View Full Version : Boat Building Talk
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. Jet's Latest Hair-Brained Idea
  2. Guys I need some input on the Vac U Pickle Build I have going
  3. Another Fighter
  4. Which ESC is good for
  5. Miss Vegas FE conversion
  6. ? About mounting motor
  7. Darin's LeeCraft/Geraghty 3.5 Tunnel FE Conversion
  8. old school kyosho hurricane
  9. Titan Build Underway Pictures / Longest Build Record
  10. Toysport Jolly "magic part"
  11. counter Rotating prop set up
  12. Tools
  13. Mean machines cheap
  14. hurricane rebuild
  15. How to reinforce my bj26?
  16. Mono strut adjustments
  17. Mono Build
  18. Matrix build
  19. SV27 W/Ouboard
  20. Thundercat 31 conversion build
  21. Link to Buy Carbon Fiber
  22. 1/10 Baby Bootlegger Build
  23. 6s2p pre production
  24. Use BEC or no?
  25. Triton Build Question / Opinion
  26. A day with the Santee Lakes SLOBS!
  27. Oval Master Refurb
  28. Properchopper's VS-1 build
  29. Motor Mount Mods for VS1
  30. Head of The River Cat video
  31. My mm build
  32. DF 29 build
  33. CF Rigger Build
  34. Scratch-built 15" CF Mono
  35. Mean Machine start
  36. Miss Vegas Conversion Done 4 Months Early
  37. thrust bearing
  38. 25" Scratch built balsa ply sandwich HYDRO hull
  39. Rigged confusion, Schumbrecht edition
  40. strut help
  41. Have'nt seen a new Mean Machine build in the past week. So.........
  42. BBY SC21 Redo
  43. Mini screws and bolts supplier ?
  44. crackerbox motor esc options
  45. New 540 Motor Mount
  46. Mtgoat's VS1 Build
  47. New Fleet??
  48. Jolly Cat
  49. Painting hull
  50. hydrofoil power system?
  51. convert my miss budweiser 1/12?
  52. Delta Force: Vortex Hydro
  53. OSE adjustable mount
  54. Hydromites, yes two!
  55. Delta Force 36 - NEU 1521 - 3s
  56. Whiplash 40 Hydro,,,,,
  57. My Micro Hydro
  58. Viper rebuild
  59. OM26 Refurb - Rossi to Stoner
  60. 2 Predators WIP
  61. Mean Machine Build - for Aussie racing
  62. Chop’s PT Boat
  63. Vacu Pickle Hydro
  64. 34 in CF rigger
  65. Flex shaft advice please ????
  66. Deep Vee from scratch
  67. Skunkworks 29 cat
  68. Delta Force 29 (knock off) Build
  69. 1:12 Scale Hydromite?
  70. Phil Thomas ss 45
  71. shockwave 36 brushless
  72. Titan 29 - SV27 Hardware Questions
  73. brushless apache 24
  74. Laser Cutter for under $50
  75. Who was lookign for a 1/10th scale hydro
  76. mm pianted up a bit
  77. ebay cat or mean machine
  78. Titan 29 Refurbish
  79. Krylon Fusion matches Aeromarine and H&M
  80. villain ex over powered ?
  81. Phil Thomas SS 21
  82. micro scat cat
  83. Sport 40
  84. Build Your Own 3-Axis CNC Machine
  85. 50 mph boat whats a good start
  86. scratch build: micro cat
  87. Cat designs for scratch builders
  88. Shim .125 strut to 2mm shaft
  89. robby76 Jolly cat build
  90. Now accepting Canard plans
  91. neu 1521 and 14 cells????
  92. Aeromarine 43" Conquest Cat w/ Lehner 3060/10
  93. setting up my 36inch mono
  94. is this the right drive dog
  95. how to modify a KB45 motor
  96. Boat Tune-up For the new Season
  97. Doby's F/E Fleet For This Year
  98. my continued cratch 36'' mono build!!!
  99. apox. speed???
