View Full Version : ProBoat BlackJack 26 Brushless Q & A
- move battery tray's - back or fwd?
- Upgrade motor and esc
- NEWBIE Please post vids on 6s and report any issues youve had
- Time for a up grade
- futaba 2.4 ghz
- Lipo fire! Toasted Blackjack!
- Battery choice...
- ammo 2300 pole count ??
- ESC options
- I Have Just a BJ26 Hull!
- speed estimate needed
- stock motor wire upgrade
- blackjack brushless on lipos
- back to props again
- Problems using the programming card???
- New BJ 26
- You expert opinion - prop, strut, rudder choice
- Looking forward to coming season
- Batteries for BJ 26?
- Prop?
- Best motor upgrade...
- Set screw size for the stock drive dog
- Pop Quiz! Blackjack flex shaft???
- best lipos
- hooking up lipo's
- boat running at 25% of its power
- Dx3r?
- Esc?
- Hydra 120 question
- Esc bec ???
- Battery packs?
- Stock ESC issue
- Waterproofing Lipos
- 3 excellent hardware upgrades...
- Spluttering frustration...
- Prop size and pitch for 26 bl?
- New paint job...
- Discharged battery level question
- New Motor Needed!
- 5s question???
- Teflon liner?
- Fuller's set up question
- Head of the River hardware question
- new boater with a q
- what batteries do u run
- Prop suggestions for upgraded blackjack
- No arming beeps?
- change the drain plug
- Blackjack 26 back flip
- rudder question from newbie. PLZ HELP
- BJ 26 turning. Speed, turn fins, etc.
- blackjack s.a.w type
- what motor to install???? Want to run !!
- Teflon liner trick
- lipo/Rx pack question
- Turn Fins?
- whats the weight of your BJ26 ??
- servo
- lipo C rating
- octura x642
- balanced and sharpened prop?
- lipo chargers and balancing
- BJ26 vids and pics lets see what you got !!
- blackjack 26
- Feigao 540XL
- Futaba Fasst 3pm Magnum 2.4g
- bullet,deans,or spade ???
- Reverse?
- antenna hole?
- motor runs hot?
- Inline rudder?
- water jacket?
- motor wires
- external BEC wiring???
- BJ26 caught fire!
- Question?
- what ! how! and is it easy to sharpen and balance your own props ?
- collet nut?
- Upgraded collet?
- input voltages series ,parallel
- Painting?
- Installing Flex Cable
- Stickers coming loose due to hatch tape
- Risking a fire with these batteries?
- Sanding?
- Decals?
- CG for the Blackjack 26bl?
- Finally bought myself a BlackJack
- Installed new 120A ESC. Where to set timing?
- Benefits of the radio box?
- Cracked Hull :-(
- I've got the runs!!
- prop help..
- High or Low timing?
- After removing the battery trays how do you.....
- Motor?
- Would this ESC been any good for a blackjack?
- New paint
- 2 11.1 3 cell packs in a stock 26bl blk jk
- Prop question for Blackjack 26
- Drain plug?
- Ballast Battery..
- bj26 prop adapter
- New paint and graphics...
- water in the hull
- programing esc
- Strut and rudder upgrade?
- turn fin adjustment
- New Food For New Cat :-)
- help running 5s stock
- Fullers?
- New Power System For BJ 26....
- help please
- fuller harware water pick up
- Bearings
- fullers question
- first roll over! HELP!!!
- Couple of questions
- steerable drive?
- BJ Twin prop BL ??
- ESC Overheating
- Hey need help?
- prop help
- stock drive hardware?
- collet nut
- rescue boat?
- fried esc!
- Esc help!
- 7c battery
- Excited new BJ26 Owner
- steering linkage?
- new goodies!!!!
- Help with removing BL26 Drive Shaft
- overkill!!!
- My Blackjack 26 Build
- lipo question
- Help with wimpy Collet nut!!!
- please help
- fuller's hardware
- Esc?
- Exploding Capacitor
- High Quality 2S Lipo packs.
- a bit dissapointed!
- What Feigaos are you running in the BJ26?
- Battery issues
- help
- Dead Hyda 240
- Upgrading to 5S, need some help.
- Brushless programable card
- bad day
- New guy
- what prop?
- what prop?
- Bad cell?
- Blown battery?
- Duratrax vs. Venom
- connectors?
- Wires too short?
- collet nut
- slack fullers
- bj hull
- "waterproofing" lipos?
- my bj 26 mods
- Some problems.
- Blackjack 26 esc shopping list
- A major loss for the hobby.
- voltage cutoff
- not sure
- New hardware.
- question
- Blackjack water jacket
- BJ Prop Question
- Deans connectors.....
- bad day for the bj
- BJ26 Motor Upgrade?
- BJ26 Lights
- Blackjack destruction!
- Timing
- Mounting the Fullers hardware.
- Turn Fin Problems
- xxSliMxx BJ26
- ? about lipos
- Anybody using a Seaking esc???
- new flex shaft installation issues
- Some problems on 5S.
- BJ26 speeds...
- BJ26 Makeover
- Smoked ESC
- Help Please need new esc
- Help please
- Stock outdrive design flaw! Fix it easily before you crash like mine!
- trim tabs ?
- boat rescue
- Hardware for BJ26 ???
- broken u joint?
- blackjack still rolls in the turns
- 5S problem
- once again a bad day of running
- Strut and Rudder Sizes?
- nylon breakaway screws, now I understand
- Water Cooling problems...
- Esc ?
- Best Motor?
- over cut off cell
- Think i have broke my new bj26 help!
- Rebuilding A BJ26
- Drive Hardware Question BJ26
- Which lipos and charger for stock BJ
- BJ 26 Lipos
- bj26 or fastech 26?
- Speed master strut and rudder for Blackjack 26
- Different esc on stock setup
- New bj 26 owner
- Two questions, the step & tupperware
- rudder flutter
- anybody tried this ??
- Help @ a stand still
- Time to give the Blackjack some attention.
- CC hv esc...
- Info on octura hardware
- Damn boat, now my esc has melted!!!
- Strut Set-up Question
- Nimi battery question
- My bj pictures
- Additional shots
- What octura strut & rudder
- Jp marine esc same as proboat but cheaper?
- After programming card results
- What flexi shaft when upgrading to bj26ss hardware
- Check this site
- New paint for the BJ's.
- Servo reversing
- Any pros or cons?
- x642 PROP
- Understanding props
- My Blackjack with twin power
- Just wondering
- Ebay/lipo ?
- clean up
- Programming ?
- New BJ Owner without maiden voyage
- BJ26 stuffing tube extension
- Blackjack Prop adapter
- Any input
- Blackjack 26 Winter Project
- Jump start nimah batterys ?
- new blackjack 26
- BlackJack 26 Brushless Hardware Replacement
- Prop Options (Carbon fiber vs. cast metal)
- BJ 26 ss hardware fitted
