View Full Version : Boat Building Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16
  1. !/8 Scale Rudder Placmnet
  2. Looking for carbon fiber cloth
  3. Motor suggestions for resurrected Campbell LSH
  4. HPR C5009 Bulletproof Mystic
  5. Miss Vegas Conversion #154287548
  6. Blackjack 29 build
  7. I need your help
  8. Removing Fiber Glass mold release agent
  9. Vintage Firehawk FE build
  10. TS3 FE setup help
  11. What setup to use.
  12. Osprey.
  13. Is this worth it
  14. Rudder Control Rod
  15. Vintage MRP Miss Budweiser build
  16. Boat identification and ideas.
  17. Proboat Stealthwake 23 brushless conversion
  18. WT Find Square drive parts?
  19. Looking for help setting up a twin outboard V hull Fine design 32.
  20. How to install brass tube properly?
  21. Tomahawk 32 RIB Build Twin Outboards
  22. Getting back to 60MPH
  23. Blackjack 29 v-3 question?
  24. First Build: 42" MRP Fountain
  25. Delta Force Pirate hull reinforcement.
  26. Delta Force Pirate trim tabs and turn fin recommendations please
  27. Leopard 4082 for my Pirate?
  28. New TFL PURSUIT BUILD
  29. Dumas Scarab 60 build finaly
  30. Repair a cracked hull
  31. Still doing props
  32. These look awful big for my Pirate
  33. Dumas hotshot 21 #1313 build instructions
  34. Anyone good at building scale hulls?
  35. Is this what I want?
  36. Building 45" AM Vector & some questions
  37. Thread size
  38. Beginner seeking advice on electric power of Scarab 45" intended for glow power
  39. Vintage Graupner Tornado Hydro build from NIB need opinions on what to do.
  40. Who’s interested in a Zelos single build thread?
  41. Osprey Offshore Endurance Boat
  42. 37" TFL Genesis single motor SAW build
  43. Seaducer P-limited Mono
  44. Which hull for which class? P mono and P spec.
  45. Power question
  46. Dual Engine DF Vortex34 Build
  47. Auqacraft ul1 build
  48. I/8 Scale FE Hydro Motor /ESC Colloing Wate rlines
  49. ML Boats RSX 310
  50. My UL1 build is finally done
  51. Sealing Struts with Lip Seals
  52. 145 cm. sportfisher boat..
  53. UL-1 Repair and Modification
  54. ML GSX338 V2 P Sport Hydro 1st Build
  55. Delta Force Vortex 34 build
  56. Zipp Kits at Toledo Show
  57. warped plywood fixing
  58. Conversion from Dumas 55 KV to Center Console Cigarette w/ Twin new X-Cat Outboards
  59. ML RSX380 FE Outrigger (First Attempt)
  60. Aluminium offshore powerboat build
  61. 1/35 scale S 100 Schnellboot RC conversion build help needed please..
  62. AML Sprint Cat 36 conversion
  63. Want to switch toward electric race setup
  64. ML Boatworks
  65. Engine mounting question
  66. Flotation
  67. Buffing out a Small Scratch
  68. COG Catamaran
  69. 42” Aeromarine sprint cat
  70. Fiberglass Repairs Top Coat?
  71. How to Eliminate Slack in Green RadioPost servo?
  72. Securing Batteries
  73. Flex Shaft Lube
  74. I have a 2200kv Castle motor... what to do with it????
  75. Cutting access port in fiberglass inner wall
  76. The Monster Horsepower Villain IV project ...
  77. twin AC R42 build
  78. Venom Seagad 34" single brushless Cat
  79. HPR is Out of Business (Again)
  80. HPR C5009 upgrade - goal 105 mph
  81. Mini TFL Zonda Carbon Cat build
  82. Fuller hardware....need contact
  83. first scratch build at 1:16 scale motor questions
  84. Single Genesis upgrade
  85. Universal joints
  86. CNC anyone ?
  87. F1 onboard plans
  88. Aquacraft ul
  89. Drilling out fiberglass holes?
  90. 25.5" Exceed Flowmaster Catatmaran
  91. prop
  92. JAE33FE Build
  93. Whiplash 20 FE, refinishing
  94. ML Boatworks Vision 20 and 40 tunnels carbon and glass
  95. ML Boatworks Florida Flats center console fishing boat, from design, to plug, to mold
  96. React 17 brushless upgrade need motor suggestions
  97. Delta force cyber storm 33 P-limited
  98. Jersey Skiff Build - Natural High
  99. Trim guide and hull tuning questions
  100. Chrome Plating
  101. Need some advice on an upcoming build
  102. Delta Force Mini Sniper Build
  103. Sharpen rudder and turn fins?
  104. New build
  105. spar urethane sealing inside wood hydro
  106. Repair chipped part fibreglass boat
  107. New Zonda full CF 980mm
  108. sealing old mylar boat decals
  109. wanting to build a 36 sprint cat with Twins
  110. Cheetah Twin build - ESC and Battery locations ??
  111. Standard or steerable drives?
  112. WHY is MTC so popular
  113. AquaCraft UL-1 motor and esc in a rigger
  114. Cat Prop Spacing
  115. Delta Force 26 mono build questions
  116. Mono 33" Twin Setup, build advices
  117. TFL Outboard
  118. Brushless & LiPo conversion
  119. How to repair CF Zonda/Phantasm hull top separated from bottom?
  120. motor size?
