View Full Version : Boat Building Talk
Pages :
3
4
5
6
7
8
9
10
11
12]
13
14
15
16
- mickiebeez Marathon River Race jet Boat
- New addition to the shop for building, fixing, and modifying
- Flat Bottom model hulls vs prototype designs???
- 8255 Driver
- ML Boatworks 1/10 Miss Renault.
- JAE .12 Rigger Christmas Build
- Fightercat Cheetah Twin Build Question
- Scale model V-Drives and such..
- Tunnel hull plans wanted.
- 32" apparition cat help
- Strut screws
- The Spartan project
- SC33 cut down to 27 inches
- impulse 31 with kehrer 28 mm jet
- Lehner Rivercat build
- flex cable
- 2S scratch cat 24" Jesse J mods to shocker plans
- twin lynx cat
- Carbon Fiber Inlay Tutorial...
- Dumas 45" Scarab
- central rc 53" skatercat build
- Rick's GP310
- KBB 45" build question/assistance needed
- 45" Everingham Build
- Advice Please - Painting a Wooden Boat
- DF pirate 35 build
- 1st build, got some questions.
- Cat build advice
- Mini Rivercat redo
- Cozy F1 Tunnel - wood build
- Found an unlabeled motor.
- Set up for 24" mono
- need suggestions please Predator rigger battery tray/hold down
- surge crusher
- My random builds in progress
- Hpr 150
- Project Fast Cat
- Wire Lengths???
- Need help!
- stinger
- MHZ 114 High End Build
- ML Boatworks- International Hobbies Seebold Tunnel Sport kit- build thread
- KEPs T2 P-Spec Rigger
- Exceed Racing Flowmaster Catamaran 650mm build help.
- Any Delta Force 34 Hydro Builds? Missed You Guys - Back After 5 yr Hiatus.
- West systems
- 40" Keith Bradley Donzi V
- Brushless conversion of a Musculus toy boat
- I need carbn fiber strips, Please Help!
- Kbb 34" mono build
- Polyester resin vs. Epoxy resin
- jae fe rigger tub height
- Cg on hydrostatic
- Another Miss Geico 29 Build...
- Designing a turn fin (What size and Shape)
- rudder, flex shaft
- New rigger
- 27" Vee toy hull, full modification..........yep another
- A different Rudder Placement question (Advice appreciated)
- SprintCat .40 for Q Sprint and Offshore
- 42" deep vee dual voltage? flood chamber?
- Motor Cooling Jacket tubing
- Prather lap cat, converting to electric
- 1/8 scale ml boatworks winston eagle lobster extreme build
- Shockwave 26 Repower/Improvements
- cooling tube ferrules/ hull trim rings for hose
- scratch built spec rigger
- Rearwheelins Rumdog Re Do Rico 31" HD Speed Version
- Stuffing tube angles on jersey skiff
- Central RC SV43
- ball bearings for wiredrive
- Daytona build question
- Water Proofing and Painting Wood Hull
- Looking for a motor mount tester.
- Strut Rudder
- Dumas Scarab 38 KV 55" " Miami Vice"
- I might be nuts, but heck with it...
- rudder push,pull linkage set up
- Epoxy or gel coat paints
- Aeromarine Challenger 48 build (First Real Mono Build)
- bending stuffing tube
- Venom King of Shaves P1 Mono Build.
- HPR C-5009 build
- 41 Fightercat Fantasm
- MHZ Lizard Extreme MGM LMT Build
- 1st Build Mean Machine 2 - guidance appreciated
- Placement of motor and rudder assembly n' stuff
- Need Hull Advice!
- Rico 31 motor
- sealing wood boat hull
- Graupner Hydrospeed
- genesis build need advice !
- Painting a hull
- Huge thrust tow barge!
- 550 size motor Cooling
- Nitro Kyosho Jetstream resurrection w/ a Brushless twist
- Painting my Shockwave 55 the primer is creaking!!!
- FDM 32 V-Hull Build - Need Build Advice
- Zonda cat single motor conversion build
- Glass or CF Cloth Weight
- Drag boat
- ShockWave 55 rebuild
- Pool noodle rescue boat
- Upgraded UL1 Flex shaft
- EKOS C1 Component Recommendations
- When to trim my laminated Cheetah hatch with Carbon Kevlar??
- TFL HobbyKing Outerlimits
- Wanting to build a cat - Need advice from the pro's
- Where to Find Teardrop/Air Foil Carbon Booms?
- just finished my daytona
- Hydro and Marine Lobster
- Delta Force 33 Cyber Storm build log and questions
- DF pirate 35" first build
- MBP Outerlimits 96 Bulletproof Build
- Water jacket and motor problem
- Braided Cooling Line Covering
- Chris Craft Project
- Twin powered carbon Rivercat build
- New Q Hydro Build
- Genesis powered by Leopard
- My new 34" mono build
- 32" Rivercat - first build
- Cheetah Repair
- Motor Mount question
- Custom paint
- Fiberglass Fightercat Daytona Transom Repair
- looking for advice for new phydro class
- How should I wire this?
