View Full Version : Hifei (Swordfish) ESC's Q & A
Pages : [1] 2
  1. Hifei 240a HV marine ESC?????
  2. swordfish esc
  3. Swordfish ESC help
  4. Swordfish Frustration
  5. Feigao 540 8xl and Hifei swordfish 120 a good como?
  6. Swordfish 120's
  7. Swordfish 120 got one
  8. Waterproof swordfish 120 esc
  9. Swordfish 120
  10. Swordfish 120 amp ESC
  11. Swordfish ESC problems
  12. settings for swordfish....
  13. Swordfish 120 amp ESC
  14. Will the Swordfish 240 buckle???
  15. Swordfish ESC problems
  16. Swordfish/Aquastar 120A ESC Timing
  17. Swordfish 120 on board BEC?
  18. Swordfish 120 and 3026 Scorpion settings?
  19. HK's swordfish
  20. swordfish 240hv users
  21. Anti-Spark on a Turnigy180? Swordfish 120?
  22. Timeing on swordfish 120 for 10xl?
  23. Swordfish dip switch settings
  24. 8xl on swordfish 120?
  25. Swordfish 120A ESC
  26. Swordfish 120 wont go to full throttle!
  27. Swordfish 120 Amp ESC and Leopard motro
  28. The new 200a Swordfish
  29. Swordfish 240LV
  30. Lipo count for BEC for Swordfish 120
  31. Swordfish 120
  32. Swordfish or Seaking?
  33. T180 or Swordfish 200 on Leopard 4082 motor
  34. Hifei Swordfish 240 amp
  35. TX programming the swordfish 200???
  36. HK 180 or swordfish 200 ESC
  37. Swordfish 120 amp ESC programming
  38. How do you replace the caps on a swordfish 240hv?
  39. swordfish 240hv esc
  40. is Swordfish 240hv same as turnigy aquastar monster??
  41. pwm rate khz ???? swordfish 240 hv
  42. Swordfish HV 240, Neu 1521 1.5D, 4S2P
  43. Hifei Swordfish 120amp issues
  44. Swordfish 240hv Programming
  45. seaking 180 or swordfish 200
  46. Which 240 ??? Hifel Swordfish or Castle Hydra Ice
  47. swordfish 200a timing
  48. Programming the swordfish esc 200a
  49. swordfish 120 esc programmong card ?
  50. How do I program the Swordfish 120 esc?
  51. new swordfish 200a esc glitching need help
  52. Swordfish 240a esc
  53. swordfish 240a HV bec?
  54. Swordfish 240A HV ESC Warranty?
  55. Swordfish 120 one fet 200 to 245f
  56. what esc, Turnigy/Seaking marine 120amp esc or Swordfish 120
  57. Swordfish 120 ?
  58. Swordfish 200 amp esc help!!!
  59. SWORDFISH 200A Died?
  60. T180 or 200a swordfish?
  61. swordfish problems.
