View Full Version : AquaCraft Revolt Mono Q & A
  1. Might want to start a new Fourm Topic!.. New from AquaCraft!
  2. Aquacraft Revolt 30 FE - WOW!
  3. Revolt Arrived today(First Consumer Pics)!!!!
  4. My revolt first pictures!
  5. Found one at my LHS- Shaft coupler will not loosen grip on flex!
  6. Got my Blue Revolt
  7. Does everyone else's screw that hold in the rudders and trim tabs not have bolts?
  8. Revolt 30 - My first boat
  9. My Test Results
  10. Revolt 30 chine walk
  11. Is it just me or does this boat look familiar ?
  12. RE VOLT center of gravity
  13. Servo replacement
  14. Slightly off topic but cool.
  15. thrust bearing
  16. Revolt help please
  17. Question on new hulls?
  18. Paging grim racer on revolt30
  19. Is This Normal???
  20. Revolt arrived from Tower - Second batch?
  21. ANOTHER is this normal thread...
  22. Revolt30 Stickers? Or paint?
  23. Tried the 2030Kv
  24. HELP! How to set the end ponts on the aquacraft 60amp esc?
  25. Revolt 30 manual
  26. Revolt 30 Speed help...
  27. Going to snag a 4s 6500mAH hyperion pack.. what is a max good weight for this size?
  28. anyone try 3s batteries?
  29. Revolt RTR ordered
  30. Revolt 30 ESC upgrade
  31. Revolt 30 just received - Stock Transom needs QC!
  32. Revolt 30 - Interior hull mods or repairs
  33. Revolt 30 - Don't you miss the drain plug?
  34. LVC for Revolt 30
  35. Revolt 30 - Rudder blade setup
  36. Re Volt pictures 45 mph
  37. Revolt 30 maiden voyage last night
  38. My Revolt 30 - "Bold Skull"
  39. thrust bearing installation
  40. Waterproof tape glue sticking to boat
  41. Revolt 30 - Adjustable stuffing tube bracket
  42. Second batch is better but, still needs some qc
  43. Wish me luck
  44. Re Volt 44.7 mph SLOWED DOWN to 35.7 mph ?
  45. Has anyone put an outrunner in one yet?
  46. new to rc boating
  47. Revolt 30 Maiden and first RC boat experience
  48. Keep it in the water?
  49. Another new to boats, maiden Revolt 30
  50. Adjusting the LVC on the RTR Revolt 30
  51. Thoughts on a s225 Prather prop
  52. Revolt motor height?
  53. Opinions wanted
  54. Revolt videos from an FE newbie
  55. Eagle tree for revolt
  56. This is a crazy revolt video (must see)!!!!!!!!!!!!
  57. Do I need anything else????????
  58. Revolt 30 - Prop - GrimRacer 45x66
  59. revolt performance
  60. motor upgrade for revolt 30 ??
  61. Got my revolt
  62. Received my Revolt too - QC looks good!
  63. Poor speed Revolt 30
  64. Revolt in Italy
  65. Will the stock motor
  66. Stock Revolt hit 46,7mph- 75,2kmh
  67. Revolt wants to go right
  68. Revolt30 battery
  69. Aquacraft support
  70. Motor choice
  71. Hull Prep
  72. Slop in rudder
  73. Stuffing tube alignment issue on Revolt
  74. Aquacraft Revolt -- 59.15mph speed run, 6S LiPo, STOCK motor (video)
  75. Think i need more prop
  76. Quick question about stock motor
  77. Repair Aquacraft Revolt Hull or replace. Other questions as well...
  78. Revolt 30 speed
  79. Revolt in high wind
  80. Dual pick-up rudder
  81. Better battery tray?
  82. Battery tray replaced
  83. Revolt finally kicks a$$
  84. Tower Sale $269.00 with 30 off only 239 RTR
  85. Revolt Breaks 60mph
  86. Revolt30
  87. Best Batteries for Revolt 30
  88. New Revolt concern
  89. Lv cut off?
  90. Canopy replacment
  91. Which Octura prop with stock electronics and 4s?
  92. Revolt upgrade questions
  93. my Revolt 30 build
  94. UL-1 Motor in Revolt
  95. Revolt gets Carbon
  96. What's y'all's opinion?
  97. Eagle Tree readings on my new revolt
  98. Revolt owners: need a measurement pls
  99. Revolt on one 3S?
  100. Finally got around to do an upgrade
  101. Battery Revolt 30
  102. New Revolt. Motor mount question
  103. Revolt on 4s
  104. got new boat any setup tips or help
  105. new speed control broken???
  106. Revolt set up
  107. Revolt 30 motor/esc/prop/batt testing
  108. Revolts on sale at tower hobbies
  109. Can Revolt use 5000mAh 4s 20c lipo?
  110. Revolt Steering Rod Boot
  111. batteries and run times????
  112. revolt 30
  113. RIP Revolt!
  114. Steering Servo slowly drifting....
  115. Revolt Cooling mods thread. Let's see'em.
  116. Silicone (Acidic/non-acidic) vs Goop
  117. Bushing: Recessed or Protruding?
  118. 55 MPH.....What do I need to do??