  100. motor trouble
  101. The Optics of FE
  102. Re build of Striler 41 Cat
  103. Whiplash 20!!
  104. Villian EX conversion
  105. Cooling can o-ring adhesive
  106. MHZ New Mystic C5000
  107. Guys I need a little help here!
  108. villain ex 970 project first run
  109. No boating today.
  110. 40'' Catamaran Motor Suggestions
  111. Mean Machine build
  112. Coming Soon to a Pond Near You
  113. DF Sniper build
  114. MHZ Chaparral FE
  115. my mini hidro
  116. Simon's 4S Balsa Rigger
  117. Outrunner Motor mounts
  118. Stealth build
  119. Help/Advice first build
  120. startup problem
  121. Darin's Raptor P-Spec Rigger Build
  122. Twin wing 1/12th scale
  123. 1/16th scale Bardahl progress
  124. arming problems
  125. Delta Force 33" My Way.....
  126. head of the river cat with medusa motor
  127. new hardware finally coming together
  128. The Barracuda that Chop built.
  129. stickers
  130. Prop selection and setup????
  131. Pay-n-Pak rebuild
  132. Prop Placement
  133. 30" Scratch Built Cat
  134. Building up the Blackjack 26 bl
  135. H&M Drifter S build
  136. 29'' Rico Mono Build
  137. Hydro & Marine 50" mono Build
  138. Not FE but it's a boat.
  139. Help!!!
  140. Stainless turnfin
  141. cat plans
  142. Rico 31" P-Mono
  143. Hand laid fiber cat hull help.
  144. Pictures of Finished Rico Mono
  145. dual rudders
  146. 1st Build DeltaForce 29 mono
  147. 39" DF knockoff
  148. Maritimo build
  149. Diegoboy's Mini Budweiser
  150. Mean machine prop recommedation
  151. Bby unlimited light ul-1 kit
  152. Warning for Balsa Builders
  153. Renegade Rigger...
  154. Decal setting solution
  155. Home made balsa catamaran
  156. need help with plans
  157. Another Pickle Build
  158. Scratch Build Hydroplane
  159. Waterslide Decals - Thanks Jim Stevens
  160. DF 33 cyber storm
  161. Aeromarine Sprintcat 40
  162. 38" H&M Intruder twin to begin
  163. Prop work
  164. Titan 40 (33")
  165. OPC Lower Unit and FE Conversion Kit
  166. Doby's Aluminum Hull, 42" Cat Retrofit
  167. 35 inch scratchbuild Cat from NZ :P
  168. Viva las Vegas BUILD ELECTRIC STYLE
  169. DX3S Owners
  170. Phil Thomas EA Hydro
  171. For all builders working on a hydrofoil...
  172. Doby's New Cat Spring/ Summer Build
  173. Dropping the bottom for motor/cooling jacket clearance
  174. Phil Thomas SS21- Build
  175. H&M Xzess Hydro II instructions
  176. Dave Franks O Boy Oberto Video
  177. DIY water cooling jacket from Neu 2230
  178. BBY oval master 29 vs. Aeromarine Titan 29..Need opinions
  179. Mystic C5000 (44.8 inch) Twin setup suggestions
  180. My First Build Mean Machine
  181. Toysport Triton build
  182. cat biuld
  183. Possible re-intro build
  184. Simon's 30"mono build
  185. How to water cool a Lipo
  186. Viper Turbine.....Miss Budwiser Build
  187. another cat build
  188. H&m intruder s
  189. project x
  190. The boogieman build
  191. Pink Flamingo Racing Team Build
  192. Retro fitting the Blackjack 55
  193. VIPER by H&M Conversion Brushed to Brushless
  194. New Hydro on the pond very soon.
  195. 2.4Ghz AM Radio
  196. Same 30"cat, limited experience
  197. 36" mystic style cat
  198. My 31" intruder s
  199. Prop help
  200. H&m intruder s
  201. New small hydro build. Need your input.
  202. Mean Machine Club
  203. looking for 17 to 20" mono?
  204. A Big Twin Screw Cat
  205. bby war zone jr v-18
  206. Help Me Build My First FE
  207. My peells micro 28" v hull
  208. MHZ Micro Shovelnose help...
  209. K7 Bluebird plans.
  210. Best Way To Attach Motor Mount
  211. Titan 33 gets a little upgrade
  212. 29.5" sprint cat build
  213. Doug Smock This ones for you!!!
  214. Aeromarine 43" Stingray 10s MONO
  215. The VS1 FE Tunnel hull build
  216. 16" Twin Cat Build
  217. Twin Catamaran Question
  218. Not so fast sport boat...
  219. Discharging Lipos
  220. Alvin's Renegade Rigger Build
  221. 75MPH Mean Machine!!
  222. Would this rigger be suitable for BL?
  223. Mean Machine Brushless Ducted Fan
  224. my rescue cat scratch built
  225. Whip 20 on 6s (no vid)
  226. Delta Force 32" Storm!! My new P-Mono!
  227. 6s Rico Racing 31"?
  228. Decal set for Model Rc Segad Class-1 Offshore Racing Boat
  229. turnigy ESC
  230. Blackjack26
  231. Two of these in a 39" Mono?
  232. First Cat 36'' Sprint Cat
  233. UL-1 Build. 55mph+
  234. Darin's 32" WildThing P-Mono Repaint
  235. Mean Machine Motor Mount
  236. delta 26" neu 1515 1y or 8xl
  237. Intruder s
  238. Question for Dupli-Color Paint Users...
  239. 28" WOF Tunnel build.
  240. Balsa Cat Drawings
  241. 15 15 year old Dumas "Short stuff" makeover.
  242. Setup help
  243. My first FE build
  244. My 32" Catamaran
  245. Intruder s testing !!!!!!!!!
  246. Diegoboy's Stretch Renegade rigger
  247. 32" Mono Build
  248. Modded ul-1 esc
  249. Aeromarine Titan 33"- Questions on set-up
  250. P Spec rigger build
