View Full Version : Motor Talk
- Lehner equivalent to Neu 1y 1515 2200kv?
- Help with choose of new motor with 12s
- Motor choice for ML Boatworks 310 Rigger
- timing for leo 4074 1800kv 4.5D
- Rigged insanity build maiden voyage
- Genesis motor questions?
- New 75k RPM TP 4070 motor...
- Motor rated max 44V. Can I use 12s?
- castle 1515 2200 kv motors
- LightFlightrc----ARC motors
- My My what have we here TP 4070-CM
- lehner motor coupler
- Turnigy sk3 3659 1900kv
- lehner wind question
- DYNAMITE DYMN3930 1750Kv
- lmt 3080/8 vs 2028
- Motors
- Leopard motor ?
- lehner 2240/5 help
- Removing water jacket ?
- water jacket ?
- Electricfly Ammo 28-45-3600 KV ?
- Timing suggestions
- Understanding amperage and wattage ratings for Leopard 3674 2200 kv motor ?
- Castle cooling jacket
- Lehner and Neu aren't the only ones to put fans in an Inrunner. Made for boats
- Needs some motor knowledge
- Timing and prop diameter for AQ 2030 kv motor?
- Cermark speed 480 7.2v- 9.6v motor ?
- Leopard 4075 X2
- Leopard 4074 1650 KV
- Skyrc PROTUES X524
- TP 5670 1050Kv 3Y What ESC to Run
- Video of Bearing differences
- Motor Setup / Run time / Current Draw
- 3650 Leopard 2290kv or 2090kv for stiletto running 4s
- Leopard 3674 2200 KV 180 amp esc for JAE .21 prop dia + timing ?
- Adding Copper wire to motor leads to make them thicker??
- Timing for a TP 4060 1950kv 5D
- Tp 4060
- Lehner motor connections to esc in any order?
- motor torque
- Decisions Decisions... 4s, 5s, 1750kv, 2000kv, Popeye, Mean Machine 2
- sss 2960 2881 kv Timing
- Turnigy AquaStar 4084 1050 KV
- Tp 3630 1950 kv 10D
- Leopard LBP4082-B-1450KV
- I have a motor idea.......
- TP 4060 or 4070
- Motor cooling
- Neu 1515 2200kv on 2s
- Motor swap ?
- TP Motor Kv unknown
- Max watts from a Castle 1415 1Y
- Old and new motor differences
- Winter motor storage
- motor rust
- Leopard 5692 1000kv questions
- TFL Caudwell F1 motor Esc
- SSS 3656 - 2030kv - 6 Pole Motor
- Want to learn how to rewind motors
- Motor and ESC or ML Boat works RSX380 38"
- Hacker B40 8L 2s prop question
- Proboat BlackJack Internals - use in surface application?
- Change bearings leopard 28mm?
- Motor kv
- Motor Swap
- Had an interesting experience
- TPP timing setup
- Burnt out motor
- Neu 1415 1Y, to trim the wires, or not to trim
- TP motors sizing issue?
- Brushless / ESC compatibility
- motor leads
- DYNM3940 5687 motor
- Dynamite 3835 1500Kv
- Which prop?
- Proboat 3630 disassembly???
- Which performs better?
- Timing for Leopard 4082 1600 KV 2Y ?
- Rotor spun on shaft
- Dr Mad Thrust 3682 - 1700kv ?
- HALLELUJAH I finally found a good motor wire insulation remover
- Discolouration of Motors wires!
- Lehner Motor order
- Motor coolers
- did i get screwed
- Is the V1 the newest version of TP motor?
- TP motor thrust bearing?
- Stock replacement motor for Traxxas 1800kv (Spartan / M41)
- " did I get screwed" follow up report
- Two TP 4050 Motors 2310 Kv but are they the same ??
- 6mm large bore water nipples
- Motor bearings
- NEU MOTORS Vs SCORPION Vs TPPower
- TFL SSS brushless motors ?
- Motor wires being so small
- Question about my TP motors
- Neu questions
- Motor length vs amp draw
- Absolute top performing RC Motor
- What would you use a 2848 3900k motor for?
- total electric package
- How to install TP can on TP motor with there tiny o ring
- CYX Supersonic Motors ?
- 40 series 10 S motor
- How to Identify a TP Power motor
- Conversion help IC to DC
- Radio noise issue
- Difference Brand Motors, Same Size & KV's, 20% Difference in Amps?
- Motor size versus Amp draw
- TP5650 1150kv thoughts
- Speed run 10 sec duration motor KV choice
- Which esc for an sss 2075kv motor?
- 3060 Shaft End Play?
- TP 4050 disassembly question
- Cheap Rocket 5692s for a Scale Scarab 54"?
- Brushless Motors and Esc explanation
- noob leopard motor choice for Miss Blackjack 29 advice
- rotor replacements?
- Old Feigao Motor Chart/Table?
- How to measure amp draw?
- leopard 1800kv timing
- Freezing motor before the run?
- Leopard 5892 1340kv
- What happens to a motor's amp draw when you decrease the supplied voltage?
- What timing should i choose?
