View Full Version : Hobby Wing (Seaking) ESC's Q & A
  1. Castle Hydra 120A vs Seaking (hobbywing) 180A
  2. Seaking Boat ESC recalled by factory
  3. does anyone have a defective seaking or hobbywing esc?
  4. Seaking 180 first run report
  5. Seaking 180A esc (non) repair
  6. what size bullet connectors does this seaking esc use ?
  7. seaking
  8. seaking 180a esc, v2 waterproof?
  9. Hobbywing Seaking 180 GO BOOM
  10. Vacu-pickle, ul1 motor & seaking 180a esc
  11. Turnigy/ Hobbywing 180a on 6s2p..anyone doing it?
  12. Seaking 180 amp ESCs
  13. Seaking 180A or what ??
  14. Seaking 60A ESC timing setting
  15. Can anyone tell me the steps for programming the SeaKing 120a SC?
  16. Seaking 180A in Genesis Cat
  17. Hobbywing 80HV on 12s?
  18. seaking 180 esc not working...HELP!!
  19. Anybody using a seaking 180esc with Spektrum DX3.
  20. 1515 1y + 180A Seaking + 5000mah 20C = Puff??
  21. Hobbywing ESC Programming card faceplate
  22. 90&120 SeaKing ESC
  23. SeaKing Timing.
  24. BEC not working on Hobbywing/Seaking ESC?
  25. hobbywing 80a hv esc how do you program it?
  26. Hobbywing 120amp ESC?
  27. seaking 120 esc BEC
  28. Seaking 180 esc issue
  29. seaking 180 timing
  30. SeaKing 180 ESC...extra cooling.
  31. Seaking 60 UL-1 motor
  32. seaking 180 on 6S power
  33. SeaKing 120A ESC Flashing RED!!!
  34. SeaKing 180 timming MG motor
  35. genesis /leapord 1500kv, 180 seaking
  36. are seaking motors any good ?
  37. Programming Seaking ESC?
  38. Seaking 180 temps?
  39. Seaking 180 esc green ring around wire?
  40. SeaKing 180A esc version 1/ version 2?????
  41. Seaking-180 ESC
  42. 180 sea king green ring on esc wire to reciever
  43. Castle 1520 seaking 180 timing
  44. Seaking 180 Possibly Blown?
  45. Seaking 180 extending leads
  46. SeaKing 180 and P Mono
  47. seaking esc problem
  48. Turnigy Motor/ Seaking 120 Timing
  49. Feigao 12L SeaKing 120A ESC - what timing?
  50. Miss gieco ul-1 motor seaking 180 programming?
  51. leopard 4074 and seaking 180
  52. Seaking 180A ESC Questions
  53. Esc 180 seaking trying to program ?
  54. SeaKing 180a Problems...please help
  55. Does the Seaking 80hv have breaking?
  56. leopard 482 1550kv hobbywing 180 takes off then slows down why!!!!!!
  57. seaking 120 with a leopard 4074 2150kv on 4s?
  58. seaking 180 trouble
  59. Seaking HV 130A esc
  60. Hobbywing (Seaking) ESC programming card
  61. SEAKING esc's
  62. New Seaking 180A-R ESC and Leopard 4082 1600Kv
  63. Seaking 180 acting up
  64. seaking 120a esc
  65. Leopard 4082/Seaking 180 OSE Combo, good for FC 37" Daytona Cat?
  66. How to... add capacitors to an esc??? (seaking 180a)
  67. Hobbywing programming
  68. Seaking 180a - Now with added cap bank?!
  69. HW seaking 80a HV esc ver2
  70. Seaking 120amp esc v HV esc
  71. Seaking 180 ESC RPM Question?
  72. Replacing resistors on Seaking Esc.HOW?
  73. seaking 120 extra capacitors
  74. Seaking 180 ESC motor timing How To?
  75. 4082 Leopard Seaking 180a. ESC won't program
  76. Hobbywing Seaking120amp & Turnigy 120amp esc,Are they the same esc.
  77. Seaking 180A-R
  78. seaking 180A-R
  79. Seaking 120 vs Hydra 120
  80. seaking 180
  81. Seaking 120A-R?
  82. Seaking 180 ESC issues & problems when wet
  83. Seaking 180A HV
  84. Shortening Leads to Motor - Installing Seaking 180a
  85. HW Seaking 120a esc advice needed setting with prog card.
  86. Seaking 180 amp esc question
  87. seaking questions
  88. SeaKing 180 ESC first time power up, few questions...
  89. I have a dream Hobbywing!
  90. Timing with seaking esc for Proboat 2900kv motor?
  91. Turnigy / Seaking 120 A - never ending nightmare
  92. Caps for Seaking 120A ESC
  93. How do i program hobbywing esc with an external bec using program card?
  94. Seaking 180amp esc w/capacitor pack and castle capacitor pack
  95. Seaking 120A ESC, what should my timing be?
  96. SeaKing 130 vs. 180
  97. Turnigy Aquastar or Seaking 120
  98. Throttle Sensitivity, Seaking 180/Tactic radio
  99. Seaking & tacon 4074 - 2150 KV motor timing question
  100. seaking 180 6s?
