View Full Version : Proboat BlackJack 29 Miss Geico V2 BL Catamaran Q & A
  1. matching pro boat paint
  2. BlackJack 29 detailed interior and exterior pics
  3. Blackjack 29 Blown Motor
  4. BJ 29 motor and esc.
  5. BJ29 Pilots, what is your setup to avoid the bouncing?
  6. Anyone try a Zippy 4500mah 5s 35c Compact
  7. Battery and EC3 Lead.
  8. BlackJack 29 upgrade questions
  9. Blackjack 29 upgrades before I hit the water
  10. Batterie info please
  11. Blackjack29
  12. Carbon Fiber Miss Geico hull?
  13. help removing water jacket from stock bj 29 motor
  14. Got back into boats with a bj 29
  15. New to boats and few questions
  16. 6s from three 2s hard packs
  17. MG 29 V2 Battery Suggestions for Longer Run Times
  18. Leopard 4082 motor mount photos
  19. props to try out need sggestions
  20. BJ29 Hull Reinforcement
  21. BJ29, how do you hold your lipo's down??
  22. second Proboat motor burnt up
  23. BJ29 replacement collet
  24. Miss Geico dialed in- strut modification
  25. running 6s question.
  26. Just bought a MG 29
  27. MY BJ29 has a new look!
  28. Short video of new BJ29
  29. Hull damage need help
  30. proboat 29 batt/prop/motor
  31. Addicted newb
  32. Question about MG versions.
  33. Data logging on the BJ29
  34. Will a proboat miss geico flex cable work for a blackjack 29?
  35. Blackjack 29 propping
  36. Miss Geico 29 ugprading ESC's
  37. A few newbie questions re Miss Geico v2
  38. Miss geico 29 v2 not 6s conpatible? How could it run in 50mph?
  39. MG V2 stuffing tube liner
  40. New member here with Black Jack 29 question
  41. Sisters and sitting with the hoard
  42. Miss Geico and Black Jack 29 mod questions...
  43. BJ29 teflon liner and flex shaff worn- looking for direction
  44. Need advice picking the shaft and rudder assembly.
  45. Proboat Blackjack 29 1800kv motor getting hot....Anyone else had these problems?
  46. just ordered a mg!
  47. Proboat offset rudder kit for MG29 V2
  48. Miss Geigo
  49. BJ29 80a/ 6s ESC... have questions
  50. Help to find propeller to miss geico stock
  51. Miss geico suddently runs like it hang up inn grass?
  52. Dynamite 6s help to connect to the geico motor, different color on motor cable.
  53. New miss geico 29 hull, fiberglass only?
  54. Miss geico/blackjack 29 6s esc on genace 25c?
  55. how much power could the stock flex axle hold up before it break? Will if fall out?
  56. How to install stuffing tube liner
  57. 1500 kv vs 1800kv
  58. Blackjack 29 Red or Orange?
  59. Blackjack or Geico 29 on 45, 2P
  60. ESC beep beep beep blackjack 29 BL
  61. Miss Geico Driveline install
  62. New blackjack 29 owner battery question
  63. Stock Blackjack 29 Motor- Is It Really a 6S motor?
  64. BJ29 flex shaft removal
  65. BJ29 Stock servo removal/replacement
  66. BJ 29 Stripped motor bolt
  67. MG29 Leopard motor Help me choose Please...
  68. water plug for blackjack29
  69. Stock Strut BJ29
  70. PB Blackjack 29 motor question
  71. Rudder play and excessive vibration
  72. hello all. my new blackjack 29 not working.
  73. Proboat Blackjack 29" V3 - new hull, 2000kv motor, 120A ESC & EC5 plugs.
  74. dual water pickup for bj29
  75. New Proboat BlackJack 29 canopy does not fit hull
  76. Needed upgrades for MG V2
  77. Need length oF sponson BJ 29
  78. Motor choice
  79. Proboat Blackjack 29 v3
  80. X645 for a modded BJ29 v2?
  81. A little help with flex shaft and collet!
  82. BJ29 v3, 30C lipos ok?
  83. BJ29 prop washers?
  84. BJ29, great first run!
  85. Blackjack 29 v3 Clearcoat Pelling (take 3)
  86. Miss Geico V3?
  87. blackjack29 no power
  88. Wow!!
  89. Looking for Wattage and Max Volts info on ProBoat motors
  90. Spartan vs Blackjack
  91. Miss Geico 29 V3
  92. my BJ 29
  93. have i ruined my bj29??
  94. OSE upgraded shaft failure?
  95. What have you done to your " BLACKJACK 29" lately?
  96. New Bj 29 v3 owner. What is stock esc settings and other questions about this boat
  97. Blackjack v3 runs to hot on 6s
  98. Bushing would not be inside strut question, how long is the flex on miss geico 29 v2?
  99. Miss geico 29 v2 vs blackjack 29 v3, looks like the miss geico is faster on 6s?
  100. Leopard motor in my BJ29
  101. use led program card, what is plus and minus on the 120A esc? With pics
  102. geico 29 v3
  103. geico v3 esc
  104. BEST 6S Prop for BJ29
  105. Blackjack running hot? now fixed!
  106. BJv3.1
  107. BI 29 Collet ?
  108. Esc help
  109. Buy touch paint Blackjack 29
  110. Proboat BlackJack 29 prop shaft/ strut making noise? HELP
  111. Blackjack 29 best speed?
  112. new v2
  113. Help me pick a prop for my BJ29
  114. Transporting MG 29" v3
  115. Upgrade props for Zelos 36 Cat ? Improved cooling?
  116. Miss Geico V2 29 Props
  117. 29 V3 best stock prop
  118. New 29 V3 suggestions.
  119. Recommended Balance Point ?
  120. Stock v3 motor versus Leopard 4082 1600 on 4s
  121. Leopard 4082 2000kv
  122. 2s1p or 2s2p batteries.
  123. Blackjack 29 V3 .187 upgrade shaft
  124. Anyone selling thier BJ 29?
  125. My Blackjack 29 V3 progress
  126. BJV3 cut off problem
  127. Blackjack dual rudder pickup upgrade
  128. BJ 29 v3 running hot help
  129. Battery?
  130. Lost my steering ?
  131. Blackjack 29 Servo ?
  132. motor reccomendation for bj29 v3 on 6s
  133. Strut and rudder question
  134. Speed ?
  135. Miss Geico V2 hull
  136. Blackjack 29v3 upgrade Veles motor and abc1716
  137. Thoughts on the Blackjack 29 V3 as afirst fast electric boat.
  138. Prop nut
  139. graphene batteries?
  140. What are the things I should look at upgrading?
  141. M445 on blackjack 29 v3
  142. Leopard 3674 2200KV
  143. I don't get it
  144. Water entering hull through the holes for the pins on the hatch
  145. Holy SHOMG
  146. Bj29v3 vid 53mph
  147. Black jack 29 v3
  148. BJ-29 V3 Leopard 4074 2200 SeaKing 180 Prop Recommendations