  119. Sealing without Tape: Whose acheived this?
  120. Confused on run times cat VS mono
  121. 60mph but runs hot
  122. "Regular" versus Lifter Prop
  123. Hull Reinforcement
  124. Steering servo coming loose:(
  125. Has anybody ever run 2 4S 14.8V 5000Mah in Parrallel
  126. My second boat, a revolt 30...
  127. Reaching Aquacraft customer support by email?
  128. Revolt 30 42 MPH but hot
  129. Stock revolt with an X440/3 questions..
  130. Water cooling Line
  131. Motor choice
  132. dual water cooling
  133. Revolt 30 - Broken transom at rudder mount
  134. Solding Larger-Gauge Wires to ESC
  135. Help I Need More Cheap Speed
  136. Replacement Decals for the Revolt 30
  137. Replacement Steering Servo
  138. Removed Battery Tray
  139. My NEW REVOLT 30.........w/Pictures
  140. Revolt Quality Control Improving or Just Inconsistant?
  141. Newbie Question
  142. Paint to Match Silver Hull
  143. Recommend a prop for my setup
  144. Flotation / Hatch's
  145. Picked up a second revolt today!
  146. Cooling Jacket
  147. Need a new hull :(
  148. hot battery
  149. revolt 30 leopard build..
  150. Benno's Revolt 30
  151. External BEC Useful in Revolt?
  152. Revolt motor mounts
  153. Revolt Speed
  154. Revolt 30 - bushing question - 1st post!
  155. Poor fit of prop to stub shaft. Video included. .007"of slop, is this normal?
  156. Revolt 30 on 5s
  157. Revolt alignment
  158. Revolt Tactic steering servo spline pattern?
  159. Revolt vs Blackjack
  160. Carbon Fiber Inlay for Revolt 30 FE - worth the effort/cost?
  161. Revolt Motor Upgrade
  162. new revolt pricing
  163. Best kv leopard for revolt
  164. What stops chine walking
  165. Leo 4082
  166. New to RC boating ...few questions on the Revolt 30
  167. Completely Submerged Revolt 30, please advise
  168. 2 motor mount screws stripped brand new
  169. .S & B L40x57x3 GrimRacer
  170. Revolt Props
  171. aftermarket battery trays
  172. Just got my Revolt 30
  173. Running wet
  174. Turnigy 180A ESC
  175. Aftermarket flex shaft
  176. Aftermarket flex shaft installed correctly
  177. Best way to adjust trim plates on Revolt?
  178. used revolt
  179. Steering Servo came loose
  180. upgraded Revolt 30
  181. OSE 46mm 3 blade CNC prop is wonderful
  182. Twin Revolt
  183. Got my new Revolt
  184. First gps run on stock revolt
  185. Crashed boat, need advice please
  186. Rudder will not return to center when I let go of the wheel
  187. Is AquaCraft discontinuing the Revolt 30 ?
  188. OSE Flex shaft and liner
  189. Revolt 30 maiden run
  190. Another successful Revolt maiden! W/video
  191. Revolt on sale at Amazon
  192. Revolt stock motor shaft bent advice
  193. upgraded revolt COG
  194. New prop shaft/collet/thrust bearing question..
  195. Time for some R&D, friendly advice please.
  196. 6S can use Leopard 3674 brushless motor 2200kv ?
  197. Real cool battery tray and a nose job
  198. I Might need a new Transmitter, what should I get?
  199. AQ ESC being used with Futaba 3GR-2.4G and two Hitec HS-5645-MG sevo's
  200. Revolt Maiden - Trials and Tribulations
  201. Revolt 30 setup
  202. Just to clear it up........... Revolt 30
  203. revolt battery and prop question.
  204. Revolt use 5s lipo to run ?
  205. What size water cooling lines for stock Revolt
  206. Revolt racing videos, all revolts, all the time
  207. Proboat A3630-1500 or Stock Revolt 30 motor?
  208. Double 2s or Single 4s?
  209. Revolt McQueen
  210. Voltage Sag?
  211. Revolt upgarde flex cable
  212. Stock esc ?
  213. leopard 3674 motor direction ?
  214. New revolt owner....question on new collet and shaft saver
  215. Revolt 30 rudder questions.......,,.
  216. Revolt 30 new ESC question
  217. Revolt 30 cooling liƱes
  218. How to sharpen and thin a copper/titanium prop?
  219. OK guys, I need some help installing new cooling lines......
  220. Revolt 30 motor mount question
  221. any thoughts on a x445 prop
  222. Replacement O Rings for Cooling Jacket
  223. Revolt Upgrades?
  224. x642 or M545
  225. Motor Mount Crooked?
  226. Hardware Modifications?
  227. Rudder Rounding?
  228. Need Boat Stand
  229. Rudder has a lot of play...
  230. Chine Walking/ Stability Issue
  231. Trick for Passing Cooling Lines through Bulkheads
  232. Rudder Hinge Pin Size?
  233. Bigger bullets on stock electronics?
  234. Increasing Run Time
  235. Tuning stock revolt for more speed
  236. Thoughts on Revolt with Leopard 3674?
  237. Revolt Repair from Crash
  238. Hats Off to OSE Forums
  239. Show me your turn fins
  240. 3/16 cable with no liner
  241. Revolt on 6s
  242. crooked revolt 30
  243. Blue/Orange Revolt 30 touch-up paint
  244. Revolt 30 2nd Time Around
  245. No more hatch tape. Easy convertion.
  246. Battery Size
  247. Calibration
  248. OSE Flexhaft
