View Full Version : Radio Talk
Pages : [1] 2
  1. DX2.0 DSM 2CH Pistol spektrum radio
  2. Spektrum question
  3. deciding on radio
  4. abs repair/ receiver pack
  5. Receiver waterproofing question
  6. Futaba R133F Receiver.
  7. Receiver Pack Voltage??
  8. Hammer upgrade receiver problems
  9. Radio Range
  10. what micro receiver works w/ JR XS3
  11. Cheap FM 10 model radio system
  12. Spektrum Telemetry Module
  13. JR Radio XS3-Pro Transmitter Pack Question...
  14. spektrum dx2.0
  15. 'binding' a spektrum dx2.0
  16. airtronics for service
  17. Spektrum DX3r and Sr3000 receiver problems
  18. Lost radio signal cutoff - Possible?
  19. rubber band on transmitter?
  20. Spektrum and Gundert Antenna
  21. Antenna question?
  22. FM Antenna
  23. Spektrum DX3R
  24. Futaba Fasst question?
  25. A question to AndyK or radio gurus
  26. conformal coating receiver
  27. Hitec Servos on Futaba 3PM Radio?
  28. spektrum 2.4 water proofing
  29. reciever help.
  30. 2.4ghz transmitter for rc boat
  31. Receiver Battery, Confused as hell
  32. futaba 3pk
  33. Free FASST Receiver Offer
  34. Has anyone tried a Tactic radio in CF hull?
  35. Spektrum DX3R - A little functional "Bling"
  36. Losing range with Spread spectrum JR10x PCM radio
  37. Tactic Pistol Tx & Rx Combo
  38. Hitec hs5745mg 1/4 scale & 3pm FASST
  39. Tactic receiver goes up in flames !
  40. Radio
  41. spektrum sr3000
  42. 2.4 GHz 'DSM' antenna length.
  43. receiver hook-up
  44. Throttle calibration Spectrum radio and hydra 240
  45. 2.4 gig transmitter/receiver
  46. Tactic 2.4 binding issues
  47. New 2.4 ghz Radio from Tower.
  48. Radio glitches...
  49. Tactic arming problem
  50. PlastiDip + Futaba Faast
  51. waterproofing a receiver
  52. receiver antenna length
  53. Spektrum DX3.0 radio in boats..are they a problem?
  54. Introducing the airtronics m11-x
  55. Futaba 3PDF converted to 2.4 Ghz.
  56. Rx antenna
  57. Spektrum Dx3S.
  58. Problems binding a DX3S.
  59. Wet Transmitter revival
  60. Which Spektrum?
  61. NEW Spektrum DX3E 3 Channel radio!
  62. New Spektrum
  63. New Airtronics
  64. MR3000 RX and Futaba Servo
  65. Getting an antenna out of a carbon fiber hull...
  66. Anyone try the Airtronics MX-3FG FHSS-2
  67. Attention all airtronics fans new product press release
  68. Cheap wheel radio!!
  69. Wheel vs. Stick radio control
  70. Why aren't more Rx's antenna-less ?
  71. VS-1 antenna/ reciever ideas
  72. What Spektrum Transmitter to choose
  73. 2.4Ghz Voltage Telemetry
  74. Radio for both FE and Sailing
  75. Radio feedback
  76. Receiver question
  77. Will HK RX work with Tactic TX?
  78. Turnigy Monster Radio Help?
  79. REAL BAD DAY!! Tactic 2.4ghz Radio Contact Loss!!
  80. Twenty Bucks Off Tactic 2.4 GHz
  81. Help With Futaba 3PM 2.4 MX Transmitter
  82. HK 2.4 Radio w/ Turborix ESC help
  83. New Radio for expanding fleet.....
  84. Spektrum Dx3 programming
  85. 2.4ghtz Computer Radio
  86. Tactic 2.4GHz radios, any good?
  87. New Radio
  88. SPEKTRUM MR200 2-Ch Receiver
  89. spectrum SR3000 rx questions - Andy?
  90. Receiver q's
  91. Spektrum Owners - Please Read
  92. spectrum DX 3 S
  93. Attention 2.4Ghz Radio Users
  94. laying CF on a hatch / radio signal interference
  95. Sealing esc & reciever
  96. Tactic Reciever... in a baloon?
  97. Sanwa MX3X Radio
  98. Tactic Radio in a Aquacraft Hammer
  99. Spektrum marine
  100. will dx5e bind to a mr3000 rx
  101. Quanum RC Telemetry
  102. Anyone using Spektrum DX2S for FE?
  103. Couple questions... radio and storage box?
  104. BBY New radio ?
  105. R2Hobbies 2.4ghz radio.
  106. Futaba Radio
  107. Spektrum DX3 interference?
  108. Quanum 2.4Ghz Telemetry System??
  109. Bec or Not on Tactic 2.4
  110. Futaba S-FHSS?
  111. Futaba 4PL?
  112. Waterproof Radio Boxes
  113. Spektrum radio question for the pros
  114. FINALLY!! NEW Spektrum DX3R-PRO Transmitter - Marine Compatible!
  115. Radio distance
  116. receiver baloon
  117. radio box
  118. do spektrum air receivers work good on water?
