View Full Version : Boat Building Talk
Pages :
3
4
5
6
7
8
9
10
11
12
13
14
15]
16
- Help battery placement on my build
- Kyosho Jet Stream 800 with Titan 1585 14 volt Marine 550 Motor Config Help
- Mhz mystic windshield decal vinyl
- Steering for Dual Outboards
- Scarab
- Has anyone built and converted a Dumas Big Swamp buggy to electric?
- First Time Flex Drive Install Into Hydro
- Scarab
- Help converting drive system on a solid shaft shallow-V mono to flex cable
- Winter Project 50" RSV Mono Twin
- turn fin
- Scarab front seats
- How to wire up twin brushed motors for my Zipkits Tug Boat
- Rudder turn fin position
- Miss Vegas brushless
- Basecoat Paint Removal HELP
- Dumas Jolly Jay build........
- First Build - Delta Force 26
- MHX Mystic 1380 Motor Height 56mm motor
- Delta Force 28 Pathfinder
- brushed to brushless ??
- Paint help
- Custom decals
- Black Pearl II Hydro - 2020
- "Old Wood" 3.5 Tunnel Restoration and FE Conversion
- Nylon breakaway bolts
- Dan-O's SAW Tsunami build!
- Recommendations for someone to finish a build
- Scarab front seat finally done!
- OSE carbon raider
- New to this, trying something different?
- Bob Smith Finish Cure on wood boats
- Eagle SGX 21/4S help
- 6s Rico 31"
- Over powered popye hydro
- Need help
- Scarab cockpit finally done!
- Motor runs after transmitter is turned off
- H&M current quality?
- Proboat Zelos 36' custom build questions
- Hydro - water outlet on the bottom?
- TFL 34" carbon fiber Cheetah Twin
- Fightercat Daytona w/1717
- Skunkworks gen 2
- Venom Fountain 56" P1 KOS gas to electric conversion
- 38kv scarab build?
- 36" aeromarine cat build follow along
- Scarab is finally DONE!
- Carbon fiber tubing
- Q-Sport Build of Shooters New Pearl Design
- Need help to power my 65" long "Klondike"
- Just starting out
- Thinning Epoxy
- ML Boatworks GSXn 380
- New Build TFL 35
- Advice for Engineering Test Bed Build
- ML Boatworks GP310 Build
- 1/8 SCALE 2008 U-1 Ellstrom E-LAM Plus
- MHZ Racemaster build...
- Problem with my Battery/ESC/motor combination
- 36? Aeromarine Avenger? Out of hibernation and Round 3 with it .
- Looking to power a 28 inch catamaran
- New Build Raider M34 CF
- Aero-Naut Air Marine Special build.
- First boat glastron cv16
- Problems to put the 8S Lipo's in MHZ 114
- Finishing "THE GECKO"
- Laying out the internal components
- To build or buy... what?s worth the cost?
- Motor Mount install
- How high to drill hole intransom for DF23 mini Sniper?
- Balancing a cat - How sensitive is the CG in boats?
- Project Zelos 36 Twin Revamp
- Graupner Systems Resurrected
- New scratch build 24" mono
- Raider m34 CF Equipment installed Need battery pick
- Outerlimits SV43 build
- Is a seperate or combined prop and rudder assembly better for a wooden rigger build
- Hpr
- Graupner Taifun X-Cat
- 1st Electric Mono Build Help
- Is this propeller angle right?
- Prop shaft sealing methods
- 36 inch rigger slow
- 31" Catamaran Scratch Build - Fireball
- Flatbottom ski boat convert to electric help
- ProBoat Sonicwake 36 Upgrade - Build Log!
- 2Questions
- Shockwave 36 Revival / brushless build 2
- Scarab-style "scratch" build
- Super Hawaii Build
- Am I on the right track?
- First boat build battery plug help
- Speed master 21 strut
- Scale Hydro plans
- removing motor mount from 36 miss geico
- Tinting epoxy.
- Where to buy 1/8" carbon fiber plate?
- Nitro to brushless F1 tunnel hull
- Outboard build
- Glue to use on motor mounts
- 36 sprint Ć/G
- MRP outboard help?
- Waterproofing boat
- Finding a paint color made easy
- Df 53 Annihilator setup Q's
- 36'' Catamaran new build
- F1 balancing?
- Jersey skiff decals
- zelos 48g to e conversion(new hull)
- Pack n Pay 1/10 Hydro
- Sheeting materials for a Whp 20?
- Equipage Riviera 80 windsheild
- Ml boatworks 1/8 scale newton 138/mhr 8255 kit
- MHZ XCAT 1400mm (55") build.
- H&M Freya hull finishing
- Aeromarine Status?
- Motor Size for a twin electric 980mm deep v
- 26? self righting impulse hull
- m34 raider
- What adhesive system is best for bonding on carbon fiber hulls?
- Any advice on Aeromarine build much appreciated.
- Baby sv43 twin build
- DF Pirate 35 build - need advice
- Carbon fiber cloth
- Zippkits jae 21fe v2 outrigger_wood kit build
- Servo bracket help
- Hull?????
- hpr 233 build
- Delta Force Vortex 34 build info?
