4092 1730kv motor with 50mm water jacket
- KEPs 4SL Rigger
- NEW Proboat Thundercat 31 (TC31) Replacement Hull with some mods
- Hydra ice 240, mr200, pro boat motors, leopard 2860, savox
- trade: like new nitro starter for a prop balancer
- New Pro Boat Voracity RTR
- Lehner 3080/8
- Buyers and Sellers please rate each other using the "Itrader" function.
- prop and collets
- brushless 2200kv outrunner new
- JAE mini rigger, modified
- TFL intagrated drive
- Tenshock motor
- Twin mean machine 2 - artr
- New, unopened GoPro Hero5 Black
- 8mm Castle bullet conn. and #8 ga. wire
- Expresscraft 58" Thundercat ARTR
- 32 inch f/g mono self righting full hardwar
- Proboat Voracity E 36" hull
- Dynamite 3935 1650kv 6 pole motor
- F/S: Octura X447's cut to 42mm
- NEU Motors - Brand New - KBB Spec Swordfish ESC
- 2 Swordfish 300amp pro plus esc
- SSS Motor - Turnigy 120 amp ESC - 2.4 Ghz Radio
- FS: X447's-counter rotating set
- Turnigy heavy duty 4000mah 3S lipos (4)
- Wooden v-cat prototype
- 1040 esc
- Proboat Classic Runabout rtr
- Carbon Fiber Cheetah Catamaran
- Capricorn large scale outdrives !! New !!
- 2 Castle ESC Ice Hydra 240
- 2 Neu Motor 1527 /1y/S/8mm
- FS: Leopard 4082
- FS: Turnigy 180 amp esc
- ESCs for Sale - Turnigy 180 Amp ESC and Seaking 130 Amp ESC
- F.S. 'LEHNER BL Motors' FINAL CLEARANCE SALE!!!
- F.S. 'SCORPION Outrunner BL Motors' FINAL CLEARANCE SALE!!!
- F.S. 'BLACKJACK 3630 BL Motors w/HRC Cooler' FINAL CLEARANCE SALE!!!
- F.S. 'Genuine HACKER BL Motors' FINAL CLEARANCE SALE!!!
- F.S. NEW 'FEIGAO BL Motors' FINAL CLEARANCE SALE!!!
- F.S. NEW 'AQUACRAFT 3656 BL Motors' FINAL CLEARANCE SALE!!!
- F.S. NEW/USED 'NEMESIS BL Motors' FINAL CLEARANCE SALE!!!
- F.S. NEW `HRC COOLING JACKETS' 540, 580, 1500 seriesFINAL CLEARANCE SALE!!!
- F.S NEW. 'HRC 1500 Series MOTOR MOUNT' for 5" Rails, FINAL CLEARANCE SALE!!!
- F/S ABC Propeller
- ABC prop for sale 2215-17-45 for larger boats
- new leopard 4092/1050/kv
- F.S. NEW MIB FUTABA FASST 2.4 Ghz 3PM Tx & (4) R603FS Rxs `FINAL CLEARANCE'
- Fs: dynamite quad charger
- K.R.Joye feedback
- F.S. iCharger 4010 Duo Progressive R/C Paraboards Solid Hobby power supply
- F.S. Revolectrix 7s 70c 5500 Silver Label
- F.S. 2 (two) MGM TMM 40063-3 X2 SPEED CONTROLLERS
- Twin motor custom mono boat
- Turnigy heavy duty lipos: 4S (4) and 6S (1)
- F.S. 'Aeromarine 3/16" SHAFT LUBE FITTINGs' FINAL CLEARANCE SALE!!!
- F.S. 'GRAUPNER K-Series CARBON PROPS LOT' for 3/16" Shaft, FINAL CLEARANCE SALE!!!
- F.S. 'Hitec RANGER II MICRO-SUBMARINE' FINAL CLEARANCE SALE!!!