- New outrunner 600 Series 1220kV - 2200 Watts
- Motor choice. MHZ Scorpion, SSS or TP.
- Tppower 4070/1090kv performans
- Tp motor issues
- Advice please: sourcing motors for 54" twin cat
- Prop KV and amp draw help
- Converting a nitro boat to electric
- Need kv of a motor
- 120 / 130cm mono Twin Setup, 2 x 4956 Outrunner motors 1250kV, 4250 Watts, 2 x 8S
- Timing for Leopard 2860 2190 KV 2.5y ?
- TP-5680 1070kV 3Y THOUGHTS
- Max Motor Loaded RPM?
- Neu 1415 1Y (2200KV)
- TP Power Motor Definitions
- TP4050 V1 motor bearing size
- Motor peak torque RPM
- TP 5680 800Kv 4Y Prop Size?
- Lehner 1940/5 in an Aquacraft Revolt 30?
- Leopard 2845 4420 KV +4700 KV motor problems ?
- SAITE Motor Co. 4 Pole - 2100kV
- Neu 1527 motor with shaft end play - repairable ?
- A look inside the sss 56123
- Turnigy XK 3674-1650 kv 4 pole
- Advice please: Motor for blackjack 24
- Kit motor, Esc, propeller
- Leopard 3674 2200 KV ?
- dumas 48 " pt109 battery set up
- The SQUID motor
- Brushless motor winding class
- Unwinding a Dynamite 3831 2000 kv
- motor and esc size?
- TP runs hot
- TOOLS to help with rewinding 36mm motors
- Question about motor timing
- Defective motor?or something else?
- How to determine the motor "wind"
- Motor trouble for my scratch built 85in 1:2.75 scale Chris Craft
- Looking for replacement motor...
- Zonda is only running in reverse
- New guy's motor questions for a non-racing 1/8 hydro
- 36mmx56mm motor ?????
- First time build, need help with correct motor size (kv)
- Motor Size for 29" Miss Geico
- PSA...Bearings for Turnigy 2845
- Maximum operation voltage for Neu 1527 2300kV competition
- Highest KV motor available for a 56 can motor
- TPPower Motors, what do you think about those motors ?
- Mount for Lehner 3060/7?
- 48" Catamaran build, looking for criticism before I buy
- I'm now able to rewind SSS 56mm Motors
- Does the motor size and length make a difference?
- Motor comparison/ reccomendation for sport hydro
- Suitable timing for a TP motor (5y winding)
- Motor, ESC & prop recommendations
- Leopard x2?
- Motor size for a 60" cat to replace a 30cc gas engine?
- Thunder Tiger 2000KV IBL- 40/20 Ripper motor question
- Brushless motor identification question
- Motor KV and RPM question
- Leapord 4074 1400 Kv motor help
- Help finding a brushless setup for my fire boat
- Gas to electric conversion 60" MTI?
- Need suggestion on motor upgrade
- Motor timing Turnigy T20 730kv "Y" winding
- Mount for Lehner 2260 motor in Seaducer Mono
- Motor for 55? catamaran and esc.
- Soldering connectors to motor wires.
- All Motor wires get really hot.
- Vented vs unvented motor?
- Motor for MHZ Chaparral
- 1/8 scale motor
- Replaced esc veles 29
- 1509 1.5D need boat recommendations
- Lehner Outrunner Motors 4140 and 7050
- 600 H Serie full power outrunner motors
- Did I get a bad motor?
- Blackjack 42 motor replacement/upgrade.
- Rotor KV on a TP
- Preventing motor corrosion ?
- ROCKET brushless motors
- Storing motor
- Original proboat 3630 motor 6s capable?
- old motor not sure what it is
- Best P-Limited 3660 motor
- SSS V2 motors at OSE Store. What is the difference from V1 ??
- feigao motor
- What motor and esc for 42 in outrigger
- Convert 72 inch gas to electric
- 40" Prather deep vee electric conversion - motor?
- Motor for OSE Raider 150A
- Converting sport 40 nitro to fe
- Type of wind on my Spektrum motor?
- TP motor identification?
- another Impulse 32 Spektrum motor question - cooling
- Water connections, RC Jet Pump
- WHY OH WHY all the worrying about timing??
- Amp Daddy, rewinds. Moved out of swap shop.
- Help!! maybe fried my motor
- How do you guys calculate prop size
- Fried Leopard 4092 and
- Motor & ESC info
- SSS 3656 motor wires
- This is my rotor at the moment... Continue to use?
- TenShock CZ112240 Motor KV
- Converting from gas to electric
- Lehner 3060 875kv
- SSS 56-154 500kv 12S
- Motor voltage and kv
- Fried motor
- Dr Mad Thrust 3682 - 1700kV.
- Does rewiring a motor give the can more power
- 48 Rico mono conversion
- TP Power CM vs SVM
- Has anyone notice that Leopard motors are more powerful
- Help choosing motors/esc for 60" MTI Cat
- FE motor question
- Winding shorted and possibly broken
- Front Endbell on a new TENSHOCK 2240 Motor
- Oxidean Marine Brushless Motor