- Carbon fiber and other questions.
- MBP 96 single 8s
- cog question
- C1 Flowmaster 920EP
- Genesis COG
- Drilling fiberglass hull
- water outlet sealing
- The TFL Scale Build has begun....
- Can some please help me out
- Custom Impulse 31 LED's
- Impulse 31 Build
- How to find CG
- painting help
- Dumas Hawk 3.5 new build FE Conversion
- Rigger 3S
- Anyone here work with CAD?
- Aeromarine xxx 45
- C1 Flowmaster rebuilt and upgrade thread
- TFL P1 Outdrive Scale build Part Two...
- TFL P1 Outdrive Scale build Part Three......
- Custom-designed mono
- Trying to modify Servo Horn for Push Rod swivel
- Reciever box and antenna location
- BBY UL-1 Sport Hydro
- MHZ 138 - McLaren Theme
- KBB mono with MTC hardware
- tools to have
- General questions about twin cat
- Hobby King Apparition Help
- 1:8 scale Unl. Hydroplane U-88 Schumacher, Full carbon fiber hull & CNC made parts
- MHZ 114 tank build
- HK Apparition Flexshaft
- Flex shaft to prop shaft??? silver soldering
- Boat Trailer
- Seaking 180 v3 is too tall I think? Need advice...
- Modifying round drives for more lift??
- Sponson savers
- Trim tabs on cats?
- MHZ 114 RTR Build
- 23" OSE Mini Sniper Build
- Rigger HYDRO1 ( NAVIGA)
- HPR 115 Build
- X-Cat World Series
- Modifying Shocker Ride Pads into "Mystic style"?
- 39" HPR 99 Bulletproof
- Tfl arrow rigger build and setup
- is this worth fixing
- Another Retrieval/Rescue Boat
- M-1 Supercat XL
- ML Boatworks KL350 Hydro.
- Alternative water proofing??
- OS Lower unit maintenance
- Rtv silicone???
- How to apply a Mono Jeff Cheetah windshield decal??
- Jacking plate
- Paint and preparation HPR 233
- Newbie considering Blazer Slingshot to electric
- cut a flex shaft
- TT Outlaw Obl JR - Rebuilding
- Chrome Drives for Radteck 233
- Jet Boat Recommendations
- Aquacraft VS1 Brushless Conversion - Need input :)
- Advice: Rudder Setback in Relation to Prop
- Carbon shocker build
- Next Best Flex???
- Carbon fibre tape
- Where to Buy parts
- 46" prather commander 2028 build
- ML BOATWORKS GSX 380 Q-Sport Build
- Blazer.21 Whip lash sport hydro ?
- Large Mono. Dual Rudders????
- submerged to surface drive conversion
- Kbb 45 Twin Cat Build
- Would like some opinions on this part I made
- Delta force mk2 q build
- any rule of thumb
- Exceed hulls artr questions
- Custom V cat
- Found this gem😎
- newbie
- Near scale hydro build, possible P sport competition plans
- New person to hobby needs help
- BBY's SS30 build
- I'm bored so here's the multiple build thread
- LMT collets or MBP?
- DUMAS HOT SHOT IV ELEC Conversion HELP!!!
- sharpshooter... Sports Hydro.
- Chrome square canopy clips.
- MHZ Racemaster ~SINISTER~
- Good flowing finish epoxy?
- Radtek 233 flexi drives.
- do it your selfi motor mount makeing
- 37"Daytona:Bullitproof
- boat builders
- Mhz MTI build TFL drives
- Who Makes the Best Flex Cable? Custom Drilled Shafts?
- Genesis Single BUDGET rebuild? Think ratrod...
- outerlimits rebuild
- MHZ Lizard extreme with outboard
- Pete's Shooter P-Sport Hydro
- Water cooling tubing
- Darin's Banzai HydroSports Rev2 Experimental Hydro Build
- My new HYDRO 1 (nawiga)
- The famous 1969 Cary 32 Cigarette boat
- Using a touchup spray gun
- Black pearl
- Watersnake
- ML Boatworks 2016- What I have been working on recently!
- Thoughts Needed Inside Please
- need help
- DF Vortex 24 info
- 33.5 CARBON KELVAR mono deep V build finished, waiting for your comments, advices
- 44" seaducer mono
- Hpr 99 ultimate layup.
- Delta Force Sniper 45" (no name yet)
- Custom jet boat
- Help on twin ESC setup..
- JetChopper30 electric, 4445 out runner motor.
- P offshore scratch cat build thread
- ML Boatworks GSX310 FE and Nitro Sport 20 hydro kit Update
- Smoked and ESC would like some Advice before buying another one....