  101. Seaking 180A ESC CAPS bulging!
  102. ESC Timing hobbywing V2 180 amp
  103. Seaking 180 LVC
  104. Seaking/Turnigy 180 fix
  105. Seaking 120A ESC prob??
  106. seaking or turnigy
  107. Seaking 180 problem
  108. Programming Seaking 180 V3
  109. Seaking ESC testing, capacitors? Warranty?
  110. Esc seaking 120
  111. How to eliminate BEC on SeaKing 180
  112. What setup for the hobbywing 130hv esc? Safely
  113. 120amp seaking with a 4074
  114. Cutoff Voltage on a Seaking
  115. HobbyWing Seaking 130A/180A High Voltage ???
  116. HobbyWing Seaking 60 A acting strange?
  117. It's killing me---let's settle which version of Seaking 180a ESC this is
  118. LED in Seaking/Turnigy 180 ESC ?
  119. Custom Label Seaking/Turnigy 180 ESC Programmer
  120. Big SeaKing price increase coming...... Dont shoot me!!!
  121. Seaking 180 version2 vs. version 3
  122. HobbyWing Seaking-120A/Turnigy Marine HELP !?
  123. Installing seaking 180 and lepord 4074 1650 kv in geico
  124. Hobbywing 90a esc
  125. Hobbywing seaking 3660 motor
  126. Seaking 180A ESC water fittings
  127. seaking 180 esc
  128. Question regarding the SeaKing 180amp esc
  129. 120a or 180a seaking?
  130. Seaking 120 help
  131. How to install a seaking/turnigy 180?
  132. seaking/turnigy 180 smoked on 2nd run...
  133. Seaking / T180 new heatsink teasing... for now
  134. seaking/turnigy 180 on 6s. BEC OR NO BEC?
  135. Hobbywing esc clarification question
  136. 180a seaking esc
  137. Seaking 180 & 130/180HV
  138. Counterfeit Seaking?!
  139. Quick question: How to disable LVC on Seaking 180a ESC
  140. Hobbywing / Skywing (rebadged Ez-Run) esc's, any info ???
  141. Seaking 180amp problem help
  142. genesis bacardi silver help, new tp power 4050 1510kv and seaking 180 timing?
  143. Seaking 180a
  144. SeaKing 80 or 130HV - on 4s?
  145. Issue with a seaking 180a esc
  146. Seaking 120 amp timing ?
  147. Hobbywing 130hv and 5692 1000kv motor, witch battery connector should i use?
  148. SeaKing 180 V3 ...... Anyone ran one yet?
  149. version 3 seaking 180 amp esc
  150. *** New SeaKing 180 V3 Testing... Could use set up advice
  151. Seaking 180 V3 Programming
  152. my ultimate seaking 180 cooling block
  153. What's going on with the SeaKing 130 HV V3.... Product not available anymore???
  154. another 180a hobbywing question
  155. castle 1420 1800 kv and seaking 120a esc poof
  156. Hobby Wing "SeaKing" 180 v3 Amp ESC.
  157. what's the deal on the program box for the new version of Seaking ESC
  158. Programming the Seaking 35a ESC modified AQ Minimono? Safemode issues and heat/smoke
  159. To add or not to add extra Capacitor Pack to a Hobby Wing "SeaKing" 180 v3 Amp ESC
  160. test
  161. SeaKing 130 HV Programming, need your thoughts
  162. How many are using them?
  163. *Does* the Seaking 180V3 need extra cooling?
  164. How waterproof is a Seaking.
  165. Seaking T180 cuts out at full throttle?????
  166. Esc
  167. setup
  168. Repair Hobbywing Seaking T180???
  169. Burnt up 180A v3 hobbywing ESC?
  170. How do i program the ESC's in my C1 Flowmaster cat?
  171. Found a great value in a marine ESC, the Turnigy 180a!
  172. Program for Zippkits Mini Sprint.
  173. how to check hobby wing esc
  174. Burnt the caps on the battery leads
  175. Can the sk180 handle a leopard 4092 1480kv
  176. throttle signal loss protection not working, potential runaway
  177. Connecting twins
  178. ESC question for specific use...
  179. Seaking V3 fast flashing red LED/fast beeping
  180. Burned caps
  181. Help on How to Hook Up the SK 130a HV v3
  182. elbow for Turnigy / Seaking 180?
  183. T-180 V3 cooling mod
  184. Sea king vs turnagy
  185. green LED on Seaking 180v3
  186. dead or not hoobywing 120a v3
  187. Looking for Help
  188. Seaking sealing circut board
  189. Timing for t600 1250kv outrunner
  190. Seaking 180a completely blows up.
  191. Sealing 160 professional
  192. Need Help with newest 180A SeaKings
  193. Seaking 120 amp V3 ?
  194. ESC Timing
  195. Hobbywing lcd box
  196. Sea king 120
  197. seaking 180a help
  198. ESC Settings
  199. waterproofing
  200. Seaking 120 pro
  201. SeaKing 180 v3 temps
  202. SK 130 hv failsafe
  203. Sea king 180 caps are popping
  204. Programming SK180 w/Traxxas TX
  205. Seaking 120 amp version # 2 ?
  206. Programming Seaking 180 V3 help
  207. Seaking 180 esc problems
  208. Quotation regarding 2 ESCs into 1 Receiver
  209. SeaKing 180 V3 & Leopard 4082 X2 Performance Issues
  210. Seaking 180 V3 problems.
  211. Power Logger/SeaKing Compatibility