- Leo and turnigy motors
- FS: (2)-Turnigy 180 amp esc's
- Garmin eTrex 10
- UL! aqua craft with sea king 120 amp esc new 2 for sale
- c/c 1515 1Y 2200 kv with 180 amp seaking will condecer bank
- aqua craft UL1 Motor new
- Turnigy motors XK3674 - 1650KV
- F.S 2(TWO) VENOM 5000mah 50C 18.5 VOLT
- F.S 1(ONE) THUNDER POWER TP100 540kv NEW
- 37" Carbon Genisis hull
- For sale 4 motors leopard and one neu castle
- SSS 4-Pole Brushless Motors - 3660-1968KV, 3660-1500KV, 3650-1968
- Neu 1410-2Y 1850KV 4-Pole Brushless Motor
- Leopard LBP3650-1840KV 4-Pole Brushless Motor
- TP 3620-8Y 1970KV Brushless Motor
- TP3630-3Y 3480KV 4-Pole Brushless Motor
- Leopard Hobby LBP3660-1900KV 4-Pole Brushless Motor
- Phantom 3 Professional
- FREE - 3 Parkzone/E-Flight Single 1S UMX/Nano-Heli Battery Chargers
- Pro Boat Voracity
- F.s. (2) lehner lmt 3080lk 5 wind
- F.S (2)Hifei Capacitor Banks with connections for running Parallel battery packs
- THUNDER POWER 2100mAh 2-Cell/2S 7.4V ProLite + Power 25C LiPo
- Leopard 4082 1600kv motors with ceramic bearings
- SSS 3660-1500KV 4-Pole Brushless Motor - NEARLY New!
- SSS 3650-1968KV 4-Pole Brushless Motor - NEARLY New!
- Vision Craft Race Boats 3.5 Tunnel Hull - NEW, UNDRILLED
- 22" WildThing Mono ALL Carbon Fiber Time-Trial Boat - ARTR
- F.S. SAVOX 1270TG High Torque High Voltage Digital Servo
- F.F. SKYRC Super BEC 3-14S LiPo
- F.s. Racers edge glitch buster capacitor
- 2 Swordfish 300A lite ESC's - waterproofed
- Two JAE P 4S Hydros for sale
- Swordfish SF240 HV
- Fightercat Daytona 37" Fiberglass hull w/Carbon inlay and Mounts
- Castle 2028 780kv
- (3) Used Aquacraft Motor
- TP 4050 3Y-2050kv Motor
- TP 4070 3Y-1440kv Motor
- AIRTRONICS AIR92724 2.4Ghz 4-Channel RX - M8/M11
- MISC Servos: Zelos 48, IM31, SAVOX Digital
- Hitec Servos: HS-755MG, HS-5645MG, HS-5245MG, HS-225MG, HS-81
- 1/10th Scale ABS Vacuum Formed Wing Set
- Castle 1415 and leopard sensored motor
- 2 Octura balanced and sharpened props
- 3/16 cables (2 pairs, counter-rotating)
- LARGE Digital Hi-Torque Servo - Pro Boat Zelos 48 S904 1/6 Scale WB Digital Servo
- Hobbywing / Seaking 180A ESC V3
- several escs F/S
- 120 amp s/f esc
- power supply
- Giant Power 2S 6500 mAh 65C-130C (Pair)
- Vcat wooden prototype
- Upgraded Motley Crew Boat for Sale
- For sale etti demon rigger
- Lehner LMT 2260/4 High Amp LK New with watercooler
- 5 in 1 battery charging leads
- C/F TFL Popeye Hydroplane
- C/F TFL Apparition Catamaran
- Server power supply and Turnigy Mega 400W charger
- HK Quanum GPS Logger V2
- New old FighterCat 240amp SC
- Two used Octura x447's - $15 shipped, each, or $25 shipped for both...
- Spektrum SR201 2CH and HK ORX 3CH Receivers
- servo sale !!
- Proboat Dynamite 6-Pole 2000KV Motor -
- Two, like new, Leopard 4082/2000kv/3D motors with jackets
- 2x Octura 5mm to 3/16 couplers and one Etti 5mm to .150 coupler - $18 shipped for all
- Solinger Hardware x 2
- Raptor Aerosports CARBON 8255 Hydro
- Proboat Shockwave 26
- Props For Sale
- UL-1 Aqua Craft
- Octura x450/3 race prop & 1455
- Like new Dynamite 120A ESC and 1750kw motor Removed from my 1 mnth old Impulse 31V3
- ML Boatworks RSX310 FE Outrigger Hydroplane Kit w/ Cowling and Turn Finl
- 150 amp ESC/Leopard 4074 Motor and other Goodies
- Proboat Zelos Twin 36 hull and canopy
- More Props For Sale
- Misc Paralell Charge leads
- Used Thunder Power G6 Pro Power 65C 2s batteries
- Promarine MTR single
- Tfl cheetah hull and parts
- Leopard 4082 1600 KV and Water Jacket
- Aquacraft Supervee 27
- ESC pulled from Traxxas Spartan
- F/s pair of tp 4050 motors
- F/S New Vortex 24 Hydro
- Fs: garmin 201
- Leopard Motor 3674 1900kv
- YGE 120 Navy V1 and Schulze Future 18.97
- Venom 4S 14.8v 5000mAh 50C
- Smokin' Joe's Avenger twin cat - will separate
- Pro Boat zelos 36 hull
- Aquacraft 60 amp esc
- F.S. FLYSKY iT4 4-CH 2.4ghz Telemetry RC Radio Control Transmitter w/LCD Touch Screen
- SSS 4082 2200kv motors (2)
- Pro boat blackjack 9
- Kyosho Streamliner (RARE) converted to brushless/Octura hardware
- Swordfish escs
- Blade 450X NIB
- Aquacraft 50A ESC for sale
- Hyperion 5s 5400mah...35c For Sale...
