View Full Version : ESC Talk
Pages : 1 [2] 3 4
  1. Castle Hydra ice 240A 8s
  2. Castle hydra 120 esc??
  3. castle esc
  4. Castle ICE Lite 160HV on sale right now..screamin deal
  5. castle ice 200hv
  6. castle hydra ice hv200 waterproofing
  7. Castle Hydra 120 amp esc problem ?
  8. Castle esc trouble... Help!
  9. NEED HELP WITH Castle Creations Hydra ICE 240A 33.6V w/Switching BEC PLEAE
  10. prblem with Turnigy 180a
  11. Etti 150 amp opto esc ?
  12. Wiring Etti E 035 cap module to Etti 150 amp OPTO esc?
  13. Castle Creations BEC
  14. sf 300 vs 240? etti 220? opinions appreciated
  15. Castle Esc problem... I think? Help anyone?
  16. Turnigy programming card ?
  17. Need instructions for a Turnigy Marine T180 esc
  18. BL reverse esc and Tactic tx/rx
  19. castle esc hydra 240
  20. latest firmware update for swordfish240hv / Aquastar turnigy 240a ESC's
  21. Castle Ice 2 and Corrossion X
  22. Etti 220 amp esc
  23. Turnigy Marine ESC max operating volts
  24. Turnigy 180a ESC question
  25. Castle creation hv200 waterproofing
  26. Castle Creation Hydra Ice 240 with cracked plastic case
  27. ADVICE NEEDED - Etti ESC
  28. Castle Creations HYDRA HV-240 High Voltage Water Cooled ESC
  29. Castle Creations Hydra HV 180 blew up
  30. Need help to program turnigy hv 80a
  31. Turnigy 180 esc MANUAL
  32. Castle hydra ice hv 200 problem
  33. Castle 200hv hydra ice 2
  34. Etti 150 won't work - no beeps - Help
  35. Leopard 5682 1650kv & 240a Turnigy water cooled ESC
  36. Swordfish 120 AMP w/ Stock 1800KV Auqacraft Motor
  37. castle has hydra 60amp hv escs on sale for 40 bucks now.
  38. Castle Ice 240 Cap Replacement
  39. Castle esc discontinued
  40. Turnigy Aquastar 160A ESC programming with Tx is this possible?
  41. Castle HV not working after .....
  42. instruction file for turnigy ESC
  43. Castle Phoenix Ice with Futaba 4Pk, what's the tricks to set up?
  44. castle 240 programming
  45. Castle Link guru's - need some help
  46. Castle data logging, ever seen this before......?
  47. Venom 5000mah 25c 5s2p, on a 60A Turnigy/Speaking ESC ? ....
  48. Castle Hydra Ice2 HV 200 data logging question
  49. esc V2 Turnigy 180a Marine
  50. ? on what to replace my Turnigy 180 ESC
  51. Turnigy Programming Card
  52. castle 240 cooling
  53. castle hv200 please help
  54. Alien Power systems ESC's
  55. Phoniex Ice lite how to program with a spektrum radio
  56. Fail Safe - Beilimodel - flysky controller
  57. Turnigy 180A shorter wires
  58. Castle HV200
  59. Castle 240 Ice Ripple voltage whats bad ?
  60. Castle ESC Ice 240
  61. Castle hydra ice 200
  62. castle creations edge 200 lite conversion
  63. Turnigy marine 180 amp esc???
  64. T180/Receiver Pack, separate BEC vs. ESC's BEC... How should I do this ?
  65. T180 vs etti 150?
  66. Castle 200 HV
  67. I need some etti esc help!
  68. canl castle and tekin links be used on windows 8.1 tablet???
  69. Need help adding capacitors to ESC
  70. CC 200hv speed controler on6s
  71. Castle ice 240 with castle 2028 motor on 8s?
  72. most Reliable ESC
  73. PREFERRED ESCs
  74. Alien esc
  75. Esc for a tp 4070 1090kv
  76. castle bec
  77. aquacraft 60a speed control question
  78. sordfish 220 pro esc question
  79. water proofing esc question
  80. swordfish 220 a pro plus
  81. alien/fightercat esc binding
  82. mah effect on esc?
  83. SF esc need help
  84. What speed control?
  85. Ripple voltage/ shorten battery wires
  86. Using a Castle ICE Aircraft Controller in FE boats
  87. castle ice 240hv esc question
  88. Question about Castle data logging
  89. castle 240 data-logging
  90. T120 esc
  91. Large Heat Shrink For ESC!
  92. ESC's
  93. Venom 60amp ESC Spec's?
  94. I need ESC info feed back..
  95. ESC Advice
  96. ESC for Neu 1530 8s SAW
  97. need a esc for my boat running 4 or 6
  98. Quick SK180 ESC Question ??
  99. whats a low use Schulze v12 40-160 worth? I found one!!!!!
  100. MGM ESC Calibration
  101. 120 a sordfish cooling help
  102. Potting an ESC
  103. Frankenesc
  104. what are these resistors for??? MGM controller
  105. A Little Disappointed with the T-180 v3 water inlet/outlet setup
  106. What is the difference between a car ESC and A boat ESC?
  107. seaking 180 vs 200 swordfish
  108. Tenshock getting into Waterproof boat esc's
  109. hk Turnigy Aquastar 120A Watercooled ESC w/Programming Card
  110. Boat newb here! Recommended ESC for impulse 31v2
  111. sunrise esc
  112. Mounting Seaking ESC on/off switch externally
  113. Ugh!
  114. Castle hydra 200
  115. wire length
  116. Aquacraft UL-1 Superior ESC Wire Length Question
  117. CC Hydra 240 stick position
  118. Old style Hydra 240Hv ?
  119. whats the best esc motor setup on a 26 " deep vee mono ?