- MHZ Alligator 1250mm 49" outboard build
- Delta Force Pirate build
- Delta Force Explorer build question
- Launching handles
- Thunder Tiger Olympian - Which shaft, strut, and prop on the rebuild?
- 40mm X 80mm HRC O rings
- Scratch cat V3... XCat
- New to boat building and introduction
- Boat balancing
- new project
- Moving into boats from planes - plans needed
- Can Anyone Help me ID this Cruiser?
- Joysway Razor 37 inch bare hull mono assembly
- Twin cat motor rotation?
- Intro and Harbor Freight boat build question
- Looking for someone to finish set up of my MHZ Mystic 114
- O-ring type cowl hatch?
- 48 Insane Synergy T mono??
- Titan 33 stinger strut height
- Stuffing tube and servo mounts?
- Hydroplane Hull from Modelshipsahoy - is it worth my time to make it run?
- PT Supersport 45 FE
- reinforcing zonda with cf
- mystic motor
- Electric conversion
- Hydroplane Hull from Modelshipsahoy - selection of running gear
- Early Bud Gold Paint
- Carbon inlay hatch tips
- prop choice for twin DF41
- Wanted to share my first rigger build
- Question about building a foam rear ski with plywood sheeting for rigger
- Wanting to twin a DF 28 Pathfinder
- New to the RC Boat building, looking for advice.
- My custom mini sprint FE build
- TFL Patron Saint "Outerlimits" "Lucky Oct" 1330mm brushless buid
- Zelos 48 G electric conversion build
- Custom decals
- Powertrain help please
- Power setup for a 50" mono hull boat
- Taking retrieval craft to the next level
- Converting on Outboard Tunnel to FE.
- Dragon 89MPH SAW 4S Outboard Record boat details
- MLB GSX338 V2 hydro canopy
- Van's Racing Hornet 7.5/11cc OPC Tunnel FE Conversion
- 171 Extreme Build - 1/8 Scale Boeing
- Skater 47 twin repairs/rebuild
- Ml Boat works 1/6 dual build thread, Newton 164 and 172.
- SR80 pro mod - issues
- New to boats
- ML Boatworks Rescue Project
- Delta force mini sniper 23 build for newbie
- Mini Zonda build
- Boat Hull inlay
- Best way to assemble a wire drive
- Need guidance / help - What hull and setup for my kids
- Carbon Fiber TFL cheetah hull question
- Can you split single water pickup
- Mr Krabs build - any hints?
- Delta Force build (bought part build
- Stable 180 km/h build
- Water Pumps for Cooling - To 'Push', or To 'Pull'
- First time builder in need of help
- Miss Enforcer 55" Hydro Electric Conversion
- advice to lay fiberglass on plastic hatch
- MAeromarine 48 popeyes build
- Zonda TP motor recommendation
- Which TP Motor, Windings And Lipos
- Mini mono hull recommendations.
- 1st Scratch Build, $70 Rescue Boat.
- 3\16 flexcable
- Rescue boat build questions
- MHZ Hunter brushless build
- NE-Stuff website updated with new links for PDFs that previously were broken
- Cnc wood boat kit by RC builder.com ?
- Twin seaking 180amp setup
- Water Cooling... Dual or Quad exit for Dual Motor Setup?
- making flex shafts
- Seeking Hull Finishing/Epoxy Coating Advice
- Paint for a Prather Hull
- Prop position = prop transom lift leverage?
- New Builder: DYMotorshop 750mm Mono - High Deep V "Jack"... watch me learn!
- stuffing tube and strut question HELP :)
- best way to secure a sleeved stuffing tube
- Anyone use a TFL flex shaft oiler??
- SO Im a newbie and had a rudder rip out and split transom, trying to repair the right
- anyone use true composites carbon fiber repair?
- Fixing battery tray to hull
- 32 inch F1 Tunnel build: Cozy F1 T800
- 3-D demon 44" mono hull build
- Stinger Mounting position
- Pursuit jet boat
- Building a proboat Impulse 32
- Vortex 34 info
- Want a mini hull
- 2215 powered cat and mono
- Adhesive for fiberglass hull
- Wolfman Racing P Cat - ?The Wolverine?
- Slow build - 8S Twin Cat
- Need pro help for great planes wildcat
- 72 inch ExpressCraft V haul build
- MHZ Chaparral build
- Strut, stuffing tube question
- Bonzi epic 60 build
- Plywood for boat building... Q's
- Rudder stand off bracket
- Phil Thomas Stealth 45 Q Sport Build
- Stuffing Tube Curvature and Resonant Vibration
- Hydro Strut and Rudder Setback
- Resto/ID Questions About an Old Dumas Tunnel Boat
- Liftmaster twin Oval
- 17" Scratch Cat Build Questions
- trying to get better flex shaft alignment to motor
- Piano Wire Drive vs. flex shaft drive
- Helion Rivos/ volantex vector 70 motor question
- Hobby 3D Printed Boat Components
- DIY Boat Stand & Travel Bag
- Zipp Kits JAE 21FE v2 33" - Carbon Fiber Wrapped
- q-sport cable size
- Assault Racing Designs Warrior
- Sprint Cat 42 FE Rebuild
