- Hobbywing program box won't work with...
- Does Turnigy have computer link like Castle Link?
- ESC Question?
- Castle's new XLX2 ESC 8s
- Hobbywing 180A ESC SETUP
- Turnigy programming card?
- Why would one motor and esc lead unsolder themselves?
- White sealer on a fightercat esc
- Problems with my ETTI HV 220 using Futaba T4PLS with NEU 1527 1.5 DS on 6S
- Experience with ZTW SEAL 200 Amp 8s ESC
- Capacitors for cap packs..
- ESC meltdown!
- ZTW 200A Help!!!
- Which ESC for new build
- Lights on a seaking 180
- Litehawk Champion ESC Help
- ESC recommendations
- Soldering 6.5mm connectors Swordfish 300amp esc 10ga wires to smaller TP4060 wires
- Fet smoking and sparking
- Turnigy 180 amp marine ESC (finger trouble)
- Flier 300amp ESC, Maytech rec'r, UBEC, BLDC config question
- What esc to choose?
- Reducing amp draw
- Flier 320 amp 16s ESC
- Unusual ESC problem, not remembering throttle range setting
- Sea King 180M dead? or just the Cappack?
- Reverse engineering schulze 40.160 (old) driver board.
- Swordfish 150 v ZTW 200
- Cappack temperature
- OSE 150a ESC issue
- 8 mm connectors
- 18 inches between ESC and Battery
- esc wiring
- ZTW 300 in need of cap bank or not?
- ZTW 200A help programming
- What ESC do I need?
- Hifei Swordfish Pro 300 amp
- Spektrum 160amp 8s ESC?
- Setting number of poles when programming Hifei Swordfish Pro ESC
- Cap pack for ZTW Seal 200A
- Swordfish 300 lite seems to be dead on arrival
- Data logger with amp draw data
- seaking 120 programing problems
- Mgm 40063
- ZTW Seal 300A - how to read max current and RPM
- Castle Hydra ????
- Need 12 volts to run two water pumps.
- Why are the wires from the ESC to motor hot?
- Has a worthy ESC been born? The Castle XLX2 looks to be an excellent ESC.
- mamba xlx2
- Understanding MambaXLX2 data logs
- ZTW Seal 200A acting strange
- Help ESC Fire
- Castle parts
- another ZTW 200a question
- RED HOT ESC cooler
- Water cooling for Castle Creations XLX2 esc
- ESC self programing
- Flier ESC
- Another worthy ESC? Watercooled Max5.
- Stump Fabrications Castle Water Cooled Adapter Plates
- ESC water nipples
- Ose 150 esc
- OSE 150a esc
- ESC programing
- Traxxas esc
- Program card
- Did I fry my ESC? Hooked up wrong? Turnigy 180a
- Castle XLX2 water cooled installation
- adding a cooling motor to bec or not
- Cap Pack for Seaking 180
- ESC problems?
- ESC throttle limit prior to LVC
- Ztw 200 cutting out
- Throttle calibration...ZTW 200
- Still struggling with ZTW200A esc calibration
- Castle Hydra XLX2 ESC
- ZTW Seal 200 amp - can not remove reverse operation - Help
- Flier 400a ESC Issues
- ESC choice
- ZTW 200A ESC problems
- Reliable & Easy to Program ESC 100-150A
- Spektrum esc timing?
- Castle Phoenix edge
- Dual motor ESC's
- Dilwe 4092 with 160A ESC
- 120A High Voltage esc, which one ?
- ztw 200 help
- ZTW ESC 150 Amp compatible to SSS 4092?
- ZTW 160A SBEC 8a
- Castle XLX2 ?
- ZTW 300amp G2 ESC
- Castle Hydra + castle futaba telemetry link + external receiver pack + 7PXR
- Arrowshark Esc
- Swordfish 220a
- FET temperature
- Newbie needs help please
- ZTW Seal 300 G2 S.Bus2
- OSE 150 esc, what cards are able to
- turnigy aquastar 240a problem
- SonicWake Won't turn on/power up. Newbie, please help!
- OSE Raider 150 Esc with Ec5 Question
- Anyone good at programming a Suppo esc?
- MGM ESC castle 1721 not working electric turbo
- OSE 150 / Flycolor 150A cooling modification
- ESC for Jet Boat - What to get ???
- 90A ESC fails to full throttle
- Sea King 120 solid green light on the LED
- Raider 150a esc up in smoke
- Recommendations for choosing BEС
- B-link
- Castle Phoenix Ice 200
- Anyone change the caps on a spectrum 120
- ZTW Seal G2 200a
- Traxxas Villain EX EVX-2 motor replacement
- ZTW 300amp G2
- Castle Mamba X
- Dr Super-Evil (Hydro 2) motor upgrade
- Sea King ESC Programing
- MGM esc
- Efficient ESC for Lehner TorqStar 1 7025/40 @86v
- Castle hydra bullet problem