  120. Just bought Schulze 40-161 esc no wk model... like new but not watercooled
  121. Has anyone seen this esc?
  122. Ever had an esc just die?
  123. Mgm 80063
  124. 1 ESC 2 Motors
  125. Any one familiar with this ESC ? link below
  126. turnigy or seaking esc ? motor options ?
  127. Soldering question
  128. Water cooled mamba xl2
  129. Does anyone have an mgm 25063-3 esc?
  130. Stumped about my proboat geico electric
  131. Sizing ESC
  132. old style t180's available again.
  133. Aquacraft UL-1 Stock ESC arming issues
  134. ESC timing ?
  135. air-cooled esc
  136. Question on Installing Cap Bank on Swordfish 300A Lite or similar set up
  137. Blackjack 29 V3 ESC problem
  138. Dynamite 120 esc, button??
  139. Manual for TMM 25035 esc
  140. Problem Calibrating/Programming ESCs With Hitec FM Radio
  141. Ripple eoltage
  142. Scorpion ESC?
  143. seaking 180 amp programming card issue
  144. CC hv 200 speed controller calibration issues
  145. ESC Burst amp?
  146. esc temp
  147. AQ 60amp problems
  148. new build questions
  149. Swordfish timing fyi
  150. Please help. Anyone knows what ESC is this?
  151. 32" pursuit esc question
  152. MGM 28026-3 Pro WR
  153. castle 240 hv question. old style.
  154. help
  155. castle 240 replacement?
  156. Leopard 180 amp ESC Timing
  157. ESC DAMAGE the answer, Motor braking damage by MGM controllers.
  158. German Brand, Chinese price??
  159. Esc
  160. need help to program my two esc with the remote
  161. New esc on the way!
  162. Electrical Questions
  163. Upgrading ESC
  164. 200 amp SUPPO ?
  165. fightercat esc's
  166. mamba xl2
  167. MGM Data logging
  168. ESC Help
  169. twin wiring.
  170. esc type
  171. At what point are caps needed?
  172. ESC drawing too many Amps?
  173. programming castle xl2 and 240 in twin setup.
  174. programming castle xl2 and 240 esc
  175. help!!!!!
  176. Hobbywing 180A vs. Turnigy 180A from Hobby King?
  177. Need sage advice on which ESC to use.
  178. Looking to build a Cap Pack. Axial versus Radial caps
  179. Newby needs help
  180. Bank idea come to mind
  181. how much esc do i need
  182. MGM program problems, need help
  183. Is auto ESC timing proper for delta wind motor?
  184. Seeking 120 a little hot
  185. Proboat 60 programming
  186. Proboat 60 programming
  187. t180 hobbywing esc
  188. Some information on Castle ESC
  189. Esc for 1527 1.5D
  190. Need Help Identifying ESC...
  191. Need assistance
  192. Question about Castle Ice 200HV, and outrunners
  193. running dual traxxas vxl-6s esc's
  194. ESC question for specific use...
  195. New Seaking ESC from HobbyWing
  196. Hobbyking YEP 100amp Heli ESC converted
  197. Hobby King 40A ESC
  198. running brushless esc slow information?
  199. German esc mod thread. Two 150 a escs made into one 300a
  200. Caps
  201. Is 120 esc enough?
  202. Going in circles
  203. ESC for 4S Outboard
  204. Seaking escs??
  205. Water proofing ESC
  206. Sealant
  207. EagleTree V4 Advice
  208. Turnigy Marine 120 VS Hobbyking 120 Boat ESC
  209. everything got wet
  210. Cheap escs???
  211. turnigy 180a v3 esc problem
  212. Castle Ice 200 HV
  213. Will this work??
  214. Is rtv ok ??
  215. Castle ESC
  216. Mystery esc from ebay made by
  217. EVX/EVX2 questions
  218. esc motor compatability question
  219. Is this CAP popped?
  220. Jeti Spin Pro 300
  221. Esc
  222. RX/esc voltage question
  223. will a T180 handle a leopard 4074 2200kv on 6s ?
  224. using a boat ESE in a car
  225. castel esc and mgm speed controller
  226. Interesting find with a castle esc
  227. seaking 130 or 180.....
  228. Best ESC placement for Aeromarine Conquest
  229. Esc help
  230. Looking to purchase a good quality 220 amp esc?
  231. kontronik kosmik cool
  232. Mgm controllers
  233. not sure
  234. What esc to use
  235. Delta Force Vortex 16 ESC recomendation ?
  236. Data Logging ESC
  237. Capacitor pack
  238. Looking for new esc
  239. skywing 150 amp water cooled?
  240. what amp esc for 84 amp max motor 6s
  241. Question for the experts
  242. Max voltage dynm 3815
  243. Do I need Castle link?
  244. How much power MOSFETs can take...
  245. need help
  246. Mamba XL X
  247. Turniigy AQ 200A vs Seaking 130HV
  248. High voltage ESC advice need
  249. Temp Probe For ESC Temp
  250. quick esc question!!
