View Full Version : Motor Talk
- Pro Boat Power System Availability: DYNM3835 (1500KV) and DYNM3830 (1800KV)
- P-Limited Motor Question
- Leopard Timing
- Mamba XL2
- Anyone use this? Turnigy 3720 1500kv outrunner motor
- Has anyone pushed a Castle Mamba XL-2 hard in a boat yet?
- SAW motor cooling
- 1518 vs 1521 motor ???'s
- Anyone turn a castle 2028 higher than 30k rpm?
- motor comes to slow halt
- Motor size vs KV question
- Best motor for speed
- Which motor is more efficient?
- Need help with excessive motor heat
- motor wind question
- Castle 1515 2200kv spacers/bearings.
- What Size motor
- Leopard 3650 3900kv ?
- mean machine motor choice
- Looking for motor ideas
- TP motor specs ?
- Looking for motor testers
- What Timing For A Leopard 4082/2Y
- Motor and ESC pairing
- KV motor battery chart rpm
- motor/ catamaran question
- Castle creations 2028 water jacket
- New to Service my Neu Motor, help
- Best motor for Mean Machine 29" cat 5 or 6s setup preferred
- Help! Lehner bearing replacement
- I wanna go fast..... Prop reccomendations for Turnigy AquaStar 3974-2200KV in a MG29
- Low kv or large kv for my 4s setup genesis
- Motor Questions Please Help
- castle motor cooling jacket question
- TP 56 mm motor size question
- leopard 4082 bearings
- Bigger motor
- Proboat/Aquacraft Motor mounting bolts size/type?
- Has anyone had contact or received anything from Neu Motors?
- Motor Timing
- Aquacraft brusless motor 3656 1800 KV and 2030KV
- Bought a 1527 2d 1150kv, no what do I put it in.
- TP 3630 1950 Test Reports
- Timing question for D wind motors
- Comparable Neu to TP 4050 & 4060
- Rebuilt NEU motors
- Not impressed with TP power!!
- Well this can't be good......
- Can anyone recommend a motor mount for a Sirius 1717?
- Corrosionx and brushless motors.
- Looking for suggestions for 28mmx60mm brushless motor for 21'' 2s sport hydro ?
- real world motor comparison pic...
- Castle 2028 Extreme
- What motor? Leopard 3674, Leopard 4074, or tp 4050
- Lehner motor timing
- Rail mount for Lehner 22 series ??
- Leopard 3674 Motor 1700kv 2y or 1900kv 3.5D for AQ revolt ?
- TP 4060 1870kv not coming back???
- 44" seaducer mono, motor or motors choice
- Houston We Have a Problem
- Leopard Timing
- Hello all, What is the best esc to run a leopard 2100 kv
- Motor for JAE 21 FE
- cheetah motor options
- Rev Limit
- Castle 1515b ??
- Leopard 3674 1900kv no vent hole base cover Motor .
- Castle 2028
- What do you use to cut flex cable?
- bearing size
- bearing size
- New Style on NEU MOTOR CANS?
- TP POWER 5670 Rear Endbell removal
- what size bullet connectors for my motor connection.
- cutting down esc wires that go to motor??
- 12 AWG Thin wire on 1521 Neu?
- leopard or tp??
- Apparition
- Need advice, motor mount template
- Volume order for tp 3630 1950
- Leopard 3650 2090kv vs aquacraft UL1 3656 2030kv
- CC motor chart
- leopard motors
- P Mono Motor Question - Castle 1515 2200KV, NEU 1527 2300kv TP Power 2200KV?
- Different Motor Shaft Key
- Hacker skylar 2300kv 1/8 motor sensored
- Motor heat
- ProBoat Impulse 31 v1 Motors
- Leopard 3660 2120 kv can use on 22" hydro
- Help Timing a TP Power
- Aquacraft UL-1 Superior Stock Water Jacket
- CZ series II 6 pole motor
- skyrc motor checker
- let the smoke out
- Motor size for 30" cat
- Lehner motors anywhere in US you can buy?
- Investigating Shockwave 26 repower
- What kv is this Neu?
- motor maintance
- Pursuit mono motor and prop advice
- SSS 3660 1620kv
- Looking for lehner motors.... Suggestions?
- need motor and ESC help please
- What wind is this Leopard Motor?
- HET 39-700-98 Typhoon Motor Question
- Which motor and esc for 6s rigger Lehner or NEU
- Motor suggestions, please........
- Leopard motor and esc for Spartan boat, bought from ode
- Leopard 3674 Rotor wear
- Leopard 3675 2650 kv
- Which TP4070 Motor for 6S2P?
- TP 4050 1700kv bearings
- Motor Leads
- motor wind type
- RC Racing Events Web Site
- what motors and esc for a mhz mystic 44.8
- pwm and timing for my neu 1527 1y
- European Hulls, Motors, ESCs, etc.
- HET Typhoon 39-700-98 Mount Pattern
- New TP motor only a few runs shaft spun out?
- 1515 black castle/ neu 2200kv timing
- Toysport Triton XO-1 1717
- UL-1 2030 KV HOW many watt's output ?