  62. Swordfish 200amp ESC problem
  63. Etti 150 or Swordfish 200?
  64. swordfish 120 burned up toaday
  65. Ned Help Pleasssssseeeeeee Swordfish 240Hv,s going itno LVC
  66. Swordfish 200's on 6s?
  67. Swordfish 200A error when programming
  68. Swordfish 200a Qusetion
  69. swordfish 200a esc "yyyy" parameter settings
  70. Swordfish HV240 Question
  71. Seaking/ T180a esc v Swordfish 200a
  72. Swordfish 200a esc, prog box or card.is one better.
  73. swordfish 240 HV. brand new never touched to water and its smoking
  74. The new swordfish 120a.....................??
  75. How to program swordfish 200
  76. Swordfish 120 timing
  77. New Swordfish Software, big improvemnt - com port detection
  78. Seaking 120 versus Swordfish 120 ESC
  79. hifei speed control
  80. Question about Swordfish 200 esc
  81. swordfish 200 amp esc questions
  82. Swordfish 240 with Castle BEC
  83. Need help with new set up twin 200amp swordfish esc's, 2300 kv scorpion MHz mototrs?
  84. Swordfish 240
  85. swordfish esc question
  86. HiFei Release New Generation Swordfish ESC
  87. Throttle trim/Swordfish ESC
  88. hobby engine swordfish hull setup advice
  89. Swordfish PC Programming Help
  90. waterproofing swordfish esc help
  91. Swordfish 200 help
  92. Wiring for swordfish 300 pro
  93. Swordfish 240HV esc receiver lead
  94. Swordfish Plus 120A esc
  95. ===HELP===new swordfish-no instructions
  96. new swordfish 120 A plus software issues
  97. Hobby King or Swordfish
  98. Whats the word on the new Swordfish 300amp ESC?
  99. Swordfish 240 new vs. old any diffefences?
  100. Swordfish 300 Data Logger
  101. Pdf manual for swordfish 300 pro
  102. Smoked Swordfish 240 HV
  103. Swordfish opinions
  104. Swordfish data logging
  105. Swordfish 120A ESC on 5S?
  106. swordfish Pro 300A cant get it programed, can any one help
  107. Timinig on Swordfish Pro ESC
  108. hifei hv capacitor problem
  109. Hifei Swordfish 200+ Esc Settings for 41" Cat
  110. ESC QUESTION, Hifei Swordfish PLUS 200 amp
  111. Hifei 300 A Plus issues
  112. Experiences with the new Swordfish 240A HV?
  113. water fitting for swordfish 200 amp esc
  114. Problems with SF 120 telemetry
  115. Need help setting up a Swordfish 120 (new edition)
  116. Swordfish or Castle?
  117. 300 Swordfish question? 80% throttle
  118. Hifei swordfish 200+ amp and Seaking 120 amp esc ?
  119. Swordfish 200 amp esc need ubec?
  120. Swordfish esc programming question
  121. Swirdfish 300 or HiFei Software: Run Time error. anyone else have?
  122. Swordfish - Can't disable BEC
  123. Swordfish 200+ ESC
  124. Hifei cap bank for saw set up.
  125. Swordfish 200 amp + esc ?
  126. Swordfish ESC Software
  127. Swordfish 200a esc???
  128. Soldering the external capicator bank to the Hifei Swordfish 300HV Pro
  129. Hifei Swordfish 240 Pro Plus Throttle Issues
  130. swordfish 240 hv esc
  131. anyone using the swordfish pro 220 6s esc?
  132. Swordfish or seaking?
  133. Swordfish 300 Pro+ ***Sent back for warranty repair to China!*** Disappointed***
  134. Updated Swordfish Firmware - Spektrum Fix
  135. Swordfish 200amp plus Why does it delay at cutoff so much?? Is this normal??
  136. Swordfish 300 Pro+ ***Sent back for warranty repair to China!*** All Better***
  137. 200A Swordfish Pro in a rigger?
  138. Swordfish 300 esc, adding cap bank??
  139. Problems setting up a new swordfish 200 pro.
  140. Swordfish Pro 200 and 220
  141. What ESC killed a swordfish 120
  142. swordfish 220 - 300 amp esc
  143. Swordfish pro 240 or Swordfish Pro+ 220 amp or.....
  144. Swordfish 220 pro + questions
  145. Help with calibrating a swordfish esc
  146. Help programming Swordfish Pro 220 ESC
  147. twin swordfish setup, one 100%thr, 2nd 80%thr
  148. Help connecting to Hifei program card
  149. swordfish esc
  150. Hifei Swordfish Pro+ Display of Logging Data
  151. Swordfish Questions
  152. Castle Link with Swordfish 120 Pro?
  153. Swordfish 300 a ESC info
  154. Swordfish esc's, do they have reverse?
  155. Swordfish 240 Pro
  156. 64 bit Swordfish software
  157. New Swordfish 120 Stops running?
  158. swordfish esc low voltage cutoff " no protection"
  159. swordfish 220/300a lvc no protection setting
  160. Swordfish 240A - Misaligned Cooling Tubes.
  161. swordfish pro+ 300a esc need help!!