- New Aquacraft 60amp ESC
- custom built 1/6667th scale jetcat spm5 turbine powered hydroplane. Built by Peter Mu
- F.s. Fightercat racing vynil logo's and lettering
- tp 4070 cm 8mm shaft 3200kv monster
- Lot of 5 new 20mm-28mm motors In & Outrunners
- 33" c5000 MHZ New
- Sick speed 3 pc kit purple 8mm wire/hose separator divider clamps
- F.s. New prather 245 prop s/s s/b dasboata crafted
- F.s. New octura prop x452/3 b b/s dasboata crafted
- F.S. COPPER REFLECTIONS CARBON FIBER 2X2 TWILL 3K 5.9oz 50"
- F.s. Purple mirage carbon fiber fabric 2x2 twill 3k 8.6oz 100"
- Csk performance anodized aluminum hold down washers
- F.S 4 NEW Radio box grommets with boots.
- ETTI Navy Brushless HV ESC 220a for sale
- reedy associated charger multi chemistry
- Octura Props (M445, X440 x 3, X442), Turnigy T600 & 4074 1400KV, Spectrum MR200
- 2 Hyperion EOS Super DUO3 Balance Chargers
- Orion Touch Max Duo Charger
- 3 Octura Props For Sale (X637, Y536)
- Lehner 3060/9
- Artr - twin mean machine 2
- Helping Hands & Killer Bee Soldering Jig
- Jae mini rigger, carbon, modified
- Parts everyone should have
- Power Supply for sale
- Delta Force Pirate for sale.
- New Large Speedmaster Skeg Strut
- New Speedmaster Large rudder and bracket
- 40mm Carbon motor mount system
- DF Cyberstorm + hardware kit. Local Pickup first.
- Tp 4050 2310kv
- Revolectrix 2s 70c 5000mah
- TWIN 60 in CRC MTI
- CRC 60in TWIN MTI
- Twin outboard hurricane mono
- F.s. `new' neu energy 6200 lipos 2s & 3s
- F.S. `NEW' HYPERION 1450 LiFe 2S packs
- F.S. `NEW' HYPERION 4200 LIPO 2S packs
- F.S. `NEW' HYPERION 5000 LIPO 3S packs
- F.S. `NEW' HYPERION EOS720i Super Duo 3 Charger
- F.S. `NEW' FUTABA FASST 3PM-2.4 gig radio package
- F.S. `NEW' HYPERION SENTRY Deluxe BALANCERS
- F.S. `NEW' HITEC HS-985MG High Torque Servo
- F.S. `NEW' NEU 1521 1Y S 8mm w/CF Mount & HRC Cooler
- F.S. 'SCHULZE FUTURE' 115Amp 2-8s Marine ESC FINAL CLEARANCE SALE!!!
- F.S. MARINE PUSH ROD SEALS Bruline / Graupner / Dubro FINAL CLEARANCE SALE
- F.S. Large Qty ESC `CAPACITOR KITS & LOOSE' / FINAL CLEARANCE SALE
- F.S. `NEW' Aluminum 4" WEDGE RUDDER Assembly
- F.S. `NEW' Blue Anodized FDM 3/16" STRUT / RUDDER Assembly combo!
- F.S. `NEW' `VIRGINIA CRAFTSMAN' SPORT 20 TURN FIN Assembly
- new Neu 1515/1.5y/f 1500 kv
- SpeedMaster Strut FS
- Free 1300mah Hyperion lipo
- "New" Neu 1527 .5Y and Neu 1530 .75D - HRC mounts and coolers
- Raptor Marine P-LTD Hydro (Rigger) - Race Ready
- 34" TFL Carbon Fiber Cheetah Twin - RTR
- Lynx OPC Tunnel Hull
- Original NEU 1512 1.5D - 3200KV
- K&B 7.5 Lowers (2)
- 60A Brushless Marine ESC and 14P 33x42mm 14P Outrunner Marine Motor - Recoil 26
