Recovery boat
  • wickedgmc
    • Jun 2007
    • 719
    Recovery boat
    I got the idea from a person on RC universe and decided to put my own together. It was easy to assemble, took about 20 minutes and works perfect! Will push almost any boat in from my micro hydro to my 1/8th scale Llumar. Yesterday my buddies were throwing the boats in the water just to use the boat, it was funny to see them.
    here are a few pics
  • Mr_nascar
    • Jun 2007
    • 14
    is that a villin in the pic
    Austin
    • wickedgmc
      • Jun 2007
      • 719
      yes it is a Villain EX
      • FE_Chris
        • Jun 2007
        • 764
        The villain's have a lot of torque. They are slow suckers, and they bounce like crazy....But I have the 7.2 volt version I am gonna do the same with. I know 159$ sounds expensive for a rescue boat, but I have read they work extremely well, and seeinf the time and effort I put into these things, it nice to have something to just grab them with. Real easy and quick.
        Let's not forget how sharp the villain turns. It turns on a dime so getting the dead boat into the cradle, even in wind I am sure is not to diffacult.
        I wonder if you put a lower gear, and a bigger prop if you could get more torque and pulling power with the same heat.
        Could you take some close up shots of what you used to attach the cradle to the hull with. I like it!
        • wickedgmc
          • Jun 2007
          • 719
          this boat works perfect for pushing anything in, remember the way it is set up the boat is on a plane right away and gets to the boat easily and right around it and reverse is very use full as well.
          I have used a tennis ball (did not like at all), tried a different boat Zig Zag with the ball catcher and that was too hard this is very very easy and works well.
          Worth every penny when I have one of my boats out floating
          • NorthernBoater
            • 811
            the Traxxas Blast probably would work out pretty well too.
            • Piranha2
              • 320
              I currently am using my Shockwave 26 as my rescue rig...used a similar 1/2" PVC set-up as you did....it works great and reverse is helpful as you stated.....try to use some 45 degree fittings on the very front and she'll cut through the chop even better......mine is just a big H configuration and when the SW26 and the rig sit in the water they are at the same level (by design) and all I did was install velcro on the rig and the SW26 for attachment.
              • FE_Chris
                • Jun 2007
                • 764
                I'm sure those boats work well, but my thing is, for the price, Which now that the villain is lowered down into the 150$ range, it's a better boat . SW26 is 139, The twin screws just push a ton of water, so pushing a big boat is no problem.
                I went to home depot today and for 1.22$ each I got 4 eight foot lengths of 1/2 inch PVC. I got a ton of elbows, 45's and T's and my total bill was 16.50. It's cheap to make this thing. All I gotta get now are some cheap pool tubes.
                Wicked, can you post some close up shots of the way you attached the PVC cradle on? please.
                SWEET! Gotta love rescue boats. I swam for my last boat the other night from now on it's all villain! :D
                EDIT: O and I forgot to mention, my 16.50 got me enough PVC and ends to make this rescue cradle, and a few boat stands. Like I said. CHEAP!
                • Jeepers
                  • May 2007
                  • 1973
                  IF you have local "dollar " stores you can get one for about a buck that were i get my pool noodles at.
                  • FE_Chris
                    • Jun 2007
                    • 764
                    Sweet jeepers, thanks. I'll do that.
                    I live right by Flint, Michigan. Flint's the dollar store capital of the USA :D
                    • wickedgmc
                      • Jun 2007
                      • 719
                      I will post some pics Chris either later today or tomorrow
                      • FE_Chris
                        • Jun 2007
                        • 764
                        Thankyou....
                        • wickedgmc
                          • Jun 2007
                          • 719
                          here are some mounting pictures, just shot a screw into the boat and sealed it with some epoxy, did the same on the PVC pipe.
                          hope this helps answer some questions
                          • FE_Chris
                            • Jun 2007
                            • 764
                            Thank-You. I am going to be getting mine ready this week. Hopefully it is ready by this weekend.
                            Also, LOL....Could you tell me the length of the bungie cords when they are not stretched out? Obviosuly I need to get some of those too. Thanks again :-)
                            • FE_Chris
                              • Jun 2007
                              • 764
                              Well, I got it built real quick. Exactly like your's. I'm taking it to work to glue and to get some screws so I can hook it up wickedFORD style! ;-)
                              Later dudes.
