View Full Version : Motor Talk
- Seaking 180-leopard 3674 2650kv timing???
- Castle 1717 Air Motor
- 2650 castle 1512
- Motor mount pattern
- Red Leopard O-rings
- Leopard 4074 motor (how do you remove end cap)
- Castle/Neu 1406 Wind Specs?
- 4092 leopard and hobbywing 180 esc
- Leopard 3674 - 2650kv on 4s,will Seaking 120a esc be enough
- Leopard 4074 1400kv
- Castle 2028 780kv motor timing
- Motor won't run, can't figure out why.
- Hyperion/Scorpion 4020 1390kv outrunner?
- leopard motor help
- What to use N2 motor
- Leopard 4082 & 4074 can diameter
- Performance difference between Leopard 4092 & 4082
- Trouble shooting a motor
- What's the difference with motor housings?
- What is the max RPM's for a Leopard 4074 2200kv?
- Leopard vs HK 3674's
- Etti Motor Mounts
- What's a good hull size to suit a castle 1406 5700kv motor????
- Leopard 3665 2100kv 3 Black wires from motor
- Experience with a Turnigy T5692 1320KV motor???
- has anyone tried this motor ?
- castle/traxxas 1428 specs
- Decent looking motor alternatives
- Initial safe motor timing for Leopard 4082 1600kv?
- TP Power motor vs Leopard
- JAE 21, Leopard 3660 or 3665 motor
- Motor Timing UL1 & Turnigy 120ESC
- brushless motor maintenance
- 5692 Leopard Motor. Is a 6mm good enough?
- What motor to buy?
- Brushless motor maintenance
- Looking for Turnigy T600 outrunner manufacturer/supplier
- Need help with motor
- Big Ammo Motor
- Turnigy HeliDrive SK3 Competition Series
- Leopard 3674 2200kv 5 Cell LiPo help please.
- fried motor
- Ammo 36/40 2900 kv Motor
- 5692 Leopard in Genesis?
- Actual O.D. of Leopard 28-series motors??
- Timing Neu Motor
- motor help
- Turnigy 4074
- motor equivalent
- what motor for a 12s mono?
- I have NEVER seen this happen to a motor!!! Fixable????????
- New 8mm Leopard 5692 shafts vs 6mm shafts - any actual difference?
- castle 1512 2650
- CC1717 and or Traxxas XO-1 motor
- Is this really a 12's motor?
- Another new HK motor
- How does a TP motor compaire to a leopard both 4092 1600kv, are the the same?
- Motor studder: Whats going on here?
- Leopard 4092 2080kv 3.5D
- In general terms when swapping out a 3674 2,000 kv motor for a 4074 2,000 kv motor?
- leopard 5674 780kv
- Ul-1 motor bearings
- Pursuit hull,What motor Leopard 4074 2200kv or 4082 2000kv
- leopard motor for 41" cat?
- Y or D wind motor?
- report on ul-1 motor pb45a esc
- leopard motor bearing size?
- Big motor options
- Castle 2028 780kv motor specs
- Sky RC Proteus marine motor.
- Castle 2028 780Kv mount
- Leopard 5692/5698; castle 2080; lehner. Which has the best bang for the $$$
- Cooling Jacket for castle 2028
- motor wont run
- two quick questions about Turnigy 56xx motors
- Custom Motor Mounts
- Motor recommedations please
- timing for a 6 pole turnigy trackstar 4068 2550kv
- NEU castle 1515 2200kv
- Motor size and KV
- Motor ?
- leopard 4282 2000kv motor
- Required motor wattage
- leopard 4092 vintage Fountain 42" boat, suggestions?
- motor size question
- motor timing
- TP power brushless motor.
- castle 1515 1y timing?
- Ul1 motor end play
- motor water jacket
- New Hobbyking motor
- Vanquish Motor and esc question
- trackstar 4069 motor kv
- Leopard Water Jacket Fitting
- Bad a$$ motor?
- help with motor please
- WOoOAAHAHA BABY!!!! new HK Motor
- Leopard 4092 1480 What is the best timing to run?
- Tacon vs. Leopard
- brushless motor for BBY V
- TP Power 5850 7D motor
- Short can motor vs long can motor
- Rust inside a brand new Leopard?
- Lehner monster motor on E Bay
- Leopard LC500 1720KV Outrunner Motor
- Motor wires cut
- motor chart
- Cheeath Motor
- Has anyone run this HOR 6 pole motor?
- Motor mount question
- What size Bullet connectors come on the Leopard 4092?
- Need help with UL-1 Motor.
- Motor kv chart
- Leopard motors
- Motor help
- MM18 motor
- Brushed motor's
- 4s vs. 6s vs. motor watts
- Castle 1717 too big for a FCR 34" Rivercat???
