View Full Version : ESC Talk
- 5.5mm bullets on AQ 60amp esc question
- Safety Margin for ESCs
- Raider 150 esc dimensions?
- OSE Raider ESC programming.
- quacraft ESC help needed
- anyone know about these brushed boat esc's?
- Traxxas Velineon 3s with castle 1406 540 size motor?
- New hobbywing link
- I SCREWED UP... PLEASE HELP (who can repair ESC's?)
- AquaCraft ESC Help needed....
- Where to buy Rubycon ZL Caps for a good price?
- Raider ESC
- Need cable length added for Esc
- Fightercat 240amp esc calibration
- Replacement ESC ?
- Novak 5600uf 10 volt Capacitor
- Swordfish pro200a issue
- Etti 150 Navy race esc. Programming help.
- 150 amp esc was not enough
- Can caps be ruined by too much heat from Solder?
- Help please !
- Two ETTI 150s burnt up in 2 weeks and ideas.
- Issue with datalog Swordfish ESC
- 125A ESC Programming trouble
- Hobby horizon 160amp marine Esc
- no throttle
- water cooling for new castle esc?
- soldering and wire size for sf 300
- need help with esc choice
- Leopard 4092 and what esc
- OSE RAIDER 150A ESC is a great choice
- ESC Selection
- Program with radio New seaking 180?
- Seaking 120a esc works but 180a doesn't? help!!!
- Blown T180
- Esc sizzling???
- Seaking 180 bec Problem
- Turnigy 180A ESC programming with radio help!
- New to electrics need esc
- swordfish 300amp pro + vs seaking 180amp esc
- Blew my Raider 150 and SK180. What now?
- Flier 3-16s 300a esc
- Huge difference between esc temps and motor temps
- Mgm usa
- Sf 220 pro +
- JLog integration with Seaking marine ESC
- flier 400 amps
- Seaking T180amp at 7S ???
- Castle link and Sidwinder esc
- Speedo sadness
- Swordfish Pro+ 300A
- Having difficultly programming swordfish 300esc with programming card
- Matching ESC's
- Swordfish 200 amp 8s
- Electrics Newbie ESC question
- What's your favorite ESC?
- Impulse 31 New Setup - Do I need to change stock ESC Settings Before I run
- Has anyone noticed this?
- Castle Hydra Ice 2 HV200
- Castle hydra ice 240 question
- Programming Swordfish 240 Amp HV 4-12S w logging by newbie (to Swordfish)
- Binding a turnagy ESC
- Seaking Pro 120A
- esc and motor on the Zelos 36" twin catamaran
- MGM Back Data Transfer
- Esc
- Pheonix cooling
- Lost power
- ESC efficiency and Manufacturer differences
- The new Swordfish'
- ESC selection help
- New ESC Advise
- 300 lite settings
- Turnigy Aquastar 200 Amp ESC
- Raider 150 amp
- Etti 220 HV
- Proboat 45A ESC & Dynamite 45A ESC.
- Seaking 160 pro blew up
- Hobbywing 860 - any feedback?
- ETTI 220 ESC / Spectrum Programming Question
- Alien power ESC?
- Choosing the right size esc for the TP Power 4070...2180kv. motor
- Seaking 120a & leopard 3650 2090kv - poof
- Bought two SF240's and am completely frustrated
- Replacing ESC Caps
- Matthias Schulze NOTE
- Tired of hobby wing
- Need advice
- Castle 2 tier warranty
- Castel ESC PHOENIX EDGE LITE HV 160 AMP ESC, 12S / 50.4V
- swordfish x 300a-hv (lite)
- HK - FlyColor 120 esc programming box etc
- Esc cutting out
- Esc going into protection on blackjack
- ubec
- 300 amp esc
- Raider 150A
- Will this work? ESC-Motor-Battery combo..
- New SW 200A ESC/Cap Bank Integrated Mount
- Motor running backwards HELP
- MGM ESC speed controlers
- Castle creations ESC
- Problems connecting my mx3 to hobbywing 30a esc and motors
- Hobbyking aquastar/swordfish 240A
- For sale !! Swordfish pro + esc 220/250 2s-6s with data logging
- New (to me anyway) HV ESC
- 220-240 amp esc ?
- MGM esc programming problem
- schulze fut-xxl-40.303WK pc software and usb drives
- Programming the Turnigy Aquastar 240 amp ESC
- Schulze 105wo
- 48” zelos build
- Throwback many Thursdays
- Common caps for two escs?
- ESC no BEC
- Water proofing and basic lines
- Fishing Torpedo
- Stand Alone Mixer Board for Use In Boats
- esc help
- Castle ESC Sealant
- Will castle return to marine esc's?
- Turnigy TrackStar 1/5 controller
- Need help finding a very small esc
- Anyone tried the SkyRC Toro 200A ESC ?
- Differences between high end ESC's and cheap ones for Lehner motors?
