View Full Version : Boat Building Talk
Pages :
3
4
5
6
7
8
9
10
11
12
13]
14
15
16
- HPR 135 build - Questions on glue/inserts & cooling
- how to install decals
- Lehner geico build
- Blandon's P-Limited tunnel build
- Hydro rudder placement
- Need help!
- Waterproofing the Mean Machine hatch
- New to boats, need help!
- Jet drive set up
- Prop shaft to flex cable - solder vs epoxy/loctite
- Radteck 233 which servo
- Anyone have fiberglass experience?
- Help newbe
- Vortex34 Hyper Sport Hydro
- !/8th scale "92" Miss Bud
- Q: installing 8" carbon battery trays in Cheetah
- Carbon fantasm twin build
- Time for a Mean Machine
- New Cat build!
- Johnny's HK Flowmaster
- 10mm brass tube and flexi shaft
- Question about mbp smart drives
- 600mm prowler boat "budget" build
- New cat build from scratch
- Dumas Windy Airboat Drawings
- Finally gettin' a round tuit
- Mystic 138 First Rc Boat assembly.
- Need some help (ideas, feedback) with laying up a hull(s)
- Prather Commander / twin TFL P1 drives
- Daytona 37 (Genesis) Canopy Template Available
- ARPRO. Boat
- Help for big-ish, slow boat/cooler...
- My first rigger build (Etti Demon)
- Darin's DYMotorshop 33.5" P-Mono Build
- Motor decision
- Delta Force 29 mono
- Dumas 1949 Chris Craft 19ft Runabout build
- Best Boca Bearings Recommendations for Drives? For High RPM... (SAW)
- BBY's Proto type HSOM-28
- My Traxxas Villain aka Mischief-Maker
- Revolt 30 rebuild
- newbie starting my cheetah build
- hull twist
- Outboard pursuit
- Traxxas Spartan Motor upgrade
- Delta Force 35 in. Pirate from OSE
- Repaint Miss Geico V2
- Vcat_2.0
- Driver, winshield, and dash for a thunder boat !
- Darin's 26" Darkhorse Mono - Ver. 2.0 Build
- Surface drive
- 1st Boat - Maxcat 28" - lots of questions
- how to set up a twin genesis
- Gelcoat vs No Gelcoat (HPR-Powerboats)
- Where to get straight 0.078" wire
- DF Mono Build Tuning Question - Current Draw
- HPR 010 Mono: Very Slow Build
- My boat look like a skipping rock on the water. Please help!
- Broken Off Screw
- a canard JAE build
- Inside hull painting / finishing
- Motor Mount Help
- Aqua Newline 20 needs all the hardware
- Help me go faster
- First build: HPR135
- Brass liner resistance
- Revolt rebuild
- Keps .21 Rigger.
- My hatch bolt method step by step
- Ml Boatworks RSX310 Rigger.
- HELP!!! NEED HELP WITH MY 1st Fe BOAT
- supervee 27 1600kv?
- JetChopper30 mono oval racing setup
- Waverider navaho
- Club racer Q Mono.
- Fighter Cat Cheetah first build
- Pursuit mono floodchamber build, first
- A new way to create a self-righting flood chamber?
- beed strut help
- Northwind 40 Conversion
- Forward Thinking Cyberstorm P-Ltd Mono
- My first construction, mystic 114
- Big cat conversion
- 1/8 Scale Winston Eagle Hydro
- Drawing and parts list of drive line installation for mono
- Plwood Choices to start building a 36" catamaran
- V-Cat - new version
- Central rc sv40 70"
- 50" Deep Vee, leopard 5698 835kv, 12s
- My JAE 21 FE....and a bit of a problem
- Looking for Mercury Outboard Decals
- Help me with my first build: Delta Force Explorer 36 cat.
- 70" stepped V,single brushless or gas?
- Tp 3630 and ul 1 water jacket
- Newbie needs some advice
- Spirit of Australia
- JAE 21 FE photos
- 1991 Winston Eagle
- 29.5 Delta Force mono rebuild.. (about to start) need help...
- Predator Outrigger Design Changes
- Outrigger transom bouncing - need help.
- Delta Force 45MKII - Ambitious first boat build
- cat hull selection
- f1 plans
- Looking for a recommendation on a digital solder station
- Who's interested?
- Shockwave 36 conversion
- Project VooDoo mono build
- ML BOAT WORKS GSX310 or GP 310
- My first Build
- Looking For a 36" Cat Plan
- JB Weld set up
- Traxxas DCB 41 - Bare Hull Available
- Outboard leg advice
- Hpr 135 cog
- 1991 winston eagle 1/8 hydro turbine tube
- Larrys DF Vortex 34 Hydro
- Avenger sillyness
- Location for water cooling pickup inlet
- 2017 Build Log - Jet Chopper 30 Hull
- Fweasel's Delta Force 26 carbon mono build
- Ac Boats Edge Sport Hydro
- The Black Pearl P Sport Hydro 2017
- Newton Marine 8th scale plans
- Proboat stealthwake mods and build
- HPR 115(Average White Boat)
- Hull repair
- 36 inch Hopper Tunnel electric conversion
- castle 6.5 connectors
- Need the correct epoxy to metal glue
- This is how it all started
- My first 50" catamaran. need help
- Aeromarine Vector 10s
- Help with nitro conversion to electric
- Help on lindenburg Constellation Rudders and motors
- First time carbon inlay
- Best epoxy to pour into bow?