  121. “A Little Bit of Tunnel Vision”
  122. Brushless & LiPo conversion
  123. Not sure what kit this is or how to convert....suggestions welcome
  124. Revived CEN Aquajet!
  125. DF Pathfinder 28
  126. Phil Thomas Super Sport 45
  127. Project: Ugly Cat
  128. Proboat Mystic 29 Salvage Rebuild
  129. Blazer Marine Sport 20 Electric Build
  130. 48” Aeromarine Challenger T Mono Yoskimmity Clam
  131. Motor Mount Suggestion
  132. Boat Build/Conversion - Prather Deep Vee Brushless Conversion
  133. New Twin Cheetah build
  134. New Twin Cheetah build
  135. 10S mono
  136. RC Powered PWC?
  137. ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  138. Gel coat repair
  139. Has anyone ever experimented with UV activated epoxy?
  140. Hydro and marine 1/8scale hydro build
  141. Pro Boat Shockwave V26
  142. Bending a stuffing box tube
  143. Another first time boat builder Info Request. Zonda, Fountain.
  144. Invention of a new hull and drive design
  145. Power system question for new Catamaran Build
  146. Question regarding size of batteries and prop
  147. Dumas SK II as a FEit up and
  148. gas to electric conversion
  149. Strake Question for Catamaran Build
  150. Bonding Carbon fiber motor mounts into a hull
  151. New to FBG, What paint?
  152. cutting 1/8" plywood in stead of lazer cutting- what can i use. Winter project.
  153. Genesis Hull Pockets
  154. Scarab Sport boat
  155. I realize that this forum deals mostly with inboard drives , but
  156. Photos Dumas SK 2 build as a FE
  157. Titan 33 slap job built in 2009 complete re-do one year ago , delayed post
  158. TFL Stinger outdrive rigging dumb questions.
  159. Another lonely boat followed me home...
  160. Zippkit Crackerbox
  161. First FE tunnel build
  162. 36” Aeromarine Avenger ... I need to just finish this thing
  163. Does the stuffing tube end at the strut
  164. Feedback on my first boat design.
  165. The Black Pearl LSH Spec Hydro 2019
  166. Need help with genesis build
  167. Jb weld for motor mounts, you ever doubt it?
  168. Rocking red Rico P Lim mono
  169. velcro straps
  170. Stuffing Tube
  171. Another tunnel hull
  172. Miss Geico 29 V3 winter build
  173. -Proboat Miss Elam Full Rebuild-
  174. 10s MHZ fountain Rebel with arrow shark outdrive
  175. Has anyone toyed with this?
  176. Twin P Cat +100KV Outside Motor?
  177. 1995 Smokin' Joes Build
  178. sponcor decals
  179. Dumas DV-20 (1976)
  180. Sniper 45" Driveshaft height above keel
  181. FE Backlash
  182. Atomik Fountain King of Shaves P1
  183. airbrush recommendations
  184. How have you set up your Raider 34?
  185. Venom Segad 55" brushless conversion
  186. 45" mystic
  187. White scale outboard
  188. Dumas Deep Vee 20 Plans
  189. Hardware for HPR 135 build
  190. Zippkits/Vbox on 16 cylinders
  191. Rudder shear bolt?
  192. Fightercar Rivercat 32" carbon Bud Select
  193. Expanding / Marine Foam
  194. Polyurethane (2-component) varnish vs. epoxy ?
  195. Traxxas Villain EX brushless build
  196. 38KV Scarab scale build is back...God help me
  197. more Scarab pics...
  198. HPR cats.
  199. recommissioning / finishing my HPR 115
  200. First build-54" ebay hull
  201. Later-Model Dumas Scarab 38KV > AVS Build
  202. Flex shaft oiling?
  203. Blackjack 29 V3 rudder assembly
  204. Help with esc and motor for jae 33 fe
  205. Looking for someone who does fiberglass repair in SoCal
  206. Need Help With My Project - Phenomenon
  207. Molds are finally done!
  208. These: Stringer drive placement
  209. The "perfect V"
  210. Turn Fin Orientation?
  211. A pair of stunners- MLB-Vision 20 and 40 Race Outboard tunnels, Orange Metal Flake!
  212. Cutting a flex shaft?
  213. Scarab Weekend!
  214. 48 inch open mono race build info
  215. Vans Racing Taboo goes FE
  216. Hydrospeed - getting the old girl back on the water
  217. Scarab Update!
  218. Scarab Pics
  219. Hydro&Marine La Grand Argentina 1500mm deep V.
  220. Does anyone know where I can get plans for CNC
  221. carbon fiber reinforcement
  222. Rockstar 48 Gas Engine is fussy
  223. Rescue boat
  224. hull rc boat how these repairs
  225. Leopard 5692 Motor rotates in ose-80927 mount
  226. center of gravity suggestions
  227. Home made outboard
  228. Wooden home made boat - 600mm
  229. 1/12 scale miss budweiser
  230. Tunnel Boat Build for TFL Outboard Motor
  231. Drilling Cooling Pickup in Rudder
  232. miss geico 17 conversion
  233. 1/10th Scale 8700 ML Boatworks Hydroplane
  234. 72" Mystic Build ONE BIG OLE CAT
  235. Scarab Update...
  236. 70" CRC Outerlimits Electric Build
  237. Miss Geico 29 v1 or v2?
  238. Soldering Scarab Stuff
  239. Powerful jet boat for rapids !!
  240. Modifiied Cat for Recovery Boat
  241. Noob found a 63" hull to build- would like input
  242. Dumas Miller American 1985
  243. Delta Force 28 Pathfinder
  244. 55" C1 Cat twin FE build
  245. Setup advice on an old 31" Prather Deep V that's gone brushless.
  246. Do cowl locks leak by design - Never used them but would like to
  247. Classic 70?s Pickle Fork build
  248. ML Boatworks GS480 tunnel Kit
  249. Smash Shark Twin setup
  250. Scratch Built Balsa Hood for Electric Outboard