- Swordfish Pro2 240HV - Adding Cap Bank - Anti-Spark Wire
- Esc caps for Castle 200hv
- Brushless / ESC compatibility
- Problems With a 4S Setup
- matching ESC's
- Turnigy Marine 120 amp ESC
- zelos twin esc confusion
- Throttle Calibration Issues with Castle Edge 200
- Swordfish data logger help
- TFL Genesis Twin 56’ ESC setup with Radio.
- New flier ESC start up
- Need help wiring parallel and series batteries
- Need recommendation on replacing blown cap board on Impulse 31 esc power wires
- zelos 36 problem
- New Turnigy Esc
- seaking 180 v3.1??
- esc cooling question
- Flycolor 150A ESC programming card?
- ZTW Seal boat esc's
- OSE Raider
- 200 amp flier ,caps get hot,
- Castle non-warranty
- problem here (esc 120)
- One or two ESCs
- Castle Edge 200 being discontinued?
- Heat sinks for ESCs
- Swordfish 220a Data logs
- ZTW Seal 300a ESC, Who is using it ?
- Raider 150 esc will it work with tp 3630 1950kv in my proboat ul 19
- Removing conformal coating
- Castle Link settings for Phoenix 200amp esc
- Motor Leads
- EDDI Power Analyzer ???
- SwordFish HV 240 or 300A Data access
- a single ESC to handle 3, 380 size motors?
- ESC cooling water flow
- Anyone running the Mamba XLX with cooling fan/no water
- Skinny on BULLET Connection ‘ s
- Sea King 120 amp esc capacitor's ?
- Problem Installing Castle Link
- Running twin Hobbyking 30amp ESC's
- ZTW 200A esc
- esc question...
- overheating problem on seaking 120 v3 after motley crew blowover
- Additional cap packs for ESC
- What ESC for Q Mono oval racing
- Alien Power ESC USB driver problems
- Urgent help with ESC Seaking V3, from 180A (to fail)
- Aquastar 200A esc
- ESC for MHZ Scorpion 5035/760KV
- Mamba XLX, Eliminate BEC and Aux cable questions
- ESC Recomendation
- Kılıçbalığı VS ZTW
- Sword 220x
- Neu 1521 jet unit no cooling esc?
- Mtronics Viper Marine ESC Problem
- Castle XL-X data logs amp ratings - are they accurate?
- How to get ZTX Seal 200A esc to work with TP motors
- Dynamite 120A Marine vs. Hobbywing Seaking 180A V3
- Esc recommendations for cheetah, 6s, Neu 1521, 1Y (1577 KV)
- Cap replacment on a Castle ICE 200 amp HV ESC
- Minicat ESC How to program?
- Programming new esc
- castle xlx conversion
- Boat Problems bby scat cat 26
- ESC Low power mode vs Low Voltage Shutoff?
- Danymite vs Hobbywing program cards
- Programming swordfish 120 esc
- 120 marine Dynamite ESC how to reset to factory settings
- Should i add a cap bank to my 150a esc
- Dynamite 120A marine ESC
- ZTW 200 & 300. Who has tried them?
- ECS question?
- 8mm vs. 10mm ose bullet connectors with 8awg wire
- Raider 150 ESC
- Mamba xlx back order
- swordfish 220X+
- ESC Recommendations
- TFL Seal 200 amp esc
- ESC Recommendations, help needed
- Check to see if esc is putting out full voltage.
- Seaking 180 v2 Programing.
- escs used in or on Thailand longtail boats
- Swordfish 240 Amp HV Pro +II problem? Help !
- ESC for a 12v Johnson 970 motor
- Alien power systems 300amp ESC??
- swordfish 220 x will not link to comuter
- Need Help! Please
- Turnigy Aquastar 120 amp esc ?
- ESC capacitors HELP NEEDED!
- HobbyWing Marine 30a and Outrunners
- A Reliable, Sport 120A - 150A ESC
- Hifei Swordfish X+ 300
- Q cat twin ESCs
- seaking 180A caps
- swordfish 300 pro double leads
- Q mono ESC amperage??
- UL-19 cutting off problem
- Selecting the right ESC
- Oil Bath Mamba XL Custom Enclosure
- 8s ESC Recommendation
- ESC programming help
- First time modding a MambaXLX . Need input thought.
- Esc reliability
- New Spektrum 160A ESC
- Video of how I modded my MAMBA xlx
- Waterproofing castle xl2
- Upgrades
- Esc Recommendations
- Blowing a Flyciolor 150
- Cooling for airboat escs
- Pro-boat Stealthwake: prop will not turn, rudder will
- ESC on fire MGM
- Good replacement for Seaking 180 v3
- Seal Series 300 & 500, long leads..
- HELP -Looking to upgrade the ESC AND MOTOR in my PROBOAT Sonicwake 36???
- ZTW SEAL Series 500 Amp 6s-14s Anyone tried it yet?
- Help in figuring out how to bind new ESC to boat and transmitter
- Ose 150a esc
- ESC cooling
- Help Needed on ESC/Prop Setup Exceed Eagle Deep V
- Brand new Z.T.W esc won?t work
- Flier 400A esc
- Two ESC's, Two batteries, Two motors....why...
- ZTW Seal 150A ESC starts up in wrong direction