- HPR 010 Mono ULTIMATE Edition - THE LAST
- Kev's ML Boatworks GSX380 build
- Crusader.
- Mhz 2400 power house build
- Twin mono build couple issues
- Q Mono motor for heat racing.
- Stuffing tube
- Mhz 114
- Flex cable
- Traxxas DCB M41 single to DCB M29 twin conversion
- Bonzi Epic 60 project with twin electric and twin Arrow Shark M8 Drives
- Shockwave 36 conversion to Twin Electric TFL_P1 drives
- Mystic 240 Torqstar
- DYMotorshop 17" Carbon Mini-Mono Build
- Deltaforce Hulls, fit finish, etc...
- Newbie with electric power questions on scratch built cat.
- Rudder link preferences
- Soldering 101
- HPR 115 - Bulletproof Layup (Miss Geico)
- Wooden Hull (fibreglass) ??
- Shockwave 26 build? Yep, lol.
- Hobby king Apparition II
- Need help with fixing a build???
- Hull Bottoms
- ESC Cooling Plate
- Zonda build
- Supervee 27 new build help
- What size servo for a Zonda? Is a high torque servo needed?
- Carbon or carbon/Kevlar inlay on carbon fibre boat?
- Tenshock/Minicat Racing Micro Hydro with a difference!
- Tfl apparition
- Best collet
- Almost but ........
- TFL Genesis twin rebuild
- VENOM 56" King of Shaves Fountain - Electric Conversion
- pursuit motor suggestions
- RandyatBBY is building a Whiplash
- Motor mounts for TFL Cheetah. Need help!
- Traxxas M41...water leaks
- Marking carbon fiber cloth
- Mean machine build
- Mini Hydro Build
- Radtek 45 steering issues
- 1990 Aeromarine flat deck Scorpion
- Genesis problem
- 2002 build Ovalmaster 21 offshore refurbish (Hi Randy!! thought you like this)
- Lady Nelson By Amati
- Traxxas blast driveshaft size question - upgraded to brushless want metal coupler
- Stuffing tube
- Strut bushings
- Converting a venom e.k.o.s to single drive?
- Graupner B24 volvo bat boat
- What is your favorite Powerboat / Offshore / Sponsor logo ?
- Micro 12" wooden boat build
- Paint problem
- Replace strut bushing Toysport Jollycat
- How to put battery trays in bby scat
- Catamaran Hull Struggles
- MonoHull troubles
- Zonda motor mount
- RPM for H and M rigger
- Modified scale rudder hydraulic rams for 73" Mystic cat.
- 12s rigger prop
- Found a great product for sealing wood boats
- How to loosen coupler
- ML Boatworks new SmugMug photo sharing page!
- When to use what size flex cable.?
- Nordic Emergency Tug Vessel
- Aero Marine Avenger
- Fishing boat and prop size
- Contemplating building a rigger for fun
- Mock turbine exhaust and cowl for 73" Mystic?
- Hinges for large scale hull canopy?
- Great Sealant
- ML Boatworks GP310 build
- F1 32" hull hardware suggestion
- First Build Advice
- Would you......with 5 minute epoxy?
- BK wildthing restauration
- Thru Hull Dual Water Pickup Mounting Question
- What Paint
- Tinning Flex Cables
- Flex shaft couplers
- Fightercat/Cheetah Insanity Build
- Help needed: "Open"canopy for my SV43,
- Need my head examined...
- Has anyone build any of the classic hydro kits
- Painting Supplies
- 27" carbon cat black edition build
- HPR 5009c bulletproof build
- Max Weight , Rule of thumb?
- GP 400 rudder offset and setback
- GP 400 CoG
- Carbon Fiber Cloth
- Help choosing hardware for hydro
- ML Boat Works 166/MHR 9601 Build
- GP 400 Ode to O'berto...
- Hobbyking Osprey build
- boat builder needed
- UL-19 Questions & somewhat build
- Best way to strap in battery Packs es
- What's up guys....I'm back! Now tell me about these scale TFL drives!
- Old member....new build....scale build...
- New Rescue Boat
- Exceed Flowmaster 650mm
- seaducer p mono motor selection
- New C5000 build from scratch
- best place to buy building materials
- Cheetah build (cat problem solved)
- Bow Trim Tabs.
- monokote covering On boat
- Carbon Fiber Puruit