  119. Spektrum Telemetry
  120. Spektrum receiver MR200 info
  121. External Antenna Question
  122. Newb - Radio Control Boat Modeler
  123. CF and radio question
  124. Spektrum Surface RX in a boating application...
  125. My 2.4ghz antenna wire snapped in two ?
  126. New Product: Spektrum DX3C
  127. Tactic Radio Problems?
  128. ***NEW*** Spektrum DX3C TX
  129. Radio distance
  130. flysky radio
  131. Cool new Spektrum Telemetry Product.
  132. Traxxas 2.4 will not bind
  133. FlySky FS-GT3B Battery Saver Mod
  134. Radio
  135. Spektrum DX2S Range
  136. Futaba 2.4 had a bit of an issue!!!
  137. Just picked up a Futaba 4PL for the Fastech..
  138. Spektrum MR3000 question
  139. First issue with Tactic Tx
  140. Spektrum MR200 on DX3S
  141. 2.4 radio gliching
  142. Cheap Spektrum receivers?
  143. A question on a Spectrum rx (mr200)
  144. Spectrum Receiver Questions
  145. Spektrum mr200
  146. Quanum 2.4Ghz Telemetry System (Volt/Amp/Temp/mAh) V2
  147. Binding multiple receivers.
  148. 2.4 antenna length questions
  149. Stick Radio Programing Need Help
  150. New 2.4 GHz Futaba
  151. Spektrum MR3000 Receiver not working suddenly after re- binding???
  152. Spektrum Binding
  153. Spektrum MR3000 Receiver not working, any ideas why???
  154. Looking for new radio, What ones should i consider
  155. Are Spektrum radios with mr3000 rx any good or are their any problems
  156. Tactic tx / rx throttle fading in and out.
  157. Throttle is on if radio turns off
  158. Brushless Reef Racer not as fast with 2.4GHz Radio
  159. Which radio should i buy
  160. Binding more than 1 rx to tx
  161. motor turns when finger off transmitter trigger
  162. Routing Dual 2.4 GHz antenna leads...
  163. spektrum rm200?
  164. Swordfish 120/Airtronics Calibration Problem
  165. Weirdest radio problem.. EVER
  166. Best antenna for 2,4 ghz radio ?
  167. Spektrum radio with aquacraft esc
  168. Extending rx antenna?
  169. The purpose of using a radio box in a FE?
  170. Venom radio
  171. Hopw much receiver time form 1100mah?
  172. Sawana MT4 Telemetry Radio
  173. GT3B binding issues - Help!
  174. Spectrum DX3E Binding procedure to Multiple RXs
  175. Radio information and identification help please !!
  176. Does carbon Kevlar interference with transmitter without external antennas?
  177. Spektrun transmitter question
  178. raido and receiver
  179. Futaba Raido
  180. Loss of Radio Communication -- Receiver Baloon?
  181. No telemetry for RC boats ?
  182. Turnigy 9X 2.4 radio receiver antennae
  183. FLYSKY GT3B --- help please
  184. receiver antennas
  185. Futaba 4PL Need Help
  186. Spektrum DX2s & Swordfish 200 Amp ESC setup - newbie needs your help please !
  187. Orange surface RX for spektrum radios
  188. Transmitter / Reciever Upgrade...Help Needed...2.4GHz - Best Range for the Buck?
  189. TS3 radio box mounting...suggestions?
  190. Need help on receiver location
  191. need reciever for futaba 3pm 2.4ghz from hk?
  192. Spektrum DX2S screen not turning on
  193. A Simple and Reliable 2.4GHz Radio?
  194. Tactic Any Link System?????
  195. E- logger+ Spektrum??
  196. futaba 3pm 2.4 help please
  197. 1:14 Scale Spurt Radio Controlled Boat 1 meter long
  198. Radio question?
  199. DX2 Spektrum question
  200. Traxxas TQi radio ok?
  201. Elogger, AND telemetry?
  202. flysky GT3B question?
  203. Spektrum 2.4 Ghz anntena question in CF hull
  204. Transmitter Question
  205. Futaba Tansmitter + Fail Safe Receiver WARNING
  206. Alternate radio options???
  207. Anyone know how to bind a new Rx to the PB TX?
  208. Flysky receivers
  209. put down the transmitter
  210. Does WIFI cause interference to 2.4 radio?
  211. What's the best long distance radio??
  212. Pro Boat and Spectrum surface transmitter compatibility?
  213. futaba pk3 info
  214. Tactik Transmitter issue
  215. Two ESC connection to receiver for twin mono?
  216. new radio need opinions
  217. Anyone using Spectrum telemetry in boats?
  218. another question...antenna tube
  219. Any advice/thought on this receiver?
  220. Spektrum dx3r pro mods?
  221. spektrum mr200 or sr 200
  222. trouble with marine 3000 receiver
  223. Motor spinning when radio is inactive or off
  224. what to do with 2.4 RX antenna?
  225. Airtronics M11X question.
  226. Futaba 4PKS-R and dual ESC Mixing
  227. Flysky FS-GT3C
  228. Preferred rc radio Futaba or Spektrum or ?
  229. FlySky GT-B3
  230. Radio's systems
  231. Airtronics/sanwa issues.
  232. Spectrum MR200 glitching and getting hot
  233. Spektrum SPM 2300 and 2310 difference?
  234. a receiver question
  235. Any advice or experience, with a Futaba 3PM-FS 2.4 conversion ??
  236. Tactic receiver question
  237. Spectrum radio queston
  238. carbon lined hull radio interference?
  239. spektrum sr200 on water?
  240. What radio do you use?
  241. DX3C Radio problem, Help
  242. Futaba 3PM and R203GF Question
  243. Antenna ?
  244. tactic radio
  245. Orange RC DSM 3 Channel Receiver
  246. stick radio
  247. Transmitter suggestions for long range
  248. Receiver range
  249. Spektrum DX3S binding question
  250. Rx on top of servo? Interfearence?