  162. Swordfish program box ??
  163. Swordfish Pro+ 220 Running Hot
  164. Hifei parallel battery cap bank for twin ESC's...is this right for me?
  165. Swordfish Pro 200 amp - 8s lipo ESC mini disc
  166. Swordfish Esc or aquastar 120
  167. Swordfish-Auto Timing?
  168. software upload for swordfish 300 esc
  169. Swordfish help on deciding
  170. Swordfish 240 ESC, program box VS pc link.
  171. Swordfish 300 and 120
  172. Swordfish Pro+ 220A
  173. Esc swordfish 120 plus not turning motor ?
  174. SwordFish 220+ Data logging software, Mine won't work...NEED HELP
  175. Swordfish 220 calibration
  176. swordfish 200a esc parameters HELP!
  177. What is the final word on Swordfish Pro+220 ESC??
  178. Swordfish esc
  179. Help on setting timing with the Swordfish Pro+ 220A-6s ESC
  180. SwordFish Timing default of "AUTO" What degree is that? Range is from 0-30 degrees
  181. Swordfish 200a esc
  182. problem with 200amp swordfish esc
  183. Anyone else think swordfish
  184. Recovering Swordfish 200A ESC
  185. swordfish 220 esc
  186. Contact info for Hifei Swordfish ?
  187. Swordfish pro 220a esc throttle programming
  188. Swordfish tempatures
  189. Swordfish 200amp and Neu 1515 1Y
  190. Swordfish 200a esc Programing
  191. Hifei v4.11 download?
  192. Need swordfish esc help!!
  193. Hifei frustration
  194. Swordfish pro+ 220A-6s
  195. Swordfish Pro 200A Esc HV Programming
  196. SK180 v3 vs. Swordfish 220+
  197. HiFei USB drivers
  198. Swordfish data logger viewing?
  199. swordfish 220 a pro with data logger
  200. Chargrilled Swordfish
  201. test
  202. FYI, Michelle from Hifei......
  203. esc for 32" mono / 4s : any experience with Swordfish 220A ?
  204. Data Log
  205. Need Help...Swordfish 220 with Data Logging so frustrated
  206. Please Help!!! Swordfish Data Logging Errors!!!!
  207. bec on swordfish 240 esc
  208. Swordfish 240 esc 2 pack lipo setup
  209. Swordfish timing troubles
  210. swordfish 220a esc data logging
  211. swordfish rev limits?
  212. Datalog from swordfiish 240....rpm seems low?
  213. swordfish auto timing?
  214. Swordfish 300 help
  215. Pro 220 amp - 6s lipo ESC run on
  216. setting up 120 swordfish esc with leopard 3650 motor
  217. Does HiFei Refurb esc's?
  218. Swordfish computer link
  219. Questions for Michlee (of Hifei)
  220. 220 pro plus waterproofing
  221. Swordfish 300amp HV Lite Wiring
  222. swordfish 240 esc help
  223. Need help swordfish 220 problems
  224. Best ways of *completely* waterproofing Swordfish ESC?
  225. Swordfish 120a questions not calibrating correctly
  226. Swordfish 120 Pro+ cutting out after motor upgrade...overheating?
  227. Swordfish 240HV procedure
  228. 220 pro won't work after crash
  229. 220 pro + just died
  230. Verifying 100 percent throttle
  231. 300+ pro ESC is going OFF please help
  232. swordfish pro +200a
  233. Swordfish Pro+ 200amp esc
  234. 220 pro on 7s ?
  235. 220 pro caps bad?
  236. 300A Lite severe cogging on startup.
  237. Esc dosent like 6s
  238. Esc repair
  239. Rcbb esc
  240. Picking the right ESC
  241. Kbb swordfish 300 cc 2028 780kv no beeps but it runs ?
  242. Anti Spark Lead
  243. 300 Lite Playing Twinkle Little Star
  244. What ESC for TP 4060 2550 kv 2y motor
  245. swordfish pro 200a problem
  246. SF 200A 8s with data shuts off
  247. Need advice on ESC
  248. Anti spark leads ?
  249. Swordfish 220a pro with Traxxas Spartan radio - full speed by itself
  250. can not see log
