View Full Version : Boat Building Talk
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16
  1. Trying to restore/upgrade my Kyosho Wavemaster!
  2. BBY War Zone Jr
  3. new skunkworks cat: twin outrunner build
  4. 29 Seaducer
  5. Rigger Input Needed: unconventional sponson design
  6. motor mount ideas?
  7. Skunkworks single drive cat
  8. 18.5" mystic build
  9. Woodstuff 28, 32 and 36" FE Tunnel builds!
  10. Liftmaster 4s BBY Rigger
  11. JAE Builds
  12. mini cat
  13. HOTR MINI HYDRO build
  14. this is just a thought!
  15. Vacu-pickle
  16. vs-1 fe build
  17. Boogie Board Airboat Rescue Craft
  18. Twin HOTR prop choice????
  19. Aeromarine Titan 29 Build
  20. New 2215 / 2230 mount
  21. H+M micro shovel nose
  22. VS1 FE rebuild
  23. 1/16 shovel nose issues
  24. 2010 Mono 26"
  25. Climate Matrix Ultra build
  26. traxxas villan build
  27. 1/10 Crackerbox brushless build
  28. Scratch build F1 tunnel
  29. Aeromarine Conquest FE Open Cat 10S Build
  30. 30" Balsa Cat
  31. "Soaring Stuff" 1/6 P-Limited Crackerbox Build.
  32. VS1 Clear Coat
  33. Twin Mini Cat, version 2
  34. P-Spec Rigger Set-Up
  35. Sprintcat build
  36. Trini's JAE FE Rigger
  37. ECO Build - "Rush"EVO (clone of Sonic EVO)
  38. Vortex 22" on 2s or 3s
  39. Primus makeover
  40. Scotts E-thundercat build
  41. Help me to choose the color
  42. Just for Fun
  43. spec rigger timing (UL-1)
  44. Wake Maker Mono Build
  45. 10" sub Micro Cat
  46. 1521 1.5d
  47. Snagged this boat
  48. Motor Selection 30" Balsa Cat
  49. Rico mono transom for BakedMopar
  50. Build Problem
  51. Tools and supplies to build a wood boat
  52. A couple last questions, maybe.
  53. Build updates
  54. CAT-Boi's Mystic build.
  55. My Dust collector build,
  56. Finishing Resin or 30 min epoxy??
  57. MRP Fountain - steps and outdrive(s)
  58. Jae 21fe
  59. Intruder Gel Coat repair
  60. My Boat Building Blog
  61. Wasabi
  62. SP40 WHIP-KILLER project
  63. New projects for Littlescreamers
  64. Darin's 28" Woodstuff
  65. MHZ Cougar
  66. It's about time BBY carbon fiber 1/8 scale
  67. Heading Hold Gyro on Rudder
  68. Making a raceboat water tight
  69. 56" cat
  70. Mini Twin Cat Build
  71. Rumdog's Delta Force 33
  72. 16th. scale Finlay Atlas Van Lines
  73. ovalmaster
  74. THE RIPPER Rigger
  75. THE RIPPER Rigger
  76. ops .90
  77. HOTR twin build
  78. Jae cowl
  79. water cooling efficiency
  80. weight of a spec tunnel
  81. Seaducer 26 inch
  82. vs-1 getting there
  83. Lap Cat FE conversion
  84. Twin cat p.eells style (cat scratch feaver)
  85. Help needed!
  86. some tech info needed on a new CAT project
  87. ***dinos mhz mystic113****
  88. Oh what to do now
  89. Rumdog's 1/8 Ms. Elam build
  90. HIPPIE"S VS1 build
  91. Bby war zone jr. Complete build
  92. 50 Feet of 1" PVC+ 28 T's + 20 Elbows = ???
  93. Dumas Atlas Van Lines 40 size FE build
  94. RC Boat EDF brushless **like Spirit of Australia**
  95. Properchopper's Top Secret Build Revealed!
  96. 4 Prop Conquest build
  97. WTB stinger drive
  98. Good spot to buy building supplies !
  99. cat plans?
  100. b uild advise please
  101. 2nd Genaration Skunkworks Kitty
  102. Dual/Twin Drive Delta Force 33 (2x540L)
  103. Drifter M - 114km/h
  104. Blackjack 26 Dual
  105. Syncron build-newbie
  106. 41" Falcon Cat with twins
  107. TS-2 Conversion & Modification
  108. 1968 1/10 "scale" Ealge Electric Test Ready
  109. some pics
  110. `SLOWS' WHIP 20 finished!
  111. Help me pick a motor!
  112. New HOR Cat Rudder
  113. My new N2 sport Hydro
  114. DF Vortex Hydro
  115. My first rc boat
  116. Where can one find z-poxy locally?
  117. Liftmaster Rigger
  118. Rumdog's Sprintcat rebuild
  119. Rico Racing 31" FE Mono
  120. Modified Super Hawaii
  121. PIP Bittburger build
  122. Arowana
  123. Spots 48" Deep-V little screamers build
  124. Post pics of your build area here !
  125. Avenger Pro Twin Makeover
  126. My 39.5" Mono... and 45" df Sniper almost ready for water
  127. Twin SV Powered Cat
  128. Any use rebuilding MRP Miss Bud?
  129. This Cat Is A Pond Bully!!!
  130. 36" Sprintcat with Twins - what motors have you run?
