Can Anyone help me get a nitro started???
  • Mich. Maniac
    Banned
    • 1384
    Ive just received a new 4wd on road car and it ran great for a few minutes. I adjust main needle valve and now it wont run. It will start and run if I keep pushing primer to keep it going,
  • dirtysouth31
    • 514
    than your probably too lean.turn needle valve clockwise until it starts to get tight.than back it out 2 full turns and try that for starters
    • Mich. Maniac
      Banned
      • 1384
      thanks, so turning it clockwise richens? Ill try that
      • dirtysouth31
        • 514
        no counter-clockwise richens it.just giving you a good starting point.because you can richen it too much and it will run like crap.too lean and you will break something.turning clockwise will shut off fuel to carb,so backing out 2 turns will richen it up to about where you want to bee.than every tank you can turn the needle valve clockwise too lean it out and get better performance.always run sloppy rich when breaking in motor.
        • Mich. Maniac
          Banned
          • 1384
          Perfect it started right up and runs, but as soon as i pull warmer off it wants to quit alot, Different plug?
          • saleens7
            • 1108
            i would revv it a few times with the warmer on, then take it off and see if it still wants to quit..
            • Mich. Maniac
              Banned
              • 1384
              Yeah, I tried that, it'll stay going at higher rpm but when I back it off it quits. maybe I just need to fine tune my richness. I kinda remember why I dont like nitro's. any more Ideas I would gladly try them thanks.
              • saleens7
                • 1108
                if its not running right at lower rpm, try adjusting the LSN...maybe make it a bit richer and try it, and then vise versa and see which setting runs better,,,
                • Mich. Maniac
                  Banned
                  • 1384
                  LSN? Low Idle needle?
                  • Mich. Maniac
                    Banned
                    • 1384
                    LOW SPEED DUH sorry
                    • rcBPman
                      • 6
                      Ok is this motor broken in at all? If not then why are you trying to lean it out. It would not lean out and would act how you are describing it. If so then tighten the highspeed all the way down and open it 3 turns. This will give that thing one smoky start but you will be thanful that you havent busted a rod.
                      Now if the motor is broken in, which if you are asking how to keep a motor running then i'm still asuming you did not break it in the proper way, but if so turn the needle closed and upen it up 2 and half turns. Now have you ever moved the low speed needle? If so put it back to the factory setting because it should not have to be set untill your high speed is done. Nitro motors can be tricky but run them slightly rich and you will love the performace. Plus cars should be ran slight rich due to them having the transmision. Your only tuning it for the first gear when the motor is reved out. Now with it slighly rich it will still have power then when it changes gears it will be perfect. Now if it was lean on the first gear you will see that second gear will bowg the car down.
                      Good luck and be sure to use after run oil or 3 in one oil or corosion X. This will help protect the motor and help with starting it every time.
                      -Greg-
                      SSI Racing
                      • Mich. Maniac
                        Banned
                        • 1384
                        well, I took your advice and it did help for a minute. now today it wont start again. itll hit but wont run. once it does that it will even quit trying to start. I prime it again and it will catch and quit, then it cranks hard like its flooded. ugh, wanna buy a new nitro car?
                        • dirtysouth31
                          • 514
                          hell no! it dont run:D :D
                          • Mich. Maniac
                            Banned
                            • 1384
                            It probly would if someone had patience. I think they sould come bit a starter!
                            • Mich. Maniac
                              Banned
                              • 1384
                              GOT IT RUNNIN LIKE A RAPED APE!!! whew . just beat a minivan!!!
