View Full Version : Proboat Impulse 31(V2) Version 2 Deep Vee Q & A
  1. ProBoat Impulse 31 Version 2 Poor Stock Motor and ESC
  2. 60 mph setup
  3. Lets fix the issues with the Impulse 31
  4. IM31 Tortue Testing and results - Totally Refuting any claims that 6S won't work!
  5. New impulse 31
  6. Failing Flex Drive
  7. turnigy typhoon 500 outrunner
  8. NEW OSE IM31 Turn Fins!!
  9. Another motor and ESC
  10. New to rc boating
  11. Hatch issues
  12. White nylon washer needed?
  13. Impluse V2 with Prather 220 prop on 5s
  14. Impulse 31 v2 on 6s? Its running fine on 5s
  15. New owner of Impulse 31 v2
  16. were to buy the water hose nipple to the rudder or new rudder?
  17. EC5 ok?
  18. Got my stock Impulse V2 up to 115 KPH / 72 MPH
  19. running 5S
  20. Just bought a impulse 31 v2
  21. My set up so far
  22. Impulse V2 Motor swap
  23. Darin's Race Prep - Pro Boat Impulse 31 V2
  24. Need some help with motor timing
  25. Need help with install of esc
  26. My Impulse 31 v2 upgrades with photos, it's comming along.
  27. Is it safe to run with this ESC
  28. New Impulse 31 v2 motor and prop upgrade
  29. My Meltdown
  30. timing question about Leopard 4082
  31. Shot out
  32. RX Issues?
  33. Just Bought an Impulse 31 V2 - any modifications before I test run?
  34. IM31 Took on water not sure what is wrong help???
  35. Battery setup
  36. Limiting throttle with 6s
  37. My setup notes; suggestions welcome!
  38. S&B x642 running same as stock prop!? whats the deal here?
  39. New v2 impulse
  40. New owner, some questions on salt water use / after run / setup
  41. Mystery part inside my new Impulse 31 V2?
  42. proboat impulse 31 v2 hairline crack ? how to strengthen ?
  43. Leopard 4074 vs. 4082 2200Kv on 4S
  44. Has anyone reinforced their im31 v2 hulls ?
  45. Impulse 31 Lipo Question
  46. Impulse 31 V2 - top speed 32 mph with 1500KV, X642, 6S
  47. hi guys lil help mabey you can watch the video give me some answers ???
  48. Dual Rutters, Worth It?
  49. ProBoat Dont Float
  50. Taking a dive
  51. How to remove the strut?
  52. Please help(new in boating)
  53. noob here...connector/lipo questions...
  54. Hairline cracks in new proboat impulse 31 v2
  55. Impulse 31 with HK Pursuit motor
  56. Do I need to use an external BEC if i'm running 5s?
  57. Impulse 31 V2 Won't Run - Noob Needs Help
  58. First post and I have a few questions
  59. New boat not responding
  60. Impulse 31 Build
  61. Impulse 31 v2 strut replacement
  62. Castle 10amp Bec
  63. Just picked up a NEW Impulse31 V2
  64. first boat