- Need Help with a Lehner 1940 4 wind motor
- Leopard motor timing
- 7.2 volt engines
- Timing for Leopard 3674 1900 kv 3.5 D?
- Neu 1527 vs lehner 2260 in a mono
- TP 3630 1950 Reviews
- What's a good 6s capable motor?
- What kv Leo 3674 for 4S sport DF 29?
- Boat newb need help for electronic
- timing on a Turnigy XK3674-2200KV
- ETTI Demon Rigger motor prop choices
- Help which motor Demon rigger on 3s or 2s
- Is the Turnigy AquaStar 3974 2200KV a good motor?
- which motor size are kv
- motor shaft size
- genesis motor upgrade help.
- Ammo 36-88
- How do these motors compare power wise?
- Motor spinning wrong direction?
- Castle creations neu 1415 collet/collar. Proboat shockwave 26
- Where have all the outrunners gone?
- Dynamite® marine 1800Kv brushless water-cooled
- 5700 kv castle in Shockwave 26
- were can i get this motor if exsist
- Motor Sizing
- Which electric motor for mono build?
- aquacraft 2030 motor question
- which motor better for 6S??
- Is this motor a good upgrade for the C1 Flomaster 920 EP?
- Which motor mount for Nue 1527's?
- Genesis stock motor test
- Difference between Y -wind and D-wind
- New motor gives inconsistent power
- motor help
- Best Speed LMT/ESC/Lipo Combo for KBB45
- Does increasing diameter or motor length help reduce cooling?
- Zonda/Phantasm motor upgrade recommendation
- Long time overdue change to neu motors
- UL 2030 kv shaft end play ?
- Trying to choose motors for 32" Apparition ll
- Better bearings for boat motors maybe?
- New 4092
- Motor timing
- Aquacraft Gold motors, 1800kv front plate stripped threads, Help
- Tp4070 vs 1530 neu in same boat, no changes
- Feel like a noob new motor and boat is slow?
- AQ 2030 props
- Hobby king 4082 1500 kv
- Twin SSS 4094 kv2200 motors in a apparition ll
- All else the same, what does a longer motor do for you?
- Who has run x528 Beast motors?
- Need advice on what motor for jae21 Outrigger
- HRC 5" Rail Motor Mount and Leopard 4092?
- what motor for 41" electric outrigger
- Tp power 4070 2y
- Scorpion Motors
- Smaller cans for a twin
- Loose washers inside Neu 1527
- Outrunners...... are they worth messing with?
- Tp motor ???
- TP 5850 vs LMT 3060 or perhaps, 155$ vs 510$... and??
- Can I use sensored brushless motor on rc boat ?
- what motor for 55" mono
- Strange change in motor end play from new. Help
- How should I remove a stator from motor can???
- timing for 4074 2200kv
- HPR 135 motor options
- Leopard motor max voltage
- Neu bearings
- Leopard 4082 &Seaking 180V3 ESC combo for 4s Wild thing?
- Timing for Dynamite 2000kv 4 pole motor
- drop in motor for traxxas spartan?
- Neu motor size
- 5629 vs 5698
- T.P. motor
- Go with a bigger can?
- Motor choice for twin mono
- Leopard brushless motor replace bearing?
- Hobbywing quickrun combo
- Timing for TP4050 motor
- Zonda want more speed
- Neu vs tp.......would you agree with this?
- shorter motor wires...
- 40mm can up grade
- Death of a Neu 2230
- motor
- leopard 4092 930 kv
- another neu vs lehner vs tp motor discussion.
- HELP NEEDED - 500-600W Outrunner Search - 3500KV??
- Stripping motor wires
- Motor wires very stiff and short
- Castle 2028 780kv vs. Leapord 56110 780kv
- Motor Question for Rafael
- motors that turn over 60,000 rpm
- motor checkers
- Neu Motor question
- 28 can size 6s capable motors
- Lehner Motor Installation Announcement
- wire size for 540 brush type motor?
- Genesis motor upgrade ideas...
- Cc 1515 vs tp 4070
- Timing SS 4082 2200Kv
- Kv and amperage question
- Motor for 24" hydro on 2s/3s parallel?
- GTX 650 outboard with speed 600 motor and XL5?
- Leo Motor amps.
- D wind or y wind & kv for new rebuilt ariane 2 help!
- New version of Leo Motors?
- Decisions, decisions......
- Castle 1515 Actual Kv
- Dr. Mad Thrust Series Motor B3682
- Motor for rescue boat suggestions - help
- Joysway US1 9112a motor (Leopard 5692?) and 10s power
- Himax 3630-1500kv VERSES Proboat/Dynamite DYNM3835 A3630-1500Kv
- Water jacket for TP Power Motor
- Lehner motors just don't last long
- Aveox question
- replacement for an Aveox 1409
- How to shorten or repair hard motor wires
- Erevo 1515 2200kv which water jacket have folks used? will green can 1515 jacket work
- Can someone explain explain KV and prop combos?
- Different between 6 pole and 4 pole
- Motor like the Energizer Bunny.
- Winding info question?
- Giant motor from TP Power
- Castle 1717 1580kv
