OSE Sport Packs
  • ReddyWatts
    • 1711
    OSE Sport Packs
    Steven, I am sure that you have run tests on your sport packs that you sell (Racers edge 3600). What is the maximum continuous amperage that you recommend drawing from these cells, using deans connectors?
    http://www.offshoreelectrics.com/products.php?cat=36
    ReddyWatts fleet photo
  • Steven Vaccaro
    • 8720
    I have run them on the bench with deans and 30amps with no problems. I will be using them more this spring with the supervees.
    • SJFE
      • 4735
      Steven, I have a DPR comming. I can run some tests on a set if ya want.
      • Steven Vaccaro
        • 8720
        There are more important things to do than test those packs. I wouldn't run them in much more than a sv.
        • ReddyWatts
          • 1711
          An SV draws from 40 - 50 continuous amps?
          • Steven Vaccaro
            • 8720
            Not the boat I tested. It was more on the average of 30 amps. I'm sure there were spikes of much higher. But not continuous at 50 amps with a stock prop.
