can the feigao 14XL hande voltages up to 29.6 volts? if i go lipo, thats how many volts ill be getting....the quantam motor i have have acutally "blown up" on 24 cells (someone on another forum tested it on 24 cells, and it happened to them)
feigao motor question
Check out the end of the "conversion" thread.
What prop did you use with the other motor?Steven Vaccaro
Where Racing on a Budget is a Reality! -
Do your self a favor...buy a feigao and unload that quantam while you can still get somthing for it. IMO your hull is way to big to for that motor to push and now you are intraducing lipos into the equasion. I have a feeling you are in for issues with that motor.Comment
issues with the quantam or feigao? since i figured ill need 24 cells, (and now lipos) i am having serious doubts with this quantam.....its a good airplance engine, it will turn a big prop with a lot of tourque...maybe ill give it to someone who would use it for that...
i would have used a larger lehner....but the prices for that are kind of over the top for me.....saleens7, the wookie of rc boatingComment
hate to jump in but on the feigo, what is the highest voltage you can put to a 10xl?
I would say the 10 will handle that. The kvm ratings are not that far apart.Comment
same
I have run 18 cells (21.6volts) on the 10XL. Ray Fuller said not to push more than a 5lb boat with it on direct drive.ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Comment
well I am running twin motors on a oh id say 6lb boat I hope I can run 18.5 lipos with octura 447s and be extremely fast! everything liquid cooled with its own intake and outletComment
well, if the 2 10xl's will push the boat without problem, and i run the 18.5v supposedly with a calculator i found this boat will be above 100mph minus drag from rudder and hull. I dont think it will do it but I guess we'll see. Hope for the best and expect the worst!Comment
same
Here is a video link to a 42" cat running two Fiegao 10XL's.