- Leopard 4092 700kv
- which motor
- 56 size motor mount
- Leopard recommended motor temps from manufacturer/ importer
- Aquacraft SV 27 L36/56 BL MOTOR ?
- Neu motor dimension
- Motor Experiment
- Motor temp reading
- Help with Leopard Cooling Jackets
- Motor temps
- motor
- NEU Castle Creations 2200kv 1515/1Y - Mystic 29.
- Motor has no power when in water
- Ul-1 motor and ESC?
- Castle Creations 1515 water Jacket
- Leopard 4074 bearing replacement
- Brushless motor size
- Motor size measurements?
- Which motor is better?
- Leopard upgrade from UL-1?
- Help with motor selection
- Brushless Motor 1000kV, which one?
- neu 1515 2200kv and castle creations 2200kv performance differences
- Do you know this motor brand?
- Motor Timing
- castle 17171y 1580 kv vs 15 series motors
- Motor Position
- What large motor?
- Motor Selection
- Brushless Motor recommendations
- 10s rigger build using castle 2028 and castle hydra ice 200 hv
- Motor Choice
- Motor maintenance
- motor timing
- 1717 castle
- Castle 2028
- leopard 4082-1600kv brushless in runner
- Motor Question
- How hot can a motor get.
- Leopard 4082 / 4092 in Osprey
- Which motor to buy for Pspec OPC ?
- leopard motor with fins cooling jacket?
- Need motor advice
- What size battery connector for Leopard 2860 ?
- Leopard 4050 Motor Water Jacket vs 4082 Water Jacket, Extra Long
- leopard 5692 1090
- leopard 3674 motor bearing change out problem
- Motor Rotor.
- motor question..
- Motor help
- Leopard motor and SF speedy cut out
- Need new motor..
- is this motor ok for my 47" mono ?
- Timing for leopard 4092
- Motor Burnout Why ?
- Motor Horsepower ratings ; Yea or Nay ?
- Leopard motor issues
- Motor twitching
- castle 1406-1y 4 pole
- How Do I determine what KV Leopard I have?
- Help determine my 56 series Leopard...question on length.
- Leopard Motor Maintenance
- Castle 2028 water jackets?
- Help with leopard 4082 1600kv
- motor question, leopard or neu
- Electric Motor repair?
- Leopard motor for SW 36 conversion?
- Leopard repair
- How to test a motor?
- Electric motor HP conversion?
- motor options
- Nue-Castle 1515 Y1 2200, Timing and Set up help
- Need advice on a motor swap
- Turnigy AquaStar 3974-2200KV
- leopard vs. tp
- tp motor suggestion?
- Thoughts on Castle 1717?
- TP Motor question
- Motor KV Compensation
- Motor timing for a turnigy 4082 1500 kv?
- castle 1515 vs leopard 4082
- Best prop for a 1500 kv 4082 turnigy motor and t-180 esc.
- T.P or Leopard motor???
- will castle repair a neu motor
- leopard 4082
- Best Q Motor
- Timing for Turnigy 600 H3740 1760kv
- Questions about my new Neu motor
- Motor Mount Jae21
- Gold Leopard 3656 2600kv
- Leopard 4082 mount?
- Help with motor selection for 36 inch CAT
- Water jacket on motor, HELP!
- 6s motor for a Rico 31"
- Motor ring to suit a 3974 motor????
- Castle vertigo out runners?
- Leopard 4074-2150kv
- Question regarding wind designation on Leopard Motor black can vs. red can
- Will a burnt motor take down an ESC?
- Leopard 3674 motor black edition
- 42mm Motor ring
- Castle 1515 1y 2200 needs a hull!
- Neu/Castle 1515 motor
- Question on Original SV 27 BL motor
- Who Sells TP BL Motor?
- Leopard 3665/2100kv
- Titanium Motor Mounts?
- Neu motor.....faaaaast!
- Leopard End Bell and Wire Orientation Difference - Which type is preferred?
- Brushless motor cleaning !!!!!
- What motor is the closest to an NEU Castle 1520 1600kv?
- motor comparison
- ??? about TPower motor
- Castle vs neu
- lmt motor mount
- Leopard 3674 2200kv and 2845 2550kv timing ?
- Leopard 5692
- mamba xl2 in a boat?
- Motor mount
- 28mm motor
- TP Brushless or Leopard Motors, Which are better and which do you prefer>>>WHY?
- TP Leopard or NEU for pursuit
- Water cooler for Castle (NEU) 1415 2400kv
- leopard 4092 1730 on 6s? need advice plz
- Leopard 3650 Motor
- Motor burned up
- info on lehner motor purchase
- 1515 2200 kv castle creations motors in a cat set up?
- does leopard make a 4092 1600kv?
- Motor Mount
- motor timing