  131. ETTI 150 Opto ESC cap bank install help?
  132. What should all be considered in deciding stuff tube length on a mono?
  133. Build pics of my Aeromarine Titan 33
  134. pic of my 30' cat build. jesse j gave me these plans
  135. Dumas 1/8th scale nitro conversion
  136. website with free balsa cat plans
  137. Does anything like an inner stuff tube seal w/ grease zerk exist?
  138. ESC question
  139. Working out Center of Gravity
  140. Paint for ABS hulls
  141. MHZ Racemaster
  142. H@m drifter s
  143. Opinions on bottom of hull type octura water pickup??
  144. Vs1 fe
  145. Speedmaster 45 Mono Hull
  146. BBY Rebuild Gone Again
  147. Miss Vegas brushless conversion
  148. I want to build a battleship
  149. School me on 55" Twin Cats
  150. Fiji F1 Built Brushless
  151. Another new Cat project at BBY
  152. Linkage question
  153. JAE Props "w/UL1 motor"
  154. "Super" Cobra
  155. whats the deal with chargers that do up to 15 nimh cells?
  156. 1/10 Scale Ted Jones hydro
  157. Jae 12 fe
  158. 380 brushless prop size
  159. Introducing my self
  160. Anyone know where to get some cheap sponsons or pontoons?
  161. Delta Force 29"
  162. Building a Pickle Help
  163. Traxxas Villain Rescue Rig
  164. Homelite shaft size?
  165. Need opinions on best RTR or close, larger FE deep V. (instead of KOS P1)
  166. Castle motor in a 40" mono?
  167. Setup question, twin or not?
  168. Vac-U-Pickle help
  169. BBY Micro Patriot
  170. BBY Oval Master with Flood Chamber
  171. Turning
  172. Minicat amp energy.........
  173. Programming aquastar 120 a esc??
  174. Contoured rubber pieces under stuff tube to deaden vibration? Dumb idea?
  175. Project Apparition!
  176. Best epoxy to use over cap-bank soldering
  177. Gas Sport Hydro Kit FE ????
  178. Simon's 13" Balsa Cat
  179. Simon's 18" Balsa cat
  180. Ride Pads
  181. Sprintcat .40 - "Norm"
  182. ML Boatworks- 30" P-spec Tunnel Build another new one!
  183. Stickers for my Freya
  184. hpr ct04 67 inch cat build
  185. Capacitor banks, use? Or not worth it?
  186. Project Genesis!
  187. Clear coat
  188. Rudder offset vs. stinger length?
  189. Titan Reduex
  190. 34" scratch built cat Plans
  191. Kept my Toysport Triton
  192. Rudder mount break-away hinge with spring latch??
  193. ebay lipos
  194. Boat Painting
  195. vac-u-pickle!
  196. Couplers
  197. Rudder depth beloew keel in titan 33???
  198. Scratch built cat - cavitation problems
  199. GENESIS (36''/935mm) Twin setup suggestions
  200. Bending stuffing tube
  201. use baking soda to thicken epoxy or cure super glue instantly
  202. Mhz Tsunami vs Delta Force 33
  203. West Coast FE Crackerbox
  204. this look about right for the stuffing tube on homemade cat?
  205. New BBY N2 SAW rigger
  206. show me pics of the strut setups on your cat's please!!!
  207. Just got a HUGE hull
  208. Hobbyking Princess boat
  209. Aeromarine Avenger Pro 44" hull
  210. Data request from stock KOS owners
  211. shadow sport .40
  212. F1 Hydrofighter
  213. Delta force 33 copy
  214. D&D's Mean Machine Sport
  215. Jae 12 fe
  216. HK Osprey/Delta 39' copy
  217. Another new Lift Master project at BBY
  218. 1/8th Scale Circus Circus FE Build
  219. Quick and Easy Boat Carry Stand Recipe
  220. Some pics
  221. JAGERMEISTER Mean Machine
  222. ripfence df 26
  223. PVC Outrigger
  224. Suggestions for an EKOS hull
  225. Bought a gfreak hull.
  226. Project 41" Sprintcat!
  227. H&M Supercat... after Paul Pachmayer
  228. U-10 Smokin' Joe's 1994 plan hull
  229. Das Boot - Generic 32" Twin Cat
  230. H&M FREYA mkII
  231. Mamba Monster 2200KV Cooling
  232. castle neu 2650kv
  233. Boat Painting
  234. Decals
  235. Miss Geico
  236. jae 12 fe video
  237. Project EKOS!
  238. '82 Executone, '83 Speedy Blueprinting, '83 Miss Rock KISW 1/8th scale Hydro Builds
  239. Phil Thomas U-10 8700 FE Smokin Joes 1/8th scale Hydro Build
  240. Interest in 34" 1/10 8255 hull
  241. Triton Build
  242. Is this wrong?
  243. i need some good paint scheme ideas
  244. F1 24" Finally finished.
  245. Wizards Pickle build
  246. Fusing catamaran hull together ?
  247. Miss Bud Gen 1 Conversion
  248. 1/12 miss circus or close
  249. Bj26 twin build
  250. Time to rebuild - BJ26 dual
